commit 33d6667416c73eb0b37f0f10f56d825b15389dab upstream.
The change to use dma_set_mask_and_coherent() incorrectly made a second
call with the 32 bit DMA mask value when the call with the 64 bit DMA mask
value succeeded.
Fixes: b000bced5739 ("scsi: 3w-9xxx: fully convert to the generic DMA API")
Cc: <stable@vger.kernel.org>
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Clang warns a few times:
drivers/scsi/3w-sas.c:386:11: warning: implicit conversion from 'int' to
'char' changes value from 128 to -128 [-Wconstant-conversion]
cdb[4] = TW_ALLOCATION_LENGTH; /* allocation length */
Update cdb's type to unsigned char, which matches the type of the cdb
member in struct TW_Command_Apache.
Link: https://github.com/ClangBuiltLinux/linux/issues/158
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Adam Radford <aradford@gmail.com>
The driver is currently using an odd mix of legacy PCI DMA API and
generic DMA API calls, switch it over to the generic API entirely.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
tw_probe() returns 0 in case of fail of tw_initialize_device_extension(),
pci_resource_start() or tw_reset_sequence() and releases resources.
twl_probe() returns 0 in case of fail of twl_initialize_device_extension(),
pci_iomap() and twl_reset_sequence(). twa_probe() returns 0 in case of
fail of tw_initialize_device_extension(), ioremap() and
twa_reset_sequence().
The patch adds retval initialization for these cases.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
In twa_chrdev_ioctl(), the ioctl driver command is firstly copied from
the userspace pointer 'argp' and saved to the kernel object
'driver_command'. Then a security check is performed on the data buffer
size indicated by 'driver_command', which is
'driver_command.buffer_length'. If the security check is passed, the
entire ioctl command is copied again from the 'argp' pointer and saved
to the kernel object 'tw_ioctl'. Then, various operations are performed
on 'tw_ioctl' according to the 'cmd'. Given that the 'argp' pointer
resides in userspace, a malicious userspace process can race to change
the buffer size between the two copies. This way, the user can bypass
the security check and inject invalid data buffer size. This can cause
potential security issues in the following execution.
This patch checks for capable(CAP_SYS_ADMIN) in twa_chrdev_open()t o
avoid the above issues.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
The TW_IOCTL_GET_LOCK ioctl uses do_gettimeofday() to check whether a
lock has expired. This can misbehave due to a concurrent settimeofday()
call, as it is based on 'real' time, and it will overflow in y2038 on
32-bit architectures, producing unexpected results when used across the
overflow time.
This changes it to using monotonic time, using ktime_get() to simplify
the code.
The calculation of the number of seconds since Sunday 00:00:00 overflows
in 2106, meaning that we instead will return the seconds since Wednesday
06:28:16 afterwards.
Using 64-bit time stamps avoids this slight inconsistency, and the
deprecated do_gettimeofday(), replacing it with the simpler
ktime_get_real_seconds().
twl_aen_queue_event/twa_aen_queue_event, we use do_gettimeofday() to
read the lower 32 bits of the current time in seconds, to pass them to
the TW_IOCTL_GET_NEXT_EVENT ioctl or the 3ware_aen_read sysfs file.
This will overflow on all architectures in year 2106, there is not much
we can do about that without breaking the ABI. User space has 90 years
to learn to deal with it, so it's probably ok.
I'm changing it to use ktime_get_real_seconds() with a comment to
document what happens when.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
This change updates the 3ware drivers (3w-xxxx, 3w-9xxx, 3w-sas) email
addresses from linuxraid@lsi.com to aradford@gmail.com, since the old
email address doesn't exist.
This patch was updated to remove www.lsi.com text.
[mkp: applied by hand]
Signed-off-by: Adam Radford <aradford@gmail.com>
Acked-by: Sumit Saxena <sumit.saxena@broadcom.com>
3w controller don't dma map small single SGL entry commands but instead
bounce buffer them. Add a helper to identify these commands and don't
call scsi_dma_unmap for them.
Based on an earlier patch from James Bottomley.
Fixes: 118c85 ("3w-9xxx: fix command completion race")
Reported-by: Tóth Attila <atoth@atoth.sote.hu>
Tested-by: Tóth Attila <atoth@atoth.sote.hu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
The 3w-9xxx driver needs to tear down the dma mappings before returning
the command to the midlayer, as there is no guarantee the sglist and
count are valid after that point. Also remove the dma mapping helpers
which have another inherent race due to the request_id index.
Cc: stable@vger.kernel.org
Replacing strncpy with strlcpy to avoid strings that lacks null terminate.
And use the sizeof on the to string rather than strlen on the from string.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
We won't ever queue more commands than the host allows. Instead of
letting drivers either reject or ignore this case handle it in
common code. Note that various driver use internal constant or
variables that are assigned to both shost->can_queue and checked
in ->change_queue_depth - I did remove those checks as well.
Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
Cc: stable@kernel.org
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Adam Radford <linuxraid@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Following reports on the list, it looks like the 3e-9xxx driver will leak dma
mappings every time we get a transient queueing error back from the card.
This is because it maps the sg list in the routine that sends the command, but
doesn't unmap again in the transient failure path (even though the command is
sent back to the block layer). Fix by unmapping before returning the status.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
Cc: linux-scsi@vger.kernel.org
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
Push down the bkl into ioctl functions on the scsi layer.
[jkacur: Forward declaration missing ';'.
Conflicting declaraction in megaraid.h changed
Fixed missing inodes declarations]
Signed-off-by: John Kacur <jkacur@redhat.com>
This small patch forces 60 second timeouts for the older 3w-xxxx &
3w-9xxx drivers for systems that don't contain the udev rule for
setting scsi timeouts to 60 seconds.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This small patch fixes a bug in the 3w-9xxx driver where it would load
an invalid sgl address in the ioctl path even if request length was zero.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
[jejb: fixed up 53c700]
something-bility is spelled as something-blity
so a grep for 'blit' would find these lines
this is so trivial that I didn't split it by subsystem / copy
additional maintainers - all changes are to comments
The only purpose is to get fewer false positives when grepping
around the kernel sources.
Signed-off-by: Dirk Hohndel <hohndel@infradead.org>
This patch fixes the following regression the occurred during the
scsi_dma_map()/unmap() changes:
3w-9xxx 0001:45:00.0: DMA-API: device driver tries to free DMA memory
it has not allocated [device address=0x0000000000000000] [size=36
bytes]
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
This is the second go through of the old DMA_nBIT_MASK macro,and there're not
so many of them left,so I put them into one patch.I hope this is the last round.
After this the definition of the old DMA_nBIT_MASK macro could be removed.
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Greg KH <greg@kroah.com>
Cc: Takashi Iwai <tiwai@suse.de>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Since the commit 50bed2e2862a8f3a4f7d683d0d27292e71ef18b9 (sg: disable
interrupts inside sg_copy_buffer), no need to disable interrupts
before calling scsi_sg_copy_from_buffer. So we can simplify
twa_scsiop_execute_scsi_complete() a bit, which disables interrupts
just for scsi_sg_copy_from_buffer.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Adam Radford <linuxraid@amcc.com>
This patch for the 3w-9xxx scsi driver applies on top of the
BKL-pushdown changes in -git9.
This patch does the following:
- Increase max AENs drained to 256.
- Add MSI support and "use_msi" module parameter.
- Fix bug in twa_get_param() on 4GB+.
- Use pci_resource_len() for ioremap().
All of the open() functions which don't need the BKL on their face may
still depend on its acquisition to serialize opens against driver
initialization. So make those functions acquire then release the BKL to be
on the safe side.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This documents the fact that somebody looked at the relevant open()
functions and concluded that, due to their trivial nature, no locking was
needed.
drivers/scsi/aha152x.c:3585:60: warning: Using plain integer as NULL pointer
drivers/scsi/aha152x.c:3845:56: warning: Using plain integer as NULL pointer
drivers/scsi/qla1280.c:2814:37: warning: Using plain integer as NULL pointer
drivers/scsi/atp870u.c:750:47: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1281:36: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1293:36: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1301:35: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:447:10: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:457:10: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:479:24: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:483:22: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:1213:23: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:1214:23: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
The memory return from scsi_host_alloc is alloced by kzalloc, which is
already zero initilized, so memset not needed.
Signed-off-by: Denis Cheng <crquan@gmail.com>
Cc: Adam Radford <linuxraid@amcc.com>
With the sg table code, every SCSI driver is now either chain capable
or broken (or has sg_tablesize set so chaining is never activated), so
there's no need to have a check in the host template.
Also tidy up the code by moving the scatterlist size defines into the
SCSI includes and permit the last entry of the scatterlist pools not
to be a power of two.
The 3ware 9500S-8 SATA RAID controller exhibits terrible write
performance when PCI memory-write-and-invalidate is disabled. This is
easy to demonstrate by replacing pci_try_set_mwi() in the patch below
with pci_clear_mwi(). My benchmarks show the following:
MWI disabled: 15 MB/s write, 330 MB/s read
MWI enabled: 240 MB/s write, 330 MB/s read
Most motherboards will enable MWI without the driver having to set it
explicitly, so most people probably wouldn't encounter this problem.
For the few motherboards that don't enable it, this patch could give a
16x performance improvement for writing.
This issue does not seem to affect the 9550SX controller, but the patch
doesn't hurt it either. I haven't tested any of the other 3ware
controllers.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Acked-by: adam radford <aradford@gmail.com>
This option is true if a low-level driver can support sg
chaining. This will be removed eventually when all the drivers are
converted to support sg chaining. q->max_phys_segments is set to
SCSI_MAX_SG_SEGMENTS if false.
