path: root/drivers/s390/virtio/kvm_virtio.c
2015-07-23Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio/vhost fixes from Michael Tsirkin: "Bugfixes and documentation fixes. Igor's patch that allows users to tweak memory table size is borderline, but it does fix known crashes, so I merged it" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: vhost: add max_mem_regions module parameter vhost: extend memory regions allocation to vmalloc 9p/trans_virtio: reset virtio device on remove virtio/s390: rename drivers/s390/kvm -> drivers/s390/virtio MAINTAINERS: separate section for s390 virtio drivers virtio: define virtio_pci_cfg_cap in header. virtio: Fix typecast of pointer in vring_init() virtio scsi: fix unused variable warning vhost: use binary search instead of linear in find_region() virtio_net: document VIRTIO_NET_CTRL_GUEST_OFFLOADS
2015-07-07virtio/s390: rename drivers/s390/kvm -> drivers/s390/virtioCornelia Huck
This more accurately reflects what these drivers actually do. Suggested-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
