path: root/drivers/scsi/Makefile
2011-07-02isci: Intel(R) C600 Series Chipset Storage Control Unit DriverDan Williams
Support for the up to 2x4-port 6Gb/s SAS controllers embedded in the chipset. This is a snapshot of the first publicly available version of the driver, commit 4c1db2d0 in the 'historical' branch. git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci.git historical Signed-off-by: Maciej Trela <maciej.trela@intel.com> Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Edmund Nadolski <edmund.nadolski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-28[SCSI] bnx2fc: Broadcom FCoE offload driverBhanu Gollapudi
This driver is for Broadcom Netxtreme II 57712 chip. The following patch contains the driver sources for bnx2fc driver. libfc/libfcoe changes to enable bnx2fc have already gone through the fcoe tree. bnx2fc is a SCSI low level driver that interfaces with SCSI midlayer, libfc, libfcoe, cnic modules. bnx2fc driver uses services of libfc for slow path operations such as FIP and fabric discovery. The fast path IO perations are performed after offloading the session information to the underlying FCoE firmware. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] cxgb3i: change cxgb3i to use libcxgbikxie@chelsio.com
Signed-off-by: Karen Xie <kxie@chelsio.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] cxgb4i v5: iscsi driverkxie@chelsio.com
Added cxgb4i iSCSI driver. This patch implements the cxgb4i iscsi connection acceleration for the open-iscsi initiator. The cxgb4i driver offers the iscsi PDU based offload: - digest insertion and verification - payload direct-placement into host memory buffer. Signed-off-by: Karen Xie <kxie@chelsio.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-06[SCSI] iscsi boot: mv iscsi_boot_sysfs to drivers/scsiMike Christie
iscsi_boot_sysfs does not depend on firmware. Any iscsi driver can use it. This patch moves iscsi_boot_sysfs to the scsi dir, so that it can be used on any arch with any driver. Signed-off-by: Mike Christie <mchristi@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] convert to the new PM frameworkAlan Stern
This patch (as1397b) converts the SCSI midlayer to use the new PM callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is created to hold the new callback routines, and the existing suspend/resume code is moved there. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-30[SCSI] add scsi trace core functions and put trace pointsKei Tokunaga
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-10[SCSI] hpsa: add driver for HP Smart Array controllers.Stephen M. Cameron
This driver supports a subset of HP Smart Array Controllers. It is a SCSI alternative to the cciss driver. [akpm@linux-foundation.org: avoid helpful cleanup patches] [achiang@hp.com: make device attrs static] [akpm@linux-foundation.org: msleep() does set_current_state() itself] Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Mike Miller <mikem@beardog.cce.hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] 3w-sas: Add new driver for LSI 3ware 9750adam radford
[jejb: fix up for new queue depth code] Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] vmw_pvscsi: SCSI driver for VMware's virtual HBA.Alok Kataria
This is a driver for VMware's paravirtualized SCSI device, which should improve disk performance for guests running under control of VMware hypervisors that support such devices. Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] pm8001: add SAS/SATA HBA driverjack wang
This driver supports PMC-Sierra PCIe SAS/SATA 8x6G SPC 8001 chip based host adapters. Signed-off-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Lindar Liu <lindar_liu@usish.com> Signed-off-by: Tom Peng <tom_peng@usish.com> Signed-off-by: Kevin Ao <aoqingyun@usish.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] be2iscsi: add 10Gbps iSCSI - BladeEngine 2 driverJayamohan Kallickal
[v2: fixed up virt_to_bus() issue spotted by sfr] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] bfa: Brocade BFA FC SCSI driverJing Huang
Add new driver for Brocade Hardware Signed-off-by: Jing Huang <huangj@brocade.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-12[SCSI] pmcraid: PMC-Sierra MaxRAID driver to support 6Gb/s SAS RAID controllerAnil Ravindranath
Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-09[SCSI] bnx2i: Add bnx2i iSCSI driver.Michael Chan
New iSCSI driver for Broadcom BNX2 devices. The driver interfaces with the CNIC driver to access the hardware. Signed-off-by: Anil Veerabhadrappa <anilgv@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-20[SCSI] mvsas: move into new directory drivers/scsi/mvsas/Jeff Garzik
Zero functional changes, just file movement. This commit prepares for the upcoming integration of the Marvell-provided driver update that splits the driver into support for both 64xx and 94xx chip families. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-13[SCSI] fnic: Add new Cisco PCI-Express FCoE HBAAbhijeet Joglekar
fnic is a driver for the Cisco PCI-Express FCoE HBA Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com> Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe, libfc: add libfcoe moduleVasu Dev
Just sets up build environment for libfcoe module towards a libfcoe library for libfc LLDs using FCoE as libfc transport. Common library code to libfcoe is added in next patch. Also, updated MODULE_LICENSE from "GPL" string to "GPL v2" for libfc, libfcoe and fcoe modules to accurately match the licenses. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] mpt2sas v00.100.11.15Eric Moore
* This is new scsi lld device driver from LSI supporting the SAS 2.0 standard. I have split patchs by filename. * Here is list of new 6gb host controllers: LSI SAS2004 LSI SAS2008 LSI SAS2108 LSI SAS2116 * Here are the changes in the 4th posting of this patch set: (1) fix compile errors when SCSI_MPT2SAS_LOGGING is not enabled (2) add mpt2sas to the SCSI Mid Layer Makefile (3) append mpt2sas_ to the naming of all non-static functions (4) fix oops for SMP_PASSTHRU (5) doorbell algorithm imported changes from windows driver * Here are the changes in the 3rd posting of this patch set: (1) add readl following writel from the function that disables interrupts (2) replace 0xFFFFFFFFFFFFFFFFULL with ~0ULL (3) when calling pci_enable_msix, only pass one msix entry (instead of 15). (4) remove the "current HW implementation uses..... " comment in the sources (5) merged bug fix for SIGIO/POLLIN notifcation; reported by the storlib team. * Here are the changes in the 2nd posting of this patch set: (1) use little endian types in the mpi headers (2) merged in bug fix's from inhouse drivers. Signed-off-by: Eric Moore <eric.moore@lsi.com> Tested-by: peter Bogdanovic <pbog@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] scsi: Add osd library to build systemBoaz Harrosh
OSD in kernel source code is assumed to be at: drivers/scsi/osd/ with its own Makefile and Kconfig Add includes to them from drivers/scsi Makefile and Kconfig Add OSD to MAINTAINERS file Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02remove ide-scsiFUJITA Tomonori
As planed, this removes ide-scsi. The 2.6 kernel supports direct writing to ide CD drives, which eliminates the need for ide-scsi. ide-scsi has been unmaintained and marked as deprecated. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James.Bottomley@HansenPartnership.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-30[SCSI] cxgb3i: Add cxgb3i iSCSI driver.Karen Xie
This patch implements the cxgb3i iscsi connection acceleration for the open-iscsi initiator. The cxgb3i driver offers the iscsi PDU based offload: - digest insertion and verification - payload direct-placement into host memory buffer. Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] fcoe: Fibre Channel over EthernetRobert Love
Encapsulation protocol for running Fibre Channel over Ethernet interfaces. Creates virtual Fibre Channel host adapters using libfc. This layer is the LLD to the scsi-ml. It allocates the Scsi_Host, utilizes libfc for Fibre Channel protocol processing and interacts with netdev to send/receive Ethernet packets. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libfc: A modular Fibre Channel libraryRobert Love
libFC is composed of 4 blocks supported by an exchange manager and a framing library. The upper 4 layers are fc_lport, fc_disc, fc_rport and fc_fcp. A LLD that uses libfc could choose to either use libfc's block, or using the transport template defined in libfc.h, override one or more blocks with its own implementation. The EM (Exchange Manager) manages exhcanges/sequences for all commands- ELS, CT and FCP. The framing library frames ELS and CT commands. The fc_lport block manages the library's representation of the host's FC enabled ports. The fc_disc block manages discovery of targets as well as handling changes that occur in the FC fabric (via. RSCN events). The fc_rport block manages the library's representation of other entities in the FC fabric. Currently the library uses this block for targets, its peer when in point-to-point mode and the directory server, but can be extended for other entities if needed. The fc_fcp block interacts with the scsi-ml and handles all I/O. Signed-off-by: Robert Love <robert.w.love@intel.com> [jejb: added include of delay.h to fix ppc64 compile prob spotted by sfr] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: hook iscsi_tcp into new libiscsi_tcp moduleMike Christie
This hooks iscsi_tcp into the libiscsi_tcp module and removes code that is now in libiscsi_tcp. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26[SCSI] sd: Support for SCSI disk (SBC) Data Integrity FieldMartin K. Petersen
Support for controllers and disks that implement DIF protection information: - During command preparation the RDPROTECT/WRPROTECT must be set correctly if the target has DIF enabled. - READ(6) and WRITE(6) are not supported when DIF is on. - The controller must be told how to handle the I/O via the protection operation field in scsi_cmnd. - Refactor the I/O completion code that extracts failed LBA from the returned sense data and handle DIF failures correctly. - sd_dif.c implements the functions required to prepare and complete requests with protection information attached. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client DriverBrian King
This patch adds a new device driver to support the Virtual Fibre Channel interface on IBM Power based servers. The Virtual I/O Server on IBM Power servers utilizes N-Port ID Virtualization to export a Virtual Fibre Channel adapter to the client. This driver is the client device driver. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-05[SCSI] scsi_dh: add infrastructure for SCSI Device HandlersChandra Seetharaman
Some of the storage devices (that can be accessed through multiple paths), do need some special handling for 1. Activating the passive path of the storage access. 2. Decode and handle the special sense codes returned by the devices. 3. Handle the I/Os being sent to the passive path, especially during the device probe time. when accessed through multiple paths. As of today this special device handling is done at the dm-multipath layer using dm-handlers. That works well for (1); for (2) to be handled at dm layer, scsi sense information need to be exported from SCSI to dm-layer, which is not very attractive; (3) cannot be done at all at the dm layer. Device handler has been moved to SCSI mainly to handle (2) and (3) properly. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] m68k: new mac_esp scsi driverFinn Thain
Replace the mac_esp driver with a new one based on the esp_scsi core. For esp_scsi: add support for sync transfers for the PIO mode, add a new esp_driver_ops method to get the maximum dma transfer size (like the old NCR53C9x driver), and some cleanups. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-23[SCSI] mvsas: Add Marvell 6440 SAS/SATA driverJeff Garzik
2008-02-07[SCSI] ses: add new Enclosure ULDJames Bottomley
This adds support to SCSI for enclosure services devices. It also makes use of the enclosure services added in an earlier patch to display the enclosure topology in sysfs. At the moment, the enclosures are SAS specific, but if anyone actually has a non-SAS enclosure that follows the SES-2 standard, we can add that as well. On my Vitesse based system, the enclosures show up like this: sparkweed:~# ls -l /sys/class/enclosure/0\:0\:1\:0/ total 0 -r--r--r-- 1 root root 4096 2008-02-03 15:44 components lrwxrwxrwx 1 root root 0 2008-02-03 15:44 device -> ../../../devices/pci0000:01/0000:01:02.0/host0/port-0:0/expander-0:0/port-0:0:12/end_device-0:0:12/target0:0:1/0:0:1:0 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 000 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 001 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 002 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 003 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 004 drwxr-xr-x 2 root root 0 2008-02-03 15:44 SLOT 005 lrwxrwxrwx 1 root root 0 2008-02-03 15:44 subsystem -> ../../enclosure --w------- 1 root root 4096 2008-02-03 15:44 uevent And the individual occupied slots like this: sparkweed:~# ls -l /sys/class/enclosure/0\:0\:1\:0/SLOT\ 001/ total 0 -rw-r--r-- 1 root root 4096 2008-02-03 15:45 active lrwxrwxrwx 1 root root 0 2008-02-03 15:45 device -> ../../../../devices/pci0000:01/0000:01:02.0/host0/port-0:0/expander-0:0/port-0:0:11/end_device-0:0:11/target0:0:0/0:0:0:0 -rw-r--r-- 1 root root 4096 2008-02-03 15:45 fault -rw-r--r-- 1 root root 4096 2008-02-03 15:45 locate -rw-r--r-- 1 root root 4096 2008-02-03 15:45 status lrwxrwxrwx 1 root root 0 2008-02-03 15:45 subsystem -> ../../../enclosure_component -r--r--r-- 1 root root 4096 2008-02-03 15:45 type --w------- 1 root root 4096 2008-02-03 15:45 uevent You can flash the various blinky lights by echoing to the fault and locate files. >From the device's point of view, you can see it has an enclosure like this: sparkweed:~# ls /sys/class/scsi_disk/0\:0\:0\:0/device/ block:sda generic queue_depth state bsg:0:0:0:0 iocounterbits queue_type subsystem bus iodone_cnt rescan timeout delete ioerr_cnt rev type device_blocked iorequest_cnt scsi_device:0:0:0:0 uevent driver modalias scsi_disk:0:0:0:0 vendor enclosure_component:SLOT 001 model scsi_generic:sg0 evt_media_change power scsi_level Note the enclosure_component:SLOT 001 which shows where in the enclosure this device fits. The astute will notice that I'm using SCSI VPD Inquiries to identify the devices. This, unfortunately, won't work for SATA devices unless we do some really nasty hacking about on the SAT because the only think that knows the SAS addresses for SATA devices is libsas, not libata where the SAT resides. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] remove m68k NCR53C9x based driversJames Bottomley
These drivers depend on the deprecated NCR53C9X core and need to be converted to the esp_scsi core. Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Linux/m68k <linux-m68k@vger.kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] dec_esp: Remove driverJames Bottomley
This driver depends on the deprecated NCR53C9X core and needs to be converted to the esp_scsi core. Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] mca_53c9x: remove driverJames Bottomley
This driver depends on the deprecated NCR53C9X core and needs to be converted to the esp_scsi core. Acked-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] sun3x_esp: convert to esp_scsiThomas Bogendoerfer
Converted sun3x_esp driver to use esp_scsi.c Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] make pcmcia directory use obj-y|m instead of subdir-y|mTejun Heo
subdir-y|m isn't supposed to contain modules or built-in components. Change subdir-$(CONFIG_PCMCIA) to obj-$(CONFIG_PCMCIA). Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] seagate: Remove driverBoaz Harrosh
- Apparently no one wonts this driver, and no one is willing to fix it for future changes to SCSI. So remove it, and if someone wants it in the future He can revive it with the needed fixes. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] psi240i: remove driverBoaz Harrosh
The psi240i driver is still written for cmnd->request_buffer as a char pointer to actual data. There was never any attempt to use the scatterlist option. - remove all source files (3) from drivers/scsi - Remove from Makefile and Kconfig Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-17[SCSI] fc4: remove this and all associated driversMatthew Wilcox
This code has been slowly rotting for about eight years. It's currently impeding a few SCSI cleanups, and nobody seems to have hardware to test it any more. I talked to Dave Miller about it, and he agrees we can delete it. If anyone wants a software FC stack in future, they can retrieve this driver from git. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] add srp transport classFUJITA Tomonori
This adds srp transport class that works with ib_srp and ibmvscsi. It creates only /sys/class/{srp_host,srp_remote_ports} and srp_remote_ports has only "port_id" attribute. viola:/sys/class/srp_remote_ports/port-0:1# ls device port_id subsystem uevent viola:/sys/class/srp_remote_ports/port-0:1# cat port_id 4c:49:4e:55:58:20:56:49:4f:00:00:00:00:00:00:00 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-21ps3: BD/DVD/CD-ROM Storage DriverGeert Uytterhoeven
Add a BD/DVD/CD-ROM Storage Driver for the PS3: - Implemented as a SCSI device driver - Uses software scatter-gather with a 64 KiB bounce buffer as the hypervisor doesn't support scatter-gather Cc: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-14[SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMACornelia Huck
With dma-mapping-prevent-dma-dependent-code-from-linking-on.patch scsi fails to build on !HAS_DMA architectures: drivers/built-in.o(.text+0x20af6): In function `scsi_dma_map': : undefined reference to `dma_map_sg' drivers/built-in.o(.text+0x20b5c): In function `scsi_dma_unmap': : undefined reference to `dma_unmap_sg' I split those functions out into a new file. Builds on s390 and i386. Move scsi_dma_{map,unmap} into scsi_lib_dma.c which is only build if HAS_DMA is set. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-14[SCSI] CONFIG_SCSI_FD_8xx no longer existsGeert Uytterhoeven
CONFIG_SCSI_FD_8xx no longer exists. Apparently it was renamed to CONFIG_SCSI_SEAGATE, but the Makefile was not correctly updated. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: Amiga Zorro NCR53c710 SCSIKars de Jong
New driver for Amiga Zorro bus NCR53c710 SCSI controllers, using the 53c700 SCSI core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: Amiga 4000T NCR53c710 SCSIKars de Jong
New driver for the Amiga 4000T built-in NCR53c710 SCSI controller, using the 53c700 SCSI core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: m68k MVME16x NCR53C710 SCSIKars de Jong
New driver for the MVME16x NCR53C710 SCSI controller, using the 53c700 SCSI core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: m68k BVME6000 NCR53C710 SCSIKars de Jong
New driver for the BVME6000 NCR53C710 SCSI controller, using the 53c700 SCSI core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-30[SCSI] Merge up to linux-2.6 headJames Bottomley
Conflicts: drivers/scsi/jazz_esp.c Same changes made by both SCSI and SPARC trees: problem with UTF-8 conversion in the copyright. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
