path: root/drivers/s390
2014-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 bugfixes from Martin Schwidefsky: "A collection a bug fixes. Most of them are minor but two of them are more severe. The linkage stack bug can be used by user space to force an oops, with panic_on_oops this is a denial-of-service. And the dump memory detection issue can cause incomplete memory dumps" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/cio: improve cio_commit_config s390: fix kernel crash due to linkage stack instructions s390/dump: Fix dump memory detection s390/appldata: restore missing init_virt_timer() s390/qdio: correct program-controlled interruption checking s390/qdio: for_each macro correctness
2014-02-06s390/cio: improve cio_commit_configSebastian Ott
The modify subchannel wrapper cio_commit_config can fail when (unexpected) status is pending on the subchannel. Callers of cio_commit_config (that operated on enabled subchannels) needed to do error handling for that case (clear the unexpected status with test subchannel and retry). This error handling is missing in some code paths and caused online setting of devices to fail. Fix this for all callers by moving the error handling inside cio_commit_config. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-31Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull more KVM updates from Paolo Bonzini: "Second batch of KVM updates. Some minor x86 fixes, two s390 guest features that need some handling in the host, and all the PPC changes. The PPC changes include support for little-endian guests and enablement for new POWER8 features" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (45 commits) x86, kvm: correctly access the KVM_CPUID_FEATURES leaf at 0x40000101 x86, kvm: cache the base of the KVM cpuid leaves kvm: x86: move KVM_CAP_HYPERV_TIME outside #ifdef KVM: PPC: Book3S PR: Cope with doorbell interrupts KVM: PPC: Book3S HV: Add software abort codes for transactional memory KVM: PPC: Book3S HV: Add new state for transactional memory powerpc/Kconfig: Make TM select VSX and VMX KVM: PPC: Book3S HV: Basic little-endian guest support KVM: PPC: Book3S HV: Add support for DABRX register on POWER7 KVM: PPC: Book3S HV: Prepare for host using hypervisor doorbells KVM: PPC: Book3S HV: Handle new LPCR bits on POWER8 KVM: PPC: Book3S HV: Handle guest using doorbells for IPIs KVM: PPC: Book3S HV: Consolidate code that checks reason for wake from nap KVM: PPC: Book3S HV: Implement architecture compatibility modes for POWER8 KVM: PPC: Book3S HV: Add handler for HV facility unavailable KVM: PPC: Book3S HV: Flush the correct number of TLB sets on POWER8 KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs KVM: PPC: Book3S HV: Align physical and virtual CPU thread numbers KVM: PPC: Book3S HV: Don't set DABR on POWER8 kvm/ppc: IRQ disabling cleanup ...
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several fixups, of note: 1) Fix unlock of not held spinlock in RXRPC code, from Alexey Khoroshilov. 2) Call pci_disable_device() from the correct shutdown path in bnx2x driver, from Yuval Mintz. 3) Fix qeth build on s390 for some configurations, from Eugene Crosser. 4) Cure locking bugs in bond_loadbalance_arp_mon(), from Ding Tianhong. 5) Must do netif_napi_add() before registering netdevice in sky2 driver, from Stanislaw Gruszka. 6) Fix lost bug fix during merge due to code movement in ieee802154, noticed and fixed by the eagle eyed Stephen Rothwell. 7) Get rid of resource leak in xen-netfront driver, from Annie Li. 8) Bounds checks in qlcnic driver are off by one, from Manish Chopra. 9) TPROXY can leak sockets when TCP early demux is enabled, fix from Holger Eitzenberger" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) qeth: fix build of s390 allmodconfig bonding: fix locking in bond_loadbalance_arp_mon() tun: add device name(iff) field to proc fdinfo entry DT: net: davinci_emac: "ti, davinci-no-bd-ram" property is actually optional DT: net: davinci_emac: "ti, davinci-rmii-en" property is actually optional bnx2x: Fix generic option settings net: Fix warning on make htmldocs caused by skbuff.c llc: remove noisy WARN from llc_mac_hdr_init qlcnic: Fix loopback test failure qlcnic: Fix tx timeout. qlcnic: Fix initialization of vlan list. qlcnic: Correct off-by-one errors in bounds checks net: Document promote_secondaries net: gre: use icmp_hdr() to get inner ip header i40e: Add missing braces to i40e_dcb_need_reconfig() xen-netfront: fix resource leak in netfront net: 6lowpan: fixup for code movement hyperv: Add support for physically discontinuous receive buffer sky2: initialize napi before registering device net: Fix memory leak if TPROXY used with TCP early demux ...
2014-01-29qeth: fix build of s390 allmodconfigEugene Crosser
commit 949efd1c "qeth: bridgeport support - basic control" broke s390 allmodconfig. This patch fixes this by eliminating one of the cross-module calls, and by making two other calls via function pointers in the qeth_discipline structure. Signed-off-by: Eugene Crosser <Eugene.Crosser@ru.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-29s390/qdio: correct program-controlled interruption checkingUrsula Braun
Get rid of compile warning in qdio_int_handler_pci() when checking for program-controlled interruption on outbound queues. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-29s390/qdio: for_each macro correctnessJose Alonso
I observed that there are for_each macros that do an extra memory access beyond the defined area. Normally this does not cause problems. But, this can cause exceptions. For example: if the area is allocated at the end of a page and the next page is not accessible. For correctness, I suggest changing the arguments of the 'for loop' like others 'for_each' do in the kernel. Signed-off-by: Jose Alonso <joalonsof@gmail.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "A new binary interface to be able to query and modify the LPAR scheduler weight and cap settings. Some improvements for the hvc terminal over iucv and a couple of bux fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/hypfs: add interface for diagnose 0x304 s390: wire up sys_sched_setattr/sys_sched_getattr s390/uapi: fix struct statfs64 definition s390/uaccess: remove dead extern declarations, make functions static s390/uaccess: test if current->mm is set before walking page tables s390/zfcpdump: make zfcpdump depend on 64BIT s390/32bit: fix cmpxchg64 s390/xpram: don't modify module parameters s390/zcrypt: remove zcrypt kmsg documentation again s390/hvc_iucv: Automatically assign free HVC terminal devices s390/hvc_iucv: Display connection details through device attributes s390/hvc_iucv: fix sparse warning s390/vmur: Link parent CCW device during UR device creation
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-24s390/hypfs: add interface for diagnose 0x304Martin Schwidefsky
To provide access to the set-partition-resource-parameter interface to user space add a new attribute to hypfs/debugfs: * s390_hypsfs/diag_304 The data for the query-partition-resource-parameters command can be access by a read on the attribute. All other diagnose 0x304 requests need to be submitted via ioctl with CAP_SYS_ADMIN rights. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-23Merge tag 'kvm-s390-20140117' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-queue This deals with 2 guest features that need enablement in the kvm host: - transactional execution - lpp sampling support In addition there is also a fix to the virtio-ccw guest driver. This will enable future features
2014-01-22s390/xpram: don't modify module parametersSebastian Ott
During parsing of the sizes array the pointer to the particular string is lost. Keep it by using an extra pointer to store the end position of the parsed string. Keeping these parameters accessible can be helpful for debugging purposes and for userspace reading the parameters at runtime via sysfs. Also this will ensure that the memory is freed at module unload time. Reported-by: Michael Veigel <veigel@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-22s390/vmur: Link parent CCW device during UR device creationHendrik Brueckner
When creating the virtual unit record (UR) device, specify the parent CCW device. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The bulk of the s390 updates for v3.14. New features are the perf support for the CPU-Measurement Sample Facility and the EP11 support for the crypto cards. And the normal cleanups and bug-fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits) s390/cpum_sf: fix printk format warnings s390: Fix misspellings using 'codespell' tool s390/qdio: bridgeport support - CHSC part s390: delete new instances of __cpuinit usage s390/compat: fix PSW32_USER_BITS definition s390/zcrypt: add support for EP11 coprocessor cards s390/mm: optimize randomize_et_dyn for !PF_RANDOMIZE s390: use IS_ENABLED to check if a CONFIG is set to y or m s390/cio: use device_lock to synchronize calls to the ccwgroup driver s390/cio: use device_lock to synchronize calls to the ccw driver s390/cio: fix unlocked access of online member s390/cpum_sf: Add flag to process full SDBs only s390/cpum_sf: Add raw data sampling to support the diagnostic-sampling function s390/cpum_sf: Filter perf events based event->attr.exclude_* settings s390/cpum_sf: Detect KVM guest samples s390/cpum_sf: Add helper to read TOD from trailer entries s390/cpum_sf: Atomically reset trailer entry fields of sample-data-blocks s390/cpum_sf: Dynamically extend the sampling buffer if overflows occur s390/pci: reenable per default s390/pci/dma: fix accounting of allocated_pages ...
2014-01-17KVM: s390: virtio-ccw: Handle command rejects.Cornelia Huck
A command reject for a ccw may happen if we run on a host not supporting a certain feature. We want to be able to handle this as special case of command failure, so let's split this off from the generic -EIO error code. Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-01-16s390: Fix misspellings using 'codespell' toolHendrik Brueckner
2014-01-15qeth: bridgeport support - address notificationsEugene Crosser
Introduce functions to enable and disable bridgeport address notification feature, sysfs attributes for access to these functions from userspace, and udev events emitted when a host joins or exits a bridgeport-enabled HiperSocket channel. Signed-off-by: Eugene Crosser <eugene.crosser@ru.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reviewed-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-15s390/qdio: bridgeport support - CHSC partEugene Crosser
Introduce function for the "Perform network-subchannel operation" CHSC command with operation code "bridgeport information", and bit definitions for "characteristics" pertaning to this command. Signed-off-by: Eugene Crosser <eugene.crosser@ru.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-15qeth: bridgeport support - basic controlEugene Crosser
Introduce functions to assign roles and check state of bridgeport-capable HiperSocket devices, and sysfs attributes providing access to these functions from userspace. Introduce udev events emitted when the state of a bridgeport device changes. Signed-off-by: Eugene Crosser <eugene.crosser@ru.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reviewed-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-01-14s390/qdio: bridgeport support - CHSC partEugene Crosser
Introduce function for the "Perform network-subchannel operation" CHSC command with operation code "bridgeport information", and bit definitions for "characteristics" pertaning to this command. Signed-off-by: Eugene Crosser <eugene.crosser@ru.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-31Merge tag 'v3.13-rc6' into for-3.14/coreJens Axboe
Needed to bring blk-mq uptodate, since changes have been going in since for-3.14/core was established. Fixup merge issues related to the immutable biovec changes. Signed-off-by: Jens Axboe <axboe@kernel.dk> Conflicts: block/blk-flush.c fs/btrfs/check-integrity.c fs/btrfs/extent_io.c fs/btrfs/scrub.c fs/logfs/dev_bdev.c
2013-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/i40e/i40e_main.c drivers/net/macvtap.c Both minor merge hassles, simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18s390/zcrypt: add support for EP11 coprocessor cardsIngo Tuchscherer
This feature extends the generic cryptographic device driver (zcrypt) with a new capability to service EP11 requests for the Crypto Express4S card in EP11 (Enterprise PKCS#11 mode) coprocessor mode. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-18s390/3270: fix allocation of tty3270_screen structureMartin Schwidefsky
The tty3270_alloc_screen function is called from tty3270_install with swapped arguments, the number of columns instead of rows and vice versa. The number of rows is typically smaller than the number of columns which makes the screen array too big but the individual cell arrays for the lines too small. Creating lines longer than the number of rows will clobber the memory after the end of the cell array. The fix is simple, call tty3270_alloc_screen with the correct argument order. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-17qeth: Accurate ethtool outputEugene Crosser
For OSA devices that support the QUERY_CARD_INFO command, supply accurate data based on the card type, port mode and link speed via the 'ethtool' interface. Signed-off-by: Eugene Crosser <Eugene.Crosser@ru.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17netiucv: improve state checking in conn_action_txdoneUrsula Braun
state checking in conn_action_txdone() is inconsistent. This patch makes it consistent and issues a trace message if an unexpected state is detected for the netiucv device. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-16s390/cio: use device_lock to synchronize calls to the ccwgroup driverSebastian Ott
When calling set_{on,off}line of a ccwgroup device driver we hold the module reference of the owner. This is pretty useless - we don't want to prevent module unloading but driver unbinding. Use the driver core's device_lock instead. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/cio: use device_lock to synchronize calls to the ccw driverSebastian Ott
When calling set_{on,off}line of a ccw device driver we hold the module reference of the owner. This is pretty useless - we don't want to prevent module unloading but driver unbinding. Use the driver core's device_lock instead. Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/cio: fix unlocked access of online memberSebastian Ott
Make sure that access to the online member of a ccw device is guarded by the ccwlock. Reported-by: Cornelia Huck <cornelia.huck@de.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/sclp_early: Add function to detect sclp console capabilitiesHendrik Brueckner
Add SCLP console detect functions to encapsulate detection of SCLP console capabilities, for example, VT220 support. Reuse the sclp_send/receive masks that were stored by the most recent sclp_set_event_mask() call to prevent unnecessary SCLP calls. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/sclp_early: Pass sccb pointer to every *_detect() functionHendrik Brueckner
Add a sccb pointer parameter to *_detect() functions instead of accessing the global sccb_early variable directly. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/sclp_early: Replace early_read_info_sccb with sccb_earlyHendrik Brueckner
Replace early_read_info_sccb and use sccb_early instead. Also saves some memory. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/sclp_early: Get rid of sclp_early_read_info_sccb_validHendrik Brueckner
The early sclp detect functions gather the available SCLP facility information. The sclp_early_read_info_sccb_valid indicates whether the early sclp request was valid. However, one external reference to it checks for particular sclp facility bits and this should be sufficient. Another occurance is in the sclp_get_ipl_info() function that is called later. Because all information are available at the early stage, save the ipl information when detecting the sclp facilities. Hence, no more checks for sclp_early_read_info_sccb_valid are required. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/3270: fix use after free of tty3270_screen structureMartin Schwidefsky
The deactivation and freeing of the tty view of the 3270 device can race with a tty3270_update invocation via the update timer. To fix this move the del_timer_sync call for the update timer from tty3270_free_view to tty3270_free prior to the tty3270_free_screen call. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/blacklist: Perform subchannel scan only when neededPeter Oberparleiter
Move scheduling of a subchannel scan to those instances where new devices may actually have become available. This reduces unnecessary scan work in case devices were added to the blacklist. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/css: Prevent unnecessary allocation in subchannel loopPeter Oberparleiter
Subchannel looping function for_each_subchannel_staged() allocates a subchannel-ID-bitmap to efficiently iterate over the list of known and unknown subchannels. Since this function is also used to iterate over known-subchannels only, optimize that case by not requiring the ID-bitmap allocation and falling back to simple bus_for_each_dev() looping. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/cio: Delay scan for newly available I/O devicesPeter Oberparleiter
The CIO layer scans for newly available I/O devices by performing a scan of available subchannels using the Store Subchannel (STSCH) instruction. Performing too many STSCH instructions in a tight loop can cause high Hypervisor overhead which can negatively impact the performance of the virtual machine as a whole. A subchannel scan is triggered for example during a hardware event that indicates that a channel path has become available. It is also triggered by the DASD device driver for each device that is set online. This patch reduces the number of STSCH instructions being performed by delaying the start of the actual subchannel scan by 1 second. Multiple scan requests that are scheduled during this time will be merged into a single scan loop. The trade-off consists of a short delay that is introduced between the time that the event is processed and a newly available device becoming usable. This delay should be acceptable since it only affects devices that have not been in use before. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/cio: Relax subchannel scan loopPeter Oberparleiter
The CIO layer scans for newly available I/O devices by performing a scan of available subchannels using the Store Subchannel (STSCH) instruction. This processing can take a significant amount of time during which no other task can run on the same CPU (unless CONFIG_PREEMPT has been enabled). As a result, scheduling latencies for other tasks are increased noticeably, especially on a single-CPU system. Fix this problem by explicitly allowing other tasks to be scheduled each time a subchannel has been processed. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-16s390/cio: More efficient handling of CHPID availability eventsPeter Oberparleiter
The CIO layer processes hardware events that indicate that a channel path has become available by performing a scan of available subchannels using the Store Subchannel (STSCH) instruction. Performing too many STSCH instructions in a tight loop can cause high Hypervisor overhead which can negatively impact the performance of the virtual machine as a whole. This patch reduces the number of STSCH instructions performed while processing a resource accessibility event and while varying a CHPID online. In both cases, Linux first performs a STSCH instruction on each unused subchannel to see if the subchannel has become available. If the STSCH instruction indicates that the subchannel is available, a full evaluation of this subchannel is scheduled. Since the full evaluation includes performing a STSCH instruction, the initial STSCH is unnecessary and can be removed. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-02s390/sclp: replace uninitialized early_event_mask_sccb variable with sccb_earlyHendrik Brueckner
Commit "s390/sclp: Consolidate early sclp init calls to sclp_early_detect()" (7b50da53f6ad2048241bef232bfc22a132a40283) replaced the sclp_event_mask_early() with sclp_set_event_mask(). The early_event_mask_sccb variable is no longer initialized but is still used in sclp_has_linemode() and sclp_has_vt220(). Replace early_event_mask_sccb with the sccb_early variable in both functions. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-02s390/dasd: fix memory leak caused by dangling references to request_queueStefan Weinhuber
After the call to del_gendisk, the gendisk still holds a reference to its request_queue. We must not modify the gendisks queue pointer before the put_disk call, or the gendisk_release function cannot release the reference and the memory for the request_queue structure is lost. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-11-23block: Convert bio_for_each_segment() to bvec_iterKent Overstreet
More prep work for immutable biovecs - with immutable bvecs drivers won't be able to use the biovec directly, they'll need to use helpers that take into account bio->bi_iter.bi_bvec_done. This updates callers for the new usage without changing the implementation yet. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: Jim Paris <jim@jtan.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com> Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Cc: support@lsi.com Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Quoc-Son Anh <quoc-sonx.anh@intel.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jan Kara <jack@suse.cz> Cc: linux-m68k@lists.linux-m68k.org Cc: linuxppc-dev@lists.ozlabs.org Cc: drbd-user@lists.linbit.com Cc: nbd-general@lists.sourceforge.net Cc: cbe-oss-dev@lists.ozlabs.org Cc: xen-devel@lists.xensource.com Cc: virtualization@lists.linux-foundation.org Cc: linux-raid@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: DL-MPTFusionLinux@lsi.com Cc: linux-scsi@vger.kernel.org Cc: devel@driverdev.osuosl.org Cc: linux-fsdevel@vger.kernel.org Cc: cluster-devel@redhat.com Cc: linux-mm@kvack.org Acked-by: Geoff Levand <geoff@infradead.org>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-20s390/dasd: validate request size before building CCW/TCW requestStefan Weinhuber
An I/O request that does not read or write full blocks cannot be translated into a correct CCW or TCW program and should be rejected right away. In particular the code that creates TCW requests will not notice this problem and create broken TCWs that will be rejected by the hardware. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Reference-ID: RQM1956
2013-11-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull second set of s390 patches from Martin Schwidefsky: "The handling of the PCI hotplug notifications has been improved, the zfcp dumper can now detect the HSA size dynamically and the default install kernel has been changed to the compressed bzImage. And two bug-fixes for scm and 3720" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/pci: implement hotplug notifications s390/scm_block: do not hide eadm subchannel dependency s390/sclp: Consolidate early sclp init calls to sclp_early_detect() s390/sclp: Move early code from sclp_cmd.c to sclp_early.c s390/sclp: Determine HSA size dynamically for zfcpdump s390/sclp: Move declarations for sclp_sdias into separate header file s390/pci: implement pcibios_remove_bus s390/pci: improve handling of bus resources s390/3270: fix missing device_destroy() call s390/boot: Install bzImage as default kernel image
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-15s390/scm_block: do not hide eadm subchannel dependencySebastian Ott
Stop hiding scm_block's dependency to the eadm subchannel driver (by using functions provided by the eadm subchannel instead of wrappers provided by the scm bus). This will help userspace recognizing module dependencies (e.g. for building a ramdisk). As a side effect we can get rid of some code reimplementing refcounting between those modules. Reported-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-11-15s390/sclp: Consolidate early sclp init calls to sclp_early_detect()Michael Holzheu
The new function calls the old ones. The sclp_event_mask_early() is removed and replaced by one invocation of sclp_set_event_mask(0, 0). Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
