path: root/drivers/sbus
2009-07-17sparc: Fix cleanup crash in bbc_envctrl_cleanup()David S. Miller
If kthread_run() fails or never gets to run we'll have NULL or a pointer encoded error in kenvctrld_task, rather than a legitimate task pointer. So this makes bbc_envctrl_cleanup() crash as it passed this bogus pointer into kthread_stop(). Reported-by: BERTRAND Joël <joel.bertrand@systella.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16openprom: Squelch useless GCC warning.David S. Miller
drivers/sbus/char/openprom.c: In function ‘openprom_sunos_ioctl’: drivers/sbus/char/openprom.c:306: warning: ‘opp’ may be used uninitialized in this function Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11jsflash: dequeue in-flight requestTejun Heo
jsflash processes requests one-by-one synchronously from a kthread and can be easily converted to dequeueing model. Convert it. [ Impact: dequeue in-flight request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: blk_rq_[cur_]_{sectors|bytes}() usage cleanupTejun Heo
With the previous changes, the followings are now guaranteed for all requests in any valid state. * blk_rq_sectors() == blk_rq_bytes() >> 9 * blk_rq_cur_sectors() == blk_rq_cur_bytes() >> 9 Clean up accessor usages. Notable changes are * nbd,i2o_block: end_all used instead of explicit byte count * scsi_lib: unnecessary conditional on request type removed [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: replace end_request() with [__]blk_end_request_cur()Tejun Heo
end_request() has been kept around for backward compatibility; however, it's about time for it to go away. * There aren't too many users left. * Its use of @updtodate is pretty confusing. * In some cases, newer code ends up using mixture of end_request() and [__]blk_end_request[_all](), which is way too confusing. So, add [__]blk_end_request_cur() and replace end_request() with it. Most conversions are straightforward. Noteworthy ones are... * paride/pcd: next_request() updated to take 0/-errno instead of 1/0. * paride/pf: pf_end_request() and next_request() updated to take 0/-errno instead of 1/0. * xd: xd_readwrite() updated to return 0/-errno instead of 1/0. * mtd/mtd_blkdevs: blktrans_discard_request() updated to return 0/-errno instead of 1/0. Unnecessary local variable res initialization removed from mtd_blktrans_thread(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Laurent Vivier <Laurent@lvivier.info> Cc: Tim Waugh <tim@cyberelk.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: unsik Kim <donari75@gmail.com>
2009-04-14sbus: changed ioctls to unlockedStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13sbus: Auto-load openprom module when device opened.Scott James Remnant
The openprom module is missing the char-major-10-139 alias that would cause it to be auto-loaded when a device of that type is opened. This patch adds the alias. Signed-off-by: Scott James Remnant <scott@canonical.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04sparc64: wait_event_interruptible_timeout may return -ERESTARTSYSRoel Kluin
wait_event_interruptible_timeout may return -ERESTARTSYS. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04jsflash: stop defining MAJOR_NRChristoph Hellwig
Ever since early 2.5 kernels block drivers don't need to define MAJOR_NR anymore, so use the JSFD_MAJOR defined directly and kill it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06sparc64: Fix unsigned long long warnings in drivers.Sam Ravnborg
Fix warnings caused by the unsigned long long usage in sparc specific drivers. The drivers were considered sparc specific more or less from the filename alone. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-01Revert "of_platform_driver noise on sparce"Linus Torvalds
This reverts commit e669dae6141ff97d3c7566207f5de3b487dcf837, since it is incomplete, and clashes with fuller patches and the sparc 32/64 unification effort. Requested-by: David Miller <davem@davemloft.net> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30of_platform_driver noise on sparceAl Viro
switch to __init for those; unlike powerpc sparc has no hotplug support for that stuff and their ->probe() tends to call __init functions while being declared __devinit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-04drivers: remove duplicated #includeJianjun Kong
Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-03sparc: Kill sbus mostek RTC driver.David S. Miller
No longer used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29bbc_envctrl: Fix build errors from bbc_i2c OF conversion.David S. Miller
2008-08-29bbc_i2c: Convert to pure OF driver.David S. Miller
This thing was a mess, who wrote this junk? :) Luckily we'll soon have nice generic I2C layer drivers for this PCF based I2C stuff on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29envctrl: Convert to pure OF driver.David S. Miller
2008-08-29display7seg: Convert to pure OF device driver.David S. Miller
2008-08-29cpwatchdog: Move to drivers/watchdog/cpwd.cDavid S. Miller
2008-08-29cpwatchdog: Cleanup and convert to pure OF driver.David S. Miller
2008-08-29riowatchdog: Move under drivers/watchdogDavid S. Miller
The config stuff was already in drivers/watchdog/Kconfig Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29riowatchdog: Convert to pure OF driver.David S. Miller
This also cleans up a lot of crud in this driver: 1) Don't touch the BBC regs, just leave the watchdog trigger behavior whatever the firmware programmed it to. 2) Use WATCHDOG_MINOR instead of hardcoded and not properly allocated RIOWD_MINOR. Hey, I haven't touched it since I wrote it years ago :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Remove generic SBUS probing layer.David S. Miller
The individual SBUS IOMMU arch code now sets the IOMMU information directly into the OF device objects. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill sbus_arch_preinit().David S. Miller
32-bit sparc just needed it to register the ioport procfs bits, do this via an arch_initcall() instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill OBP property members of sbus_dev and sbus_busDavid S. Miller
Unused. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Remove dinky old-style SBUS probing facilities.David S. Miller
No drivers or code uses this stuff any more, every driver has been converted over to OF device probing. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Remove SBUS layer resource and irq handling.David S. Miller
All the drivers use OF device objects now for this information. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill SBUS layer IRQ hooks.David S. Miller
IRQs are obtained by drivers from the of_device struct. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Convert uctrl driver to OF driver.David S. Miller
2008-08-29sparc: Convert flash driver to OF device probing.David S. Miller
2008-08-29sparc: Propagate SBUS iommu archdata into real of_device objects.David S. Miller
2008-08-29sparc: Kill SBUS DVMA layer.David S. Miller
This thing was completely pointless. Just find the OF device in the parent of drivers that want to program this device, and map the DMA regs inside such drivers too. This also moves the dummy claim_dma_lock() and release_dma_lock() implementation to floppy_32.h, which makes it handle this issue just like floppy_64.h does. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill videopix SBUS driver.David S. Miller
This has been marked BROKEN for a long time and it's more likely to get rewritten from scratch than to be fixed up and made usable. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Delete bare sbus char bpp driver, obsoleted by parport_sunbppDavid S. Miller
2008-08-11sparc/drivers: use linux/of_device.h instead of asm/of_device.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-21sparc64: fix up bus_id changes in sparc core codeGreg Kroah-Hartman
This converts all instances of bus_id in the sparc core kernel to use either dev_set_name(), or dev_name() depending on the need. This is done in anticipation of removing the bus_id field from struct driver. Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-17drivers/sbus/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - char/uctrl.c: uctrl_get_event_status() - char/uctrl.c: uctrl_get_external_status() - char/vfc_dev.c: struct vfc_dev_lst - char/vfc_dev.c: vfc_lock_device() - char/vfc_dev.c: vfc_unlock_device() - char/vfc_dev.c: vfc_captstat_reset() - char/vfc_dev.c: vfc_memptr_reset() - char/vfc_dev.c: vfc_csr_init() - char/vfc_dev.c: vfc_saa9051_init() - char/vfc_dev.c: init_vfc_hw() - char/vfc_dev.c: init_vfc_devstruct() - char/vfc_dev.c: init_vfc_device() - char/vfc_dev.c: vfc_get_dev_ptr() - char/vfc_dev.c: vfc_capture_start() - char/vfc_dev.c: vfc_capture_poll() - char/vfc_dev.c: vfc_port_change_ioctl() - char/vfc_dev.c: vfc_set_video_ioctl() - char/vfc_dev.c: vfc_get_video_ioctl() - char/vfc_i2c.c: vfc_i2c_wait_for_bus() - char/vfc_i2c.c: vfc_i2c_wait_for_pin() - char/vfc_i2c.c: vfc_i2c_xmit_addr() - char/vfc_i2c.c: vfc_i2c_xmit_byte() - char/vfc_i2c.c: vfc_i2c_recv_byte() - dvma.c: init_one_dvma() - remove an unused variable from a function: - char/uctrl.c: ts102_uctrl_init() - remove the following unused and empty function: - char/uctrl.c: uctrl_set_video() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-02uctrl: BKL pushdownArnd Bergmann
2008-07-02sbus-rtc: BKL pushdownArnd Bergmann
2008-07-02riowatchdog: BKL pushdownArnd Bergmann
2008-07-02openprom: BKL pushdownArnd Bergmann
2008-06-20jsflash: BKL pushdownArnd Bergmann
2008-06-20flash: BKL pushdownArnd Bergmann
2008-06-20envctrl: BKL pushdownArnd Bergmann
2008-06-20display7seg: BKL pushdownArnd Bergmann
2008-06-20cpwatchdog: BKL pushdownArnd Bergmann
