commit a87eeb900dbb9f8202f96604d56e47e67c936b9d upstream.
Commit 655ee63cf371 ("scsi constants: command, sense key + additional
sense string") added a "Completed" sense string with key 0xF to
snstext[], but failed to updated the upper bounds check of the sense key
in scsi_sense_key_string().
Fixes: 655ee63cf371 ("[SCSI] scsi constants: command, sense key + additional sense strings")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Instead of having constants.c littered with ifdef statements we should
be moving dummy functions into the header and condintionally compile in
constants.c if selected. And update the Kconfig description to reflect
the actual size difference.
Suggested-by: Christoph Hellwig <hch@infradead.org>
Tested-by: Robert Elliott <elliott@hp.com>
Reviewed-by: Robert Elliott <elliott@hp.com>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Convert scsi_print_result() to use the per-cpu buffer for decoding the
command result and disposition.
Convert sense buffer logging to use the per-cpu buffer to avoid line
breakup.
Use an external buffer for __scsi_print_command() and move command
logging over to use the per-cpu logging buffer. With that we can
guarantee the command always will always be formatted in one line.
So we can even print out a variable length command correctly across
several lines. Finally rename __scsi_print_command() to
__scsi_format_comment() to better reflect the functionality.
The last time these SCSI asc/ascq codes were synced with T10 was
2013/06/05. Sync the SCSI ASC/ASCQ number to string tables with those
found at http://www.t10.org/lists/asc-num.txt dated 2014/12/21.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
One of the two callers passes an unintialized pointer as "fmt" and
expects it to be set to NULL if there is no format string. Let's make
this function work as expected.
Fixes: d811b848ebb7 ('scsi: use sdev as argument for sense code printing')
Reviewed-by: James Bottomley <JBottomley@Parallels.com>
SPC-3 defines SERVICE ACTION IN(12), SERVICE_ACTION OUT(12),
SERVICE ACTION OUT(16), and SERVICE ACTION BIDIRECTIONAL.
And READ MEDIA SERIAL NUMBER has long since been deprecated.
So update callers to refer to the new cdb name.
SPC-3 defines SERVICE ACTION IN(12) and SERVICE ACTION IN(16).
So rename SERVICE_ACTION_IN to SERVICE_ACTION_IN_16 to be
consistent with SPC and to allow for better distinction.
Simplify scsi_log_(send|completion) by externalizing
scsi_mlreturn_string() and always print the command address.
Open-code scsi_print_result in sd.c, and cleanup logging to
not print duplicate informations.
Also remove the call to scsi_show_result() in ufshcd.c
to be consistent with other callers of scsi_execute().
With that we can remove scsi_show_result in constants.c
Export functions for later use.
print_opcode_name() was only ever called with a '0' argument
from LLDDs and ULDs which were _not_ supporting variable length
CDBs, so the 'if' clause was never triggered.
Instead we should be using the last argument to specify
the cdb length to avoid accidental overflow when reading
the cdb buffer.
Consolidate the CDB opcode lookup in scsi_opcode_sa_name(),
so that we don't have to call several functions to figure
out the CDB opcode string.
Instead of having two versions of print_opcode_name() we
should be consolidating them into one version.
Implement a lookup array for SERVICE ACTION commands instead
of hardcoding it in a large switch statement.
Last caller is gone, so we can remove it.
Currently we're only decoding sense extras for tape devices.
And even there only for fixed format sense formats.
As this is of rather limited use in the general case we should
be stop trying to decode sense extras; the tape driver does
its own decoding anyway.
If scsi_normalize_sense() fails we couldn't decode the sense
buffer, and the scsi_sense_hdr fields are invalid.
For those cases we should rather dump the sense buffer
and not try to decode invalid fields.
We should be using the standard dev_printk() variants for
sense code printing.
[hch: remove __scsi_print_sense call in xen-scsiback, Acked by Juergen]
[hch: folded bracing fix from Dan Carpenter]
Unused.
It has been several years since the SCSI constants.c
file has been updated. The attached is against lk 3.10
and brings the command strings, sense keys and additional
sense code strings into sync with spc4r36g.pdf.
Certain SCSI command names that previously only took the
opcode (i.e. byte 0 of the cdb) into account, have been
split into several command names using the associated
service action field to differentiate. For example,
persistent reservations that previously had 2 commands
(i.e. "in" and "out") have been expanded to 12 commands
(e.g. "Persistent reserve in, read reservation").
Sync SCSI command names, sense key strings and additional
sense code strings with SPC-4 draft revision 36g
[jejb: whitespace fix]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
constants.c
Without this patch, scsi_show_result prints hostbyte as invalid for statuses
that are not defined in hostbyte_table (when scsi logging is enabled).
Signed-off-by: Babu Moger <babu.moger@netapp.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
At least log the message that we received a THIN PROVISIONING SOFT
THRESHOLD REACHED Unit Attention. Also added it to unit attention
decodes.
Signed-off-by: Shyam Iyer <shyam_iyer@dell.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
warning: zero-length gnu_printf format string
Fix the above warning by inserting a space into the literal string.
Signed-off-by: Jean Sacren <sakiwit@gmail.com>
Having the large CDB allocation logic in sd.c means that
scsi_io_completion does not have access to the command buffer. That in
turn causes garbage to be printed when a 32-byte command fails. Move the
command printing to sd_done where the command buffer is intact. Clear
the command buffer pointer after the extended CDB has been freed.
Make scsi_print_command ignore commands with NULL CDB pointers to
inhibit printing of garbled command strings.
Reviewed-by: Boaz Harrosh <bharrosh@panasas.com>
We dereferenced the MAINTENANCE IN array when decoding variable length
commands. Use the right array. Also consolidate identical if
statements below.
Add definitions for UNMAP, WRITE SAME{16,32} and GET LBA STATUS
commands.
It has been 3 years since this file was sync-ed with
www.t10.org . Information taken from the last bunch
of drafts released in May 2009. More asc/ascq codes
are coming for thin provisioning; when approved and
allocated another patch could add them prior to this
patch going live.
Changelog:
- add some new command names and rename two commands
- sync asc/ascq table with www.t10.org/lists/asc-num.txt
- correct bug in scsi_extd_sense_format() [second
for loop]
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
The SUGGEST_* flags in the SCSI command result have been out of fashion
for a while and we don't actually use them in the error handling.
Remove the remaining occurrences.
Currently, if there is a transport problem the iscsi drivers will return
outstanding commands (commands being exeucted by the driver/fw/hw) with
DID_BUS_BUSY and block the session so no new commands can be queued.
Commands that are caught between the failure handling and blocking are
failed with DID_IMM_RETRY or one of the scsi ml queuecommand return values.
When the recovery_timeout fires, the iscsi drivers then fail IO with
DID_NO_CONNECT.
For fcp, some drivers will fail some outstanding IO (disk but possibly not
tape) with DID_BUS_BUSY or DID_ERROR or some other value that causes a retry
and hits the scsi_error.c failfast check, block the rport, and commands
caught in the race are failed with DID_IMM_RETRY. Other drivers, may
hold onto all IO and wait for the terminate_rport_io or dev_loss_tmo_callbk
to be called.
The following patches attempt to unify what upper layers will see drivers
like multipath can make a good guess. This relies on drivers being
hooked into their transport class.
This first patch just defines two new host byte errors so drivers can
return the same value for when a rport/session is blocked and for
when the fast_io_fail_tmo fires.
The idea is that if the LLD/class detects a problem and is going to block
a rport/session, then if the LLD wants or must return the command to scsi-ml,
then it can return it with DID_TRANSPORT_DISRUPTED. This will requeue
the IO into the same scsi queue it came from, until the fast io fail timer
fires and the class decides what to do.
When using multipath and the fast_io_fail_tmo fires then the class
can fail commands with DID_TRANSPORT_FAILFAST or drivers can use
DID_TRANSPORT_FAILFAST in their terminate_rport_io callbacks or
the equivlent in iscsi if we ever implement more advanced recovery methods.
A LLD, like lpfc, could continue to return DID_ERROR and then it will hit
the normal failfast path, so drivers do not have fully be ported to
work better. The point of the patches is that upper layers will
not see a failure that could be recovered from while the rport/session is
blocked until fast_io_fail_tmo/recovery_timeout fires.
V3
Remove some comments.
V2
Fixed patch/diff errors and renamed DID_TRANSPORT_BLOCKED to
V1
initial patch.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Add support for variable-length, extended, and vendor specific
CDBs to scsi-ml. It is now possible for initiators and ULD's
to issue these types of commands. LLDs need not change much.
All they need is to raise the .max_cmd_len to the longest command
they support (see iscsi patch).
- clean-up some code paths that did not expect commands to be
larger than 16, and change cmd_len members' type to short as
char is not enough.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Add Documentation/DocBook/scsi_midlayer.tmpl, add to Makefile, and update
lots of kerneldoc comments in drivers/scsi/*.
Updated with comments from Stefan Richter, Stephen M. Cameron,
James Bottomley and Randy Dunlap.
Signed-off-by: Rob Landley <rob@landley.net>
I was working on patches which add new transport error values, when I
noticed that DID_REQUEUE was not in the hostbyte_table. I do not think
there is any way to hit the code path where scsi_show_result is called
and where you return DID_REQUEUE, because DID_REQUEUE causes scsi-ml to
always requeue the command. However, for completeness and because I want
to one day send a patch that tries to add new host bytes values, I am
sending this patch.
Because scsi_print_sense_hdr prefixes with KERN_INFO, the output from
scsi_io_completion looks like:
sd 0:0:0:0: [sdb] Device not ready: <6>: Sense Key : 0x2 [current]
: ASC=0x4 ASCQ=0x3
By using scsi_show_sense_hdr, we can get the much more appealing output:
sd 0:0:0:0: [sdb] Device not ready: Sense Key : 0x2 [current]
sd 0:0:0:0: [sdb] Device not ready: ASC=0x4 ASCQ=0x3
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Add missing additional sense code and provide pointer to upstream
reference (from Doug Gilbert).
Add missing const (from Michael Tokarev).
Clean up constants.c and make result printing more user friendly:
- Refactor the command and sense functions so that the actual
formatting can be called from the various helper functions with the
correct prefix.
- Replace scsi_print_hostbyte() and scsi_print_driverbyte() with
scsi_print_result() which is verbose when CONFIG_SCSI_CONSTANTS is
on.
Following on from my post titled: "additional sense codes
need update" see the attachment against lk 2.6.17 .
ChangeLog:
- update additional sense codes table to agree with
SPC-4 revision 5a (14 June 2006)
- adjust some of the opcode names
Signed-off-by: Douglas Gilbert <dougg@torque.net>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
With Achim patch the last user (gdth) is switched away from scsi_request
so we an kill it now. Also disables some code in i2o_scsi that was
broken since the sg driver stopped using scsi_requests.
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of the macro.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
scsi_print_msg() is an SPI-specific concept. This patch moves it from
constants.c to scsi_transport_spi.c and updates the Kconfig to link in
the SPI class for the drivers which use scsi_print_msg().
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
patch below marks a few scsi core datastructures as const, so that they end up
in the .rodata section and don't cacheline share with things that get dirtied
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This should eliminate (at least in the mid layer) to make numeric
assumptions about any of the enumeration variables. As a side effect,
it will also make all the messages consistent and line us up nicely for
the error logging strategy (if it ever shows itself again).
This one removes struct scsi_request entirely from sd. In the process,
I noticed we have no callers of scsi_wait_req who don't immediately
normalise the sense, so I updated the API to make it take a struct
scsi_sense_hdr instead of simply a big sense buffer.
C files should include the files with the prototypes for their global
functions.
We have the scsi_print_* functions in the proper namespace for a long
time now and there weren't a lot users left.
