path: root/drivers/s390/cio/idset.h
2016-06-13s390: use canonical include guard styleDaniel van Gerpen
Signed-off-by: Daniel van Gerpen <daniel@vangerpen.de> Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-01-08s390/cio: idset.c: remove some unused functionsRickard Strandqvist
Removes some functions that are not used anywhere: idset_clear() idset_sch_get_first() This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-10-18s390/css: stop stsch loop after cc 3Sebastian Ott
Receiving cc=3 from store subchannel means 2 things: * the subchannel is not provided * there are no further subchannels in this subchannel set With this patch we abort the store subchannel loop after cc=3 (or an exception) and clear the subsequent bits in the subchannel id set. Reported-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Acked-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-09-22[S390] cio: introduce consistent subchannel scanningSebastian Ott
Previously, there were multiple subchannel scanning mechanisms which could potentially conflict with each other. Fix this problem by moving blacklist and ccw driver triggered scanning to the existing evaluation method. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-22[S390] cio: introduce css_eval_scheduledSebastian Ott
Use css_eval_scheduled to determine if all scheduled subchannel evaluation is finished. Wait for this value to be 0 in the channel subsystem init function. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] cio: Add chsc subchannel driver.Cornelia Huck
This patch adds a driver for subchannels of type chsc. A device /dev/chsc is created which may be used to issue ioctls to: - obtain information about the machine's I/O configuration - dynamically change the machine's I/O configuration via asynchronous chsc commands Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] cio: replace subchannel evaluation queue with bitmapPeter Oberparleiter
Use a bitmap for indicating which subchannels require evaluation instead of allocating memory for each evaluation request. This approach reduces memory consumption during recovery in case of massive evaluation request occurrence and removes the need for memory allocation failure handling. Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
