path: root/drivers/s390/net/lcs.c
2008-04-29lcs: CCL-sequ. numbers required for protocol 802.2 only.Klaus D. Wacker
Sequence numbers in skbs (Receive path) are assigned only to 802.2 packets. Signed-off-by: Klaus D. Wacker <kdwacker@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-11lcs: avoid/reduce unused s390dbf debug areas.Peter Tiedemann
Since lcs makes use of 1 debug area only, the number of debug areas is reduced, while the number of pages per area is increased. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-26[S390] drivers/s390: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-10lcs: Channel errors drive lcs_recovery which leads to kernel panic.Klaus D. Wacker
When the lcs irq routine detects channel failures it drives device recovery. After this event the device is no longer usable for shutdown requests, because the lcs_irq routine may get wrong channel status information. In such a case the lcs_irq routine marks the channel in 'error' state. The channel state comes back to 'running' after restarting the channels. Signed-off-by: Klaus D. Wacker <kdwacker@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[HIPPI/FDDI]: Make {hippi,fddi}_type_trans set skb->devArnaldo Carvalho de Melo
Now all the _type_trans routines are consistent in this regard. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-11[PATCH] Replace regular code with appropriate calls to container_of()Robert P. J. Day
Replace a small number of expressions with a call to the "container_of()" macro. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-06[PATCH] More work_struct induced breakage (s390)Al Viro
2006-12-04[S390] non-unique constant/macro identifiers.Ursula Braun
Add some prefixes to constands defined in drivers/s390/net/qdio.h and drivers/s390/lcs.h to make it possible to include the three header files drivers/s390/net/qeth.h, drivers/s390/net/qdio.h and drivers/net/s390/lcs.h in one C file. This is required for the patch that generates the kerntypes.o file for use by lcrash. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-02[NET] driver/s390/net: Checksum annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-17[PATCH] s390: minor s390 network driver fixesFrank Pavlic
Hi Jeff, this is a RESEND of the nine s390 network driver patches. I finally found that my kmail corrupted almost every patch I sent the last time. Please apply these 9 patches and forget about my first attempt! Sorry for the delay, I had some fights with sendmail, IMAP and mutt configuration. Frank [RESEND PATCH 1/9] s390: minor s390 network driver fixes From: Frank Pavlic <fpavlic@de.ibm.com> - iucv driver: use do { } while (0) constructs instead of empty defines to avoid compile bugs. - ctc driver: missing lock initialization added - lcs driver: BUG_ON usage was removed accidently with the last lcs patch. Put them back in place. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-26[PATCH] drivers: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under drivers/. Acked-by: Corey Minyard <minyard@mvista.com> Cc: Ben Collins <bcollins@debian.org> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Alasdair Kergon <dm-devel@redhat.com> Cc: Gerd Knorr <kraxel@bytesex.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Frank Pavlic <fpavlic@de.ibm.com> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: Andrew Vasquez <linux-driver@qlogic.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-26[netdrvr s/390] trim trailing whitespaceJeff Garzik
Previous fix patches added a bunch of trailing whitespace, which git-applymbox complained loudly about.
2006-05-26[PATCH] s390: lcs driver bug fixes and improvements [1/2]Klaus Wacker
Several problems occured with lcs device driver: - device not operational anymore after cable pull/plug-in. - unpredictable results occured, e.g. kernel panic using cards of type QD8F. - STOPLAN and delete multicast address command were not proper recognized by OSA card under heavy network workload. - channel/device error checks missing in interrupt handler. To fix all problems at once recovery of lcs devices has been improved. missing error checks in lcs interrupt handler has been added. Once a hardware problem occurs lcs will recover the device now properly. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-15[PATCH] s390: lcs incorrect testGreg Smith
While debugging why our LCS emulator is having some problems I noticed the following weirdness in drivers/s390/net/lcs.c routine lcs_irq. The `if' statement is always true since SCHN_STAT_PCI is defined as 0x80. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in drivers/s390/net/lcs.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] s390: kzalloc() conversion in drivers/s390Eric Sesterhenn
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] s390: lcs performance enhancementsFrank Pavlic
[patch 1/2] s390: lcs performance enhancements From: Klaus Wacker <kdwacker@de.ibm.com> - When flood pinging (with large packet size) an LCS device, about 90 % of all packets are dropped by driver. - increased number of lcs IO buffers to 32. - use netif_stop_queue/netif_wake_queue in lcs_start_xmit routine - don't lock the whole xmit routine but just the piece of code where tx_buffer is touched. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> diffstat: lcs.c | 31 +++++++++++++++++-------------- lcs.h | 2 +- 2 files changed, 18 insertions(+), 15 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-02-01[PATCH] s390: Remove CVS generated informationHeiko Carstens
- Remove all CVS generated information like e.g. revision IDs from drivers/s390 and include/asm-s390 (none present in arch/s390). - Add newline at end of arch/s390/lib/Makefile to avoid diff message. Acked-by: Andreas Herrmann <aherrman@de.ibm.com> Acked-by: Frank Pavlic <pavlic@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11[PATCH] s390: mail address changedFrank Pavlic
[patch 7/7] s390: mail address changed From: Frank Pavlic <fpavlic@de.ibm.com> - mail address changed to fpavlic@de.ibm.com Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> diffstat: lcs.c | 4 ++-- qeth_main.c | 4 ++-- qeth_mpc.c | 2 +- qeth_mpc.h | 2 +- qeth_sys.c | 2 +- qeth_tso.h | 2 +- 6 files changed, 8 insertions(+), 8 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-07[PATCH] kfree cleanup: drivers/s390Jesper Juhl
This is the drivers/s390/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/s390/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Cornelia Huck <cohuck@de.ibm.com> Acked-by: Stefan Bader <Stefan.Bader@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: debug feature changesMichael Holzheu
This patch changes the memory allocation method for the s390 debug feature. Trace buffers had been allocated using the get_free_pages() function before. Therefore it was not possible to get big memory areas in a running system due to memory fragmentation. Now the trace buffers are subdivided into several subbuffers with pagesize. Therefore it is now possible to allocate more memory for the trace buffers and more trace records can be written. In addition to that, dynamic specification of the size of the trace buffers is implemented. It is now possible to change the size of a trace buffer using a new debugfs file instance. When writing a number into this file, the trace buffer size is changed to 'number * pagesize'. In the past all the traces could be obtained from userspace by accessing files in the "proc" filesystem. Now with debugfs we have a new filesystem which should be used for debugging purposes. This patch moves the debug feature from procfs to debugfs. Since the interface of debug_register() changed, all device drivers, which use the debug feature had to be adjusted. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/char/raw3270.c - drivers/net/netiucv.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-15[PATCH] s390: set online race in the lcs driverFrank Pavlic
[patch 3/10] s390: set online race in the lcs driver. From: Michael Holzheu <holzheu@de.ibm.com> There is a race between lcs_stopcard() and lcs_open_device() which can lead to the error 'lcs: Error in starting channel, rc=-16'. lcs_open_device() is invoked when 'ifconfig up' is called due to a hotplug event, which is caused by register_netdev(). In parallel lcs_stopcard() is executed. Both functions are sending lcs commands. The second invocation fails with -EBUSY (-16) as return value. Move invocation of register_netdev() after invocation of lcs_stopcard to avoid the race. Signed-off-by: Frank Pavlic <pavlic@de.ibm.com>
2005-05-15[PATCH] s390: multicast address registration in lcsFrank Pavlic
[patch 2/10] s390: multicast address registration in lcs. From: Michael Holzheu <holzheu@de.ibm.com> When setting lcs devices online you can run into an endless loop, because the code that registers the multicast addresses uses list_for_each_entry instead of list_for_each_entry_safe. Signed-off-by: Frank Pavlic <pavlic@de.ibm.com>
