This patch allows iscsiadm to set/ delete static IP and enable /disable
DHCP.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@emulex.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
The async handle corresponding to unknown Opcode was not freed
earlier. This code does the fix for that.
Signed-off-by: John Soni Jose <sony.john-n@emulex.com>
For each ASYNC PDU received there is an HDR and DATA handle for it.
There will be only 1 HDR ASYNC Handle, but DATA Handle can be more
than 1 for each ASYNC PDU received. Checking if the ASYNC Handle
correspongs to HDR or DATA while returning the Handle to the free list.
hwi_free_async_msg just return the handles to the free list. No return
values are needed so changing the return type to void.
Signed-off-by: Minh Tran <MinhDuc.Tran@Emulex.Com>
Change MODULE_AUTHOR, driver name and other external print strings from
Serverengines to Emulex.
In case of MCC_Q creation failed, the MCCQ info memory is freed
from be_mcc_queues_destroy and be_mcc_queues_create. This caused
kernel to panic because of double free.
The WRB and SGL Handle allocated for Login task were not freed
back to the pool after the login process was done. This code
releases the WRB and SGL Handle after the login process.
v2:
- Fix up locking so bh calls are not done when not needed.
- Make beiscsi_cleanup_task static.
[various fixes]
Removing code duplication during the WRB_Handle and WRB
initialization.
Added memory allocation failure handling code during WRB
initialization.
The buffer length passed for processing the ASYNC PDU
was not proper.
Set the ASYNC PDU Handle pBuffer for Data ring with the VA/PA
of the allocated memory for it.
To get the correct ASYNC PDY Handle iterate the list and compare
the PA set during initialization with the passed PHY Address.
The buffer_size and num_enteries are common for HDR and Data ring
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6
SCSI updates for post 3.2 merge window
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (67 commits)
[SCSI] lpfc 8.3.28: Update driver version to 8.3.28
[SCSI] lpfc 8.3.28: Add Loopback support for SLI4 adapters
[SCSI] lpfc 8.3.28: Critical Miscellaneous fixes
[SCSI] Lpfc 8.3.28: FC and SCSI Discovery Fixes
[SCSI] lpfc 8.3.28: Add support for ABTS failure handling
[SCSI] lpfc 8.3.28: SLI fixes and added SLI4 support
[SCSI] lpfc 8.3.28: Miscellaneous fixes in sysfs and mgmt interfaces
[SCSI] mpt2sas: Removed redundant calling of _scsih_probe_devices() from _scsih_probe
[SCSI] mac_scsi: Remove obsolete IRQ_FLG_* users
[SCSI] qla4xxx: Update driver version to 5.02.00-k10
[SCSI] qla4xxx: check for FW alive before calling chip_reset
[SCSI] qla4xxx: Fix qla4xxx_dump_buffer to dump buffer correctly
[SCSI] qla4xxx: Fix the IDC locking mechanism
[SCSI] qla4xxx: Wait for disable_acb before doing set_acb
[SCSI] qla4xxx: Don't recover adapter if device state is FAILED
[SCSI] qla4xxx: fix call trace on rmmod with ql4xdontresethba=1
[SCSI] qla4xxx: Fix CPU lockups when ql4xdontresethba set
[SCSI] qla4xxx: Perform context resets in case of context failures.
[SCSI] iscsi class: export pid of process that created
[SCSI] mpt2sas: Remove unused duplicate diag_buffer_enable param
"sense_len" was declared as int type but actually it only stores a
u16 value that comes from hardware. The cast to u16 in min_t()
confuses static analysis because it truncates the int to u16 so I've
fixed the declaration to reflect that "sense_len" is just a u16.
Also there was a call to cpu_to_be16() which I've changed to
be16_to_cpu(). The functions are equivalent, but obviously the
hardware is big endian and we're doing the min_t() comparison on CPU
endian values.
This whole patch is just a cleanup and doesn't affect how the code
works.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Acked-by: Jayamohan Kallickal <Jayamohan.kallickal@emulex.com>
The module.h header was implicitly present everywhere, so files
with no explicit include of the module infrastructure would build
anyway. We are now removing the implicit include, and so we need
to call out the module.h file that we need explicitly.
This patch fixes a bug where the task->sc was cleaned up earlier on a
different thread, possibly abort, and the completion comes later.
This was causing a crash which has been reported in multiple places
This patch fixes wrong dmsg setting when we send out wrb.
If the ttt is not ISCSI_RESERVED_TAG then we should be setting
dmsg=1 so that the completion is done without waiting for a
iscsi level response from the target
This patch fixes the Kdump failure reported by Redhat wich was caused by
be2iscsi resetting the Chip when be2iscsi detects it is in crashdump mode. If
be2net was loaded before be2iscsi then this leaves be2net driver hanging on to
resources that the chip stopped recognising after the reset.
This patch replaces chip reset with Function reset so that only the
particular function and not the whole chip is affected
This patch adds call to pci_disable_device during
rmmod and shutdown. The lack of this call was causing hang in
insmod - rmmod loop test
This patch adds a shutdown routine. It fixes a bug where when be2net
and be2iscsi are both used be2iscsi was not cleaning up its resources
properly causing be2net to fail to get loaded when the system is
rebooted.
Fix be2iscsi driver to use a separate pointer for each irq action->name
field and avoid display corruption in /proc/interrupts. The be2iscsi driver
was using a single static array in a function for the irq action->name field.
This results in garbage output from /proc/interrupts
The pointer for action->name is garbage and scribbles the output on the screen.
This patch fixes the problem:
156: 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 0 0 PCI-MSI-X beiscsi_msix_0017
This patch is based on Prarit's patch here:
http://www.spinics.net/lists/linux-scsi/msg52325.html
but I have fixed up the failure paths and removed
redundant check for !i suggested by Eike.
The iscsi class currently does not support writable sysfs
attrs for LLD sysfs settings. This patch converts the
iscsi class and driver's host attrs to use the attribute
container sysfs group and the sysfs group's is_visible callout
to be able to support readable or writable sysfs attrs.
iscsi class and driver's session attrs to use the attribute
iscsi class and drivers to use the attribute container
be2iscsi passes the boot functions its phba object which is
allocated in the shost, but iscsi_ibft passes in a object
allocated for each item to display. The problem is that
iscsi_boot_sysfs was managing the lifetime of the object
passed in and doing a kfree on release. This causes a double
free for be2iscsi which frees the shost in its pci_remove.
This patch fixes the problem by adding a release callback
which the drivers can call kfree or a put() type of function
(needed for be2iscsi which will do a get/put on the shost).
This moves the check for NULL boot_sets to the iscsi_boot_sysfs
module instead of having the drivers do it.
struct scsi_lun is also just a struct with an array of 8 octets (64 bits)
but using it instead in iscsi structs lets us call scsilun_to_int
without a cast, and also lets us copy it using assignment, instead of
memcpy().
Signed-off-by: Andy Grover <agrover@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
This patch fixes a bug where the interrupts were not rearmed if
the Interrupt Mask was enabled. This patch checks for Interrupt mask
enabled and still rearms interrupt generation even if the Interrupt
mask was enabled
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
There was a bug in setting up type and dmsg for FW
- Modifying copyright year to 2011
- Replacing Serverengines with Emulex as Serverengines Corp
has been acquired by Emulex Corp
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
The ep_disconnect function could be freeing the ep
while beiscsi_conn_get_param is running. This has
the driver use the get ep param callback instead
of the get conn param to fix this.
Switch to new workqueue interface alloc_workqueue(). These are
identity conversions.
Acked-by: Madhuranath Iyengar <Madhu.Iyengar@qlogic.com>
Cc: Jayamohan Kallickal <jayamohank@serverengines.com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: linux-scsi@vger.kernel.org
If alloc_pdu fails then the task->hdr pointer may not be
set. This adds a check for this case in the cleanup callback.
The pdu allication callout is called from a spin lock
and in the IO path so we cannot use GFP_KERNEL. This
has the driver use GFP_ATOMIC.
This patch contains changes for adding support for iscsi_boot.
Have modified to make read of mac address from chip as a function.
The mac_address is being cached after teh first call as it is
not expected to change
Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com>
This patch fixes a bug where the buffer was being freed as soon as
submission to HW is done.
This patch removes a Debug Print in the IO path
This patch ensures that the same ITT is maintained across
all login pdu's
These changes allow the driver to support crashdump. We need to reset the
chip incase of a crashdump
This patch handles request_irq failures by properly cleaning up
hwi_enable_intr need not return any value. This patch fixes the
that and removes code designed to handle a failure return value
Fixing some functions return values that did not match with
the possible return values
