Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
There is no urgent need to restart a netiucv connection automatically,
if packets are sent while the netiucv device is not up and running.
Signed-off-by: Ursula Braun <braunu@de.ibm.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
additional check of s390dbf level results in better performance
if the default low debugging level is active.
Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Dummy NOP actions for fsm-statemachines have to be defined
separately for every using module of fsm-statemachines.
Thus the generic name fsm_action_nop is replaced by
module specific name netiucv_action_nop.
single list_head variable initialized with LIST_HEAD_INIT could almost
always can be replaced with LIST_HEAD declaration, this shrinks the code
and looks better.
Signed-off-by: Denis Cheng <crquan@gmail.com>
CC: Ursula Braun <ubraun@linux.vnet.ibm.com>
Recently, Wang Chen submitted a patch
(d30f53aeb31d453a5230f526bea592af07944564) to move a call to netif_rx(skb)
after a subsequent reference to skb, because netif_rx may call kfree_skb on
its argument. netif_rx_ni calls netif_rx, so the same problem occurs in
the files below.
I have left the updating of dev->last_rx after the calls to netif_rx_ni
because it seems time dependent, but moved the other field updates before.
This was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression skb, e,e1;
netif_rx(skb);
netif_rx_ni(skb);
... when != skb = e
skb = e1
* skb
// </smpl>
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
This avoids use of the kernel-internal "xtime" variable directly outside
of the actual time-related functions. Instead, use the helper functions
that we already have available to us.
This doesn't actually change any behaviour, but this will allow us to
fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ
(because much of the realtime information is maintained as separate
offsets to 'xtime'), which has caused interfaces that use xtime directly
to get a time that is out of sync with the real-time clock by up to a
third of a second or so.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
The recent iucv rework patches re-introduced some unnecessary inlines.
Remove them again.
Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com>
spinlock initializer cleanup in netiucv.c
net/iucv/iucv.c creates the requirement for
iucv_path_connect not to be called from tasklet context anymore.
An extra checking is added in case of a failing netiucv_tx
to fulfil this requirement for netiucv.
don't remove an entry from iucv_connection_list in netiucv_exit().
netiucv_free_netdevice is called anyway, which takes care of entry
removal.
To clearly state the intent of copying from linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes
on 64bit architectures, allowing us to combine the 4 bytes hole left by the
layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4
64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN...
Many calculations that previously required that skb->{transport,network,
mac}_header be first converted to a pointer now can be done directly, being
meaningful as offsets or pointers.
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Adapt netiucv network device driver to new IUCV API
[PATCH 2/9] s390: netiucv driver fixes
- missing lock initialization added
- avoid duplicate iucv-interfaces to the same peer
- rw-lock added for manipulating the list of
defined iucv connections
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Andreas Herrmann <aherrman@de.ibm.com>
Cc: Michael Holzheu <holzheu@de.ibm.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Previous fix patches added a bunch of trailing whitespace,
which git-applymbox complained loudly about.
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
- Remove all CVS generated information like e.g. revision IDs from
drivers/s390 and include/asm-s390 (none present in arch/s390).
- Add newline at end of arch/s390/lib/Makefile to avoid diff message.
Acked-by: Andreas Herrmann <aherrman@de.ibm.com>
Acked-by: Frank Pavlic <pavlic@de.ibm.com>
This patch changes the memory allocation method for the s390 debug feature.
Trace buffers had been allocated using the get_free_pages() function before.
Therefore it was not possible to get big memory areas in a running system due
to memory fragmentation. Now the trace buffers are subdivided into several
subbuffers with pagesize. Therefore it is now possible to allocate more
memory for the trace buffers and more trace records can be written.
In addition to that, dynamic specification of the size of the trace buffers is
implemented. It is now possible to change the size of a trace buffer using a
new debugfs file instance. When writing a number into this file, the trace
buffer size is changed to 'number * pagesize'.
In the past all the traces could be obtained from userspace by accessing files
in the "proc" filesystem. Now with debugfs we have a new filesystem which
should be used for debugging purposes. This patch moves the debug feature
from procfs to debugfs.
Since the interface of debug_register() changed, all device drivers, which use
the debug feature had to be adjusted.
device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
infrastructure for it.
Let it rip!
