path: root/drivers/scsi/advansys.c
2010-05-01[SCSI] advansys: fix narrow board error pathHerton Ronaldo Krzesinski
Error handling on advansys_board_found is fixed, because it's buggy in the case we have an ASC_NARROW_BOARD set and failure happens on AscInitAsc1000Driver step: it was freeing items of wrong struct in the dvc_var union of struct asc_board, which could lead to an oops in the case we set some of the fields in struct of narrow board as code was choosing to always freeing wide board fields, and not everything was being freed/released properly. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-27[SCSI] advansys: fix regression with request_firmware changeHerton Ronaldo Krzesinski
On newer kernels users of advansys module are reporting system hang when trying to load it without firmware files present. After looking closely at description on https://qa.mandriva.com/show_bug.cgi?id=53220, I think this is related to commit "[SCSI] advansys: use request_firmware". The problem is that after switch to request_firmware, asc_dvc->err_code isn't being set when firmware files aren't found or loading fails. err_code is used by the driver to judge if there was a fatal error or not, as can be seen for example on advansys_board_found, which will only return -ENODEV when err_code is set. Because err_code isn't being set when request_firmware fails, this is a change of behaviour of the code before request_firmware addition, making it continue to load and it fails later as the firmware wasn't really loaded. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04tree-wide: fix misspelling of "definition" in commentsAdam Buchbinder
"Definition" is misspelled "defintion" in several comments; this patch fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-03[SCSI] advansys: use request_firmwareJaswinder Singh Rajput
Firmware blob looks like this... __le32 checksum unsigned char data[] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] advansys, arcmsr, ipr, nsp32, qla1280, stex: use pci_ioremap_bar()Arjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/scsi. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: Brian King <brking@us.ibm.com> Cc: Ed Lin <ed.lin@promise.com> Cc: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-11-30advansys fix on ISA-less configsAl Viro
The code if (shost->dma_channel != NO_ISA_DMA) free_dma(shost->dma_channel); in there is triggerable only if we have CONFIG_ISA (we only set ->dma_channel to something other than NO_ISA_DMA under #ifdef CONFIG_ISA). OTOH, free_dma() is not guaranteed to be there in absense of CONFIG_ISA. IOW, driver runs into undefined symbols on PCI-but-not-ISA configs (e.g. on frv) and it's a false positive. Fix: put the entire if () under #ifdef CONFIG_ISA; behaviour doesn't change and dependency on free_dma() disappears for !CONFIG_ISA. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-07[SCSI] advansys: Fix bug in AdvLoadMicrocodeMatthew Wilcox
buf[i] can be up to 0xfd, so doubling it and assigning the result to an unsigned char truncates the value. Just use an unsigned int instead; it's only a temporary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] advansys: fix overrun_buf aligned bugFUJITA Tomonori
struct asc_dvc_var needs overrun buffer to be placed on an 8 byte boundary. advansys defines struct asc_dvc_var: struct asc_dvc_var { ... uchar overrun_buf[ASC_OVERRUN_BSIZE] __aligned(8); The problem is that struct asc_dvc_var is placed on shost->hostdata. So if the hostdata is not on an 8 byte boundary, the advansys crashes. The hostdata is placed on a sizeof(unsigned long) boundary so the 8 byte boundary is not garanteed with x86_32. With 2.6.23 and 2.6.24, the hostdata is on an 8 byte boundary by chance, but with the current git, it's not. This patch removes overrun_buf static array and use kzalloc. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] advansys: make 3 functions staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-14advansys: fix section mismatch warningRandy Dunlap
Fix section mismatch warning: WARNING: vmlinux.o(.exit.text+0x152a): Section mismatch: reference to .init.data:_asc_def_iop_base (between 'advansys_isa_remove' and 'advansys_exit') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[SCSI] advansys: Changes to work on pariscMatthew Wilcox
Change PortAddr to be an unsigned int instead of an unsigned short (IO Port address are 24 bit on parisc). Fix a couple of printk argument warnings. Remove the Kconfig marking as 'BROKEN'. I haven't removed the #warning yet because virt_to_bus/bus_to_virt are only eliminated for narrow boards. Wide boards need more work. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Use dma mapping for overrun bufferMatthew Wilcox
Convert the call to virt_to_bus() into a call to dma_map_single(). Some architectures may require different DMA addresses for different devices, so allocate one overrun buffer per host rather than one for all cards. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove a couple of uses of bus_to_virtMatthew Wilcox
Replace ASC_VADDR_TO_U32 and ASC_U32_TO_VADDR with an auto-expanding array that maps pointers to 32-bit IDs and back. One of the uses of ASC_VADDR_TO_U32 was in error; it should have been using ADV_VADDR_TO_U32. Also replace the use of virt_to_bus when setting the sense_address with a call to dma_map_single() followed by dma_cache_sync. This part cribbed from the 53c700 driver. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: convert to use the data buffer accessorsMatthew Wilcox
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> - convert the statistics to not distinguish between single and sg xfers - replace ASC_CEILING with DIV_ROUND_UP - remove an obsolete comment Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove DvcGetPhyAddrMatthew Wilcox
This rather complex function boiled down to calling virt_to_bus(). Also get rid of some obsolete defines and variables that could never vary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Move a couple of fields from struct board to struct adv_dvcMatthew Wilcox
board->carrp is a duplicate of asc_dvc->carrier_buf, so cut out the middle-man and assign directly to carrier_buf. Move orig_reqp to adv_dvc too, since it's wide-board specific. Also eliminate an unnecessary BUG_ON (we'll never get there with a NULL carrier_buf, and will crash if we do). The bulk of this patch is rearranging structures so everything's declared in the right order. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Make sdtr_period_tbl a pointerMatthew Wilcox
It's somewhat neater to make this a pointer to one of two tables than initialising an array in the driver. Also delete the unused AscSynIndexToPeriod and rename host_init_sdtr_index to min_sdtr_index Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Get rid of board index numberMatthew Wilcox
It's always a mistake to have your own index of boards; just use the scsi host number. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove private lockMatthew Wilcox
The board lock was essentially identical with the host lock. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Sort out debug macrosMatthew Wilcox
Replace ASC_DBG{,1,2,3,4,5} with a single variadic macro ASC_DBG. As suggested by Jeff Garzik, include DRV_NAME and __FUNCTION__ in the output. Change all callers to no longer include the function name in the string. Enabling ADVANSYS_DEBUG to test this feature shows a lot of other problems that need to be fixed: - Reorder asc_prt_* functions now that their prototypes have been removed. - There is no longer a struct device in ASC_DVC_CFG/ADV_DVC_CFG, and it wasn't necessarily a PCI device to begin with. Print the bus_id from asc_board->dev instead. - isr_callback no longer exists. - ASC_DBG_PRT_SCSI_CMND isn't being used, so delete asc_prt_scsi_cmnd too. - A missing semicolon Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove library version & serial numbersMatthew Wilcox
With the ASC and ADV libraries merged into the driver, there really is no point in reporting their version numbers, or even trying to maintain them. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove asc_board_t typedef and ASC_BOARDP macroMatthew Wilcox
asc_board_t was simply a typedef for struct asc_board. ASC_BOARDP() can be replaced by shost_priv() except in the ASC_STATS* macros which rely on the cast; add an explicit cast there. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Merge ASC_IERR definitionsMatthew Wilcox
There were two blocks of ASC_IERR definitions; one for narrow and one for wide boards. Some of the same names were used (with the same values), and some of the same values were used with different names. This could only lead to confusion, so I unified them in one block of definitions with no overlapping values. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Sort out irq number messMatthew Wilcox
The interrupt number was being stored in 4-5 different places, each with its own type, rules and usage. Fix this by keeping an unsigned int in the struct asc_board, and filling it in from the bus probe functions (since it's different for each of the four bus types). In order to do this, we have to allocate the Scsi_Host in the bus probe functions too. Then we can return an error from advansys_board_found, which requires a little rearranging of code (and removing of the err_code variable). Move the Wide Board flag setting into the PCI bus probe function. Split the AscGetChipIRQ function into three functions (one for each bus type that needs it) and add some commentary to explain what's going on. Also get rid of the AscSetChipIRQ function as we only ever set the interrupt number to the same value it already had. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove ASC_WIDE_BOARD predicateMatthew Wilcox
Replace it with !ASC_NARROW_BOARD Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove ASC_SELECT_QUEUE_DEPTHSMatthew Wilcox
It was only ever set; never tested, nor cleared. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Improve reset handlerMatthew Wilcox
- Don't need to set ASC_HOST_IN_RESET any more - Don't need to test scp->device->host for NULL -- if it's NULL, we couldn't've been called. - Use scmd_printk instead of ASC_PRINT Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Fix simultaneous calls to ->queuecommandMatthew Wilcox
The narrow board used two global structures to set up a command; unfortunately they weren't locked, so with two boards in the machine, one call to queuecommand could corrupt the data being used by the other call to queuecommand. Fix this by allocating asc_scsi_q on the stack (64 bytes) and using kmalloc for the asc_sg_head (2k) Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Restructure asc_execute_scsi_cmnd()Matthew Wilcox
The wide and narrow boards share identical handling of the return value, except for some trivial error messages. Move the handling to the common end of the function. Also move variable declarations to the arms of the `if' that they're used in and delete some pointless comments. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove array of scsi targetsMatthew Wilcox
The driver was saving a scsi_device for each target, but wasn't doing anything useful with them. Just delete the array. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Eliminate prototypesMatthew Wilcox
Rearrange a lot of the functions in the file to get rid of all the forward declarations. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Use DRV_NAMEMatthew Wilcox
Follow the example of some other drivers by defining DRV_NAME to be "advansys". Prevents spelling mistakes. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Comment/indentation/macro cleanupMatthew Wilcox
- Delete comments relating to the previous structure of the driver. I have no intention of honouring them ;-) - Reformat comments > 80 columns - Remove now-obsolete comments from advansys_interrupt - Change adv_get_sglist() from do {} while (1) to for (;;) - Return void from AscInitQLinkVar() - Take out a level of indentation in adv_get_sglist() - Reduce indentation level of AscAsyncFix() - Remove unused macros - Refactor AscSendScsiQueue slightly Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove some custom wrappersMatthew Wilcox
- Replace ASC_ASSERT() with BUG_ON(). In a few places, get rid of the assertion altogether -- the ensuing crash will tell us all we need to know. Use BUG() where it fits better than BUG_ON(). Also fix a fencepost error in advansys_proc_info(). - Replace DvcSleepMilliSecond with mdelay. Despite its name using 'sleep', the implementation was a delay. I've marked some places with XXX where we should probably be using msleep instead. They need to be audited to be sure we can sleep in that context. - Replace DvcDelayMicroSecond with udelay. - Replace DvcDelayNanoSecond with udelay too. All callers were multiples of 1000. - Remove DvcEnterCritical and DvcLeaveCritical. These functions are no-ops, and as the comments said, the spinlock protects the critical sections. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove a check for an impossible conditionMatthew Wilcox
AscExeScsiQueue() has one caller, and it passes the address of a variable; this cannot ever be NULL. This is the only place that ever sets ASCQ_ERR_SCSIQ_NULL_PTR, so delete that error code too, as well as several other unused ASCQ_ERR codes. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Support 16-byte commands properlyMatthew Wilcox
The SCSI midlayer won't send commands greater than ->max_cmd_len. So the checks on length in asc_build_req and adv_build_req are obsolete and can be deleted, but also we have to set the max_cmd_len in advansys_board_found(). Also move the length definitions together, and write a helpful comment. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Enable interrupts earlier in queuecommandMatthew Wilcox
Move as much as possible outside the critical section in queuecommand, eg: - Set the scsi_done field before acquiring the lock - Call asc_scsi_done after dropping the lock Also remove a comment suggesting we should enable interrupts (now we do) and do some minor reformatting for readability. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove `active' queue and all remaining internal queueing codeMatthew Wilcox
The `active' list was used in the reset handler -- but the midlayer guarantees that list is empty by the time the reset handler is invoked. It was also checked in the interrupt routines to be sure that this command belonged to this board, but we don't need to check that either. We can then delete the asc_prt_target_stats() function as it will never print anything, along with asc_enqueue(), asc_dequeue_list(), asc_rmqueue(), asc_scsi_done_list(), struct asc_queue, ASC_QUEUE_EMPTY, ASC_TID_ALL, ASC_FRONT, ASC_BACK, and all the REQ* macros. Also remove this item from the todo list. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove `done' queueMatthew Wilcox
- Move the guts of asc_scsi_done_list() into a new function, asc_scsi_done. - Call asc_scsi_done() in asc_isr_callback() and adv_isr_callback(). The comment was wrong; scsi_done cannot enable interrupts. - All other places which queued an scp on the done list are error paths for queuecommand, and so we can just call asc_scsi_done() in queuecommand if we receive an error. - We no longer need to keep a list of done requests in advansys_interrupt Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
The midlayer guarantees it won't call ->queuecommand for a host which is handling a reset condition. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove `waiting' queueMatthew Wilcox
If the adapter is busy, return the request to the midlayer rather than queueing it in the driver. asc_execute_queue() and asc_dequeue() become unused, and we don't need to print out stats on the waiting queue any more. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Shrink advansys_board_found a little moreMatthew Wilcox
Move the error reporting into AscInitGetConfig, AdvInitGetConfig and AscInitSetConfig. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Reformat microcodeMatthew Wilcox
It's just data, so format it to something that looks more visually appealing (and saves some lines) Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Create AdvLoadMicrocodeMatthew Wilcox
Split AdvLoadMicrocode out of AdvInitAsc3550Driver, AdvInitAsc38C0800Driver and AdvInitAsc38C1600Driver. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Create AdvBuildCarrierFreelistMatthew Wilcox
Split AdvBuildCarrierFreelist out of AdvInitAsc3550Driver, AdvInitAsc38C0800Driver and AdvInitAsc38C1600Driver. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Fix VLB driver nameMatthew Wilcox
You can't have two drivers for the same bus type with the same name. Since ISA and VLB are both isa_drivers, rename the VLB one to advansys_vlb. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
