partitions in storage
rdac hardware handler assumes that there is one-to-one relation ship
between the host and the controller w.r.t lun. IOW, it does not
support "multiple storage partitions" within a storage.
Example:
HBA1 and HBA2 see lun 0 and 1 in storage A (1)
HBA3 and HBA4 see lun 0 and 1 in storage A (2)
HBA5 and HBA6 see lun 0 and 1 in storage A (3)
luns 0 and 1 in (1), (2) and (3) are totally different.
But, rdac handler treats the lun 0s (and lun 1s) as the same when
sending a mode select to the controller, which is wrong.
This patch makes the rdac hardware handler associate HBA and the
storage w.r.t lun (and not the host itself).
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
to identify storage
rdac hardware handler uses "Subsystem Identifier" from C4 inquiry page
to uniquely identify a storage. The problem with that is that if any
any of the bytes are non-ascii, subsys_id will all be spaces (hex
0x20). This creates lot of problems especially when there are multiple
rdac storages are connected to the server.
Use "Storage Array Unique Identifier" from C8 inquiry page, which is the
world wide unique identifier for the storage array, to uniquely identify
the storage.
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Based on the operating modes, handler decides whether to send mode
select or not. Purpose here is to reduce io-shipping as much as
possible whenever there is an option.
Signed-off-by: Babu Moger <babu.moger@lsi.com>
Reviewed-by: Yanling Qi <yanling.qi@lsi.com>
Reviewed-by: Sudhir Dachepalli <Sudhir.Dachepalli@lis.com>
Reviewed-by: Somasundaram Krishnasamy <Somasundaram.Krishnasamy@lsi.com>
Reviewed-by: Bob Stankey <Robert.Stankey@lsi.com>
Reviewed-by: Vijay Chauhan <Vijay.Chauhan@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
This patch detects different operating RDAC modes during the
discovery. It also collects the information about the preferred path.
This patch adds definitions to support for different operating modes
for LSI rdac storage. Currently, rdac support 3 operation modes.
1. RDAC mode(legacy)
2. AVT mode
3. IOSHIP mode
These definitions are used while activating the path(rdac_activate).
This patch is to add Dell MD36xxf array into the RDAC handler device list.
Singed-off-by: Yanqing Liu <Yanqing_Liu@Dell.com>
Adding MODULE_VERSION for scsi_dh_rdac. This will be helpful sometimes
to get the code level without looking at the code.
instead of doing sizeof(struct X) it's better to do sizeof(*v) where v
is the variable pointing to struct X.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
During one of our testing, we noticed that mode select command sent
from the host did not have the lun_table updated.
Problem is root caused to the way lun table is updated. Lun table
update was done after the call to blk_rq_map_kern is made. This was
causing problem because kernel uses bounce buffer(bio_copy_kern) if
the address is not aligned. The command buffer updated after the
call(blk_rq_map_kern) was not going on the wire. Moved the code to
update the lun_table before the call to fix the problem.
Signed-off-by: Somasundaram Krishnasamy <Somasundaram.Krishnasamy@lsi.com>
Signed-off-by: Yanling Qi <Yanling.Qi@lsi.com>
Signed-off-by: Vijay Chauhan <vijay.chauhan@lsi.com>
Acked-by: Chandra Seetharaman <sekharan@us.ibm.com>
This patch is to add next generation of Dell iSCSI PowerVault
controller MD36xxi into RDAC device list.
Signed-off-by: Yanqing Liu <Yanqing_Liu@Dell.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch adds two new IBM storage devices which can use rdac device handlers.
Batch up MODE_SELECT in rdac device handler.
LSI RDAC storage has the capability of handling mode selects for
multiple luns in a same command. Make use of that ability to send
as few MODE SELECTs as possible to the storage controller as possible.
This patch creates a work queue and queues up activate requests
when a MODE SELECT is sent down the wire. When that MODE SELECT
completes, it compiles queued up activate requests for multiple
luns into a single MODE SELECT.
This reduces the time to do failover/failback of large number of LUNS.
Make scsi_dh_activate() function asynchronous, by taking in two additional
parameters, one is the callback function and the other is the data to call
the callback function with.
The function mode_select_handle_sense returns SCSI_DH_OK even when there is a sense code which is incorrect. Removing it so that it returns SCSI_DH_IO when there is sense that is not handled by this function.
Reviewed-by: Vijay Chauhan <vijay.chauhan@lsi.com>
Reviewed-by: Bob Stankey <Robert.stankey@lsi.com>
Reviewed-by: Chandra Seetharaman <sekharan@us.ibm.com>
Patch to add debugging stuff for rdac device handler.
- Added a bit mask "module parameter" rdac_logging with 2 bits for each type
of logging.
- currently defined only two types of logging(failover and sense logging). Can
be enhanced later if required.
- By default only failover logging is enabled which is equivalent of current
logging.
the initialization
Adding the code to read the debug information during initialization. This
patch collects the information about storage and controllers during
rdac_activate.
Moving the initialization code from rdac_activate to rdac_bus_attach which is
more efficient. We don't have to collect all the information during every
activate.
These storage arrays can use RDAC when configured with 'linux' as the
initiator.
http://www.sun.com/storage/disk_systems/workgroup/2500/
http://www.sun.com/storage/disk_systems/workgroup/2510/
http://www.sun.com/storage/disk_systems/workgroup/2530/
Signed-off-by: Charlie Brady <charlieb@budge.apana.org.au>
This patch is to add DM support for next generation of Dell PowerVault
storage array.
Reported-by: Rice Brown <rick.brown@oit.gatech.edu>
Signed-Off-by: Chandra Seetharaman <sekharan@us.ibm.com>
During device discovery read capacity fails with 0x020401 and sets the
device size to 0. As a reason any I/O submitted to this path gets
killed at sd_prep_fn with BLKPREP_KILL. This patch is to retry for
0x020401. NEED_RETRY in scsi_decide_disposition does not give
sufficient time for the device to become ready.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
This patch adds retry for NOT_READY check condition - Quiesce in
progress (02/A1/02)
Signed-off-by: Vijay Chauhan<vijay.chauhan@lsi.com>
UNIT_ATTENTION, NOT_READY(02/04/01)
This patch is to add retry for mode select if mode select command is
returned with sense NO_SENSE, UNIT_ATTENTION, ABORTED_COMMAND,
NOT_READY(02/04/01). This patch reorganise the sense keys from if-else
to switch-case format for better maintainability.
During device discovery read capacity fails with 0x068b02 and sets the
0x068b02
[jejb: fixed whitespace damage]
Signed-off-by: Babu Moger <Babu.Moger@lsi.com>
When the mode select sent to the controller fails with the retryable
error, it is better to retry the mode_select from the hardware handler
itself, instead of propagating the failure to dm-multipath.
controller is swapped from passive to active
When the controller ownership is changed (from passive to active),
check_ownership() doesn't set the state of the device to ACTIVE.
Reported-by: "Moger, Babu" <Babu.Moger@lsi.com>
Set the path state to be passive when we learn that the controller does
not own the path to the LUN.
This will avoid sending even a single i/o thru the passive path at the
probe time.
Multipath is best at handling transport errors. If it gets a device
error then there is not much the multipath layer can do. It will just
access the same device but from a different path.
This patch breaks up failfast into device, transport and driver errors.
The multipath layers (md and dm mutlipath) only ask the lower levels to
fast fail transport errors. The user of failfast, read ahead, will ask
to fast fail on all errors.
Note that blk_noretry_request will return true if any failfast bit
is set. This allows drivers that do not support the multipath failfast
bits to continue to fail on any failfast error like before. Drivers
like scsi that are able to fail fast specific errors can check
for the specific fail fast type. In the next patch I will convert
scsi.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Cc: Jens Axboe <jens.axboe@oracle.com>
Add Dell Powervault storage arrays into device list of rdac device
handler.
Signed-off-by: Yanqing Liu <yanqing_liu@dell.com>
blk_get_request initializes rq->cmd (rq_init does) so the users don't
need to do that.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Change scsi_dh check_sense functions to return ADD_TO_MLQUEUE
to allow retries to occur without restriction of blk_noretry_request
check.
Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (22 commits)
[SCSI] ibmvfc: Driver version 1.0.2
[SCSI] ibmvfc: Add details to async event log
[SCSI] ibmvfc: Sanitize response lengths
[SCSI] ibmvfc: Fix for lost async events
[SCSI] ibmvfc: Fixup host state during reinit
[SCSI] ibmvfc: Fix another hang on module removal
[SCSI] ibmvscsi: Fixup desired DMA value for shared memory partitions
[SCSI] megaraid_sas: remove sysfs dbg_lvl world writeable permissions
[SCSI] qla2xxx: Update version number to 8.02.01-k7.
[SCSI] qla2xxx: Explicitly tear-down vports during PCI remove_one().
[SCSI] qla2xxx: Reference proper ha during SBR handling.
[SCSI] qla2xxx: Set npiv_supported flag for FCoE HBAs.
[SCSI] qla2xxx: Don't leak SG-DMA mappings while aborting commands.
[SCSI] qla2xxx: Correct vport-state management issues during ISP-ABORT.
[SCSI] qla2xxx: Correct synchronization of software/firmware fcport states.
[SCSI] scsi_dh: Initialize lun_state in check_ownership()
[SCSI] scsi_dh: Do not use scsilun in rdac hardware handler
[SCSI] megaraid_sas: version and Documentation Update
[SCSI] megaraid_sas: add new controllers (0x78 0x79)
[SCSI] megaraid_sas: add the shutdown DCMD cmd to driver shutdown routine
lun_state need to be initialized inside check_ownership().
RDAC storage controller doesn't seem to use the scsilun format. It uses
only the last byte for LUN.
This patch makes several needlessly global struct scsi_dh_devlist's
static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch updates the RDAC device handler to
refuse to attach to devices not supporting the
RDAC vpd pages.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Instead of having each and every driver implement its own
device table scanning code we should rather implement a common
routine and scan the device tables there.
This allows us also to implement a general notifier chain
callback for all device handler instead for one per handler.
[sekharan: Fix rejections caused by conflicting bug fix]
Before accessing the device data structure in hardware handlers,
make sure it is a indeed a sdev device.
Yinghai Lu <yhlu.kernel@gmail.com> found the bug on Jul 16, 2008,
and later tested/verified the following fix.
This patch provides the device handler to support the LSI RDAC SCSI
based storage devices.
