[ Upstream commit 4d7d39a18b8b81511f0b893b7d2203790bf8a58b ]
We accidentally return an uninitialized variable on success.
Fixes: b6ff1b14cdf4 ("[SCSI] scsi_dh: Update EMC handler")
Reviewed-by: Hannes Reinecke <hare@suse.de>
commit 0c994c03c926d26ce48e6bbabbbe60366044fcae upstream.
When the scsi_dh core was moved into the scsi core module,
CONFIG_SCSI_DH became a 'bool' option, and now anything depending on it
can be built-in even when CONFIG_SCSI=m. This of course cannot link
successfully:
drivers/scsi/built-in.o: In function `rdac_init':
scsi_dh_alua.c:(.init.text+0x14): undefined reference to `scsi_register_device_handler'
scsi_dh_alua.c:(.init.text+0x64): undefined reference to `scsi_unregister_device_handler'
drivers/scsi/built-in.o: In function `alua_init':
scsi_dh_alua.c:(.init.text+0xb0): undefined reference to `scsi_register_device_handler'
As a workaround, this adds an extra dependency on CONFIG_SCSI, so
Kconfig can figure out whether built-in is allowed or not.
Fixes: 086b91d052eb ("scsi_dh: integrate into the core SCSI code")
commit d2d06d4fe0f2cc2df9b17fefec96e6e1a1271d91 upstream.
If MODE SELECT returns with sense '05/91/36' (command lock violation)
it should always be retried without counting the number of retries.
During an HBA upgrade or similar circumstances one might see a flood
of MODE SELECT command from various HBAs, which will easily trigger
the sense code and exceed the retry count.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Add a ->handler and a ->handler_data field to struct scsi_device and kill
this indirection. Also move struct scsi_device_handler to scsi_dh.h so that
changes to it don't require rebuilding every SCSI LLDD.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Add a single list of devices that need non-ALUA device handlers to the core
scsi_dh code so that we can autoload the modules for them at probe time.
While this is a little ugly in terms of architecture it actually
significantly simplifies the code in addition to the new autoloading
functionality.
Acked-by: Mike Snitzer <snitzer@redhat.com>
Stop building scsi_dh as a separate module and integrate it fully into the
core SCSI code with explicit callouts at bus scan time. For now the
callouts are placed at the same point as the old bus notifiers were called,
but in the future we will be able to look at ALUA INQUIRY data earlier on.
Note that this also means that the device handler modules need to be loaded
by the time we scan the bus. The next patches will add support for
autoloading device handlers at bus scan time to make sure they are always
loaded if they are enabled in the kernel config.
Prepare for building scsi_dh.c into the core SCSI module by moving it to
drivers/scsi.
This way we can reused the same code any attachment method, not just those
requested from dm-mpath.
[jejb: fixup checkpatch error]
While allowing dm-mpath to attach device handlers is a functionality we need
for backwards compatibility reason there is no reason to reference count
them and detach them if dm-mpath stops using the device for some reason.
If the device handler works for the given device it can just stay attached,
and we can take the retain_hw_handler codepath.
Acked-by: Hannes Reinecke <hare@Suse.de>
This fixes a regression caused by commit 1d5203 ("scsi: handle more device
handler setup/teardown in common code").
The bug is that the alua detach() callout will try to access the
sddev->scsi_dh_data, but we have already set it to NULL. This patch
moves the clearing of that field to after detach() is called.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Move all code to set up and tear down sdev->scsi_dh_data to common code.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
All drivers now do their own matching, so there is no more need to expose
a device list as part of the interface.
We need to grab a reference to the module before calling the attach
routines to avoid a small race vs module removal. It also cleans up
the code significantly as a side effect.
This patch fixes an issue with multipath ipr SAS devices which require a
start unit command to be issued following an adapter reset. Without this
patch, paths get marked failed following an adapter reset and since the
error handler never gets invoked to issue the start unit, the paths are
never recovered. Returning FAILED for this case ensures the error
handler wakes up to issue the start unit.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Tested-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
The blk_get_request function may fail in low-memory conditions or during
device removal (even if __GFP_WAIT is set). To distinguish between these
errors, modify the blk_get_request call stack to return the appropriate
ERR_PTR. Verify that all callers check the return status and consider
IS_ERR instead of a simple NULL pointer check.
For consistency, make a similar change to the blk_mq_alloc_request leg
of blk_get_request. It may fail if the queue is dead, or the caller was
unwilling to wait.
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Acked-by: Jiri Kosina <jkosina@suse.cz> [for pktdvd]
Acked-by: Boaz Harrosh <bharrosh@panasas.com> [for osd]
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
With the optimizations around not clearing the full request at alloc
time, we are leaving some of the needed init for REQ_TYPE_BLOCK_PC
up to the user allocating the request.
Add a blk_rq_set_block_pc() that sets the command type to
REQ_TYPE_BLOCK_PC, and properly initializes the members associated
with this type of request. Update callers to use this function instead
of manipulating rq->cmd_type directly.
Includes fixes from Christoph Hellwig <hch@lst.de> for my half-assed
attempt.
transitioning
During testing, it was discovered that when a device tries to attach to the
alua handler while in TPG state of transitioning, the alua_rtpg function will
wait for it to exit the state before allowing it to continue. As a result, if
the 60 second timeout expires, the alua handler will not attach to the device.
To fix this, I have introduced an input argument to alua_rtpg called
wait_for_transition. The idea is that it will wait for the transition to
complete before an activation (because the current TPG state has some bearing
in that case), but during a discovery if it is transitioning, it will not
wait, and will store the state as standby for the time being.
I believe the precedent exists for this from commit
c0d289b3e59577532c45ee9110ef81bd7b341272 Since if the device reports a state
of transitioning, it can transition to other more valid states, and it has
been established TPGS is supported on the device, if it is attaching.
Signed-off-by: Sean Stewart <Sean.Stewart@netapp.com>
Acked-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
unit attention
When the scsi_dh_alua handler issues an RTPG during initialization, if it gets
0x06/0x29/0x04 as the sense, it will fail to attach the handler. NetApp
E-Series returns 0x29/0x00 for power on, and 0x29/0x04 for conditions that
cause the controller to reboot again. These conditions should be treated
identically within the handler.
path without STPG
Resending with requested rewording of the parameter description. Currently
ALUA device handler sends STPG command during failover and failback. Failover
can be optimized by implicit failover (by not to sending STPG command), when 1
is passed as hwhandler parameter in multipath.conf. ex "2 alua 1". We may need
to pass the parameter through module param for alua device handler to optimize
failover if incase retain_attached_hwhandler set in multipath.conf and
hwhandler is set with non-tpgs device handler ex: '1 rdac'.
[jejb: fix up whitespace and other issues]
Signed-off-by: Vijay Chauhan <vijay.chauhan@netapp.com>
For the stpg_endio path we are not evaluating the sense. The bug
is that
1. The error value is set to -EIO when there is sense, so we hit the first
error check and always return SCSI_DH_IO.
2. h->senselen is set to zero in submit_stpg. It is not later set to
req->sense_len like in the synchrounous exection paths, so we must
check the req->sense_len field.
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "James E.J. Bottomley" <JBottomley@parallels.com>
A quote from SPC-4: "While in the unavailable primary target port
asymmetric access state, the device server shall support those of
the following commands that it supports while in the active/optimized
state: [ ... ] d) SET TARGET PORT GROUPS; [ ... ]". Hence enable
sending STPG to a target port group that is in the unavailable state.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: <stable@vger.kernel.org>
Signed-off-by: Babu Moger <babu.moger@netapp.com>
This patch consolidates the strings together. Purpose is to remove minor product strings extensions.
That way the future products with similar strings should not require change here.
This patch adds a new vendor/product strings for netapp E series product.
Also consolidated the strings together with similar names.
Introduce scsi_dh_attached_handler_name() to retrieve the name of the
scsi_dh that is attached to the scsi_device associated with the provided
request queue. Returns NULL if a scsi_dh is not attached.
Also, fix scsi_dh_{attach,detach} function header comments to document
@q rather than @sdev.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Tested-by: Babu Moger <babu.moger@netapp.com>
Reviewed-by: Chandra Seetharaman <sekharan@us.ibm.com>
state: [ ... ] d) SET TARGET PORT GROUPS; [ ... ]". Hence re-enable
Reviewed-by: Babu Moger <babu.moger@netapp.com>
Currently the backoff algorithm for when to retry alua rtpg
requests progresses geometrically as so:
2, 4, 8, 16, 32, 64... seconds.
This progression can lead to un-needed delay in retrying
alua rtpg requests when the rtpgs are delayed. A less
aggressive backoff algorithm that is additive would not
lead to such large jumps when delays start getting long, but
would backoff linearly:
2, 4, 6, 8, 10... seconds.
Signed-off-by: Martin George <marting@netapp.com>
Signed-off-by: Rob Evers <revers@redhat.com>
response
Some storage arrays are known to return 'illegal request'
when an rtpg extended header request is made. T10 says the
array should ignore the bit, and return the non-extended
rtpg as the array doesn't support the request. Working
around this by retrying the rtpg request without the extended
header bit set when the extended rtpg request results in
illegal request.
During alua transitions, an array can return transitioning
status in response to rtpg requests. These requests get
retried for a maximum of 60 seconds by default before timing
out. Sometimes this timeout isn't sufficient to allow the
array to complete the transition. T10-spc4 addresses this
under 'Report Target Port Groups' command.
This update retrieves the timeout value from the storage
array if available and retries the transitioning rtpgs
for up to the 'implied transitioning timeout' value
This patch optimizes the set target port group(STPG) command. During our
testing, we found that it is not optimal to send stpg command every time
the path group switch happens. This patch uses PREF (preferred target port)
bit with combination of flags passed by multipath user level tool to
optimize this behaviour. If PREF bit is set then it issues a STPG command,
otherwise it will let implicit transfer take place.
By default there is no change in the behaviour. User tool needs to pass the
parameter to make this change take effect. Patch has been tested on NetApp
E series storage.
PREF bit indicates preferred target port group for accessing a logical
unit. This bit is used to optimize the STPG command handling.
Handler expects only one parameter to set the flag ALUA_OPTIMIZE_STPG.
This flag is used to optimize the STPG behaviour. There is no change in
behaviour by default.
For example, to set the flag pass the following parameters from multipath.conf
hardware_handler "2 alua 1"
This patch fixes an unbalanced refcount issue.
Elevating the lock for both kref_put and also for controller node deletion.
Previously, controller deletion was protected but the not the kref_put. This
was causing the other thread to pick up the controller structure which was
already kref'd zero.
This was causing the following WARN_ON and also sometimes panic.
WARNING: at lib/kref.c:43 kref_get+0x2d/0x30() (Not tainted)
Hardware name: IBM System x3655 -[7985AC1]-
Modules linked in: fuse scsi_dh_rdac autofs4 nfs lockd fscache nfs_acl
auth_rpcgss sunrpc 8021q garp stp llc ipv6 ib_srp(U) scsi_transport_srp
scsi_tgt ib_cm(U) ib_sa(U) ib_uverbs(U) ib_umad(U) mlx4_ib(U) mlx4_core(U)
ib_mthca(U) ib_mad(U) ib_core(U) dm_mirror dm_region_hash dm_log dm_round_robin
dm_multipath uinput bnx2 ses enclosure sg ibmpex ibmaem ipmi_msghandler
serio_raw k8temp hwmon amd64_edac_mod edac_core edac_mce_amd shpchp i2c_piix4
ext4 mbcache jbd2 sr_mod cdrom sd_mod crc_t10dif sata_svw pata_acpi ata_generic
pata_serverworks aacraid radeon ttm drm_kms_helper drm i2c_algo_bit i2c_core
dm_mod [last unloaded: freq_table]
Pid: 13735, comm: srp_daemon Not tainted 2.6.32-71.el6.x86_64 #1
Call Trace:
[<ffffffff8106b857>] warn_slowpath_common+0x87/0xc0
[<ffffffff8106b8aa>] warn_slowpath_null+0x1a/0x20
[<ffffffff8125c39d>] kref_get+0x2d/0x30
[<ffffffffa01b4029>] rdac_bus_attach+0x459/0x580 [scsi_dh_rdac]
[<ffffffff8135232a>] scsi_dh_handler_attach+0x2a/0x80
[<ffffffff81352c7b>] scsi_dh_notifier+0x9b/0xa0
[<ffffffff814cd7a5>] notifier_call_chain+0x55/0x80
[<ffffffff8109711a>] __blocking_notifier_call_chain+0x5a/0x80
[<ffffffff81097156>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff8132bec5>] device_add+0x515/0x640
[<ffffffff813329e4>] ? attribute_container_device_trigger+0xc4/0xe0
[<ffffffff8134f659>] scsi_sysfs_add_sdev+0x89/0x2c0
[<ffffffff8134d096>] scsi_probe_and_add_lun+0xea6/0xed0
[<ffffffff8134beb2>] ? scsi_alloc_target+0x292/0x2d0
[<ffffffff8134d1e1>] __scsi_scan_target+0x121/0x750
[<ffffffff811df806>] ? sysfs_create_file+0x26/0x30
[<ffffffff8132b759>] ? device_create_file+0x19/0x20
[<ffffffff81332838>] ? attribute_container_add_attrs+0x78/0x90
[<ffffffff814b008c>] ? klist_next+0x4c/0xf0
[<ffffffff81332e30>] ? transport_configure+0x0/0x20
[<ffffffff8134df40>] scsi_scan_target+0xd0/0xe0
[<ffffffffa02f053a>] srp_create_target+0x75a/0x890 [ib_srp]
[<ffffffff8132a130>] dev_attr_store+0x20/0x30
[<ffffffff811df145>] sysfs_write_file+0xe5/0x170
[<ffffffff8116c818>] vfs_write+0xb8/0x1a0
[<ffffffff810d40a2>] ? audit_syscall_entry+0x272/0x2a0
[<ffffffff8116d251>] sys_write+0x51/0x90
[<ffffffff81013172>] system_call_fastpath+0x16/0x1b
This patch adds a check-condition in scsi_dh_alua handler for a retry.
Sometimes, I have seen attach failing due to this check-condition with
following error messages on NetApp E series storage.
Dec 7 15:31:01 nilgiris kernel: [102979.696673] scsi 3:0:2:9: alua: port group 00 rel port 01
Dec 7 15:31:01 nilgiris kernel: [102979.697082] scsi 3:0:2:9: alua: rtpg failed with 8000002
Dec 7 15:31:01 nilgiris kernel: [102979.697086] scsi 3:0:2:9: alua: rtpg sense code 06/2a/01
Dec 7 15:31:01 nilgiris kernel: [102979.697088] scsi 3:0:2:9: alua: not attached
If create_singlethread_workqueue() failes, rdac_init should fail too.
Signed-off-by: Richard Weinberger <richard@nod.at>
Acked-by: "Moger, Babu" <Babu.Moger@netapp.com>
All the handlers have now implemented the match function so We don't need to
use scsi_dev_info any more for matching purposes.
This patch introduces the match function for rdac device handler. Without
this, sometimes handler attach fails during the device_add. Included check for
TPGS bit before proceeding further. The match function was introduced by
commit 6c3633d08acf514e2e89aa95d2346ce9d64d719a
This patch introduces the match function for hp_sw device handler. Included
the check for TPGS bit before proceeding further per Hannes comment. The
match function was introduced by commit
This patch introduces the match function for emc device handler. Included
check for TPGS bit before proceeding further. The match function was
introduced by commit 6c3633d08acf514e2e89aa95d2346ce9d64d719a
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
This patch corrects the retry interval for alua rtpg command. Purpose was to retry the commands in seconds.
But that was not happening. Reason is msleep takes argument in milliseconds.
Also added minor text after successful attach.
The module.h header was implicitly present everywhere, so files
with no explicit include of the module infrastructure would build
anyway. We are now removing the implicit include, and so we need
to call out the module.h file that we need explicitly.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Cc: stable@kernel.org
This patch adds one more check-condition for scsi_dh_alua handler. Without
this, the handler attach fails sometimes during the discovery. I have noticed
this with NetApp E-Series storage with alua mode. Also removed some
unnecessary brackets {} for consistency.
Signed-off-by: Vijay Chauhan <Vijay.chauhan@netapp.com>
Reviewed-by: Bob Stankey <Robert.stankey@netapp.com>
Reviewed-by: Babu Moger <Babu.moger@netapp.com>
Acked-by: Chandra Seetharaman <sekharan@us.ibm.com>
