path: root/drivers/scsi/aacraid/aacraid.h
2007-01-27[SCSI] aacraid: rework packet support codeMark Haverkamp
Received from Mark Salyzyn, Replace all if/else packet formations with platform function calls. This is in recognition of the proliferation of read and write packet types, and in the need to migrate to up-and-coming packets for new products. Signed-off-by Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] aacraid: Begin adding support for new adapter typeMark Haverkamp
Received from Mark Salyzyn, Add in the NEMER/ARK physical register mapping, represented in up and coming products currently under test at Adaptec. Signed-off-by Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-27[SCSI] aacraid: rework communication support codeMark Haverkamp
Received from Mark Salyzyn, Replace all if/else communication transports with a platform function call. This is in recognition of the need to migrate to up-and-coming transports. Currently the Linux driver does not support two available communication transports provided by our products, these will be added in future patches, and will expand the platform function set. Signed-off-by Mark Haverkamp <markh@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] aacraid: Driver version updateMark Haverkamp
Received from Mark Salyzyn: Version patch, update to reflect a rough estimate of the Adaptec build (2423) that coincides with the sources on kernel.org. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[SCSI] aacraid: merge rx and rkt codeMark Haverkamp
Received from Mark Salyzyn: The only real difference between the rkt and rx platform modules is the offset of the message registers. This patch recognizes this similarity and simplifies the driver to reduce it's code footprint and to improve maintainability by reducing the code duplication. Visibly, the 'rkt.c' portion of this patch looks more complicated than it really is. View it as retaining the rkt-only specifics of the interface. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[SCSI] aacraid: misc cleanupMark Haverkamp
Received from Mark Salyzyn: Basically cleanup, nothing here will have an affect. Adjusting some error codes, removing superfluous definitions and code fragments. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] aacraid: Reset adapter in recovery timeoutMark Haverkamp
Received from Mark Salyzyn If the adapter is in blinkled (Firmware Assert) when error recovery timeout actions have been triggered, perform an adapter warm reset and restart the initialization. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] aacraid: Restart adapter on firmware assert (Update 2)Mark Haverkamp
Received from Mark Salyzyn If the adapter should be in a blinkled (Firmware Assert) state when the driver loads, we will perform a warm restart of the Adapter Firmware to see if we can rescue the adapter. Possible causes of a blinkled can occur on some early release motherboard BIOSes, transitory PCI bus problems on embedded systems or non-x86 based architectures, transitory startup failures of early release drives or transitory hardware failures; some of which can bite the adapter later at runtime. Future enhancements will include recovery during runtime. Fixed extra whitespace space issue. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-19[SCSI] aacraid: small misc. cleanupsMark Haverkamp
Received from Mark Salyzyn Spelling correction, orphaned comment removal & update branch name. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-20[SCSI] aacraid: remove unneeded listMark Haverkamp
Received From Mark Salyzyn The queue tracking is just not being used, not even for debugging. Information about outstanding commands can be acquired from the scsi structures. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-20[SCSI] aacraid: adjustable timeoutsMark Haverkamp
Received From Mark Salyzyn Add the ability to adjust for unusual corner case failures. Both of these additional module parameters deal with embedded, non-intel or complicated system scenarios. Aif_timeout can be increased past the default 2 minute timeout to drop application registrations when a system has an unusually high event load resulting from continuing management requests, or simultaneous builds, or sluggish user space as a result of system load. Startup_timeout can be increased past the default 3 minute timeout to drop an adapter initialization for systems that have a very large number of targets, or slow to spin-up targets, or a complicated set of array configurations that extend the time for the firmware to declare that it is operational. This timeout would only have an affect on non-intel based systems, as the (more patient) BIOS would generally be where the startup delay would be dealt with. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] aacraid: Driver version updateMark Haverkamp
Received from Mark Salyzyn Fix module param Update driver version. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] aacraid: Add timeout for eventsMark Haverkamp
Received from Mark Salyzyn Plug and play actions resulting from event sequences shall time out if they take longer than 30 seconds to complete. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] aacraid: Track command ownership in driverMark Haverkamp
Received from Mark Salyzyn The loss of the ownership flags, despite their flaws, in the scsi command were sorely missed and are reinstated more accurately in the aacraid driver to track commands and permit us to properly handle error recovery actions. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] aacraid: Use scmd_ functionsMark Haverkamp
Received from Mark Salyzyn Clean up the remaining scsi id access methods, drop ID_LUN_TO_CONTAINER macro. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] aacraid: use kthread_ APIChristoph Hellwig
Use the kthread_ API instead of opencoding lots of hairy code for kernel thread creation and teardown. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Salyzyn, Mark <mark_salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] aacraid: Update global function namesMark Haverkamp
Received from Mark Salyzyn, Reduce the possibility of namespace collision. Prefix with aac_. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] aacraid: 17 element sg performance updateMark Haverkamp
Received From Mark Salyzyn. The Jaguar and Corsair class of adapters (2410, 2810, 2610, 21610, CERC) perform better (about 10% better read performance, write performance neutral) with current Firmware if the OS limits the number of scatter gather elements to 17 per request. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] aacraid: Newer adapter communication iterface supportMark Haverkamp
Received from Mark Salyzyn. This patch adds the 'new comm' interface, which modern AAC based adapters that are less than a year old support in the name of much improved performance. These modern adapters support both the legacy and the 'new comm' interfaces. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28Merge HEAD from ../scsi-misc-2.6-old James Bottomley
2005-10-28[SCSI] aacraid: fix struct element cpu orderMark Haverkamp
Received from Mark Salyzyn. The compat field needed to be in cpu order. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-16[SCSI] Fix aacraid regressionSalyzyn, Mark
Juan was kind enough to linger on site, and work on a production machine, to try the parameter to make the system stable. He discovered that reducing the maximum transfer size issued to the adapter to 128KB stabilized his system. This is related to an earlier change for the 2.6.13 tree resulting from Martin Drab's testing where the transfer size was reduced from 4G to 256KB; we needed to go still further in scaling back the request size. Here is the patch that tames this regression. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-26[SCSI] aacraid: remove aac_insert_entryMark Haverkamp
Received from Mark Salyzyn from Adaptec. High Priority Queues have *never* been used in the entire history of the aac based adapters. Associated with this, aac_insert_entry can be removed, SavedIrql can be removed & padding variable can be removed. With the movement of SavedIrql out & replaced with an automatic variable qflags, the locking can be refined somewhat. The sparse warnings did not catch the need for byte swapping in the 'dprintk' debugging print macros, so fixed this up when this code was moved outside of the now refined locking. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-26[SCSI] aacraid: handle AIF hotplug events (update)Mark Haverkamp
Received from Mark Salyzyn from Adaptec. Hotplug sniffs the AIFs (events) from the adapter and if a container change resulting in the device going offline (container zero), online (container zero completed) or changing capacity (morph) it will take actions by calling the appropriate API. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-26[SCSI] aacraid: Greater than 2TB capacity supportMark Haverkamp
Received from Mark Salyzyn from Adaptec. There are a few adapters that are capable of creating devices with this large of a capacity, but now that we have the large fib support in, the management applications will be capable of generating them. The problem is, once they are created, the driver will not be able to access the devices correctly without this patch. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-28Merge HEAD from ../scsi-misc-2.6-tmp James Bottomley
2005-08-05[SCSI] aacraid: sgraw command supportMark Haverkamp
Received from Mark Salyzyn from Adaptec: This patch adds support for the new raw io command. This new command offers much larger io commands, is more friendly to the internal firmware structure requiring less translation efforts by the firmware and offers support for targets greater than 2TB (patch to support >2TB will be sent in the future). Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-05[SCSI] aacraid: driver shutdown methodMark Haverkamp
Add in pci shutdown method so that the adapter shuts down correctly and flushes its cache. Shutdown should also disable the adapter's interrupt when shutdown (in particularly if the driver is rmmod'd) to prevent spurious hardware activities. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-05[SCSI] aacraid: driver version updateMark Haverkamp
Received from Mark Salyzyn from Adaptec. Fixes a bug in check_revision. It should return the driver version not the firmware version. Update driver version number. Update driver version string. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-01[PATCH] aacraid: Fix for controller load based timeoutsMark Haverkamp
Martin Drab found that he could get aacraid timeouts with high load on his controller / disk drive combinations. After some experimentation Mark Salyzyn has come up with a patch to reduce the default max_sectors to something that will keep the controller from being overloaded and will eliminate the timeout issues. Signed-off-by: Mark Haverkamp <markh@osdl.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26[SCSI] aacraid: New products patchMark Haverkamp
This patch add the following products to the driver: IBM ServeRAID 8i ICP 9014R0 ICP 9024R0 ICP 9047MA ICP 9087MA ICP 9085LI ICP 5085AU Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] 2.6 aacraid: Variable FIB size (updated patch)Mark Haverkamp
New code from the Adaptec driver. Performance enhancement for newer adapters. I hope that this isn't too big for a single patch. I believe that other than the few small cleanups mentioned, that the changes are all related. - Added Variable FIB size negotiation for new adapters. - Added support to maximize scatter gather tables and thus permit requests larger than 64KB/each. - Limit Scatter Gather to 34 elements for ROMB platforms. - aac_printf is only enabled with AAC_QUIRK_34SG - Large FIB ioctl support - some minor cleanup Passes sparse check. I have tested it on x86 and ppc64 machines. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] aacraid: remove sparse warningsMark Haverkamp
This patch addresses the sparse -Wbitwise warnings that Christoph wanted me to eliminate. This mostly consisted of making data structure elements of hardware associated structures the __le* equivalent. Although there were a couple places where there was mixing of cpu and le variable math. These changes have been tested on both an x86 and ppc machine running bonnie++. The usage of the LE32_ALL_ONES macro has been eliminated. Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] drivers/scsi/aacraid/: make some functions staticAdrian Bunk
This patch makes some needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
