path: root/drivers/scsi/atp870u.c
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29[SCSI] Clean up my email address and use a single standard address for ↵Alan Cox
everything Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-23scsi: fix integer as NULL pointer warningHarvey Harrison
drivers/scsi/aha152x.c:3585:60: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:3845:56: warning: Using plain integer as NULL pointer drivers/scsi/qla1280.c:2814:37: warning: Using plain integer as NULL pointer drivers/scsi/atp870u.c:750:47: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1281:36: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1293:36: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1301:35: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:447:10: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:457:10: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:479:24: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:483:22: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:1213:23: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:1214:23: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[SCSI] atp870u: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup - Probably not ready for sg-chaining Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: jameshsu <jameshsu@acard.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[SCSI] atp870u: reduce huge stack usageRandy Dunlap
The atp870u driver is the largest stack eater reported by checkstack (on x86_864, allmodconfig). This converts the offending function to kmalloc+kfree struct atp_unit instead of allocating it on the stack. Was: 0x0000164c atp870u_probe [atp870u]: 3176 Now: 0x0000164c atp870u_probe [atp870u]: 408 Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-28[SCSI] audit drivers for incorrect max_id useHannes Reinecke
max_id now means the maximum number of ids on the bus, which means it is one greater than the largest possible id number. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[SCSI] use scmd_id(), scmd_channel() throughout codeJeff Garzik
Wrap a highly common idiom. Makes the code easier to read, helps pave the way for sdev->{id,channel} removal, and adds a token that can easily by grepped-for in the future. There are a couple sdev_id() and scmd_printk() updates thrown in as well. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use sfoo_printk() in driversJeff Garzik
2005-09-15[SCSI] atp870u: fix memory addressing bugJames Bottomley
From: Alan Cox <alan@redhat.com> The virt_to_bus() wasn't correctly taken out of this driver. It needs to be able to track both physical and virtual addresses for its prd table. Update the driver to do this with separate tracking entries. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] drivers/scsi/atp870u.c: make a function staticAdrian Bunk
This patch makes a needlessly global function static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
