path: root/drivers/scsi/aic94xx/aic94xx.h
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] aic94xx: Use sas_request_addr() to provide SAS WWN if the adapter ↵Darrick J. Wong
lacks one If the aic94xx chip doesn't have a SAS address in the chip's flash memory, make libsas get one for us. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-23[SCSI] aic94xx: plumb in I_T_nexus_reset task management functionJames Bottomley
Currently aic94xx has no exported I_T_nexus_reset function. This is a bit of a huge problem, since sas_ata relies on this function to perform an ATA phy reset and also it means that if abort fails, we really have no bigger hammer to hit everything with. Plumb in the I_T_nexus_reset by quiescing the sequencer, sending the correct phy reset (link for ATA and hard for SAS) and then carefully resuming the sequencer again. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2006-09-24[PATCH] SCSI gfp_t annotationsAl Viro
2006-09-07[SCSI] aci94xx: implement link rate settingJames Bottomley
This patch implements the ability to set the minimum and maximum linkrates for both libsas (for expanders) and aic94xx (for the host phys). It also tidies up the setting of the hardware min and max to make sure they're updated when the expander emits a change broadcast. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-29[SCSI] aic94xx: new driverJames Bottomley
This is the end point of the separate aic94xx driver based on the original driver and transport class from Luben Tuikov <ltuikov@yahoo.com> The log of the separate development is: Alexis Bruemmer: o aic94xx: fix hotplug/unplug for expanderless systems o aic94xx: disable split completion timer/setting by default o aic94xx: wide port off expander support o aic94xx: remove various inline functions o aic94xx: use bitops o aic94xx: remove queue comment o aic94xx: remove sas_common.c o aic94xx: sas remove depot's o aic94xx: use available list_for_each_entry_safe_reverse() o aic94xx: sas header file merge James Bottomley: o aic94xx: fix TF_TMF_NO_CTX processing o aic94xx: convert to request_firmware interface o aic94xx: fix hotplug/unplug o aic94xx: add link error counts to the expander phys o aic94xx: add transport class phy reset capability o aic94xx: remove local_attached flag o Remove README o Fixup Makefile variable for libsas rename o Rename sas->libsas o aic94xx: correct return code for sas_discover_event o aic94xx: use parent backlink port o aic94xx: remove channel abstraction o aic94xx: fix routing algorithms o aic94xx: add backlink port o aic94xx: fix cascaded expander properties o aic94xx: fix sleep under lock o aic94xx: fix panic on module removal in complex topology o aic94xx: make use of the new sas_port o rename sas_port to asd_sas_port o Fix for eh_strategy_handler move o aic94xx: move entirely over to correct transport class formulation o remove last vestages of sas_rphy_alloc() o update for eh_timed_out move o Preliminary expander support for aic94xx o sas: remove event thread o minor warning cleanups o remove last vestiges of id mapping arrays o Further updates o Convert aic94xx over entirely to the transport class end device and o update aic94xx/sas to use the new sas transport class end device o [PATCH] aic94xx: attaching to the sas transport class o Add missing completion removal from prior patch o [PATCH] aic94xx: attaching to the sas transport class o Build fixes from akpm Jeff Garzik: o [scsi aic94xx] Remove ->owner from PCI info table Luben Tuikov: o initial aic94xx driver Mike Anderson: o aic94xx: fix panic on module insertion o aic94xx: stub out SATA_DEV case o aic94xx: compile warning cleanups o aic94xx: sas_alloc_task o aic94xx: ref count update o aic94xx nexus loss time value o [PATCH] aic94xx: driver assertion in non-x86 BIOS env Randy Dunlap: o libsas: externs not needed Robert Tarte: o aic94xx: sequence patch - fixes SATA support Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
