path: root/drivers/scsi/fnic
2018-06-12treewide: Use array_size() in vmalloc()Kees Cook
The vmalloc() function has no 2-factor argument form, so multiplication factors need to be wrapped in array_size(). This patch replaces cases of: vmalloc(a * b) with: vmalloc(array_size(a, b)) as well as handling cases of: vmalloc(a * b * c) with: vmalloc(array3_size(a, b, c)) This does, however, attempt to ignore constant size factors like: vmalloc(4 * 1024) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ type TYPE; expression THING, E; @@ ( vmalloc( - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | vmalloc( - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression COUNT; typedef u8; typedef __u8; @@ ( vmalloc( - sizeof(u8) * (COUNT) + COUNT , ...) | vmalloc( - sizeof(__u8) * (COUNT) + COUNT , ...) | vmalloc( - sizeof(char) * (COUNT) + COUNT , ...) | vmalloc( - sizeof(unsigned char) * (COUNT) + COUNT , ...) | vmalloc( - sizeof(u8) * COUNT + COUNT , ...) | vmalloc( - sizeof(__u8) * COUNT + COUNT , ...) | vmalloc( - sizeof(char) * COUNT + COUNT , ...) | vmalloc( - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( vmalloc( - sizeof(TYPE) * (COUNT_ID) + array_size(COUNT_ID, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * COUNT_ID + array_size(COUNT_ID, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * (COUNT_CONST) + array_size(COUNT_CONST, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * COUNT_CONST + array_size(COUNT_CONST, sizeof(TYPE)) , ...) | vmalloc( - sizeof(THING) * (COUNT_ID) + array_size(COUNT_ID, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * COUNT_ID + array_size(COUNT_ID, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * (COUNT_CONST) + array_size(COUNT_CONST, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * COUNT_CONST + array_size(COUNT_CONST, sizeof(THING)) , ...) ) // 2-factor product, only identifiers. @@ identifier SIZE, COUNT; @@ vmalloc( - SIZE * COUNT + array_size(COUNT, SIZE) , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( vmalloc( - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vmalloc( - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vmalloc( - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vmalloc( - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( vmalloc( - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | vmalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | vmalloc( - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | vmalloc( - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | vmalloc( - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | vmalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ identifier STRIDE, SIZE, COUNT; @@ ( vmalloc( - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vmalloc( - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products // when they're not all constants... @@ expression E1, E2, E3; constant C1, C2, C3; @@ ( vmalloc(C1 * C2 * C3, ...) | vmalloc( - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants. @@ expression E1, E2; constant C1, C2; @@ ( vmalloc(C1 * C2, ...) | vmalloc( - E1 * E2 + array_size(E1, E2) , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org>
2018-04-18scsi: fnic: fix spelling mistake in fnic stats "Abord" -> "Abort"Colin Ian King
Trivial fix to spelling mistake in fnic stats message text. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-01-22scsi: fnic: use 64-bit timestampsArnd Bergmann
struct timespec is deprecated since it overflows in 2038 on 32-bit architectures, so we should use timespec64 consistently. I'm slightly adapting the format strings here, to make sure we print the nanoseconds with the correct number of leading zeroes. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2018-01-17scsi: fnic: use kzalloc in fnic_fcoe_process_vlan_respRasmus Villemoes
This saves a little .text and gets rid of the unmotivated line break and the sizeof(...) style inconsistency. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-12-11scsi: fnic: add a space after %p in printf formatNicolas Iooss
fnic_fcpio_icmnd_cmpl_handler() displays the value of sc with: FNIC_SCSI_DBG(KERN_INFO... "... sc = 0x%p" "scsi_status ..." ... As the literal strings get merged, the function uses %ps instead of the intended raw %p format. Fix this by inserting a space. Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-12-04scsi: fnic: Fix coccinelle warningsVasyl Gomonovych
Remove the duplicate copies of this simple function and use an open-coded version. drivers/scsi/fnic/fnic_debugfs.c:122:11-31: WARNING opportunity for simple_open, see also structure on line 223 Generated by: coccinelle/api/simple_open.cocci Signed-off-by: Vasyl Gomonovych <gomonovych@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-11-21treewide: setup_timer() -> timer_setup()Kees Cook
This converts all remaining cases of the old setup_timer() API into using timer_setup(), where the callback argument is the structure already holding the struct timer_list. These should have no behavioral changes, since they just change which pointer is passed into the callback with the same available pointers after conversion. It handles the following examples, in addition to some other variations. Casting from unsigned long: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... setup_timer(&ptr->my_timer, my_callback, ptr); and forced object casts: void my_callback(struct something *ptr) { ... } ... setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr); become: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... timer_setup(&ptr->my_timer, my_callback, 0); Direct function assignments: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... ptr->my_timer.function = my_callback; have a temporary cast added, along with converting the args: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback; And finally, callbacks without a data assignment: void my_callback(unsigned long data) { ... } ... setup_timer(&ptr->my_timer, my_callback, 0); have their argument renamed to verify they're unused during conversion: void my_callback(struct timer_list *unused) { ... } ... timer_setup(&ptr->my_timer, my_callback, 0); The conversion is done with the following Coccinelle script: spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/timer_setup.cocci @fix_address_of@ expression e; @@ setup_timer( -&(e) +&e , ...) // Update any raw setup_timer() usages that have a NULL callback, but // would otherwise match change_timer_function_usage, since the latter // will update all function assignments done in the face of a NULL // function initialization in setup_timer(). @change_timer_function_usage_NULL@ expression _E; identifier _timer; type _cast_data; @@ ( -setup_timer(&_E->_timer, NULL, _E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E->_timer, NULL, (_cast_data)_E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E._timer, NULL, &_E); +timer_setup(&_E._timer, NULL, 0); | -setup_timer(&_E._timer, NULL, (_cast_data)&_E); +timer_setup(&_E._timer, NULL, 0); ) @change_timer_function_usage@ expression _E; identifier _timer; struct timer_list _stl; identifier _callback; type _cast_func, _cast_data; @@ ( -setup_timer(&_E->_timer, _callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | _E->_timer@_stl.function = _callback; | _E->_timer@_stl.function = &_callback; | _E->_timer@_stl.function = (_cast_func)_callback; | _E->_timer@_stl.function = (_cast_func)&_callback; | _E._timer@_stl.function = _callback; | _E._timer@_stl.function = &_callback; | _E._timer@_stl.function = (_cast_func)_callback; | _E._timer@_stl.function = (_cast_func)&_callback; ) // callback(unsigned long arg) @change_callback_handle_cast depends on change_timer_function_usage@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; identifier _handle; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { ( ... when != _origarg _handletype *_handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg ) } // callback(unsigned long arg) without existing variable @change_callback_handle_cast_no_arg depends on change_timer_function_usage && !change_callback_handle_cast@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { + _handletype *_origarg = from_timer(_origarg, t, _timer); + ... when != _origarg - (_handletype *)_origarg + _origarg ... when != _origarg } // Avoid already converted callbacks. @match_callback_converted depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier t; @@ void _callback(struct timer_list *t) { ... } // callback(struct something *handle) @change_callback_handle_arg depends on change_timer_function_usage && !match_callback_converted && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; @@ void _callback( -_handletype *_handle +struct timer_list *t ) { + _handletype *_handle = from_timer(_handle, t, _timer); ... } // If change_callback_handle_arg ran on an empty function, remove // the added handler. @unchange_callback_handle_arg depends on change_timer_function_usage && change_callback_handle_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; identifier t; @@ void _callback(struct timer_list *t) { - _handletype *_handle = from_timer(_handle, t, _timer); } // We only want to refactor the setup_timer() data argument if we've found // the matching callback. This undoes changes in change_timer_function_usage. @unchange_timer_function_usage depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg && !change_callback_handle_arg@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type change_timer_function_usage._cast_data; @@ ( -timer_setup(&_E->_timer, _callback, 0); +setup_timer(&_E->_timer, _callback, (_cast_data)_E); | -timer_setup(&_E._timer, _callback, 0); +setup_timer(&_E._timer, _callback, (_cast_data)&_E); ) // If we fixed a callback from a .function assignment, fix the // assignment cast now. @change_timer_function_assignment depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_func; typedef TIMER_FUNC_TYPE; @@ ( _E->_timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -&_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)_callback; +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -&_callback; +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; ) // Sometimes timer functions are called directly. Replace matched args. @change_timer_function_calls depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression _E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_data; @@ _callback( ( -(_cast_data)_E +&_E->_timer | -(_cast_data)&_E +&_E._timer | -_E +&_E->_timer ) ) // If a timer has been configured without a data argument, it can be // converted without regard to the callback argument, since it is unused. @match_timer_function_unused_data@ expression _E; identifier _timer; identifier _callback; @@ ( -setup_timer(&_E->_timer, _callback, 0); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0L); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0UL); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0L); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0UL); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_timer, _callback, 0); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0L); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0UL); +timer_setup(&_timer, _callback, 0); | -setup_timer(_timer, _callback, 0); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0L); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0UL); +timer_setup(_timer, _callback, 0); ) @change_callback_unused_data depends on match_timer_function_unused_data@ identifier match_timer_function_unused_data._callback; type _origtype; identifier _origarg; @@ void _callback( -_origtype _origarg +struct timer_list *unused ) { ... when != _origarg } Signed-off-by: Kees Cook <keescook@chromium.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-25scsi: fnic: do not call host reset from command abortHannes Reinecke
Command abort already returns FAILED, which will then be escalated to a host reset. So no need to call host_reset directly. Signed-off-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-07scsi: fnic: fix format string overflow warningArnd Bergmann
The MSI interrupt name can require 11 bytes in addition to the device name, for a total of 23 bytes: drivers/scsi/fnic/fnic_isr.c: In function 'fnic_request_intr': drivers/scsi/fnic/fnic_isr.c:192:4: error: '-fcs-rq' directive writing 7 bytes into a region of size between 5 and 16 [-Werror=format-overflow=] "%.11s-fcs-rq", fnic->name); drivers/scsi/fnic/fnic_isr.c:206:3: note: 'sprintf' output between 12 and 23 bytes into a destination of size 16 sprintf(fnic->msix[FNIC_MSIX_ERR_NOTIFY].devname, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "%.11s-err-notify", fnic->name); This extends the buffer to fit any possible value. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-06Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is mostly updates of the usual suspects: lpfc, qla2xxx, bnx2fc, qedf, hpsa, hisi_sas, smartpqi, cxlflash, aacraid, csiostor along with a host of minor and miscellaneous changes" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (276 commits) qla2xxx: Fix NVMe entry_type for iocb packet on BE system scsi: qla2xxx: avoid unused-function warning scsi: snic: fix a couple of spelling mistakes/typos scsi: qla2xxx: fix a bunch of typos and spelling mistakes scsi: lpfc: don't double count abort errors scsi: lpfc: spin_lock_irq() is not nestable scsi: hisi_sas: optimise DMA slot memory scsi: ibmvfc: constify dev_pm_ops structures. scsi: ibmvscsi: constify dev_pm_ops structures. scsi: cxlflash: Update debug prints in reset handlers scsi: cxlflash: Update send_tmf() parameters scsi: cxlflash: Avoid double free of character device scsi: Add STARGET_CREATED_REMOVE state to scsi_target_state scsi: ses: do not add a device to an enclosure if enclosure_add_links() fails. scsi: ufs: flush eh_work when eh_work scheduled. scsi: qla2xxx: Protect access to qpair members with qpair->qp_lock scsi: sun_esp: fix device reference leaks scsi: fnic: changing queue command to return result DID_IMM_RETRY when rport is init scsi: fnic: correct speed display and add support for 25,40 and 100G scsi: fnic: added timestamp reporting in fnic debug stats ...
2017-06-27scsi: fnic: changing queue command to return result DID_IMM_RETRY when rport ↵Satish Kharat
is init Currently the queue command returns DID_NO_CONNECT anytime the rport is not in RPORT_ST_READY state. Changing it to return DID_NO_CONNECT only when the rport is in RPORT_ST_DELETE state. When the rport is in one of the init states retruning DID_IMM_RETRY. Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: fnic: correct speed display and add support for 25,40 and 100GSatish Kharat
Setting speed based on the vinc device parameter read during linkup. Also adding support to display 25,40 and 100G Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: fnic: added timestamp reporting in fnic debug statsSatish Kharat
Added the timestamps for 1. current timestamp 2. last fnic stats read timestamp 3. last fnic stats reset timestamp and the deltas since last stats read and last reset in fnic stats. fnic stats uses debugfs Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: fnic: Zero io_cmpl_skip on fw reset completionSatish Kharat
io_cmpl_skip keep track of number of completions to skip when stats are reset. If a fw_reset happens immediately after stats reset it could put it out of sync so need to reset io_cmpl_skip when fw reset is completed. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-16networking: make skb_push & __skb_push return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) @@ expression SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - fn(SKB, LEN)[0] + *(u8 *)fn(SKB, LEN) Note that the last part there converts from push(...)[0] to the more idiomatic *(u8 *)push(...). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: make skb_pull & friends return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_pull, __skb_pull, skb_pull_inline, __pskb_pull_tail, __pskb_pull, pskb_pull }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_pull, __skb_pull, skb_pull_inline, __pskb_pull_tail, __pskb_pull, pskb_pull }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-23scsi: fnic: bug fix for fip.fip_subcode in fnic_fcoe_send_vlan_reqSatish Kharat
This is a bug introduced when they moved the fip subcodes to central place. Was sending FIP_SC_VL_NOTE in fip.fip_subcode for VLAN request in fnic_fcoe_send_vlan_req. Change is to use FIP_SC_VL_REQ instead. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: Adding debug IO and Abort latency counter to fnic statsSatish Kharat
The IO and Abort latency counter counts the time taken to complete the IO and abort command into broad buckets. This is not intended for performance measurement, just a debug statistic. current_max_io_time tries to keep track of the maximum time an IO has taken to complete if it is > 30sec. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: Adding Check Condition counter to misc fnicstatsSatish Kharat
Just a simple counter of number of check conditions encountered on that host. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: Avoid false out-of-order detection for aborted commandSatish Kharat
If SCSI-ML has already issued abort on a command i.e FNIC_IOREQ_ABTS_PENDING is set and we get a IO completion, avoid this being flagged as out-of-order completion by setting the FNIC_IO_DONE flag in fnic_fcpio_icmnd_cmpl_handler Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: Fix for "Number of Active IOs" in fnicstats becoming negativeSatish Kharat
Fixing the IO stats update (Active IOs and IO completion) to prevent "Number of Active IOs" from becoming negative in the fnistats output. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: minor cleanup in fnic_fcpio_itmf_cmpl_handler, removing else caseSatish Kharat
Getting rid of else case to make the flow look bit simpler. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: Ratelimit printks to avoid flooding when vlan is not set by the ↵Satish Kharat
switch.i This is to avoid the log from being filled with vlan discovery messages when there is no vlan configured on the switch. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-23scsi: fnic: switch to pci_alloc_irq_vectorsChristoph Hellwig
Not a full cleanup for the IRQ code, for that we'd need to know if the max number of the various CQ types is going to stay 1 forever. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-02-21Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (ncr5380, ufs, lpfc, be2iscsi, hisi_sas, storvsc, cxlflash, aacraid, megaraid_sas, ...). There's also an assortment of minor fixes and the major update of switching a bunch of drivers to pci_alloc_irq_vectors from Christoph" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (188 commits) scsi: megaraid_sas: handle dma_addr_t right on 32-bit scsi: megaraid_sas: array overflow in megasas_dump_frame() scsi: snic: switch to pci_irq_alloc_vectors scsi: megaraid_sas: driver version upgrade scsi: megaraid_sas: Change RAID_1_10_RMW_CMDS to RAID_1_PEER_CMDS and set value to 2 scsi: megaraid_sas: Indentation and smatch warning fixes scsi: megaraid_sas: Cleanup VD_EXT_DEBUG and SPAN_DEBUG related debug prints scsi: megaraid_sas: Increase internal command pool scsi: megaraid_sas: Use synchronize_irq to wait for IRQs to complete scsi: megaraid_sas: Bail out the driver load if ld_list_query fails scsi: megaraid_sas: Change build_mpt_mfi_pass_thru to return void scsi: megaraid_sas: During OCR, if get_ctrl_info fails do not continue with OCR scsi: megaraid_sas: Do not set fp_possible if TM capable for non-RW syspdIO, change fp_possible to bool scsi: megaraid_sas: Remove unused pd_index from megasas_build_ld_nonrw_fusion scsi: megaraid_sas: megasas_return_cmd does not memset IO frame to zero scsi: megaraid_sas: max_fw_cmds are decremented twice, remove duplicate scsi: megaraid_sas: update can_queue only if the new value is less scsi: megaraid_sas: Change max_cmd from u32 to u16 in all functions scsi: megaraid_sas: set pd_after_lb from MR_BuildRaidContext and initialize pDevHandle to MR_DEVHANDLE_INVALID scsi: megaraid_sas: latest controller OCR capability from FW before sending shutdown DCMD ...
2017-02-06scsi: remove eh_timed_out methods in the transport templateChristoph Hellwig
Instead define the timeout behavior purely based on the host_template eh_timed_out method and wire up the existing transport implementations in the host templates. This also clears up the confusion that the transport template method overrides the host template one, so some drivers have to re-override the transport template one. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-01-05scsi: fnic: Avoid sending reset to firmware when another reset is in progressSatish Kharat
This fix is to avoid calling fnic_fw_reset_handler through fnic_host_reset when a finc reset is alreay in progress. Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-16scsi: fnic: Correcting rport check location in fnic_queuecommand_lckSatish Kharat
Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Reviewed-by: Tomas Henzl <thenzl@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: fnic: use kernel's '%pM' format option to print MACAndy Shevchenko
Instead of supplying each byte through stack let's use %pM specifier. Cc: Hiral Patel <hiralpat@cisco.com> Cc: Suma Ramars <sramars@cisco.com> Acked-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: libfc: Replace ->lport_reset callback with function callHannes Reinecke
The ->lport_reset callback only ever had one implementation, which already is exported. So remove it and use the function directly. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-11-08scsi: fnic: Use time64_t to represent trace timestampsDeepa Dinamani
Trace timestamps use struct timespec and CURRENT_TIME which are not y2038 safe. These timestamps are only part of the trace log on the machine and are not shared with the fnic. Replace then with y2038 safe struct timespec64 and ktime_get_real_ts64(), respectively. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Cc: Hiral Patel <hiralpat@cisco.com> Cc: Suma Ramars <sramars@cisco.com> Cc: Brian Uchino <buchino@cisco.com> Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: linux-scsi@vger.kernel.org Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-20fnic: pci_dma_mapping_error() doesn't return an error codeDan Carpenter
pci_dma_mapping_error() returns true on error and false on success. Fixes: fd6ddfa4c1dd ('fnic: check pci_map_single() return value') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-13fcoe: use enum for fip_modeHannes Reinecke
The FIP mode is independent on the FIP state machine, so use a separate enum for that instead of overloading it with state machine values. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-13fc_fip: Update to latest FC-BB-6 draftHannes Reinecke
Update to latest FC-BB-6 draft to include FIP VN2VN VLAN notifications and additional flags. Signed-off-by: Hannes Reinecke <hare@suse.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11fnic: Using rport->dd_data to check rport online instead of rport_lookup.Satish Kharat
When issuing I/O we check if rport is online through libfc rport_lookup() function which needs to be protected by mutex lock that cannot acquired in I/O context. The change is to use midlayer remote port s dd_data which is preserved until its devloss timeout and no protection is required. The the scsi_cmnd error code is expected to be in the left 16 bits of the result field. Changed to correct this. Fnic driver version changed from 1.6.0.20 to 1.6.0.21 Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11fnic: Cleanup the I/O pending with fw and has timed out and is used to issue ↵Satish Kharat
LUN reset In case of LUN reset, the device reset command is issued with one of the I/Os that has timed out on that LUN. The change is to also return this I/O with error status set to DID_RESET. In case when the reset is issued using the sg_reset tool (from sg3_utils) it is a new command and new_sc is set to 1. Fnic driver version changed from 1.6.0.19 to 1.6.0.20 [mkp: Fixed checkpatch warning] Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Reviewed-by: Ewan Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-04-11fnic: Fix to cleanup aborted IO to avoid device being offlined by mid-layerSatish Kharat
If an I/O times out and an abort issued by host, if the abort is successful we need to set scsi status as DID_ABORT. Or else the mid-layer error handler which looks for this error code, will offline the device. Also if the original I/O is not found in fnic firmware, we will consider the abort as successful. The start_time assignment is moved because of the new goto. Fnic driver version changed from 1.6.0.17a to 1.6.0.19, version 1.6.0.18 has been skipped [mkp: Fixed checkpatch warning] Signed-off-by: Satish Kharat <satishkh@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-03-18fnic: move printk()s outside of the critical code section.Maurizio Lombardi
This patch moves a printk() outside of the code section where interrupt are disabled. In some cases a flood of error messages may cause a kernel panic. It also removes one of the printk()s because the same error message was printed twice. [709686.317197] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 12 [709686.317200] CPU: 12 PID: 1963 Comm: systemd-journal Tainted: GF O-------------- 3.10.0-229.el7.x86_64 #1 [709686.317201] Hardware name: Cisco Systems Inc UCSB-B200-M3/UCSB-B200-M3, BIOS B200M3.2.2.3.6.030620151309 03/06/2015 [709686.317206] ffffffff8182b2e8 00000000392722ba ffff88046fcc5c48 ffffffff81603f36 [709686.317209] ffff88046fcc5cc8 ffffffff815fd7da 0000000000000010 ffff88046fcc5cd8 [709686.317211] ffff88046fcc5c78 00000000392722ba ffff88046fcc5c88 000000000000000c [709686.317212] Call Trace: [709686.317221] <NMI> [<ffffffff81603f36>] dump_stack+0x19/0x1b [709686.317223] [<ffffffff815fd7da>] panic+0xd8/0x1e7 [709686.317227] [<ffffffff8110a760>] ? watchdog_enable_all_cpus.part.2+0x40/0x40 [709686.317229] [<ffffffff8110a822>] watchdog_overflow_callback+0xc2/0xd0 [709686.317233] [<ffffffff8114c901>] __perf_event_overflow+0xa1/0x250 [709686.317235] [<ffffffff8114d404>] perf_event_overflow+0x14/0x20 [709686.317239] [<ffffffff810301fd>] intel_pmu_handle_irq+0x1fd/0x410 [709686.317242] [<ffffffff811908d1>] ? unmap_kernel_range_noflush+0x11/0x20 [709686.317246] [<ffffffff81373574>] ? ghes_copy_tofrom_phys+0x124/0x210 [709686.317249] [<ffffffff8160cfcb>] perf_event_nmi_handler+0x2b/0x50 [709686.317251] [<ffffffff8160c719>] nmi_handle.isra.0+0x69/0xb0 [709686.317252] [<ffffffff8160c830>] do_nmi+0xd0/0x340 [709686.317256] [<ffffffff8160bb71>] end_repeat_nmi+0x1e/0x2e [709686.317260] [<ffffffff812e24fd>] ? memcpy+0xd/0x110 [709686.317263] [<ffffffff812e24fd>] ? memcpy+0xd/0x110 [709686.317265] [<ffffffff812e24fd>] ? memcpy+0xd/0x110 [709686.317269] <<EOE>> [<ffffffff8132c297>] ? vgacon_scroll+0x2d7/0x330 [709686.317273] [<ffffffff813a086c>] scrup+0xfc/0x110 [709686.317275] [<ffffffff813a0920>] lf+0xa0/0xb0 [709686.317278] [<ffffffff813a1b32>] vt_console_print+0x2d2/0x420 [709686.317283] [<ffffffff8106f4a1>] call_console_drivers.constprop.15+0x91/0xf0 [709686.317287] [<ffffffff8107069f>] console_unlock+0x3bf/0x400 [709686.317291] [<ffffffff81070996>] vprintk_emit+0x2b6/0x530 [709686.317294] [<ffffffff815fd961>] printk_emit+0x44/0x5b [709686.317297] [<ffffffff81070d98>] devkmsg_writev+0x158/0x1d0 [709686.317303] [<ffffffff811c5ef9>] do_sync_readv_writev+0x79/0xd0 [709686.317307] [<ffffffff811c73ee>] do_readv_writev+0xce/0x260 [709686.317310] [<ffffffff811c8d18>] ? __sb_start_write+0x58/0x110 [709686.317314] [<ffffffff811c7615>] vfs_writev+0x35/0x60 [709686.317318] [<ffffffff811c776c>] SyS_writev+0x5c/0xd0 [709686.317322] [<ffffffff81613da9>] system_call_fastpath+0x16/0x1b Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Reviewed-by: Laurence Oberman <loberman@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2015-11-09scsi: use host wide tags by defaultChristoph Hellwig
This patch changes the !blk-mq path to the same defaults as the blk-mq I/O path by always enabling block tagging, and always using host wide tags. We've had blk-mq available for a few releases so bugs with this mode should have been ironed out, and this ensures we get better coverage of over tagging setup over different configs. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-10-27fnic: check pci_map_single() return valueMaurizio Lombardi
the kernel prints some warnings when compiled with CONFIG_DMA_API_DEBUG. This is because the fnic driver doesn't check the return value of pci_map_single(). [ 11.942770] scsi host12: fnic [ 11.950811] ------------[ cut here ]------------ [ 11.950818] WARNING: at lib/dma-debug.c:937 check_unmap+0x47b/0x920() [ 11.950821] fnic 0000:0c:00.0: DMA-API: device driver failed to check map error[device address=0x0000002020a30040] [size=44 bytes] [mapped as single] Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed By: Tomas Henzl <thenzl@redhat.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-18fnic: Use the local variable instead of I/O flag to acquire io_req_lock in ↵Hiral Shah
fnic_queuecommand() to avoid deadloack We added changes in fnic driver patch 1.6.0.16 to acquire io_req_lock in fnic_queuecommand() before issuing I/O so that io completion is serialized. But when releasing the lock we check for the I/O flag and this could be modified if IO abort occurs before I/O completion. In this case we wont release the lock and causes deadlock in some scenerios. Using the local variable to check the IO lock status will resolve the problem. Fixes: 41df7b02db82cf6c14f094757bac3830d10a827f Signed-off-by: Hiral Shah <hishah@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Anil Chintalapati <achintal@cisco.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-06-03x86/mm: Decouple <linux/vmalloc.h> from <asm/io.h>Stephen Rothwell
Nothing in <asm/io.h> uses anything from <linux/vmalloc.h>, so remove it from there and fix up the resulting build problems triggered on x86 {64|32}-bit {def|allmod|allno}configs. The breakages were triggering in places where x86 builds relied on vmalloc() facilities but did not include <linux/vmalloc.h> explicitly and relied on the implicit inclusion via <asm/io.h>. Also add: - <linux/init.h> to <linux/io.h> - <asm/pgtable_types> to <asm/io.h> ... which were two other implicit header file dependencies. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> [ Tidied up the changelog. ] Acked-by: David Miller <davem@davemloft.net> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Colin Cross <ccross@android.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: James E.J. Bottomley <JBottomley@odin.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Kees Cook <keescook@chromium.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Kristen Carlson Accardi <kristen@linux.intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Suma Ramars <sramars@cisco.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-30fnic: IOMMU Fault occurs when IO and abort IO is out of orderAnil Chintalapati (achintal)
When I/O is aborted by mid-layer, fnic FW will complete the I/O before completing the abort task. In some cases abort request is completed before the I/O, which could lead to inconsistent driver and firmware states. In this case firmware reset would clear the inconsistent state. Signed-off-by: Anil Chintalapati <achintal@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Hiral Shah <hishah@cisco.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-12-04scsi: remove ->change_queue_type methodChristoph Hellwig
Since we got rid of ordered tag support in 2010 the prime use case of switching on and off ordered tags has been obsolete. The other function of enabling/disabling tagging entirely has only been correctly implemented by the 53c700 driver and isn't generally useful. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: drop reason argument from ->change_queue_depthChristoph Hellwig
Drop the now unused reason argument from the ->change_queue_depth method. Also add a return value to scsi_adjust_queue_depth, and rename it to scsi_change_queue_depth now that it can be used as the default ->change_queue_depth implementation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-24scsi: avoid ->change_queue_depth indirection for queue full trackingChristoph Hellwig
All drivers use the implementation for ramping the queue up and down, so instead of overloading the change_queue_depth method call the implementation diretly if the driver opts into it by setting the track_queue_depth flag in the host template. Note that a few drivers validated the new queue depth in their change_queue_depth method, but as we never go over the queue depth set during slave_configure or the sysfs file this isn't nessecary and can safely be removed. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Venkatesh Srinivas <venkateshs@google.com>
2014-11-20Fnic: Fnic Driver crashed with NULL pointer referenceHiral Shah
When issuing I/O request, if the I/O completes before returning from fnic_queuecommand(), we may be referencing scsi_cmnd structure that may be freed by interrupt handler. Acquring IO lock would synchronize fnic_queuecommand and interrupt handler. - Increment fnic version from 1.6.0.15 to 1.6.0.16 Signed-off-by: Hiral Shah <hishah@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Anil Chintalapati <achintal@cisco.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20Fnic: For Standalone C series, "sending VLAN request" message seen even if ↵Hiral Shah
the link is down When physical link between standalone C series and switch is down, the fip timer is not turned off and timer expiration will keep sending vlan request. It can be fixed by stopping the fip_timer and it will be restarted automatically when Link is up. - Increment fnic version from 1.6.0.14 to 1.6.0.15 Signed-off-by: Hiral Shah <hishah@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Anil Chintalapati <achintal@cisco.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-20Fnic: Improper resue of exchange IdsHiral Shah
IOs belonging to an rport are aborted with Internal terminate option when rport goes offline. Any new IO issued to the rport during this time can reuse the terminated exchange which will cause inconsistent state of the exchange between local port and remote port. fc_rport_priv is set to RPORT_ST_DELETE before exchanges are aborted by libfc. Not issuing amy more I/O requests when RPORT_ST_DELETE is set, will avoid inconsistent state of the exchange between local port and remote port. - Increment fnic version from 1.6.0.13 to 1.6.0.14 Signed-off-by: Hiral Shah <hishah@cisco.com> Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com> Signed-off-by: Anil Chintalapati <achintal@cisco.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
