The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Acked-by: Neil Horman <nhorman@txudriver.com>
No need to put ethtool_ops in data, they should be const.
Clear separation of cast-type determination (send path) for layer-2
resp. layer-3. Allowing to have inline functions for qeth layer-
discipline.
Signed-off-by: Klaus-Dieter Wacker <kdwacker@de.ibm.com>
In case the IP address list contains entries (not removed when the device was set
offline) this entries should be registered next time the device is brought online.
In the past this was done implicitly with the device open call but since we wait
in the set IPv4 IPA and the device open common code holds various locks this
does not work any longer.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Last two drivers that need skb->dst in their start_xmit() function
Tell dev_hard_start_xmit() to no release it by unsetting IFF_XMIT_DST_RELEASE
For HiperSocket devices receive-path checksumming is not required.
Thus NO_CHECKSUMMING is used as default for HiperSocket interfaces.
For layer3 devices configured with NO_CHECKSUMMING received skbs
should have set their ip_summed field to CHECKSUM_UNNECESSARY.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
If a qeth device is plugged off, setting the device online stops in
state HARDSETUP and a failure is reported to the base cio-layer
causing halt/clear to be invoked. Replugging the device again triggers
a qeth recovery without notification of the cio-layer. If a device
is ungrouped in this state, the qeth set_offline function is not
invoked, because the corresponding ccwgroup device is not in state
ONLINE. Then incoming traffic is still handled by the qdio layer
resulting in a crash in qeth_l<x>_qdio_input_handler, because (part
of) the qeth data structures for this device are already removed.
Solution: After replugging the device qeth recovery should lead to a
working net device. Thus a "LAN offline" result when setting a qeth
device online must not report a failure to the base cio-layer.
When a recovery is started for a qeth device, additional invocations
to change a mac address, to configure a VLAN interface on top, or to
add multicast addresses should wait till recovery is finished,
otherwise recovery might fail.
Performance measurements showed EDDP does not lower CPU costs but increase
them. So we dump out EDDP code from qeth driver.
Add statistics counter for software tx checksumming.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Have separate netdev_ops for OSA and HiperSocket/TR.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
qeth_l2, qeth_l3 convert to net_device_ops.
qeth_l3 remove vlan neigh_setup hack since it does not work any longer
with the new net_device_ops.
Replace s390_root_dev_register() with root_device_register() etc.
[Includes fix from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
drivers/s390/net/qeth_l3_main.c: In function 'qeth_l3_setadapter_parms':
drivers/s390/net/qeth_l3_main.c:1049: warning: too many arguments for format
For z/VM GuestLAN or VSWITCH devices the transport layer is
configured in z/VM. The layer2 attribute of a participating Linux
device has to match the z/VM definition. In case of a mismatch
Linux currently crashes in qeth recovery due to a reference to the
not yet existing net_device.
Solution: add a check for existence of net_device and add a message
pointing to the mismatch of layer definitions in Linux and z/VM.
OSA-devices operating in layer3 mode offer adding of the source MAC
address to the QDIO header of inbound packets. The qeth driver can
exploit this functionality to replace FAKELL-entries in the ethernet
header of received packets.
IP-threads have been removed from the qeth driver. Only the
recover-thread is left over. This makes checkings for
non-recover threads superfluous.
Do not touch IFF_UP flag during qeth recovery, but invoke dev_close()
in case of failing recovery.
Cancel outstanding control commands in case of Data Checks or
Channel Checks.
Do not invoke qeth_l2_del_all_mc() in case of a hard stop to speed up
removal of qeth devices.
For hiper socket devices this patch will economize the reallocation
of the tx skb data segment by allocating separate memory for the qdio
transport information (qeth header).
This makes qeth working again after git commit
e3c50d5d25ac09efd9acbe2b2a3e365466de84ed
"netdev: netdev_priv() can now be sane again.".
Adrian Bunk reports this build error:
CC drivers/s390/net/qeth_l3_main.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/s390/net/qeth_l3_main.c:
In function 'qeth_l3_hard_start_xmit':
2654: error: implicit declaration of function 'VLAN_TX_SKB_CB'
2654: error: invalid type argument of '->' (have 'int')
make[3]: *** [drivers/s390/net/qeth_l3_main.o] Error 1
The intention of the driver appears to be to invalidate the VLAN tag.
Change it to set skb->vlan_tci to zero, which has the same effect.
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
List of major changes:
- split qdio driver into several files
- seperation of thin interrupt code
- improved handling for multiple thin interrupt devices
- inbound and outbound processing now always runs in tasklet context
- significant less tasklet schedules per interrupt needed
- merged qebsm with non-qebsm handling
- cleanup qdio interface and added kerneldoc
- coding style
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Reviewed-by: Utz Bacher <utz.bacher@de.ibm.com>
Reviewed-by: Ursula Braun <braunu@de.ibm.com>
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
Cc: Jeff Garzik <jgarzik@redhat.com>
Hide struct vlan_dev_info from drivers to prevent them from growing
more creative ways to use it. Provide accessors for the two drivers
that currently use it.
In case the xmit function drop out with an error, we have to wake
the netdevice queue to start another xmit.
Remove unnecessary messages. Write important debug information to
s390dbf.
The ip event handler may present us non qeth network interfaces.
Add qeth card pointer check.
In case the ccwgroup device is set online/offline we have to run
the corresponding dev_open/close for the netdevice.
Remove unnecessary traces. Remove unnecessary wrappers for skb
functions.
Load balancing bonding queries the speed of the slave interfaces.
To support a bond consisting of different slave speeds we have to
report the speed by ethtool settings.
hiper socket require the QETH_HDR_EXT_VLAN_FRAME flag in the
qdio header to handle vlan tagged frames.
Replace complex macro for s390dbf calls by equivalent function. This reduces
module size about 10% without visible performance impact.
Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com>
Problem: If setting of an ip-address fails with LAN_OFFLINE,
qeth does not save the ip-address in its internal
list of set ip-addresses. qeth recovers after a
following STARTLAN event, but cannot set the unsaved
ip-address.
Solution: save the ip-address in the qeth-maintained list of
ip-addresses after a LAN_OFFLINE failure for SETIP.
Signed-off-by: Ursula Braun <braunu@de.ibm.com>
Improving debug message handling, moving ipa into messages from kernel
to dbf, some cleanups and typo fixes.
hw does not allow to change the mac address.
1. ip_list handling after deregister failure of multicast address:
If error code "MC Address not found" is returned do not re-add
multicast address to ip_list.
For other error codes readd multicast address at the end of
function qeth_delete_all_mc.
2. ip_list handling after deregister failure or normal ip address:
If error code "IP Address not found" is returned do not re-add
multicast address to ip list.
This is especially important in IP address takeover scenarios,
to enable re-takeover of a taken over IP address.
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
drivers/s390/net/qeth_main.c
List of major changes and improvements:
no manipulation of the global ARP constructor
clean code split into core, layer 2 and layer 3 functionality
better exploitation of the ethtool interface
better representation of the various hardware capabilities
fix packet socket support (tcpdump), no fake_ll required
osasnmpd notification via udev events
coding style and beautification
Signed-off-by: Jeff Garzik <jeff@garzik.org>
