path: root/drivers/scsi/esp_scsi.h
2008-08-29sparc: Kill SBUS DVMA layer.David S. Miller
This thing was completely pointless. Just find the OF device in the parent of drivers that want to program this device, and map the DMA regs inside such drivers too. This also moves the dummy claim_dma_lock() and release_dma_lock() implementation to floppy_32.h, which makes it handle this issue just like floppy_64.h does. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27[SCSI] m68k: new mac_esp scsi driverFinn Thain
Replace the mac_esp driver with a new one based on the esp_scsi core. For esp_scsi: add support for sync transfers for the PIO mode, add a new esp_driver_ops method to get the maximum dma transfer size (like the old NCR53C9x driver), and some cleanups. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] esp_scsi: Make cur_residue and tot_residue signed.David S. Miller
Many of the overflow checks test whether the value has gone negative, and we want to retain such checks. Reported by Julia Lawall. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-07-31[SCSI] ESP: Revert ESP_BUS_TIMEOUT back down to 250David Miller
This reverts d73f5222a618a91452d41c29f5996ce3d9c63673 The bug that made us increase ESP_BUS_TIMEOUT to 275 turned out to be a memset bug on 32-bit sparc. It is better to put this back at the correct timeout value than to leave it increased when there is no reason for doing so. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-20[SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275.David Miller
This matches the original driver's value and seems to be necessary for some disks on sun4c systems. Reported by Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-31[SCSI] esp: use shost_privChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-27[SCSI] SUNESP: Complete driver rewrite to version 2.0David S. Miller
Major features: 1) Tagged queuing support. 2) Will properly negotiate for synchronous transfers even on devices that reject the wide negotiation message, such as CDROMs 3) Significantly lower kernel stack usage in interrupt handler path by elimination of function vector arrays, replaced by a top-level switch statement state machine. 4) Uses generic scsi infrastructure as much as possible to avoid code duplication. 5) Automatic request of sense data in response to CHECK_CONDITION 6) Portable to other platforms using ESP such as DEC and Sun3 systems. Signed-off-by: David S. Miller <davem@davemloft.net>
