This patch uses the ndo_set_features callback during normal device
startup or recovery to turn on hardware RX checksum. Patch was done
with much help from Michal Miroslaw, thx!!!
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Reviewed-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
This patch improves FFDC (first failure data capture) by requesting
a hardware trace in case the device driver, the hardware or a user
detects an error.
Set rx csum default to hw checksumming again.
Remove sysfs interface for rx csum (checksumming) and TSO (large_send).
With the new hw_features it does not work to keep the old sysfs
interface in parallel. Convert options.checksum_type to new hw_features.
options.large_send was easy to get rid of. options.checksum_type has deeper
roots so is left for later cleanup.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
This patch turns on RX checksum and GRO by default. To improve
receiving performance and reduce congestion in case of network
bursts we also increase the default number of inbound buffers.
If a qeth device is set offline, data and control subchannels are
cleared, which means removal of all IP Assist Primitive settings
implicitly. There is no need to delete those settings explicitly.
This patch removes all IP Assist invocations from offline.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Some OSA level have a bug in the hw tx csum logic. We can circumvent
this bug by turning on IP hw csum also.
The open function of qeth is not executed if the qeth device is in
state DOWN or HARDSETUP. A recovery switches from state SOFTSETUP to
HARDSETUP to DOWN to HARDSETUP and back to SOFTSETUP. If open and
recover are running concurrently, open fails if it hits the states
HARDSETUP or DOWN. This patch inserts waiting for recovery finish
in the qeth open functions to enable successful qeth device opening
in spite of a running recovery.
OSA l3 mode is hw accelerated VLAN only for IPv4. Take care we
add the vlan hdr to a passthru frame in the device driver.
Only work through the IP adddress to do list if the card is UP or
SOFTSETUP. Enables to configure VIPA add/del in offline mode.
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
Function qeth_l3_arp_query now queries for IPv6 addresses, too, if
QETH_QARP_WITH_IPV6 is passed as parameter to the ioctl. HiperSockets
and GuestLAN in HiperSockets mode provide corresponding entries.
The tso hdr is longer then the regular l3 hdr. Fix the calculation
of the total len by accounting the size of the tso hdr.
Device initialization of a qeth device contains a STARTLAN step.
This step may fail, if cable is not yet plugged in. The qeth device
stays in state HARDSETUP until cable is plugged in. This prevents
further preparational initialization steps of the qeth device and
its network interface. This patch makes sure initialization of qeth
device continues, even though cable is not yet plugged in.
Once carrier is available, qeth is notified, triggers a recovery
which results in a working network interface.
Commit 1d7138de878d1d4210727c1200193e69596f93b3
igmp: RCU conversion of in_dev->mc_list
converted rwlock to RCU.
Update the s390 network drivers(qeth & lcs) code to adapt to this change.
V2 : Changes based on suggestions given by Eric Dumazet
Signed-off-by: Sachin Sant <sachinp@in.ibm.com>
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs.
Since vlan groups will soon be more of an implementation detail
for vlan devices, rename the constant to be descriptive of its
actual purpose.
Signed-off-by: Jesse Gross <jesse@nicira.com>
This patch adapts qeth to handle tagged frames with VLAN-ID 0 and
with or without priority information in the tag. It enables qeth to
receive priority-tagged frames on a base interface, for example from
z/OS, without configuring an additional VLAN interface.
This patch adds NAPI support to the qeth layer 2 and layer 3
discipline. It is important to understand that we can not enable/disable
IRQs as usual, we have to use the corresponding new QDIO interface.
Also to not overdraw the budget we have to stop and restart buffer
processing at any point during processing a bulk of QDIO buffers.
Having the driver NAPI enabled it is possible to turn on GRO for the
layer 3 discipline.
Format an ipv6 address using vsprintf extensions.
This patch serializes device removal and other sysfs-triggered
configurations by moving removal of sysfs-attributes to the beginning
of the remove functions. And it serializes online/offline setting
and discipline-switching (causing reestablishing of the net_device)
by making use of a new discipline mutex.
The qeth IP address flag setting is possible when device is
offline. When setting device online afterwards the current set
IP addresses have to be correctly registered with the device
regarding the IP address takeover attribute.
Signed-off-by: Klaus-Dieter Wacker <kdwacker@de.ibm.com>
Turning on memory debugging showed there could be page breaks in
hardware headers. OSA does not allow this so we had to add code
to bounce the header in case there is a page break. This patch also
fixes a problem in case the skb->data part of a fragmented skb
spreads multiple pages.
This patch removes the qeth_trace debug area. All relevant data is logged into
either qeth_setup or into each card's own debug area. Superfluous information
(such as the card number when logging into the card's own debug area) is
removed without replacement.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
The qeth driver is enabled to support the new OSA CHPID types OSX
and OSM.
Synchronize access to the drivers configuration interface.
Also do not allow configuration changes during online/offline
transition.
OSA supports HW TX checksumming in layer 3 mode. Enable this
feature and remove software fallback used for TSO. Cleanup
checksum bits to indicate OSA can do checksumming only for
IPv4 TCP and UDP.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Adapt qeth l3 to:
commit c2e21293c054817c42eb5fa9c613d2ad51954136
(ipv6: convert addrconf list to hlist)
converted lst_next member of inet6_ifaddr struct to a hlist.
Depending on their definition in z/VM, virtual devices for z/VM
VSWITCH or GuestLAN must be configured either in layer2 or in
layer3 mode. If qeth detects a layer mismatch, device activation
fails. Trying to recover from this error cannot help; thus
scheduling a recovery should be avoided.
In addition, since recovery is forbidden during online setting of
a qeth device, existence of its network device is guaranteed for all
dev_close() calls in qeth. The corresponding checks can be removed.
If HiperSockets Network Traffic Analyzer is switched off, but trace
disabling fails somehow, the qeth driver does not switch off its
promisc mode status. A following sniffer reactivation fails, since
qeth does not see a need to reenable tracing.
At the same time the code analyzing results of trace commands is
restructured.
dhcp frames are valid IPv4 packets so there is no need to send them
in pass thru mode. This allows dhcp packets to pass HiperSockets.
Also the dhcp release frame is send out correctly with this patch.
If a qeth device is set online, several initialisation steps are
performed. If a failure in one of these steps occurs, the qeth
device is reset into DOWN state. If due to the failure a qeth recovery
is scheduled and started in another thread, this might cause all kinds
of conflicts, even a kernel panic. The patch forbids scheduling of a
qeth recovery while online processing is performed till the card is in
state SOFTSETUP.
New feature to trace HiperSockets network traffic for debugging
purposes.
Technically there is no need to set the card offline to change
RX checksumming. Get rid of this stupid limitation.
The maximum TSO size OSA can handle is 15 * PAGE_SIZE. This
patch reduces gso_max_size to this value and adds some sanity
checks and statistics to the TSO implementation.
Since only layer 3 is able to do TSO move all TSO related functions
to the qeth_l3 module.
Setting a qeth device online requires to call function
ccw_device_set_online() for read-, write-, and data-subchannel.
Failures should be detected immediately without an attempt to
invoke follow-on activity qeth_qdio_clear_card().,
In addition, ccw_device_set_online calls are consolidated in
qeth_core_main.c only.
Isolate data connection to a shared OSA card against other data
connections to the same OSA card. Connectivity between isolated
data connections sharing the same OSA card is therefore possible only
through external network gear (e.g. a router).
This string query operation was supposed to be replaced by the
generic get_sset_count() starting in 2007. Convert qeth's
implementation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Acked-by: Neil Horman <nhorman@txudriver.com>
No need to put ethtool_ops in data, they should be const.
Clear separation of cast-type determination (send path) for layer-2
resp. layer-3. Allowing to have inline functions for qeth layer-
discipline.
In case the IP address list contains entries (not removed when the device was set
offline) this entries should be registered next time the device is brought online.
In the past this was done implicitly with the device open call but since we wait
in the set IPv4 IPA and the device open common code holds various locks this
does not work any longer.
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Last two drivers that need skb->dst in their start_xmit() function
Tell dev_hard_start_xmit() to no release it by unsetting IFF_XMIT_DST_RELEASE
For HiperSocket devices receive-path checksumming is not required.
Thus NO_CHECKSUMMING is used as default for HiperSocket interfaces.
For layer3 devices configured with NO_CHECKSUMMING received skbs
should have set their ip_summed field to CHECKSUM_UNNECESSARY.
If a qeth device is plugged off, setting the device online stops in
state HARDSETUP and a failure is reported to the base cio-layer
causing halt/clear to be invoked. Replugging the device again triggers
a qeth recovery without notification of the cio-layer. If a device
is ungrouped in this state, the qeth set_offline function is not
invoked, because the corresponding ccwgroup device is not in state
ONLINE. Then incoming traffic is still handled by the qdio layer
resulting in a crash in qeth_l<x>_qdio_input_handler, because (part
of) the qeth data structures for this device are already removed.
Solution: After replugging the device qeth recovery should lead to a
working net device. Thus a "LAN offline" result when setting a qeth
device online must not report a failure to the base cio-layer.
When a recovery is started for a qeth device, additional invocations
to change a mac address, to configure a VLAN interface on top, or to
add multicast addresses should wait till recovery is finished,
otherwise recovery might fail.
Performance measurements showed EDDP does not lower CPU costs but increase
them. So we dump out EDDP code from qeth driver.
