path: root/drivers/scsi/a3000.c
2009-04-03[SCSI] a3000: make 2 functions staticAdrian Bunk
a3000_{detect,release}() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] WD33C93: let platform stub override no_sync/fast/dma_modeThomas Bogendoerfer
SGI machines with WD33C93 allow usage of burst mode DMA, which increases performance noticable. To make this selectable by the sgiwd93 stub, setting the values for no_sync, fast and dma_mode has been moved to the individual platform stubs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-06cleanup after APUS removalAdrian Bunk
After the APUS removal, some code can be removed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[SCSI] a3000: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-12[SCSI] wd33c93: Scsi_Cmnd convertionHenrik Kretzschmar
Changes obsolete typedef'd Scsi_Cmnd to struct scsi_cmnd. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
