path: root/drivers/scsi/hosts.c
2014-11-12scsi: remove ordered_tag host template fieldChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-12scsi: fixup logging messages in scsi_error.cHannes Reinecke
Use the matching scope for logging messages to allow for better command tracing. Signed-off-by: Hannes Reinecke <hare@suse.de> Suggested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-07-25scsi: add support for a blk-mq based I/O path.Christoph Hellwig
This patch adds support for an alternate I/O path in the scsi midlayer which uses the blk-mq infrastructure instead of the legacy request code. Use of blk-mq is fully transparent to drivers, although for now a host template field is provided to opt out of blk-mq usage in case any unforseen incompatibilities arise. In general replacing the legacy request code with blk-mq is a simple and mostly mechanical transformation. The biggest exception is the new code that deals with the fact the I/O submissions in blk-mq must happen from process context, which slightly complicates the I/O completion handler. The second biggest differences is that blk-mq is build around the concept of preallocated requests that also include driver specific data, which in SCSI context means the scsi_cmnd structure. This completely avoids dynamic memory allocations for the fast path through I/O submission. Due the preallocated requests the MQ code path exclusively uses the host-wide shared tag allocator instead of a per-LUN one. This only affects drivers actually using the block layer provided tag allocator instead of their own. Unlike the old path blk-mq always provides a tag, although drivers don't have to use it. For now the blk-mq path is disable by defauly and must be enabled using the "use_blk_mq" module parameter. Once the remaining work in the block layer to make blk-mq more suitable for slow devices is complete I hope to make it the default and eventually even remove the old code path. Based on the earlier scsi-mq prototype by Nicholas Bellinger. Thanks to Bart Van Assche and Robert Elliot for testing, benchmarking and various sugestions and code contributions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Webb Scales <webbnh@hp.com> Acked-by: Jens Axboe <axboe@kernel.dk> Tested-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Robert Elliott <elliott@hp.com>
2014-07-17scsi: use dev_printk variants where possibleHannes Reinecke
Using dev_printk variants prefixes the logging message with the originating device, which makes debugging easier. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-03-15[SCSI] scsi_error: disable eh_deadline if no host_reset_handler is setHannes Reinecke
When the host template doesn't declare an eh_host_reset_handler the eh_deadline mechanism is pointless and will set the device to offline. So disable eh_deadline if no eh_host_reset_handler is present. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] Set the minimum valid value of 'eh_deadline' as 0Ren Mingxin
The former minimum valid value of 'eh_deadline' is 1s, which means the earliest occasion to shorten EH is 1 second later since a command is failed or timed out. But if we want to skip EH steps ASAP, we have to wait until the first EH step is finished. If the duration of the first EH step is long, this waiting time is excruciating. So, it is necessary to accept 0 as the minimum valid value for 'eh_deadline'. According to my test, with Hannes' patchset 'New EH command timeout handler' as well, the minimum IO time is improved from 73s (eh_deadline = 1) to 43s(eh_deadline = 0) when commands are timed out by disabling RSCN and target port. Signed-off-by: Ren Mingxin <renmx@cn.fujitsu.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] improved eh timeout handlerHannes Reinecke
When a command runs into a timeout we need to send an 'ABORT TASK' TMF. This is typically done by the 'eh_abort_handler' LLDD callback. Conceptually, however, this function is a normal SCSI command, so there is no need to enter the error handler. This patch implements a new scsi_abort_command() function which invokes an asynchronous function scsi_eh_abort_handler() to abort the commands via the usual 'eh_abort_handler'. If abort succeeds the command is either retried or terminated, depending on the number of allowed retries. However, 'eh_eflags' records the abort, so if the retry would fail again the command is pushed onto the error handler without trying to abort it (again); it'll be cleared up from SCSI EH. [hare: smatch detected stray switch fixed] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-11-29[SCSI] Disable WRITE SAME for RAID and virtual host adapter driversMartin K. Petersen
Some host adapters do not pass commands through to the target disk directly. Instead they provide an emulated target which may or may not accurately report its capabilities. In some cases the physical device characteristics are reported even when the host adapter is processing commands on the device's behalf. This can lead to adapter firmware hangs or excessive I/O errors. This patch disables WRITE SAME for devices connected to host adapters that provide an emulated target. Driver writers can disable WRITE SAME by setting the no_write_same flag in the host adapter template. [jejb: fix up rejections due to eh_deadline patch] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-10-25[SCSI] Add 'eh_deadline' to limit SCSI EH runtimeHannes Reinecke
This patchs adds an 'eh_deadline' sysfs attribute to the scsi host which limits the overall runtime of the SCSI EH. The 'eh_deadline' value is stored in the now obsolete field 'resetting'. When a command is failed the start time of the EH is stored in 'last_reset'. If the overall runtime of the SCSI EH is longer than last_reset + eh_deadline, the EH is short-circuited and falls through to issue a host reset only. [jejb: add comments in Scsi_Host about new fields] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-20[SCSI] Fix device removal NULL pointer dereferenceBart Van Assche
Use blk_queue_dead() to test whether the queue is dead instead of !sdev. Since scsi_prep_fn() may be invoked concurrently with __scsi_remove_device(), keep the queuedata (sdev) pointer in __scsi_remove_device(). This patch fixes a kernel oops that can be triggered by USB device removal. See also http://www.spinics.net/lists/linux-scsi/msg56254.html. Other changes included in this patch: - Swap the blk_cleanup_queue() and kfree() calls in scsi_host_dev_release() to make that code easier to grasp. - Remove the queue dead check from scsi_run_queue() since the queue state can change anyway at any point in that function where the queue lock is not held. - Remove the queue dead check from the start of scsi_request_fn() since it is redundant with the scsi_device_online() check. Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20[SCSI] properly initialize atomic_tJosh Hunt
Initialize atomic_t scsi_host_next_hn and ioerr_cntas per the guidelines defined in Documentation/atomic_ops.txt Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-05-10[SCSI] fix oops in all legacy host adapters caused by 6f381faJames Bottomley
Commit 6f381fa344911d5a234b13574433cf23036f9467 Author: Lin Ming <ming.m.lin@intel.com> [SCSI] scsi_lib: use correct DMA device in __scsi_alloc_queue Caused a regression where we oops in every legacy mode SCSI host driver because they supply a NULL pointer to scsi_add_host(). Fix this by checking for the NULL in scsi_add_host_with_dma() and changing the DMA device to being the platform_bus in that case (which replicates the original behaviour). Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-10-30[SCSI] Make scsi_free_queue() kill pending SCSI commandsBart Van Assche
Make sure that SCSI device removal via scsi_remove_host() does finish all pending SCSI commands. Currently that's not the case and hence removal of a SCSI host during I/O can cause a deadlock. See also "blkdev_issue_discard() hangs forever if underlying storage device is removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also http://lkml.org/lkml/2011/8/27/6. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: <stable@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devicesKay Sievers
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option, but it keeps the logic around to handle block devices in the old manner as some people like to run new kernel versions on old (pre 2007/2008) distros. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] scsi:hosts.c Fix warning: variable 'rval' set but not usedJustin P. Mattock
The below patch fixes a warning message generated by gcc 4.6.0 CC drivers/scsi/hosts.o drivers/scsi/hosts.c: In function 'scsi_host_alloc': drivers/scsi/hosts.c:328:6: warning: variable 'rval' set but not used Fix this by removing the rval but placing a printk warning where it would have been set. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26PM: Allow SCSI devices to suspend/resume asynchronouslyRafael J. Wysocki
Set power.async_suspend for all SCSI devices, targets and hosts, so that they can be suspended and resumed in parallel with the main suspend/resume thread and possibly with other devices they don't depend on in a known way (i.e. devices which are not their parents or children). The power.async_suspend flag is also set for devices that don't have suspend or resume callbacks, because otherwise they would make the main suspend/resume thread wait for their "asynchronous" children (during suspend) or parents (during resume), effectively negating the possible gains from executing these devices' suspend and resume callbacks asynchronously. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] scsi_lib_dma: fix bug with dma maps on nested scsi objectsJames Bottomley
Some of our virtual SCSI hosts don't have a proper bus parent at the top, which can be a problem for doing DMA on them This patch makes the host device cache a pointer to the physical bus device and provides an extra API for setting it (the normal API picks it up from the parent). This patch also modifies the qla2xxx and lpfc vport logic to use the new DMA host setting API. Acked-By: James Smart <james.smart@emulex.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-11-26[SCSI] fix crash when disconnecting usb storageAlexey Kuznetsov
__scsi_remove_device() in scsi_forget_host() is executed out of scan_mutex and races with scsi_destroy_sdev() <- scsi_sysfs_add_devices() <- scsi_finish_async_scan(). The result is use after free and/or double free, oops. The fix is simple, move scsi_forget_host() under scan_mutex. scsi_forget_host() is just sequence of __scsi_remove_device(). All another calls of __scsi_remove_device() are made under scan_mutex. So that it is safe. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-21fix race that can give duplicate host numberJoe Eykholt
Just once, two fcoe instances got the same host number from scsi_add_host(). Use atomic_t and atomic_inc_return() to get next host number. Subtract 1, so that scsi_host still starts with 0. [jejb: added comment about unusual subtraction] Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] fix /proc memory leak in the SCSI coreAlan Stern
The SCSI core calls scsi_proc_hostdir_add() from within scsi_host_alloc(), but the corresponding scsi_proc_hostdir_rm() routine is called from within scsi_remove_host(). As a result, if a host is allocated and then deallocated without ever being registered, the host's directory in /proc is leaked. This patch (as1181b) fixes this bug in the SCSI core by moving scsi_proc_hostdir_rm() into scsi_host_dev_release(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-03[SCSI] scsi_host_lookup: error returns and NULL pointersJames Smart
This patch cleans up the behavior of scsi_host_lookup(). The original implementation attempted to use the dual role of either returning a pointer value, or a negative error code. User's needed to use IS_ERR() to check the result. Additionally, the IS_ERR() macro never checks for when a NULL pointer was returned, so a NULL pointer actually passes with a success case. Note: scsi_host_get(), used by scsi_host_lookup(), can return a NULL pointer. Talk about a mudhole for the unitiated to step into.... This patch converts scsi_host_lookup() to return either NULL or a valid pointer. The consumers were updated for the change. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Driver Core: add ability for class_find_device to start in middle of listGreg Kroah-Hartman
This mirrors the functionality that driver_find_device has as well. We add a start variable, and all callers of the function are fixed up at the same time. The block layer will be using this new functionality in a follow-on patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-12[SCSI] make struct scsi_{host,target}_type staticAdrian Bunk
Make the needlessly global struct scsi_{host,target}_type static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-15[SCSI] scsi_host regression: fix scsi host leakMike Christie
commit 9c7701088a61cc0cf8a6e1c68d1e74e3cc2ee0b7 Author: Dave Young <hidave.darkstar@gmail.com> Date: Tue Jan 22 14:01:34 2008 +0800 scsi: use class iteration api Isn't a correct replacement for the original hand rolled host lookup. The problem is that class_find_child would get a reference to the host's class device which is never released. Since the host class device holds a reference to the host gendev, the host can never be freed. In 2.6.26 we started using class_find_device, and this function also gets a reference to the device, so we end up with an extra ref and the host will not get released. This patch adds a put_device to balance the class_find_device() get. I kept the scsi_host_get in scsi_host_lookup, because the target layer is using scsi_host_lookup and it looks like it needs the SHOST_DEL check. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] fix SLUB WARN_ONJames Bottomley
We're getting a WARN_ON from SLUB indicating that we're trying to free caches with in-use objects. The root cause is a new dependency in the command/sense free on unchecked_isa_dma. The WARN_ON is caused by drivers which change this in their setup after the command/sense cache is allocated. The fix is to move the allocation of this cache into scsi_add_host() so things like gdth have an opportunity to modify it between alloc and add (but *not* after). The true fix would be to move unchecked_isa_dma into the template and out of the host, so it because a truly read only variable. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] use default attributes for scsi_hostHannes Reinecke
This patch removes the unused sysfs attibute overwriting logic for the scsi host attibutes, and plugs them into the driver core default attribute creation. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] add scsi_host and scsi_target to scsi_busHannes Reinecke
This patch implements scsi_host and scsi_target device types and adds both to the scsi_bus. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-07[SCSI] hosts.c: removed one unneeded shost->active_mode assignmentDenis Cheng
In the following if/else statement, shost->active_mode will always be set, so this assignment is unneeded. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-27[SCSI] hosts.c: fixes for "no error" reported after error scenariosJames Smart
This patch corrects some cases in scsi_add_host() that fail, but the "error" return code was not reset after a prior use which set it to a non-error value. Patch cut against scsi-rc-fixes-2.6 Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-24scsi: use class iteration apiDave Young
Convert to use the class iteration api. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-23[SCSI] don't use __GFP_DMA for sense buffers if not requiredJames Bottomley
Only hosts which actually have ISA DMA requirements need sense buffers coming out of ZONE_DMA, so only use the __GFP_DMA flag for that case to avoid allocating this scarce resource if it's not necessary. [tomo: fixed slab leak in failure case] Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] use dynamically allocated sense bufferFUJITA Tomonori
This removes static array sense_buffer in scsi_cmnd and uses dynamically allocated sense_buffer (with GFP_DMA). The reason for doing this is that some architectures need cacheline aligned buffer for DMA: http://lkml.org/lkml/2007/11/19/2 The problems are that scsi_eh_prep_cmnd puts scsi_cmnd::sense_buffer to sglist and some LLDs directly DMA to scsi_cmnd::sense_buffer. It's necessary to DMA to scsi_cmnd::sense_buffer safely. This patch solves these issues. __scsi_get_command allocates sense_buffer via kmem_cache_alloc and attaches it to a scsi_cmnd so everything just work as before. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] Add Documentation and integrate into docbook buildRob Landley
Add Documentation/DocBook/scsi_midlayer.tmpl, add to Makefile, and update lots of kerneldoc comments in drivers/scsi/*. Updated with comments from Stefan Richter, Stephen M. Cameron, James Bottomley and Randy Dunlap. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-17[SCSI] make supported_mode default to initiator.James Bottomley
if shost->supported mode is zero (i.e. MODE_UNKNOWN) show it as initiator (it's obviously an unconverted driver that won't do target). Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] add supported_mode and active_mode attributes to the hostFUJITA Tomonori
This adds supported_mode and active_mode attributes to /sys/class/sys_host/hostX/ for specifying the mode that a lld supports and the currently activated mode. The output format is similar to fc rport roles: luce:/sys/class/scsi_host/host0$ cat supported_mode Initiator luce:/sys/class/scsi_host/host0$ cat active_mode Initiator The mode values uses bitmap since we would support dual-mode llds in the future like this: luce:/sys/class/scsi_host/host0$ cat supported_mode Initiator, Target The supported_mode attribute looks at a scsi_host_template and the active_mode attribute looks at a scsi_host. We would add a hook to a scsi_host_template to change the active_mode attribute dynamically. But now there is no hook since no lld supports that feature. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-08-01[SCSI] initialize shost_data to zeroFUJITA Tomonori
It's better to initialize host->shost_data to zero like target->starget_data and device->sdev_data. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-27SCSI: use the proper semaphore to protect the class listsGreg Kroah-Hartman
SCSI was using the incorrect lock to protect walking the list of all devices in the class. This patch fixes this. Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
