path: root/drivers/scsi/ipr.c
2010-07-21[SCSI] ipr: fix resource path display and formattingWayne Boyer
It was possible to overflow the buffer used to print out the formatted version of the resource path. The fix is to limit the number of bytes that get formatted. This patch also updates the ipr_show_resource_path function to display the resource address for devices that are attached to adapters that don't support resource paths. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24[SCSI] ipr: improve interrupt service routine performanceWayne Boyer
During performance testing on P7 machines it was observed that the interrupt service routine was doing unnecessary MMIO operations. This patch rearranges the logic of the routine and moves some of the code out of the main routine. The result is that there are now fewer MMIO operations in the performance path of the code. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24[SCSI] ipr: set the data list length in the request control blockWayne Boyer
In bring up testing for the new 64 bit adapters, the first read command failed after loading the driver. The cause was that the command requires more than one scatter gather element and the corresponding code to set the data list length in the request control block was missing. This patch adds the correct assignment. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24[SCSI] ipr: fix a register read to use the correct address for 64 bit adaptersWayne Boyer
Fix ipr_reset_enable_ioa() to read the correct IOA to host interrupt register address for 64 bit adapters. We need to read the lower 32 bits, not the upper 32 bits. Also change the write of the 64 bit mask value to a single writeq instead of two writel calls. Finally, use the correct u8 type for the type field in the ipr_resource_entry structure. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24[SCSI] ipr: include the resource path in the IOA status area structureWayne Boyer
The IOA status area now includes the new resource path field for 64 bit adapters. This patch changes the driver to fix the ioasa structure and to use the correct structure definition based on the type of adatper. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24[SCSI] ipr: implement fixes for 64 bit adapter supportWayne Boyer
Implement some small fixes for 64 bit support that were preventing the adapter from becoming operational. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-17libata: kill ATA_FLAG_DISABLEDTejun Heo
ATA_FLAG_DISABLED is only used by drivers which don't use ->error_handler framework and is largely broken. Its only meaningful function is to make irq handlers skip processing if the flag is set, which is largely useless and even harmful as it makes those ports more likely to cause IRQ storms. Kill ATA_FLAG_DISABLED and makes the callers disable attached devices instead. ata_port_probe() and ata_port_disable() which manipulate the flag are also killed. This simplifies condition check in IRQ handlers. While updating IRQ handlers, remove ap NULL check as libata guarantees consecutive port allocation (unoccupied ports are initialized with dummies) and long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03[SCSI] ipr: adds PCI ID definitions for new adaptersWayne Boyer
This patch adds the PCI ID definitions for new adapters based on the next generation 64 bit IOA PCI interface chip. New entries have been added to the ipr_pci_table[] array for the adapters and to the ipr_chip[] array for the new versions of the chip. Older entries have been removed for cards that did not ship. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: add support for new IOASCsWayne Boyer
This patch adds support for new errors that can be received from adapters using the next generation 64 bit IOA PCI interface chip. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: add support for multiple stages of initializationWayne Boyer
This patch adds support for using the new IOA initialization feedback register. It also enables 64 bit support in the ipr_ioafp_identify_hrrq and ipr_mask_and_clear_interrupts routines. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: implement shutdown changes and remove obsolete write cache parameterWayne Boyer
This patch adds a reboot notifier that will issue a shutdown prepare command to all adapters. This helps to prevent a problem where the primary adapter can get shut down before the secondary adapter and cause the secondary adapter to fail over and log and error. This patch also removes the "enable_cache" paramater as it is obsolete. Write cache for an adapter is now controlled from the iprconfig utility. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: add hardware assisted smart dump functionalityWayne Boyer
This patch adds the hardware assisted smart dump functionality for the next generation IOA PCI interface chip. Signea-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: add error handling updates for the next generation chipWayne Boyer
Add support for the new log data notification and overlay IDs. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: update the configuration table code for the next generation chipWayne Boyer
This patch changes the configuration table structures and related code such that both 32 bit and 64 bit based adapters can work with the driver. This patch also implements the code to generate the virtual bus/id/lun values for devices connected to the new adapters. It also implements support for the new device resource path. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: define new offsets to registers for the next generation chipWayne Boyer
This patch adds the entry to the ipr_chip_cfg array that defines the register offsets for the next generation 64 bit IOA PCI interface chip. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-03-03[SCSI] ipr: add support for new adapter command structures for the next ↵Wayne Boyer
generation chip Change the adapter command structures such that both 32 bit and 64 bit based adapters can work with the driver. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (40 commits) [SCSI] 3w-9xxx fix bug in sgl loading [SCSI] fcoe, libfc: adds enable/disable for fcoe interface [SCSI] libfc: reduce hold time on SCSI host lock [SCSI] libfc: remote port gets stuck in restart state without really restarting [SCSI] pm8001: misc code cleanup [SCSI] pm8001: enable read HBA SAS address from VPD [SCSI] pm8001: do not reset local sata as it will not be found if reset [SCSI] pm8001: bit set pm8001_ha->flags [SCSI] pm8001:fix potential NULL pointer dereference [SCSI] pm8001: set SSC down-spreading only to get less errors on some 6G device. [SCSI] pm8001: fix endian issues with SAS address [SCSI] pm8001: enhance error handle for IO patch [SCSI] pm8001: Fix for sata io circular lock dependency. [SCSI] hpsa: add driver for HP Smart Array controllers. [SCSI] cxgb3i: always use negative errno in case of error [SCSI] bnx2i: minor code cleanup and update driver version [SCSI] bnx2i: Task management ABORT TASK fixes [SCSI] bnx2i: update CQ arming algorith for 5771x chipsets [SCSI] bnx2i: Adjust sq_size module parametr to power of 2 only if a non-zero value is specified [SCSI] bnx2i: Add 5771E device support to bnx2i driver ...
2009-12-15Subject: Re: [PATCH] strstrip incorrectly marked __must_checkKOSAKI Motohiro
Recently, We marked strstrip() as must_check. because it was frequently misused and it should be checked. However, we found one exception. scsi/ipr.c intentionally ignore return value of strstrip. Because it wishes to keep the whitespace at the beginning. Thus we need to keep with and without checked whitespace trim function. This patch adds a new strim() and changes ipr.c to use it. [akpm@linux-foundation.org: coding-style fixes] Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10[SCSI] ipr: fix EEH recoveryKleber Sacilotto de Souza
After commits c82f63e411f1b58427c103bd95af2863b1c96dd1 (PCI: check saved state before restore) and 4b77b0a2ba27d64f58f16d8d4d48d8319dda36ff (PCI: Clear saved_state after the state has been restored) PCI drivers are prevented from restoring the device standard configuration registers twice in a row. These changes introduced a regression on ipr EEH recovery. The ipr device driver saves the PCI state only during the device probe and restores it on ipr_reset_restore_cfg_space() during IOA resets. This behavior is causing the EEH recovery to fail after the second error detected, since the registers are not being restored. One possible solution would be saving the registers after restoring them. The problem with this approach is that while recovering from an EEH error if pci_save_state() results in an EEH error, the adapter/slot will be reset, and end up back in ipr_reset_restore_cfg_space(), but it won't have a valid saved state to restore, so pci_restore_state() will fail. The following patch introduces a workaround for this problem, hacking around the PCI API by setting pdev->state_saved = true before we do the restore. It fixes the EEH regression and prevents that we hit another EEH error during EEH recovery. [jejb: fix is a hack ... Jesse and Rafael will fix properly] Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: stable@kernel.org Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-11-06[SCSI] ipr: add workaround for MSI interrupts on P7Wayne Boyer
This patch adds some additional logic to the interrupt service routine to fix a potential problem where an MSI interrupt does not get cleared the first time. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-21ipr: differentiate pci-x and pci-e based adaptersWayne Boyer
MSI has only been tested on and known to work with PCI-E based adapters. This patch adds a field to struct ipr_chip_t to indicate which type of interrupt to use based on what is known about the chip. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21ipr: add test for MSI interrupt supportWayne Boyer
The return value from pci_enable_msi() can not always be trusted. This patch adds code to generate an interrupt after MSI has been enabled and tests whether or not we can receive and process it. If the tests fails, then fall back to LSI. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] ipr: fix PCI permanent error handlerKleber S. Souza
The ipr driver can hang if it encounters enough PCI errors to trigger the permanent error handler. The driver will attempt to initiate a "bringdown" of the adapter and fail all pending ops back. However, this bringdown is unlike any other bringdown of the adapter in the code as the driver. In this code path we end up failing back ops with allow_cmds still set to 1. This results in some commands, the HCAM commands in particular, getting immediately re-issued to the adapter on the done call, which results in an infinite loop in ipr_fail_all_ops. Fix this by setting allow_cmds to zero in this path. Signed-off-by: Kleber S. Souza <klebers@linux.vnet.ibm.com> [brking@linux.vnet.ibm.com: alternate patch substituted] Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-20[SCSI] ipr: ipr_remove() marked __devexitKleber S. Souza
Marking the ipr clean up function ipr_remove() as __devexit and using __devexit_p() macro in its address reference. Signed-off-by: Kleber Sacilotto de Souza <kleber@linux.vnet.ibm.com> Reported-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] ipr: Fix sleeping function called with interrupts disabledBrian King
The ata_sas_slave_configure was changed such that it now allocates some memory for a drain buffer for ATAPI devices. Fixup the ipr driver such that we no longer make this call with interrupts disabled. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12[SCSI] ipr: Expose debug and fastfail parametersWayne Boyer
Expose the debug and fastfail parameters to /sys/module/ipr/parameters such that they can be enabled/disabled at run time. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] ipr: add message to error tableWayne Boyer
Adds a message to the error table for an error that wasn't previously handled. In some cases the I/O Adapter will detect an error condition and mark a block as "logically bad". Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] ipr: add MSI supportWayne Boyer
Enable MSI if available/supported. Signed-off-by: Wayne Boyer <wayneb@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-16[libata] get-identity ioctl: Fix use of invalid memory pointerJeff Garzik
for SAS drivers. Caught by Ke Wei (and team?) at Marvell. Also, move the ata_scsi_ioctl export to libata-scsi.c, as that seems to be the general trend. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] ipr: fix lockdep warning from ipr_ioa_reset_doneMark Nelson
To fix the following lockdep warning we turn the spin_unlock_irq() into a spin_unlock() and similarly for the corresponding spin_lock_irq(). We can do this because there is no need to enable interrupts in this path (thanks to Bring King for the tip). Badness at kernel/lockdep.c:2193 NIP: c0000000000855d0 LR: c0000000000855b4 CTR: c0000000000482d0 REGS: c00000000fffb8d0 TRAP: 0700 Not tainted (2.6.28-rc5-autokern1) MSR: 8000000000021032 <ME,IR,DR> CR: 28000022 XER: 00000004 TASK = c00000000091fa80[0] 'swapper' THREAD: c000000000a3c000 CPU: 0 GPR00: 0000000000000000 c00000000fffbb50 c000000000a3c2e0 0000000000000001 GPR04: 000000000000a580 c0000000003870d4 0000000000000000 0000000000000001 GPR08: 0000000000000000 c00000000112fdf0 c0000000008ed918 c000000000abcfd0 GPR12: 0000000048000088 c000000000a7f300 0000000000000000 0000000002100000 GPR16: c000000000644bd0 c000000000643390 0000000000000000 00000000003d0c00 GPR20: 00000000028372d8 c0000000007372d8 0000000002837548 c000000000737548 GPR24: c000000000644660 00000000028372d8 000000000000001a c000000076760000 GPR28: 0000000000000004 c0000000004e8450 c0000000009aafb0 c00000000091fa80 NIP [c0000000000855d0] .trace_hardirqs_on_caller+0x10c/0x194 LR [c0000000000855b4] .trace_hardirqs_on_caller+0xf0/0x194 Call Trace: [c00000000fffbb50] [c00000000fffbbe0] 0xc00000000fffbbe0 (unreliable) [c00000000fffbbe0] [c0000000004e8450] ._spin_unlock_irq+0x38/0x5c [c00000000fffbc70] [c0000000003870d4] .ipr_ioa_reset_done+0x204/0x284 [c00000000fffbd10] [c00000000037d234] .ipr_reset_ioa_job+0xc4/0xec [c00000000fffbda0] [c000000000385ce0] .ipr_isr+0x208/0x484 [c00000000fffbe50] [c0000000000aaf3c] .handle_IRQ_event+0x58/0xd4 [c00000000fffbef0] [c0000000000ad978] .handle_fasteoi_irq+0x110/0x1ac [c00000000fffbf90] [c000000000025214] .call_handle_irq+0x1c/0x2c [c000000000a3f9a0] [c00000000000d168] .do_IRQ+0x120/0x210 [c000000000a3fa40] [c000000000004804] hardware_interrupt_entry+0x1c/0x98 --- Exception: 501 at .pseries_dedicated_idle_sleep+0xec/0x1cc LR = .pseries_dedicated_idle_sleep+0xdc/0x1cc [c000000000a3fd30] [c000000000038208] .pseries_dedicated_idle_sleep+0x74/0x1cc (unreliable) [c000000000a3fdd0] [c000000000012134] .cpu_idle+0x114/0x1dc [c000000000a3fe60] [c0000000004ecb18] .rest_init+0x7c/0x94 [c000000000a3fee0] [c000000000700a40] .start_kernel+0x4b8/0x4e0 [c000000000a3ff90] [c000000000008368] .start_here_common+0x1c/0x34 Instruction dump: e92d01b0 80090894 2f800000 41be002c 481ed1d1 60000000 2fa30000 419e0080 e93e8090 80090000 2f800000 409e0070 <0fe00000> 48000068 7fe3fb78 38800001 Signed-off-by: Mark Nelson <markn@au1.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] advansys, arcmsr, ipr, nsp32, qla1280, stex: use pci_ioremap_bar()Arjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/scsi. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: Brian King <brking@us.ibm.com> Cc: Ed Lin <ed.lin@promise.com> Cc: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (21 commits) [SCSI] sd: fix computation of the full size of the device [SCSI] lib: string_get_size(): don't hang on zero; no decimals on exact [SCSI] sun3x_esp: Convert && to || [SCSI] sd: remove command-size switching code [SCSI] 3w-9xxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] 3w-xxxx: remove unnecessary local_irq_save/restore for scsi sg copy API [SCSI] fix netlink kernel-doc [SCSI] sd: Fix handling of NO_SENSE check condition [SCSI] export busy state via q->lld_busy_fn() [SCSI] refactor sdev/starget/shost busy checking [SCSI] mptfusion: Increase scsi-timeouts, similariy to the LSI 4.x driver. [SCSI] aic7xxx: Take the LED out of diagnostic mode on PM resume [SCSI] aic79xx: user visible misuse wrong SI units (not disk size!) [SCSI] ipr: use memory_read_from_buffer() [SCSI] aic79xx: fix shadowed variables [SCSI] aic79xx: fix shadowed variables, add statics [SCSI] aic7xxx: update *_shipped files [SCSI] aic7xxx: update .reg files [SCSI] aic7xxx: introduce "dont_generate_debug_code" keyword in aicasm parser [SCSI] scsi_dh: Initialize path state to be passive when path is not owned ...
2008-10-23[SCSI] ipr: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Brian King <brking@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-20PCI: remove dynids.use_driver_dataMilton Miller
The driver flag dynids.use_driver_data is almost consistently not set, and causes more problems than it solves. It was initially intended as a flag to indicate whether a driver's usage of driver_data had been carefully inspected and was ready for values from userspace. That audit was never done, so most drivers just get a 0 for driver_data when new IDs are added from userspace via sysfs. So remove the flag, allowing drivers to see the data directly (a followon patch validates the passed driver_data value against what the drivers expect). Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-11[SCSI] ipr: Fix HDIO_GET_IDENTITY oops for SATA devicesBrian King
Currently, ipr does not support HDIO_GET_IDENTITY to SATA devices. An oops occurs if userspace attempts to send the command. Since hald issues the command, ensure we fail the ioctl in ipr. This is a temporary solution to the oops. Once the ipr libata EH conversion is upstream, ipr will fully support HDIO_GET_IDENTITY. Tested-by: Milton Miller <miltonm@bga.com> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisionsBrian King
Due to recent device model changes it now no longer tolerates name collisions. This causes a problem for ipr whose "state" attribute collides with an identically named one in the SCSI mid-layer. Rename the ipr driver attribute to be more specific. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17libata: kill ata_noop_dev_select()Tejun Heo
Now that SFF assumptions are separated out from non-SFF reset sequence, port_ops->sff_dev_select() is no longer necessary for non-SFF controllers. Kill ata_noop_dev_select() and ->sff_dev_select initialization from base and other non-SFF port_ops. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: remove check_status from non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->[alt_]check_status(). In fact, no one calls them for non-SFF drivers anymore. Kill them. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: replace tf_read with qc_fill_rtf for non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->tf_read directly. It gets called only via ops->qc_fill_rtf() for non-SFF drivers. This patch directly implements private ops->qc_fill_rtf() for non-SFF controllers and kill ops->tf_read(). This is much cleaner for non-SFF controllers as some of them have to cache SFF register values in private data structure and report the cached values via ops->tf_read(). Also, ops->tf_read() gets nasty for controllers which don't have clear notion of TF registers when operation is not in progress. As this change makes default ops->qc_fill_rtf unnecessary, move ata_sff_qc_fill_rtf() form ata_base_port_ops to ata_sff_port_ops where it belongs. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: add qc_fill_rtf port operationTejun Heo
On command completion, ata_qc_complete() directly called ops->tf_read to fill qc->result_tf. This patch adds ops->qc_fill_rtf to replace hardcoded ops->tf_read usage. ata_sff_qc_fill_rtf() which uses ops->tf_read to fill result_tf is implemented and set in ata_base_port_ops and other ops tables which don't inherit from ata_base_port_ops, so this patch doesn't introduce any behavior change. ops->qc_fill_rtf() is similar to ops->sff_tf_read() but can only be called when a command finishes. As some non-SFF controllers don't have TF registers defined unless they're associated with in-flight commands, this limited operation makes life easier for those drivers and help lifting SFF assumptions from libata core layer. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
