commit ab5758848039de9a4b249d46e4ab591197eebaf2 upstream.
ccw console is created early in start_kernel and used before css is
initialized or ccw console subchannel is registered. Until then console
subchannel does not have a parent. For that reason assume subchannels
with no parent are not pseudo subchannels. This fixes the following
kasan finding:
BUG: KASAN: global-out-of-bounds in sch_is_pseudo_sch+0x8e/0x98
Read of size 8 at addr 00000000000005e8 by task swapper/0/0
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.3.0-rc8-07370-g6ac43dd12538 #2
Hardware name: IBM 2964 NC9 702 (z/VM 6.4.0)
Call Trace:
([<000000000012cd76>] show_stack+0x14e/0x1e0)
[<0000000001f7fb44>] dump_stack+0x1a4/0x1f8
[<00000000007d7afc>] print_address_description+0x64/0x3c8
[<00000000007d75f6>] __kasan_report+0x14e/0x180
[<00000000018a2986>] sch_is_pseudo_sch+0x8e/0x98
[<000000000189b950>] cio_enable_subchannel+0x1d0/0x510
[<00000000018cac7c>] ccw_device_recognition+0x12c/0x188
[<0000000002ceb1a8>] ccw_device_enable_console+0x138/0x340
[<0000000002cf1cbe>] con3215_init+0x25e/0x300
[<0000000002c8770a>] console_init+0x68a/0x9b8
[<0000000002c6a3d6>] start_kernel+0x4fe/0x728
[<0000000000100070>] startup_continue+0x70/0xd0
Cc: stable@vger.kernel.org
Reviewed-by: Sebastian Ott <sebott@linux.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
The sysfs attributes implemented by the vfio_ccw driver are also implemented by
the io_subchannel driver. Move these into a device_type which is set by the
css bus.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reviewed-by: Dong Jia Shi <bjsdjshi@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Remove an unused member of struct channel subsystem.
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Simplify error handling during css initialization by moving the error
handling code to setup_css (which now cleans up after itself).
Also remove the odd special cleanup handling of the pseudo_subchannel.
Cleanup the code to handle the css device attribute. Move everything
to an attribute group to let the driver core handle attribute
creation and removal.
Obtain the real channel subsystem id and use that for the generation
of a unique path group id. Note that this change does not affect the
channel subsystem id as used in the user-visible naming of subchannels
and friends.
Reviewed-by: Dong Jia Shi <bjsdjshik@linux.vnet.ibm.com>
Currently the cssid in various structures is used as the id of
the respective channel subsystem. Sometimes however we call the
index in the channel_subsystems array cssid. In some places the
id is even used as the index.
Provide a new define MAX_CSS_IDX and use it where appropriate.
In addition to that provide a dummy function to find a channel
subsystem by its id and a macro to iterate over the channel
subsystems.
The Makefile currently controlling compilation of this code is:
obj-y += airq.o blacklist.o chsc.o cio.o css.o chp.o idset.o isc.o \
fcx.o itcw.o crw.o ccwreq.o trace.o ioasm.o
ccw_device-objs += device.o device_fsm.o device_ops.o
ccw_device-objs += device_id.o device_pgid.o device_status.o
obj-y += ccw_device.o cmf.o
...meaning that the files here are not being built as modular.
Lets remove the couple traces of modular infrastructure use, so that
when reading the code there is no doubt it is builtin-only.
Since module_init translates to device_initcall in the non-modular
case, the init ordering remains unchanged with this commit.
Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code.
We delete the MODULE_LICENSE tag etc. since all that information
was (or is now) contained at the top of the file in the comments.
We replace module.h with export.h where the file does export some
symbols.
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Cc: Arnd Bergmann <arndb@de.ibm.com>
Cc: linux-s390@vger.kernel.org
There is no longer a need to maintain two versions of the same inline
assembly - one with exception handling, and one without - so get rid of
the duplicates and adjust names accordingly. This applies to stsch_err
and msch_err which are now renamed to stsch and msch respectively,
while the original msch function is removed.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Simplify the css_generate_pgid code by using stap() independent of
CONFIG_SMP. For !CONFIG_SMP builds stap() will deliver the address
of the cpu we IPL'ed from (which can be != 0).
Note: the ifdef was likely added to be compatible with _very_ old
machines which we don't support anyway.
The ret variable is always set by the fn function.
There is no need to initialize it.
Signed-off-by: Pierre Morel <pmorel@linux.vnet.ibm.com>
Reviewed-By: Sascha Silbe <silbe@linux.vnet.ibm.com>
During resume from hibernate we already reenable measurement block
updates on a per device basis. In addition to that we also need to
activate channel measurement globally using the set channel monitor
instruction.
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Subchannel looping function for_each_subchannel_staged() allocates a
subchannel-ID-bitmap to efficiently iterate over the list of known
and unknown subchannels. Since this function is also used to iterate
over known-subchannels only, optimize that case by not requiring the
ID-bitmap allocation and falling back to simple bus_for_each_dev()
looping.
Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
The CIO layer scans for newly available I/O devices by performing a scan
of available subchannels using the Store Subchannel (STSCH) instruction.
Performing too many STSCH instructions in a tight loop can cause high
Hypervisor overhead which can negatively impact the performance of the
virtual machine as a whole.
A subchannel scan is triggered for example during a hardware event that
indicates that a channel path has become available. It is also triggered
by the DASD device driver for each device that is set online.
This patch reduces the number of STSCH instructions being performed by
delaying the start of the actual subchannel scan by 1 second. Multiple
scan requests that are scheduled during this time will be merged into a
single scan loop.
The trade-off consists of a short delay that is introduced between
the time that the event is processed and a newly available device
becoming usable. This delay should be acceptable since it only
affects devices that have not been in use before.
This processing can take a significant amount of time during which no
other task can run on the same CPU (unless CONFIG_PREEMPT has been
enabled). As a result, scheduling latencies for other tasks are
increased noticeably, especially on a single-CPU system.
Fix this problem by explicitly allowing other tasks to be scheduled
each time a subchannel has been processed.
Access to the slow_subchannel_set has to be secured via the
slow_subchannel_lock.
The usage of strict_strtoul() is not preferred, because
strict_strtoul() is obsolete. Thus, kstrtoul() should be
used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
cio_validate_subchannel is used to do some basic checks to find out
if it's worth to further investigate a subchannel. Move the allocation
and initialization of the subchannels locks to css_alloc_subchannel.
Clean up the functions involved while at it.
Make css_probe_device static and remove an unimplemented prototype.
Use cio_register_early_subchannels to register early subchannels
which are already in use. Call this function before we do the
actual subchannel scanning loop. This helps us to get rid of some
more special cases regarding the console subchannel.
Remove the static console subchannel (and friends) and use dynamic
allocation for these structures. With this change the console
subchanel is treated (mostly) like any other subchannel and we can
remove some special cases.
Split the subchannel registration in device_initialize and device_add
and move the initialization part inside the allocation function. With
this change we can use refcounting during the complete lifespan of a
subchannel which is important for devices where we do the actually
registration at a later time.
Collect format 1 channel-path description data for each CHPID
and update the information in one place.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Fix name clash with some common code device drivers and add "tod"
to all tod clock access function names.
Receiving cc=3 from store subchannel means 2 things:
* the subchannel is not provided
* there are no further subchannels in this subchannel set
With this patch we abort the store subchannel loop after cc=3 (or an
exception) and clear the subsequent bits in the subchannel id set.
Reported-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Acked-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Allow subchannel drivers build as a module to schedule subchannel work.
Using the generic css_schedule_eval to evaluate subchannels
while resuming from hibernation is very slow when used with
many devices. Provide a new evaluation trigger which exploits
css_sched_sch_todo and use this in the resume callback for
ccw devices.
This enables pm_notifier_call_chain() to get the actual error code
in the callback rather than always assume -EINVAL by converting all
PM notifier calls to return encapsulate error code with
notifier_from_errno().
Make css_bus_type static. Subchannel drivers have to
use css_driver_register.
Remove the owner and name members of struct
css_driver and convert all drivers to store
this data in the embedded struct device_driver.
Update the subchannel descriptor if we receive a
"Installed parameters modified" crw.
Use correct bit positions of rsid field.
Update the subchannel descriptor while resuming from hibernate
in order to obtain current link addresses.
Update the channel path descriptors after hibernation.
This is done unlocked, since we are the only active
task at this time.
Note: chsc_determine_base_channel_path_desc is changed
to use spin_lock_irqsave, since it's called with
interrupts disabled in this case.
Most wrappers around the channel subsystem call have their own logic
to allocate memory (with proper alignment) or use preallocated or
static memory. This patch converts most users of the channel
subsystem call to use the same preallocated page (proteced by a
spinlock).
Note: The sei_page which is used in our crw handler to call
"store event information" has to coexist, since
a) in crw context, while accessing the sei_page, sleeping is allowed
(which will conflict with the spinlock protection of the chsc_page)
b) in crw context, while accessing the sei_page, channel subsystem
calls are allowed (which itself would require the page).
This patch fixes:
* kfree vs. free_page usage
* structure definition for determine_css_characteristics
* naming convention for the chsc init function
* deregistration of crw handlers in the cleanup path
fix this sparse warning:
drivers/s390/cio/css.c:580:6: warning: symbol 'css_schedule_eval_all_unreg'
was not declared. Should it be static?
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Use nonseekable_open for a couple of s390 device drivers. This avoids
the use of default_llseek function which has a dependency on the BKL.
Remove cpu_id from lowcore and replace addr_t with __u64.
Reenable multiple subchannel sets after hibernation,
prior to the device callbacks.
Cc: <stable@kernel.org>
Prepare chsc_enable_facility to be used from outside init functions.
Use static memory for the chsc call and protect its access by a
spinlock (although there is no concurrent usage).
ccw_device_pm_restore: trigger subchannel event to better handle
changes to the subchannel device.
Make the potentially long blocking wait_event's used by the cio
settle mechanism interruptible.
This patch introduces a proc file cio_settle. A write request to
this file is blocked until all queued cio actions are handled.
This will allow userspace to wait for pending work affecting
device availability after changing cio_ignore or the hardware
configuration.
We used to maintain 2 singlethreaded workqueues for synchronization
and to trigger work from interrupt context. Since our latest cio
changes we only use one of these workqueues. So get rid of the
unused workqueue, rename the remaining one to "cio_work_q" and move
its ownership to the channel subsystem driver.
Ensure that current and future users of sch->work do not overwrite
each other by introducing a single mechanism for delayed subchannel
work.
Change the initiative to update subchannel-ccw device associations
to the subchannel: when there is an indication that the internal
association no longer reflects the current hardware state, mark
each affected subchannel as requiring attention. Once processing
reaches a subchannel, determine the correct association for that
subchannel at that time and perform the necessary device_move
operations.
This change fixes problems with the previous approach which would
leave devices in an inconsistent state when a new hardware change
occurred while a device_move was already scheduled.
