path: root/drivers/s390/char/tape_3590.c
2013-01-08s390/irq: remove split irq fields from /proc/statHeiko Carstens
Now that irq sum accounting for /proc/stat's "intr" line works again we have the oddity that the sum field (first field) contains only the sum of the second (external irqs) and third field (I/O interrupts). The reason for that is that these two fields are already sums of all other fields. So if we would sum up everything we would count every interrupt twice. This is broken since the split interrupt accounting was merged two years ago: 052ff461c8427629aee887ccc27478fc7373237c "[S390] irq: have detailed statistics for interrupt types". To fix this remove the split interrupt fields from /proc/stat's "intr" line again and only have them in /proc/interrupts. This restores the old behaviour, seems to be the only sane fix and mimics a behaviour from other architectures where /proc/interrupts also contains more than /proc/stat's "intr" line does. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-05-16s390/tape: remove tape block leftoversHeiko Carstens
2011-10-30[S390] fix mismatch in summation of I/O IRQ statisticsPeter Oberparleiter
Current IRQ statistics support does not show detail counts for I/O interrupts which are processed internally only. The result is a summation count which is way off such as this one: CPU0 CPU1 CPU2 I/O: 1331 710 442 [...] QAI: 15 16 16 [I/O] QDIO Adapter Interrupt QDI: 1 0 0 [I/O] QDIO Interrupt DAS: 706 645 381 [I/O] DASD C15: 26 10 0 [I/O] 3215 C70: 0 0 0 [I/O] 3270 TAP: 0 0 0 [I/O] Tape VMR: 0 0 0 [I/O] Unit Record Devices LCS: 0 0 0 [I/O] LCS CLW: 0 0 0 [I/O] CLAW CTC: 0 0 0 [I/O] CTC APB: 0 0 0 [I/O] AP Bus Fix this by moving I/O interrupt accounting into the common I/O layer. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] tape: remove unused/not handled return codesHeiko Carstens
Return codes are on purpose not handled or used. So remove them. Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] get rid of unused variablesHeiko Carstens
Remove trivially unused variables as detected with -Wunused-but-set-variable. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] ccw_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccw_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-03[S390] tape: deadlock on system work queueMartin Schwidefsky
The 34xx and 3590 tape driver uses the system work queue to defer work from the interrupt function to process context, e.g. a medium sense after an unsolicited interrupt. The tape commands started by the work handler need to be asynchronous, otherwise a deadlock on the system work queue can occur. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-12-24s390: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. * tape_3590: Create and use tape_3590_wq instead of the system_wq. * tape_block: Directly flush requeue_task on cleanup instead of using flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org
2010-08-09Fix spelling fuction -> function in commentsStefan Weil
To avoid more patches, I also fixed other spelling and grammar bugs when they were in the same or following line: successfull -> successful parse -> parses controler -> controller controlers -> controllers Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-18[S390] Use strim instead of strstrip to avoid false warnings.Heiko Carstens
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] tape: Add pr_fmt() macro to all tape source filesMichael Holzheu
Without defining the pr_fmt() macro, the "tape: " prefix will not be printed when using the pr_xxx printk macros. This patch adds the missing definitions. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: cleanup reference countingMartin Schwidefsky
Rename tape_get_device to tape_find_device and tape_get_device_reference to tape_get_device. The old names didn't make too much sense. Follow the get_device()/put_device() semantic and convert tape_put_device to a void function. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-11[S390] tape: Use pr_xxx instead of dev_xxx in shared driver codeMichael Holzheu
For messages from the tape core that is shared between the 3590 and 34xx tape disciplines, we want to have the "tape" prefix instead of "tape_3590" or "tape_34xx". In order to fix this, we now use the pr_xxx printk macros. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (64 commits) debugfs: use specified mode to possibly mark files read/write only debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem. xen: remove driver_data direct access of struct device from more drivers usb: gadget: at91_udc: remove driver_data direct access of struct device uml: remove driver_data direct access of struct device block/ps3: remove driver_data direct access of struct device s390: remove driver_data direct access of struct device parport: remove driver_data direct access of struct device parisc: remove driver_data direct access of struct device of_serial: remove driver_data direct access of struct device mips: remove driver_data direct access of struct device ipmi: remove driver_data direct access of struct device infiniband: ehca: remove driver_data direct access of struct device ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct device hvcs: remove driver_data direct access of struct device xen block: remove driver_data direct access of struct device thermal: remove driver_data direct access of struct device scsi: remove driver_data direct access of struct device pcmcia: remove driver_data direct access of struct device PCIE: remove driver_data direct access of struct device ... Manually fix up trivial conflicts due to different direct driver_data direct access fixups in drivers/block/{ps3disk.c,ps3vram.c}
2009-06-16[S390] pm: tape power management callbacksFrank Munzert
Signed-off-by: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-15s390: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Thanks to Sebastian Ott <sebott@linux.vnet.ibm.com> for fixing a few typos in my original version of this patch. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: linux-s390@vger.kernel.org Cc: linux390@de.ibm.com Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-23[S390] Use tape_generic_offline directly.Frank Munzert
tape_3590_offline and tape_34xx_offline are removed and tape_generic_offline is called directly instead. Signed-off-by: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] BUG to BUG_ON changesStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] tape message cleanupCarsten Otte
This is a cleanup of all the messages this driver prints. It uses the dev_message macros now. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-08fix similar typos to successfullColy Li
When I review ocfs2 code, find there are 2 typos to "successfull". After doing grep "successfull " in kernel tree, 22 typos found totally -- great minds always think alike :) This patch fixes all the similar typos. Thanks for Randy's ack and comments. Signed-off-by: Coly Li <coyli@suse.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10[S390] bus_id -> dev_name conversionsKay Sievers
bus_id -> dev_name() conversions in s390 code. [cornelia.huck@de.ibm.com: minor adaptions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] cio: introduce fcx enabled scsw formatPeter Oberparleiter
Extend the scsw data structure to the format required by fcx. Also provide helper functions for easier access to fields which are present in both the traditional as well as the modified format. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-06-10[S390] tape_3590.c: introduce missing kfreeJulia Lawall
The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) @r exists@ expression E,E1; statement S; position p1,p2,p3; @@ E =@p1 \(kmalloc\|kcalloc\|kzalloc\)(...) ... when != E = E1 if (E == NULL || ...) S ... when != E = E1 if@p2 (...) { ... when != kfree(E) } ... when != E = E1 kfree@p3(E); @forall@ position r.p2; expression r.E; int E1 != 0; @@ * if@p2 (...) { ... when != kfree(E) when strict return E1; } Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] drivers/s390/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-12[S390] tape: Fix medium state handlingMichael Holzheu
Currently there are situations, where the tape medium state (loaded, unloaded, unknown) is not set correctly. The reason is that the medium association field is used to determine the medium state. This not always leads to correct results. To fix that we use another field of the medium sense data instead. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-10Fixup rq_for_each_segment() indentationJens Axboe
Remove one level of nesting where appropriate. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10Introduce rq_for_each_segment replacing rq_for_each_bioNeilBrown
Every usage of rq_for_each_bio wraps a usage of bio_for_each_segment, so these can be combined into rq_for_each_segment. We define "struct req_iterator" to hold the 'bio' and 'index' that are needed for the double iteration. Signed-off-by: Neil Brown <neilb@suse.de> Various compile fixes by me... Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-04[S390] tape: New read configuration data.Michael Holzheu
Instead of the deprecated read_conf_data(), implement a new function tape_3590_read_dev_chars(). Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Add crypto support for 3592 tape devicesMichael Holzheu
3592 tape devices are able to write data encrpyted on tape mediums. This z/Linux device driver support includes the following functions: * ioctl to switch on/off encryption * ioctl to query encryption status of drive * ioctls to set and query key encrypting keys (kekls) * long busy interrupt handling Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] more workqueue fixes.Martin Schwidefsky
2006-04-28[PATCH] s390: tape 3590 changesStefan Bader
Added some changes that where proposed by Andrew Morton. Added 3592 device type. Signed-off-by: Stefan Bader <shbader@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: 3590 tape driverStefan Bader
Michael Holzheu <holzheu@de.ibm.com>, Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Stefan Bader <shbader@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
