path: root/drivers/scsi/esp_scsi.h
2018-10-17scsi: esp_scsi: De-duplicate PIO routinesFinn Thain
As a temporary measure, the code to implement PIO transfers was duplicated in zorro_esp and mac_esp. Now that it has stabilized move the common code into the core driver but don't build it unless needed. This replaces the inline assembler with more portable writesb() calls. Optimizing the m68k writesb() implementation is a separate patch. [mkp: applied by hand] Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Tested-by: Stan Johnson <userm57@yahoo.com> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-17scsi: esp_scsi: Eliminate ESP_FLAG_DOING_SLOWCMDFinn Thain
The concept of a 'slow command' as it appears in esp_scsi is confusing because it could refer to an ESP command or a SCSI command. It turns out that it refers to a particular ESP select command which the driver also tracks as 'ESP_SELECT_MSGOUT'. For readability, it is better to use the terminology from the datasheets. The global ESP_FLAG_DOING_SLOWCMD flag is redundant anyway, as it can be inferred from esp->select_state. Remove the ESP_FLAG_DOING_SLOWCMD cruft and just use a boolean local variable. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-17scsi: esp_scsi: Track residual for PIO transfersFinn Thain
If a target disconnects during a PIO data transfer the command may fail when the target reconnects: scsi host1: DMA length is zero! scsi host1: cur adr[04380000] len[00000000] The scsi bus is then reset. This happens because the residual reached zero before the transfer was completed. The usual residual calculation relies on the Transfer Count registers. That works for DMA transfers but not for PIO transfers. Fix the problem by storing the PIO transfer residual and using that to correctly calculate bytes_sent. Fixes: 6fe07aaffbf0 ("[SCSI] m68k: new mac_esp scsi driver") Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Tested-by: Michael Schmitz <schmitzmic@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-15scsi: esp_scsi: remove union in esp_cmd_privChristoph Hellwig
The dma_addr_t member is unused ever since we switched the SCSI layer to send down single-segement command using a scatterlist as well many years ago. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-15scsi: esp_scsi: move dma mapping into the core codeChristoph Hellwig
Except for the mac_esp driver, which uses PIO or pseudo DMA, all drivers share the same dma mapping calls. Move the dma mapping into the core code using the scsi_dma_map / scsi_dma_unmap helpers, with a special identify mapping variant triggered off a new ESP_FLAG_NO_DMA_MAP flag for mac_esp. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-15scsi: esp_scsi: remove the dev argument to scsi_esp_registerChristoph Hellwig
We can simplify use esp->dev now. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-10-15scsi: esp_scsi: use strong typing for the dev fieldChristoph Hellwig
esp->dev is a void pointer that points either to a struct device, or a struct platform_device. As we can easily get from the device to the platform_device if needed change it to always point to a struct device and properly type the pointer to avoid errors. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-10scsi: esp_scsi: Clean up control flow and dead codeFinn Thain
This patch improves readability. There are no functional changes. Since this touches on a questionable ESP_INTR_DC conditional, add some commentary to help others who may (as I did) find themselves chasing an "Invalid Command" error after the device flags this condition. This cleanup also eliminates a warning from "make W=1": drivers/scsi/esp_scsi.c: In function 'esp_finish_select': drivers/scsi/esp_scsi.c:1233:5: warning: variable 'orig_select_state' set but not used [-Wunused-but-set-variable] u8 orig_select_state; Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2014-11-24esp_scsi: correctly detect am53c974Hannes Reinecke
The am53c974 returns the same ID as the FAS236, but implements things slightly differently. So detect the am53c974 by checking for ESP_CONFIG4 register. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-24am53c974: BLAST residual handlingHannes Reinecke
The am53c974 has an design issue where a single byte might be left in the SCSI FIFO after a DMA transfer. As the handling code is currently untested add a WARN_ON() statement here. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-24esp_scsi: use FIFO for command submissionHannes Reinecke
Using DMA for command submission has the drawback that it might generate additional DMA completion interrupts after the command has been submitted to the device. Additionally the am53c974 has a design flaw causing it to generate spurious interrupts even though DMA completion interrupts are not enabled. This can be avoided by using the FIFO for command submission. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-24esp_scsi: make number of tags configurableHannes Reinecke
Add a field 'num_tags' to the esp structure to allow drivers to overwrite the number of avialable tags if required. Default is ESP_DEFAULT_TAGS. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-24esp_scsi: spellcheck 'driver'Hannes Reinecke
2013-08-01esp_scsi: Fix tag state corruption when autosensing.David S. Miller
Meelis Roos reports a crash in esp_free_lun_tag() in the presense of a disk which has died. The issue is that when we issue an autosense command, we do so by hijacking the original command that caused the check-condition. When we do so we clear out the ent->tag[] array when we issue it via find_and_prep_issuable_command(). This is so that the autosense command is forced to be issued non-tagged. That is problematic, because it is the value of ent->tag[] which determines whether we issued the original scsi command as tagged vs. non-tagged (see esp_alloc_lun_tag()). And that, in turn, is what trips up the sanity checks in esp_free_lun_tag(). That function needs the original ->tag[] values in order to free up the tag slot properly. Fix this by remembering the original command's tag values, and having esp_alloc_lun_tag() and esp_free_lun_tag() use them. Reported-by: Meelis Roos <mroos@linux.ee> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill SBUS DVMA layer.David S. Miller
This thing was completely pointless. Just find the OF device in the parent of drivers that want to program this device, and map the DMA regs inside such drivers too. This also moves the dummy claim_dma_lock() and release_dma_lock() implementation to floppy_32.h, which makes it handle this issue just like floppy_64.h does. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27[SCSI] m68k: new mac_esp scsi driverFinn Thain
Replace the mac_esp driver with a new one based on the esp_scsi core. For esp_scsi: add support for sync transfers for the PIO mode, add a new esp_driver_ops method to get the maximum dma transfer size (like the old NCR53C9x driver), and some cleanups. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] esp_scsi: Make cur_residue and tot_residue signed.David S. Miller
Many of the overflow checks test whether the value has gone negative, and we want to retain such checks. Reported by Julia Lawall. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-07-31[SCSI] ESP: Revert ESP_BUS_TIMEOUT back down to 250David Miller
This reverts d73f5222a618a91452d41c29f5996ce3d9c63673 The bug that made us increase ESP_BUS_TIMEOUT to 275 turned out to be a memset bug on 32-bit sparc. It is better to put this back at the correct timeout value than to leave it increased when there is no reason for doing so. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-20[SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275.David Miller
This matches the original driver's value and seems to be necessary for some disks on sun4c systems. Reported by Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-31[SCSI] esp: use shost_privChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-27[SCSI] SUNESP: Complete driver rewrite to version 2.0David S. Miller
Major features: 1) Tagged queuing support. 2) Will properly negotiate for synchronous transfers even on devices that reject the wide negotiation message, such as CDROMs 3) Significantly lower kernel stack usage in interrupt handler path by elimination of function vector arrays, replaced by a top-level switch statement state machine. 4) Uses generic scsi infrastructure as much as possible to avoid code duplication. 5) Automatic request of sense data in response to CHECK_CONDITION 6) Portable to other platforms using ESP such as DEC and Sun3 systems. Signed-off-by: David S. Miller <davem@davemloft.net>
