The 3w-xxxx driver needs to tear down the dma mappings before returning
the command to the midlayer, as there is no guarantee the sglist and
count are valid after that point. Also remove the dma mapping helpers
which have another inherent race due to the request_id index.
Cc: stable@vger.kernel.org
Acked-by: Adam Radford <aradford@gmail.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
We won't ever queue more commands than the host allows. Instead of
letting drivers either reject or ignore this case handle it in
common code. Note that various driver use internal constant or
variables that are assigned to both shost->can_queue and checked
in ->change_queue_depth - I did remove those checks as well.
Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
Cc: stable@kernel.org
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Make the driver return appropriate sense data when an unsupported
operation is queued. This will cause the SCSI layer to stop issuing the
offending command.
Reported-by: Florian Westphal <fw@strlen.de>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Adam Radford <linuxraid@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
Cc: linux-scsi@vger.kernel.org
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
Push down the bkl into ioctl functions on the scsi layer.
[jkacur: Forward declaration missing ';'.
Conflicting declaraction in megaraid.h changed
Fixed missing inodes declarations]
Signed-off-by: John Kacur <jkacur@redhat.com>
This small patch forces 60 second timeouts for the older 3w-xxxx &
3w-9xxx drivers for systems that don't contain the udev rule for
setting scsi timeouts to 60 seconds.
Signed-off-by: Adam Radford <aradford@gmail.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
[jejb: fixed up 53c700]
something-bility is spelled as something-blity
so a grep for 'blit' would find these lines
this is so trivial that I didn't split it by subsystem / copy
additional maintainers - all changes are to comments
The only purpose is to get fewer false positives when grepping
around the kernel sources.
Signed-off-by: Dirk Hohndel <hohndel@infradead.org>
This patch fixes the following regression that occurred during the
scsi_dma_map()/unmap()
changes when compiling with CONFIG_DMA_API_DEBUG=y :
WARNING: at lib/dma-debug.c:496 check_unmap+0x142/0x542()
Hardware name:
3w-xxxx 0000:02:02.0: DMA-API: device driver tries to free DMA memory
it has not allocated [device address=0x0000000000000000] [size=36
bytes]
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Since the commit 50bed2e2862a8f3a4f7d683d0d27292e71ef18b9 (sg: disable
interrupts inside sg_copy_buffer), no need to disable interrupts
before calling scsi_sg_copy_from_buffer. So we can simplify
tw_transfer_internal, which disables interrupts just for
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>\
Acked-by: Adam Radford <linuxraid@amcc.com>
All of the open() functions which don't need the BKL on their face may
still depend on its acquisition to serialize opens against driver
initialization. So make those functions acquire then release the BKL to be
on the safe side.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This documents the fact that somebody looked at the relevant open()
functions and concluded that, due to their trivial nature, no locking was
needed.
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
The memory return from scsi_host_alloc is alloced by kzalloc, which is
already zero initilized, so memset not needed.
Signed-off-by: Denis Cheng <crquan@gmail.com>
Cc: Adam Radford <linuxraid@amcc.com>
This rewrites tw_transfer_internal with scsi_sg_copy_from/to_buffer.
With the sg table code, every SCSI driver is now either chain capable
or broken (or has sg_tablesize set so chaining is never activated), so
there's no need to have a check in the host template.
Also tidy up the code by moving the scatterlist size defines into the
SCSI includes and permit the last entry of the scatterlist pools not
to be a power of two.
This option is true if a low-level driver can support sg
chaining. This will be removed eventually when all the drivers are
converted to support sg chaining. q->max_phys_segments is set to
SCSI_MAX_SG_SEGMENTS if false.
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
3w-xxxx emulates a REQUEST_SENSE response by simply returning nothing.
Unfortunately, it's assuming that the REQUEST_SENSE command is
implemented with use_sg == 0, which is no longer the case. The oops
occurs because it's clearing the scatterlist in request_buffer instead
of the memory region.
This is fixed by using tw_transfer_internal() to transfer correctly to
the scatterlist.
Acked-by: adam radford <aradford@gmail.com>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The attached patch updates the 3ware 8000 driver:
- Free irq handler in __tw_shutdown().
- Turn on RCD bit for caching mode page.
- Serialize reset code.
Signed-off-by: Adam Radford <linuxraid@amcc.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Converts pci_module_init() to pci_register_driver() in the scsi subsys on
23 drivers which only return the value of pci_module_init().
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of the macro.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their
queuecommand functions. Those fields are internal storage for the
midlayer only and are used to restore the original payload after
request_buffer and request_bufflen have been overwritten for EH. Using
the buffer and bufflen fields means they do very broken things in error
handling.
We must disable local IRQs while holding KM_IRQ0 or KM_IRQ1. Otherwise, an
IRQ handler could use those kmap slots while this code is using them,
resulting in memory corruption.
Thanks to Nick Orlov <bugfixer@list.ru> for reporting.
Cc: <linuxraid@amcc.com>
Cc: James Bottomley <James.Bottomley@SteelEye.com>
Convert a the 3w-9xxx.c and 3w-xxxx.c drivers to use mutexes instead
of semaphores. Untested, but compiles and looks obviously correct.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Rejections fixed up and
The 3ware emulated commands all expect they are executing in the
use_sg == 0 case, which isn't true either in the block layer rework or
an SG_IO ioctl.
Fix this by adding the correct kmapping of the first element in the sg
list.
driver core callback.
Now we can change the pci core to always set this pointer, as pci drivers
should use it, not the driver core callback.
infrastructure for it.
Let it rip!
