It allows for cleaning up on a considerable amount of places. They did
port_get, wakeup, kref_put. Now the only thing needed is to call
tty_port_tty_wakeup which does exactly that.
One exception is ifx6x60 where tty_wakeup was open-coded. We now call
tty_wakeup properly there.
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
One point is to have less places where we actually need tty pointer.
The other is that low_latency is bound to buffer processing and
buffers are now in tty_port. So it makes sense to move low_latency to
tty_port too.
tty_insert_flip_string this time.
After commit "TTY: move tty buffers to tty_port", the tty buffers are
not freed in some drivers. This is because tty_port_destructor is not
called whenever a tty_port is freed. This was an assumption I counted
with but was unfortunately untrue. So fix the drivers to fulfil this
assumption.
To be sure, the TTY buffers (and later some stuff) are gone along with
the tty_port, we have to call tty_port_destroy at tear-down places.
This is mostly where the structure containing a tty_port is freed.
This patch does exactly that -- put tty_port_destroy at those places.
So now for those drivers that can use neither tty_port_install nor
tty_port_register_driver but still have tty_port available before
tty_register_driver we use newly added tty_port_link_device.
The rest of the drivers that still do not provide tty_struct <->
tty_port link will have to be converted to implement
tty->ops->install.
Acked-by: Alan Cox <alan@linux.intel.com>
80 bytes which are allocated in tty->ops->open and assigned to
tty->driver_data are never used. Remove that.
Cc: linux390@de.ibm.com
Cc: linux-s390@vger.kernel.org
tty_port will hold tty buffers in the future. So we need to have it
even here. The only needed member here is tty, so let us store it in
the structure now.
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
When opening a SCLP VT220 terminal, the terminal window size is not
initialized (defaults to zero).
Since the SCLP VT220 terminal supports only 80x24, explicitly set
the window size to prevent (n)curses applications from guessing
the default setting.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Fix this build error:
next-20091013 randconfig build on s390x build breaks with
drivers/s390/built-in.o:(.data+0x3354): undefined reference to `sclp_vt220_pm_event_fn'
Reported-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Signed-off-by: Michael Holzheu <michael.holzheu@linux.vnet.ibm.com>
The slab allocator is earlier available so convert the
bootmem allocations to slab/gfp allocations.
The SCLP base driver defines a new notifier call back for all upper level SCLP
drivers, like the SCLP console, etc. This guarantees that in suspend first the
upper level drivers are suspended and afterwards the SCLP base driver. For
resume it is the other way round. The SCLP base driver itself registers a
new platform device at the platform bus and gets PM notifications via
the dev_pm_ops.
In suspend, the SCLP base driver switches off the receiver and sender mask
This is done in sclp_deactivate(). After suspend all new requests will be
rejected with -EIO and no more interrupts will be received, because the masks
are switched off. For resume the sender and receiver masks are reset in
the sclp_reactivate() function.
When the SCLP console is suspended, all new messages are cached in the
sclp console buffers. In resume, all the cached messages are written to the
console. In addition to that we have an early resume function that removes
the cached messages from the suspend image.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
get rid of this one:
CC drivers/s390/char/sclp_vt220.o
drivers/s390/char/sclp_vt220.c:588: warning: '__sclp_vt220_flush_buffer' defined but not used
The s390 console drivers use the unblank callback of the console
structure to flush the console buffer. In case of a panic or a
reboot the CPU doing the callback can block on the console i/o.
The other CPUs in the system continue to work. For panic this is
not a good idea.
Replace the unblank callback with proper panic/reboot notifier.
These get called after all but one CPU have been stopped.
Signed-off-by: Holger Smolinski <Holger.Smolinski@de.ibm.com>
Fix a number of sclp_vt220 cleanup problems:
* fix list_empty check after list_del()
* mark init-only flag as __initdata
* remove implicit dependency between slab_available() and num_pages
* straighten multiple init handling (use init count)
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
This patch fixes a null pointer dereference during initialisation when no
sclp event facility is available:
sclp vt220 tty driver: could not register vt220 - sclp_register returned -5
Unable to handle kernel paging request at virtual user address 0000000000000000
Oops: 0004 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 Not tainted 2.6.26-rc3-kvm-bigiron-00968-gd939e93-dirty #30
Process swapper (pid: 0, task: 0000000000600be0, ksp: 000000000064a000)
Krnl PSW : 0400000180000000 0000000000320d8c (sclp_unregister+0x48/0x8c)
R:0 T:1 IO:0 EX:0 Key:0 M:0 W:0 P:0 AS:0 CC:0 PM:0 EA:3
Krnl GPRS: 0000000000000000 0000000000000000 0000000000630478 0700000000649c20
0000000000000000 0000000000433060 000000000064a660 0000000002e26000
00000000006db000 0000000000000000 0000000000a78578 0000000000649b80
0000000000630dc0 000000000044fa20 0000000000320d76 0000000000649b80
Krnl Code: 0000000000320d7c: e310c0080004 lg %r1,8(%r12)
0000000000320d82: b9040032 lgr %r3,%r2
0000000000320d86: c02000187b79 larl %r2,630478
>0000000000320d8c: e34010000024 stg %r4,0(%r1)
0000000000320d92: e31040080024 stg %r1,8(%r4)
0000000000320d98: c01100200200 lgfi %r1,2097664
0000000000320d9e: e310c0080024 stg %r1,8(%r12)
0000000000320da4: c01100100100 lgfi %r1,1048832
Call Trace:
([<0000000000320d76>] sclp_unregister+0x32/0x8c)
[<00000000006657b4>] __sclp_vt220_cleanup+0xc4/0xe0
[<000000000066595c>] __sclp_vt220_init+0x18c/0x1a0
[<0000000000665aba>] sclp_vt220_con_init+0x42/0x68
[<00000000006601ca>] console_init+0x4e/0x68
[<000000000064acae>] start_kernel+0x3a2/0x4dc
[<0000000000100020>] _stext+0x20/0x80
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<000000000041f964>] _spin_lock_irqsave+0xb0/0xb4
<4>---[ end trace 31fd0ba7d8756001 ]---
The issue is caused by a list_empty() check in __sclp_vt220_cleanup, which
usually fails on non-initialized list heads that contain {NULL,NULL} instead.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
The driver incorrectly assumed that putchar will only be called from
schedulable process context and therefore blocked and waited if no
free output buffers where available.
Since putchar may also be called from BH context this may lead to
deadlocks.
To fix this just return the number of characters accepted and let the
upper layer handle the rest.
The console write function will busy wait (sclp_sync_wait) until a
buffer is available again.
Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Put the changes into the drivers first. This will still compile/work but
produce a warning if bisected so can still be debugged
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Reintroduces in_interrupt() check in sclp_tty code. Add may_schedule
parameter to vt220 write function, so we can let the write function
know if it may schedule or not. So we disallow scheduling for all
console calls and may allow them for tty calls.
Currently an output buffer can wait up to HZ/2 until the buffer is
flushed. The wait time is noticeable in interactive tools like mc.
Change the value to HZ/20, which seems enough for interactive work.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Make state change events adjust the correct mask by cleaning up
naming inconsistencies. Also remove chance for lockup by removing
unnecessary mask related check before reading events.
There are two problems in the vt220 intialization:
o Currently the vt220 console looses early printk events until the
the vt220 tty is registered.
o console should work if tty_register fails
sclp_vt220_con_init calls __sclp_vt220_init and register_console.
It does not register the driver with the sclp core code via
sclp_register. That results in an sclp_send_mask=0. Therefore,
__sclp_vt220_emit will reject buffers with EIO. Unfortunately
register_console will cause the printk buffer to be sent to the
console and, therefore, every early message gets dropped. The
sclp_send_mask is set later during boot, when sclp_vt220_tty_init
calls sclp_register.
The solution is to move the sclp_register call from sclp_vt220_tty_init
to __sclp_vt220_init. This makes sure that the console is properly
registered with the sclp subsystem before the first log buffer messages
are passed to the vt220 console.
We also adopt the cleanup on error to keep the console alive if
tty_register fails.
Thanks to Peter Oberparleiter and Heiko Carstens for review and ideas
for improvement.
Under load the following bug message appeared while using sysrq-t:
BUG: scheduling while atomic: bash/3662/0x00000004
0000000000105b74 000000003ba17740 0000000000000002 0000000000000000
000000003ba177e0 000000003ba17758 000000003ba17758 0000000000105bfe
0000000000817ba8 000000003f2a5350 0000000000000000 0000000000000000
000000003ba17740 000000000000000c 000000003ba17740 000000003ba177b0
0000000000568630 0000000000105bfe 000000003ba17740 000000003ba17790
Call Trace:
([<0000000000105b74>] show_trace+0x13c/0x158)
[<0000000000105c58>] show_stack+0xc8/0xfc
[<0000000000105cbc>] dump_stack+0x30/0x40
[<000000000012a0c8>] __schedule_bug+0x84/0x94
[<000000000056234e>] schedule+0x5ea/0x970
[<0000000000477cd2>] __sclp_vt220_write+0x1f6/0x3ec
[<0000000000477f00>] sclp_vt220_con_write+0x38/0x48
[<0000000000130b4a>] __call_console_drivers+0xbe/0xd8
[<0000000000130bf0>] _call_console_drivers+0x8c/0xd0
[<0000000000130eea>] release_console_sem+0x1a6/0x2fc
[<0000000000131786>] vprintk+0x262/0x480
[<00000000001319fa>] printk+0x56/0x68
[<0000000000125aaa>] print_cfs_rq+0x45e/0x4a4
[<000000000012614e>] sched_debug_show+0x65e/0xee8
[<000000000012a8fc>] show_state_filter+0x1cc/0x1f0
[<000000000044d39c>] sysrq_handle_showstate+0x2c/0x3c
[<000000000044d1fe>] __handle_sysrq+0xae/0x18c
[<00000000002001f2>] write_sysrq_trigger+0x8a/0x90
[<00000000001f7862>] proc_reg_write+0x9a/0xc4
[<00000000001a83d4>] vfs_write+0xb8/0x174
[<00000000001a8b88>] sys_write+0x58/0x8c
[<0000000000112e7c>] sysc_noemu+0x10/0x16
[<0000020000116f68>] 0x20000116f68
The problem seems to be, that with a full console buffer, release_console_sem
disables interrupts with spin_lock_irqsave and then calls the console function
without enabling interrupts. __sclp_vt220_write checks for in_interrupt, to
decide if it can schedule. It should check for in_atomic instead.
The same is true for sclp_tty.c.
Also convert to slab_is_available() as an indicator if
get_zeroed_page() will work or not.
Use only capital letters for defines.
Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com>
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Hopefully this will make it more maintainable and less error prone.
Code makes use of search_exception_tables(). Since it calls this
function before the kernel exeception table is sorted, there is an
early call to sort_main_extable().
This way it's easy to use the already present infrastructure of fixup
sections. Also this would allows to easily convert the rest of
head[31|64].S into C code.
As part of an SMP cleanliness pass over UML, I consted a bunch of
structures in order to not have to document their locking. One of these
structures was a struct tty_operations. In order to const it in UML
without introducing compiler complaints, the declaration of
tty_set_operations needs to be changed, and then all of its callers need to
be fixed.
This patch declares all struct tty_operations in the tree as const. In all
cases, they are static and used only as input to tty_set_operations. As an
extra check, I ran an i386 allyesconfig build which produced no extra
warnings.
53 drivers are affected. I checked the history of a bunch of them, and in
most cases, there have been only a handful of maintenance changes in the
last six months. serial_core.c was the busiest one that I looked at.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Cc: Paul Fulghum <paulkf@microgate.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
infrastructure for it.
Let it rip!
