A wait_event call with a stack local wait_queue_head_t structure that is
used to do the wake up for the wait_event is inherently racy. After the
wait_event finished the wake_up call might not have completed yet.
Remove the stack local wait_queue_head_t from raw3270_start_init and
use the global raw3270_wait_queue instead.
single list_head variable initialized with LIST_HEAD_INIT could almost
always can be replaced with LIST_HEAD declaration, this shrinks the code
and looks better.
Signed-off-by: Denis Cheng <crquan@gmail.com>
Convert struct class_device users under drivers/s390/char to use
struct device.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
There are several s390 diagnose calls, which must be executed below the
2GB memory boundary. In order to enforce this, those diagnoses must be
compiled into the kernel. Currently diag 14 can be called within the
vmur kernel module from addresses above 2GB. This leads to specification
exceptions. This patch moves diag10, diag14 and diag210 into the new
diag.c file.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
The function shouldn't have existed in the first place (not MSS-aware).
Introduce a new function ccw_device_get_id() that extracts the
ccw_dev_id structure of a ccw device and convert all users of
_ccw_device_get_device_number to ccw_device_get_id.
Take return values of sysfs_create_group & friends into account.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The initial i/o to a 3270 device is done using the static module variables
raw3270_init_data and raw3270_init_request. If the 3270 device driver is
built as a module and gets loaded above 2GB, the initial i/o will fail
because these variables will get addresses > 2GB. To make it work the
two variables are moved to struct raw3270 and the data structure is
allocated with GFP_DMA.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Jens Axboe <axboe@suse.de>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Acked-by: Alasdair G Kergon <agk@redhat.com>
Cc: Greg KH <greg@kroah.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Adam Belay <ambx1@neo.rr.com>
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Add the missing NULL argument to the class_device_create calls.
This is the drivers/s390/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/s390/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Cornelia Huck <cohuck@de.ibm.com>
Acked-by: Stefan Bader <Stefan.Bader@de.ibm.com>
Fix fullscreen view of the 3270 device driver.
Signed-off-by: Richard Hitt <rbh00@utsglobal.com>
Fix reboot with a disconnected 3270 console.
device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
infrastructure for it.
Let it rip!
