Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
No need to check use_sg since sg_tablesize is set appropriately in the
scsi host template.
Brian King's patch (2a7309372fe56ae46c499b772d811ad31c501dd9) did this
cleanup but the data buffer accessors patch (written before the patch
and merged after it) restored the check.
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
Cc: Santiago Leon <santil@us.ibm.com>
The viosrp_crq timeout field is in seconds.
Since it is completely possible for scsi core to call
a LLDD's eh_abort function after the command has completed,
fix ibmvscsi to return SUCCESS if this is the case.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Fix a couple locking bugs discovered during code inspection.
ibmvscsi_send_srp_event needs to be called with the host lock
held. This patch fixes a couple paths in the code where this
wasn't true.
Adds an eh_host_reset_handler to ibmvscsi which resets the connection
to the vscsi server. This patch also adds a timer to internally
issues commands to prevent client hangs in the case of a misbehaving
server. Tested by modifying the VIOS such that it would occasionally
drop one or more request in sequence.
Converts ibmvscsi to use dev_printk and friends to simplify
debugging. ibmvscsi adapter initialization now looks like this:
ibmvscsi 30000005: SRP_VERSION: 16.a
ibmvscsi 30000005: partner initialization complete
ibmvscsi 30000005: sent SRP login
ibmvscsi 30000005: SRP_LOGIN succeeded
Additionally, this patch adds the logging of a couple return codes in
a couple logs.
Since sg_tablesize is set appropriately in the scsi host template,
remove the unnecessary check to make sure it is not exceeded
following the dma_map_sg call.
Adds support for a changeable queue depth to ibmvscsi.
Fixed the kernel-doc comment for ibmvscsi_slave_configure. Thanks to
Randy Dunlap for pointing this out.
Adding a slave_configure function for the driver. Now the disks can be
restarted by the scsi mid-layer when the are disconnected and reconnected.
Signed-off-by: "Robert Jennings" <rcj@linux.vnet.ibm.com>
Signed-off-by: "Santiago Leon" <santil@us.ibm.com>
The request limit calculations used previously on the client failed to
mirror the state of the server. Additionally, when a value < 3 was provided
there could be problems setting can_queue and handling abort and reset
commands.
Signed-off-by: Santiago Leon <santil@us.ibm.com>
The "ibmvscsi: treat busy and error conditions separately" patch
submitted by Dave Boutcher back in June incorrectly reenables the CRQ.
The broken logic causes the adapter to get disabled if the CRQ
connection happens to close temporarily. This patch "fixes that
obviously wrong logic check" (Dave's words).
Signed-off-by: David Boutcher <sleddog@us.ibm.com>
This patch fixes a condition where ibmvscsi treats a transport error as a
"busy" condition, so no errors were returned to the scsi mid-layer.
In a RAID environment this means that I/O hung rather than failing
over.
Convert kmalloc + memset to kcalloc in ibmvscsi
Acked-by: Dave Boutcher <sleddog@us.ibm.com>
There is a window where we can be re-enabling an adapter, but
still allow SCSI commands to be sent to the target. This fix
sets our window (request_limit) to -1 as soon as we know the
adapter is being reenabled, and closes a very teeny tiny
window where we could set the window back to 1 before we
grab a lock.
Signed-off-by: Dave Boutcher <sleddog@us.ibm.com>
New versions of the Power5 firmware can send a "re-enable" message to
the virtual scsi adapter. This fix makes us handle the message
correctly. Without it, the driver goes catatonic and the system crashes
unpleasantly.
Just set the name field directly in the device_driver structure
contained in the vio_driver struct.
Linda Xie ever so gently pointed out that she had a patch
to preserve compatibility with older SLES targets, and I told
her we didn't need to push it to mainline.
This patch explicitly checks the version of the IBMVSCSI target
and ensures that large scatterlists are not sent to older
targets.
Signed-off-by: Linda Xie <lxie@us.ibm.com>
Signed-off-by: Dave Boutcher <boutcher@us.ibm.com>
The maximum size of a scatter-gather list that the current IBM VSCSI
Client can handle is 10. This patch adds large scatter-gather support
to the client so that it is capable of handling up to SG_ALL(255)
number of requests in the scatter-gather list.
Acked by: Dave C Boutcher <sleddog@us.ibm.com>
Rejections fixed up and
Make MODULE_DEVICE_TABLE work for vio devices.
This patch fixes a long term borkenness in
ibmvscsi where we were using the wrong timeout
field from the scsi command (and using the
wrong units.) Now broken by the fact that the
scsi_cmnd timeout field is gone entirely.
This only worked before because all the SCSI
targets assumed that 0 was default.
With the removal of the spinlocking around eh calls, we need to add a
little more locking back in, otherwise we do some naked list
manipulation.
Fix the problem in IBM VSCSI Client where the client doesn't send the
information which is expected by the server.
infrastructure for it.
Let it rip!
