Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 or at your option any
later version this program is distributed in the hope that it will
be useful but without any warranty without even the implied warranty
of merchantability or fitness for a particular purpose see the gnu
general public license for more details you should have received a
copy of the gnu general public license along with this program see
the file copying if not write to the free software foundation 675
mass ave cambridge ma 02139 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 52 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154042.342335923@linutronix.de
Most SCSI drivers want to enable "clustering", that is merging of
segments so that they might span more than a single page. Remove the
ENABLE_CLUSTERING define, and require drivers to explicitly set
DISABLE_CLUSTERING to disable this feature.
The driver currently uses pci_set_dma_mask despite otherwise using the
generic DMA API.
The initio driver has for many years had two copies of the
same module device table. One of them is also used for registering
the other driver, the other one is entirely useless after the
large scale cleanup that Alan Cox did back in 2007.
The compiler warns about this whenever the driver is built-in:
drivers/scsi/initio.c:131:29: warning: 'i91u_pci_devices' defined but not used [-Wunused-variable]
This removes the extraneous table and the warning.
Fixes: 72d39fea901 ("[SCSI] initio: Convert into a real Linux driver and update to modern style")
'0' is now used as the default cmd_per_lun value,
so there's no need to explicitly set it to '1' in the
host template.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
It's a NOOP since 2.6.35 and it will be removed one day.
[jejb: remove from missed arm scsi drivers]
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Adam Radford <linuxraid@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
At the point where cmnd is initialized, it is tested for NULL, so it
doesn't have to be tested again here.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
everything
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
- struct scsi_cmnd had a 16 bytes command buffer of its own.
This is an unnecessary duplication and copy of request's
cmd. It is probably left overs from the time that scsi_cmnd
could function without a request attached. So clean that up.
- Once above is done, few places, apart from scsi-ml, needed
adjustments due to changing the data type of scsi_cmnd->cmnd.
- Lots of drivers still use MAX_COMMAND_SIZE. So I have left
that #define but equate it to BLK_MAX_CDB. The way I see it
and is reflected in the patch below is.
MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB
as per the SCSI standard and is not related
to the implementation.
BLK_MAX_CDB. - The allocated space at the request level
- I have audit all ISA drivers and made sure none use ->cmnd in a DMA
Operation. Same audit was done by Andi Kleen.
(*)fixed-length here means commands that their size can be determined
by their opcode and the CDB does not carry a length specifier, (unlike
the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly
true and the SCSI standard also defines extended commands and
vendor specific commands that can be bigger than 16 bytes. The kernel
will support these using the same infrastructure used for VARLEN CDB's.
So in effect MAX_COMMAND_SIZE means the maximum size command
scsi-ml supports without specifying a cmd_len by ULD's
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Most of the cpu_to_le32() usage was wrong in one way or another.
Compiler warning on BE builds was just the tip of the iceberg.
This patch attempts to make this driver work on BE though I
don't have the HW to test it.
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
With the sg table code, every SCSI driver is now either chain capable
or broken (or has sg_tablesize set so chaining is never activated), so
there's no need to have a check in the host template.
Also tidy up the code by moving the scatterlist size defines into the
SCSI includes and permit the last entry of the scatterlist pools not
to be a power of two.
I've verified (on my Initio 9100 with a DAT drive) that the
2.6.24-rc8-git6 initio module still hangs on loading.
These fixes (other than the printk) are needed to get the module to load
ok (and work correctly) with my adapter & tape drive.
a) printk cosmetic fix
b) cblk->sglen needs setting for later DMA I/O routines to use
c) host->bios_addr needs setting for debug output correctness
d) semaph & semaph_lock initialisation had got lost since 2.6.22
e) since 2.6.22 the bios data address was truncated to 16 bits (needs 20
when shifted left)
patch: [SCSI] initio: convert to use the data buffer accessors had a
small but fatal bug in that it didn't increment the pointer into the
initio scatterlist descriptors as it looped over the block generated
ones. Fixed here.
> I have a scanner connected to a Initio INI-950 SCSI card and I recently
> upgraded from SuSE 10.2 to 10.3. The new kernel doesn't see any of my
> devices. I get the following in /var/log/messages:
> ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 17 (level, low) -> IRQ 16
> initio: I/O port range 0x0 is busy.
> ACPI: PCI interrupt for device 0000:00:0a.0 disabled
Humm not a collision - thats a bug in the driver updating. Looks like the
changes I made and combined with Christoph's lost a line somewhere when I
was merging it all.
Fix IRQ reporting - just assign the ->pci_dev pointer earlier and use the
pci_dev irq field rather than keeping a private one
Init the spinlock as it works better on SMP that way
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
This option is true if a low-level driver can support sg
chaining. This will be removed eventually when all the drivers are
converted to support sg chaining. q->max_phys_segments is set to
SCSI_MAX_SG_SEGMENTS if false.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup.
This is a mix of a grand clean up I did and a reworking of the hotplug
support by Christoph. In testing it works as well as the previous code
did (that is -quite badly-) but we can now read it and as it settles in
actually debug the long standing problems it shares with the old driver.
From Christoph:
removal of the BSD license is also fine with me, but should really
get a mention in the changelog aswell.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
WARNING: drivers/scsi/initio.o - Section mismatch: reference to .init.data: from .text between 'i91u_detect' (at offset 0x26e8) and 'i91uSCBPost'
WARNING: drivers/scsi/initio.o - Section mismatch: reference to .init.data:i91u_pci_devices from .text between 'i91u_detect' (at offset 0x26ef) and 'i91uSCBPost'
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of the macro.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask()
and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from
linux/dma-mapping.h.
Signed-off-by: Matthias Gehre <M.Gehre@gmx.de>
turn many #if $undefined_string into #ifdef $undefined_string to fix some
warnings after -Wno-def was added to global CFLAGS
Signed-off-by: Olaf Hering <olh@suse.de>
This patch contains the following cleanups:
- make needlessly global code static
- remove or #if 0 the following unused functions:
- tul_pop_pend_scb
- tul_device_reset
- tul_reset_scsi_bus
infrastructure for it.
Let it rip!
