Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Jens Axboe <axboe@suse.de>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Acked-by: Alasdair G Kergon <agk@redhat.com>
Cc: Greg KH <greg@kroah.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Adam Belay <ambx1@neo.rr.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (21 commits)
BUG_ON() Conversion in drivers/video/
BUG_ON() Conversion in drivers/parisc/
BUG_ON() Conversion in drivers/block/
BUG_ON() Conversion in sound/sparc/cs4231.c
BUG_ON() Conversion in drivers/s390/block/dasd.c
BUG_ON() Conversion in lib/swiotlb.c
BUG_ON() Conversion in kernel/cpu.c
BUG_ON() Conversion in ipc/msg.c
BUG_ON() Conversion in block/elevator.c
BUG_ON() Conversion in fs/coda/
BUG_ON() Conversion in fs/binfmt_elf_fdpic.c
BUG_ON() Conversion in input/serio/hil_mlc.c
BUG_ON() Conversion in md/dm-hw-handler.c
BUG_ON() Conversion in md/bitmap.c
The comment describing how MS_ASYNC works in msync.c is confusing
rcu: undeclared variable used in documentation
fix typos "wich" -> "which"
typo patch for fs/ufs/super.c
Fix simple typos
tabify drivers/char/Makefile
MODULE_PARM was actually breaking: recent gcc version optimize them out as
unused. It's time to replace the last users, which are generally in the
most unloved drivers anyway.
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Cast the argument correctly.
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage.
Undetected edge case for CRT messages to CEX2A caused length to be too short,
thus truncating the message. The solution was to check a different variable
which actually determines which key type is being used.
Increment version number in z90main.c to correct level of 1.3.3, fix copyright
year and add comment about bitlength limit of CEX2A.
Signed-off-by: Eric Rossman <edrossma@us.ibm.com>
Michael Holzheu <holzheu@de.ibm.com>,
Signed-off-by: Stefan Bader <shbader@de.ibm.com>
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
If a tape device is assigned to another host, the interrupt for the assign
operation comes back with deferred condition code 1. Under some conditions
this can lead to an endless loop of retries. Check if the current request is
still in IO in deferred condition code handling and prevent retries when the
request has already been cancelled.
When a request is aborted because of a signal, we currently stop the request
via csh, but we do not wait for the interrupt of csh in any case. We free the
request structure and therefore when the interrupt for the csh operation is
presented, the request object is no longer valid and an invalid callback
pointer is used.
To fix this wait until the interrupt for csh arrives and until
wait_event_interruptible() does not return -ERESTARTSYS.
If a deferred CC happens there will be lots of messages, because the retry is
done immediatly in the interrupt handler which can be too fast. To avoid this
requeue the request and schedule the queue to be processed.
The DASD extended error reporting is a facility that allows to get detailed
information about certain problems in the DASD I/O. This information can be
used to implement fail-over applications that can recover these problems.
Signed-off-by: Stefan Weinhuber <wein@de.ibm.com>
Use kzalloc to get a zeroed buffer for the structure returned to user space by
the BIODASDINFO2 ioctl. Not all fields are set up, e.g. the read_devno is
missing.
Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com>
The dasd diag discipline has been tested on 64 bit and is no longer
experimental.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Now that there are no more users of the awkward dynamic ioctl hack we can
remove the code to support it.
dasd_cmd just implements three ioctls which are wrappers around functionality
in the core kernel or other modules. When merging those into dasd_mod they
just add 22 lines of code which is far less than the amount of code removed in
the last two patches, and which doesn't spill into another 4k pages when build
modular, while removing a 128lines module.
Add an ->ioctl method to the dasd_discipline structure. This allows to apply
the same kind of cleanups the last patch applied to dasd_ioctl.c to
dasd_eckd.c (the only dasd discipline with special ioctls) aswell.
Again lots of code removed. During auditing the ioctls I found two fishy
return value propagations from copy_{from,to}_user, maintainers please check
those, I've marked them with XXX comments.
Handle ioctls implemented in dasd_ioctl through the normal switch statement
that most drivers use instead of the awkward dasd_ioctl_no_register routine.
This avoids searching a linear list on every call to dasd_ioctl(), and allows
to give the various ioctl implementation functions sane prototypes, aswell as
moving the check for bdev->bd_disk->private_data from the individual functions
to dasd_ioctl. (I think it can't actually every be NULL, but let's keep that
for later)
Gather extended measurements for channel paths from the channel subsystem and
expose them to userspace via a sysfs attribute.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
When cio waits for the interrupt for a basic sense, interrupts for hsch() or
csch() issued in the meantime are wrongly counted as interrupts for the basic
sense and the accumulated irb is passed to the device driver. In
ccw_device_w4sense(), check for clear or halt function in the irb and pass the
irb for the csch() or hsch() to the device driver.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Acked-by: Jens Axboe <axboe@suse.de>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6:
[PATCH] Use of uninitialized variable in drivers/net/depca.c
[PATCH] Use after free in net/tulip/de2104x.c
[PATCH] sis900 adm7001 PHY support
[PATCH] sky2: more ethtool stats
[PATCH] s390: qeth :allow setting of attribute "route6" to "no_router".
[PATCH] s390: qeth driver cleanups
[PATCH] s390: qeth driver statistics fixes
[PATCH] AMD Au1xx0: fix Ethernet TX stats
[PATCH] fix spidernet build issue
[patch 4/6] s390: qeth :allow setting of attribute "route6" to "no_router".
when setting route6 attribute back to no_router qeth does not
issue an IP ASSIST command to reset router value to no_router.
Once primary_router is set device stays in this mode.
Issue an IP ASSIST command when no_router is set in route6.
Device will be reset and thus will not longer run as a primary
router.
Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com>
diffstat:
qeth_main.c | 5 -----
1 files changed, 5 deletions(-)
Signed-off-by: Jeff Garzik <jeff@garzik.org>
[patch 3/6] s390: qeth driver cleanups
- code analyzing tool BEAM has found some unreachable
and unnecessary statements and also conditions
which are always true.
- removed some useless MII code since OSA card will never
allow to set such values.
diffstat:
qeth_main.c | 49 ++++---------------------------------------------
qeth_proc.c | 18 +++++++++---------
qeth_sys.c | 2 +-
3 files changed, 14 insertions(+), 55 deletions(-)
[patch 2/6] s390: qeth driver statistics fixes
- display "unsigned int" values in /proc/qeth_perf with %u instead of %i
- omit qdio header length when increasing card->stats.tx_bytes
diffstat:
qeth_main.c | 3 ++-
qeth_proc.c | 38 +++++++++++++++++++-------------------
2 files changed, 21 insertions(+), 20 deletions(-)
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
It seems this patch got dropped (it was in addition to the `s390:
improve response code handling in chsc_enable_facility()' patch).
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] zfcp: fix device registration issues
[SCSI] scsi_transport_fc: fix FC_HOST_NUM_ATTRS
[SCSI] scsi: aha152x pcmcia driver needs spi transport
[SCSI] zfcp: correctly set this_id for hosts
[SCSI] Add Brownie to blacklist
This fixes a typo introduced with 90f0094dc607abe384a412bfb7199fb667ab0735.
The patch fixes following issues:
(1) Replace scsi_add_device with scsi_scan_target.
(Thus the rport instead of the scsi_host becomes parent of a
scsi_target again.)
(2) Avoid scsi_device allocation during registration of an remote port.
(Would be done during fc_scsi_scan_rport.)
(3) Fix queuecommand behaviour when an zfcp unit is blocked.
(Call scsi_done with DID_NO_CONNECT instead of returning
SCSI_MLQUEUE_DEVICE_BUSY otherwise we might end up waiting
for completion in blk_execute_rq for ever.)
Signed-off-by: Andreas Herrmann <aherrman@de.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
DASD allows to open a device as soon as gendisk is registered, which means the
device is a fake device (capacity=0) and we do know nothing about blocksize
and partitions at that point of time. In case the device is opened by
someone, the bdev and inode creation is done with the fake device info and the
following partition detection code is just using the wrong data.
To avoid this modify the DASD state machine to make sure that the open is
rejected until the device analysis is either finished or an unformatted device
was detected.
The message limit on the iucv connect call for the smsg module is too low.
Therefore increase the smsg message limit to 255.
Rather than checking for some known failures, check positively for the
success response code 0x0001 and return -EIO for unrecognized failure
response codes.
Cc: Greg Smith <gsmith@nc.rr.com>
It fixes a bug in zfcp which provokes a race
in scsi_scan.c. Finally this can lead to an Oops like:
kernel BUG at fs/sysfs/symlink.c:87!
Correctly set this_id for the host. Otherwise we provoke
a race between scsi_target_reap_work and concurrent
scsi_add_device.
Revert dasd eer module until we have a common understanding of how the
interface should be.
When using the dasd diag discipline, the base discipline module (eckd or fba)
can be unloaded, even though the dasd driver requires both discipline modules
(base and diag) to work correctly.
Implement reference counting for both base and diag discipline modules in
order to fix this.
Using FCP devices with V=V support, the input queue stalled when CCQ 97 had
been returned in qdio_do_eqbs. When this happen we have to reissue the eqbs
instruction.
Another bug was when V=V was enabled we checked if hardware has SIGA-sync
support. If not we returned with 0 from tiqdio_is_inbound_q_done. Thus qdio
lost initiative on FCP devices and input queue stalled. Running devices in
V=V there is no SIGA-sync support but nevertheless we have to process
tiqdio_is_inbound_q_done either.
Fix assignment instead of check in ccw_device_set_online(). Also remove
unneeded assignment in ccw_device_do_sense().
If __ccw_device_disband_start() fails to initiate disbanding, it should finish
with ccw_device_disband_done() (which leaves the device in offline state)
instead of ccw_device_verify_done() (which leaves the device in online state).
[patch 2/2] s390: some qeth driver fixes
- fixed kernel panic when using EDDP support in Layer 2 mode
- NULL pointer exception in qeth_set_offline fixed.
- setting EDDP in Layer 2 mode did not set NETIF_F_(SG/TSO)
flags when device became online.
- use sscanf for parsing and converting IPv4 addresses
from string to __u8 values.
- qeth_string_to_ipaddr6 fixed. in case of double colon
the converted IPv6 address out from the string was not correct
in previous implementation.
diffstat:
qeth.h | 112 +++++++++++++++++++++++++-----------------------------------
qeth_eddp.c | 11 ++++-
qeth_main.c | 17 +++------
3 files changed, 63 insertions(+), 77 deletions(-)
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
[patch 1/2] s390: lcs performance enhancements
- When flood pinging (with large packet size) an LCS device,
about 90 % of all packets are dropped by driver.
- increased number of lcs IO buffers to 32.
- use netif_stop_queue/netif_wake_queue in lcs_start_xmit routine
- don't lock the whole xmit routine but just the piece of code where
tx_buffer is touched.
diffstat:
lcs.c | 31 +++++++++++++++++--------------
lcs.h | 2 +-
2 files changed, 18 insertions(+), 15 deletions(-)
Flush workqueue of a scsi host after a remote port for that host
is registered at the fc transport class. Otherwise immediate
registration of a scsi device on that host is racy.
Avoid access to old fsf_requests if device reset is logged.
Signed-off-by: Maxim Shchetynin <maxim@de.ibm.com>
Remove endless polling for replug of the local link. Just wait for
link up notification.
Remove all remainders of obsolete zfcp adapter attributes physical_wwpn and
physical_s_id.
When the sclp interface takes very long to serve a request, the sclp core
driver will report a failed request to the sclp tty driver even though the
request is still being processed by the sclp interface. Eventually the sclp
interface completes the request and updates some fields in the request buffer
which leads to a corrupted tty pages list. The next time function
sclp_tty_write_room is called, the corrupted list will be traversed, resulting
in an oops.
To avoid this remove the busy retry limit and increase retry intervals.
Fix locking in __chp_add() and s390_subchannel_remove_chpid(): Need to
disable/enable because they are always called from a thread (and not
directly from a machine check...)
Fix broken to_channelpath macro (fortunately worked in all current cases...).
Signed-off-by: Cornelia Huck <cohuck@de.ibm.com>
