path: root/drivers/scsi/iscsi_tcp.c
2010-05-25[SCSI] iscsi_tcp: remove sk_sleep checkMike Christie
There is no need to call sk_sleep before calling wake_up_interruptible, because the wait_queue_head is now with the socket. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-21Fix networking tree iscsi_tcp.c mis-mergeLinus Torvalds
The removal of the 'waitqueue_active()' test in commit d7d05548a6 ("[SCSI] iscsi_tcp: fix relogin/shutdown hang") got incorrectly resolved by David when he back-merged the main git tree into the networking tree in commit 278554bd65 ("Merge branch 'master' of master.kernel.org:..."). There was a content conflict due to 'sock->sk->sk_sleep' being changed into 'sk_sleep(sock->sk)' in the networking tree, but David didn't pick up the iscsi change from the main tree. Reported-by: James Bottomley <James.Bottomley@suse.de> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits) [SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline [SCSI] aacraid: prohibit access to array container space [SCSI] aacraid: add support for handling ATA pass-through commands. [SCSI] aacraid: expose physical devices for models with newer firmware [SCSI] aacraid: respond automatically to volumes added by config tool [SCSI] fcoe: fix fcoe module ref counting [SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn [SCSI] libfcoe: Fix incorrect MAC address clearing [SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex [SCSI] libfc: Move the port_id into lport [SCSI] fcoe: move link speed checking into its own routine [SCSI] libfc: Remove extra pointer check [SCSI] libfc: Remove unused fc_get_host_port_type [SCSI] fcoe: fixes wrong error exit in fcoe_create [SCSI] libfc: set seq_id for incoming sequence [SCSI] qla2xxx: Updates to ISP82xx support. [SCSI] qla2xxx: Optionally disable target reset. [SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive [SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did. [SCSI] qla2xxx: T10 DIF support added. ...
2010-05-18[SCSI] Merge scsi-misc-2.6 into scsi-rc-fixes-2.6James Bottomley
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11[SCSI] iscsi_tcp: Change iscsi_sw_tcp_conn_restore_callbacks argumentsAvi Kaplan
This patch changes the arguments to iscsi_sw_tcp_conn_restore_callbacks, so that it works like the function to set the callbacks and because in upcoming patches we need a iscsi_conn. Signed-off-by: Avi Kaplan <savik751@gmail.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] iscsi_tcp: fix relogin/shutdown hangMike Christie
When I made this patch: b64e77f70b8c11766e967e3485331a9e6ef01390 it was to solve a problem where we were already on the waitqueue becuase a connection problem/logout caused us to be on there when we were cleaning up the session. If we happen to get on queue for more normal reasons like their just does not happen to be any send space at the same time we are closing the connection we hit a race and get stuck in the wait. We should not check if the waitqueue is active because we could race with the network code. If the network xmit code is just about to enter the prepare to wait when we check for the waitqueue to be active then we will miss each other and the network code will fall into the wait and we will not run wake_up. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03[SCSI] libiscsi: Make iscsi_eh_target_reset start with session resetJayamohan Kallickal
The iscsi_eh_target_reset has been modified to attempt target reset only. If it fails, then iscsi_eh_session_reset will be called. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-17[SCSI] iscsi_tcp: wake xmit thread when killing sessionMike Christie
If the connection is bad, then the xmit thread could end up waiting a long time (up to sendtmeo seconds) in tcp_sendpage. This patch has us set the sk_error and wake up the xmit thread so we can quickly fail. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libiscsi: add warm target reset tmf supportMike Christie
This implements warm target reset tmf support for the scsi-ml target reset callback. Previously we would just drop the session in that callback. This patch will now try a target reset and if that fails drop the session. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] libiscsi: iscsi_session_setup to allow for private spaceJayamohan Kallickal
This patch contains changes that allow iscsi_session_setup to allocate private space for LLD's Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-05[SCSI] iscsi_tcp: add new conn error to indicate tcp conn closedMike Christie
If a target closed the connection, we will detect it in the state_changed or data_ready callout. This adds a new conn error value to use for this problem, so it is not confused with when the initiator throws a conn error and drops the connection. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-05[SCSI] iscsi_tcp: Evaluate socket state in data_ready()Hannes Reinecke
The network core will call the state_change() callback prior to the data_ready() callback, which might cause us to lose a connection state change. So we have to evaluate the socket state at the end of the data_ready() callback, too. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-21iscsi_tcp: propogate EAGAIN from sendpage to libiscsiMike Christie
The net layer might return -EAGAIN because it could not get space/mem within the sock sndtimeo or becuase the tcp/ip connection was down. For the latter we do not want to retry because the conn/session should just be shutdown and restarted. libiscsi knows the state of the session recovery so propogate this error to that layer. It will either do iscsi recovery or have us retry the operation. Right now if we have partially sent a pdu we would always retry the IO xmit slowing down recovery. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] cxgb3i, iser, iscsi_tcp: set target can queueMike Christie
Set target can queue limit to the number of preallocated session tasks we have. This along with the cxgb3i can_queue patch will fix a throughput problem where it could only queue one LU worth of data at a time. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] iscsi_tcp: don't fire conn error if pdu init failsMike Christie
If a command's scsi cmd pdu setup fails then we can just fail the IO to the scsi layer. If a DATA_OUT for a R2T fails then we will want to drop the session, because it means we got a bad request from the target (iscsi protocol error). This patch has us propogate the error upwards so libiscsi_tcp or libiscsi can decide what the best action is to take. It also fixes a bug where we could try to grab the session lock while holding it, because if iscsi_tcp drops the session in the pdu setup callout the session lock is held when setting up the scsi cmd pdu. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi class: remove host no argument from session creation calloutMike Christie
We do not need to have llds set the host no for the session's parent, because we know the session's parent is going to be the host. This removes it from the session creation callback and converts the drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: remove qdepth param from iscsi host allocationMike Christie
The qdepth setting was useful when we needed libiscsi to verify the setting. Now we just need to make sure if older tools passed in zero then we need to set some default. So this patch just has us use the sht->cmd_per_lun or if for LLD does a host per session then we can set it on per host basis. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: have lib create work queue for transmitting IOMike Christie
We were using the shost work queue which ended up being a little akward since all iscsi hosts need a thread for scanning, but only drivers hooked into libiscsi need a workqueue for transmitting. So this patch moves the xmit workqueue to the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn loggingMike Christie
This makes the logging a compile time option and replaces the tcp_debug macro with a iscsi connection one that prints out a driver model id prefix. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi tcp: bidi capablePete Wyckoff
Mark iscsi_tcp as being capable of bidirectional transfers. The bsg interface checks this bit before attempting any bidirectional commands. Signed-off-by: Pete Wyckoff <pw@padd.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi_tcp: support padding offloadMike Christie
cxgb3i does not offload the processing of the header, but it will always process the padding. This patch adds a padding offload flag to detect when the LLD supports this. The patch also modifies the header processing so that we do not try to read/bypass the header dugest in the skb. cxgb3i will not include it with the header like with other offload cards. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] libiscsi: pass opcode into alloc_pdu calloutMike Christie
We do not need to allocate a itt for data_out, so this passes the opcode to the alloc_pdu callout. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: hook iscsi_tcp into new libiscsi_tcp moduleMike Christie
This hooks iscsi_tcp into the libiscsi_tcp module and removes code that is now in libiscsi_tcp. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: add iscsi_tcp prefix to iscsi_tcp functionsMike Christie
Add iscsi_tcp prefix to most functions. Some are not changed becuase they are going to move in the next patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: remove unused r2t handlingMike Christie
libiscsi's iscsi_prep_data_out_pdu now handles what iscsi_tcp's helpers were so we can remove iscsi_tcp's helpers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: convert to new alloc_hdr apiMike Christie
This converts iscsi_tcp to the new api and modifies how it handles r2ts. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] iscsi_tcp: prepare helpers for LLDs that can offload some operationsMike Christie
cxgb3i is unlike qla4xxx and bnx2i in that it does not offload entire scsi commands or iscsi sequences. Instead it only offloads the transfer of a ISCSI DATA_IN pdu's data, the digests and padding. This patch fixes up the iscsi tcp recv path so that it exports its skb recv processing so cxgb3i and other drivers can call them. All they have to do is pass the function the skb with the hdr or data pdu header and this function will do the rest. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-31drivers: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28misc: replace NIP6_FMT with %p6 format specifierHarvey Harrison
The iscsi_ibft.c changes are almost certainly a bugfix as the pointer 'ip' is a u8 *, so they never print the last 8 bytes of the IPv6 address, and the eight bytes they do print have a zero byte with them in each 16-bit word. Other than that, this should cause no difference in functionality. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13[SCSI] iscsi_tcp: return a descriptive error value during connection errorsMike Christie
The segment->done functions return a iscsi error value which gives a lot more info than conn failed, so this patch has us return that value. I also add a new one for xmit failures. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: rename host reset to target resetMike Christie
I had this in my patchset to add target reset support, but it got dropped due to patching conflicts. This initial patch just renames the function and users. We are actually just dropping the session, and so this does not have anything to do with the host exactly. It does for software iscsi because we allocate a host per session, but for cxgb3i this makes no sense. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: Support drivers initiating session removalMike Christie
If the driver knows when hardware is removed like with cxgb3i, bnx2i, qla4xxx and iser then we will want to remove the sessions/devices that are bound to that device before removing the host. cxgb3i and in the future bnx2i will remove the host and that will remove all the sessions on the hba. iser can call iscsi_kill_session when it gets an event that indicates that a hca is removed. And when qla4xxx is hooked in to the lib (it is only hooked into the class right now) it can call iscsi remove host like the partial offload card drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] libiscsi: fix data corruption when target has to resend data-in packetsMike Christie
iscsi_tcp was updating the exp_statsn (exp_statsn acknowledges status and tells the target it is ok to let the resources for a iscsi pdu to be reused) before it got all the data for pdu read into OS buffers. Data corruption was occuring if something happens to a packet and the network layer requests a retransmit, and the initiator has told the target about the udpated exp_statsn ack, then the target may be sending data from a buffer it has reused for a new iscsi pdu. This fixes the problem by having the LLD (iscsi_tcp in this case) just handle the transferring of data, and has libiscsi handle the processing of status (libiscsi completion processing is done after LLD data transfers are complete). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, ib_iser: fix setting of can_queue with old tools.Mike Christie
This patch fixes two bugs that are related. 1. Old tools did not set can_queue/cmds_max. This patch modifies libiscsi so that when we add the host we catch this and set it to the default. 2. iscsi_tcp thought that the scsi command that was passed to the eh functions needed a iscsi_cmd_task allocated for it. It only needed a mgmt task, and now it does not matter since it all comes from the same pool and libiscsi handles this for the drivers. ib_iser had copied iscsi_tcp's code and set can_queue to its max - 1 to handle this. So this patch removes the max -1, and just sets it to the max. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi_tcp: Enable any size commandBoaz Harrosh
Let through upto the largest command of 260 defined by the scsi standard. iscsi core supports this already. Now that the scsi-ml supports it we can start using large commands. [jejb:rejections fixed up] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] Replace __FUNCTION__ with __func__ in iscsi_tcp.Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ (Update diff by Mike Christie) Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iser, tcp: remove recv_lockMike Christie
The recv lock was defined so the iscsi layer could block the recv path from processing IO during recovery. It turns out iser just set a lock to that pointer which was pointless. We now disconnect the transport connection before doing recovery so we do not need the recv lock. For iscsi_tcp we still stop the recv path incase older tools are being used. This patch also has iscsi_itt_to_ctask user grab the session lock and has the caller access the task with the lock or get a ref to it in case the target is broken and sends a tmf success response then sends data or a response for the command that was supposed to be affected bty the tmf. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: Add session initiatorname and ifacename sysfs attrs.Mike Christie
This adds two new attrs used for creating initiator ports and binding sessions to hardware. The session level initiatorname: Since bnx2i does a scsi_host per host device, we need to add the iface initiator port settings on the session, so we can create multiple initiator ports (each with different inames) per device/scsi_host. The current iname reflects that qla4xxx can have one iname per hba, and we are allocating a host per session for software. The iname on the host will remain so we can export and set the hba level qla4xxx setting. The ifacename attr: To bind a session to a some peice of hardware in userspace we maintain some mappings, but during boot or iscsid restart (iscsid contains the user space part of the driver) we need to be able to figure out which of those host mappings abstractions maps to certain sessions. This patch adds a ifacename attr, which userspace can set to id the host side of the endpoint across pivot_roots and iscsid restarts. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi_tcp: hook iscsi_tcp into iscsi_endpoint codeMike Christie
iscsi_tcp creates its ep in userspace using sockets because it is virtual, so we just check if we are sent a ep and fail if we are. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class: user device_for_each_child instead of duplicating ↵Mike Christie
session list Currently we duplicate the list of sessions, because we were using the test for if a session was on the host list to indicate if the session was bound or unbound. We can instead use the target_id and fix up the class so that drivers like bnx2i do not have to manage the target id space. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi_tcp: handle iscsi_cmd_task renameMike Christie
This converts iscsi_tcp to use the iscsi_task name. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi_tcp: convert iscsi_tcp to support merged tasksMike Christie
Convert iscsi_tcp to support merged tasks. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] libiscsi, iscsi_tcp, iser: add session cmds array accessorMike Christie
Currently to get a ctask from the session cmd array, you have to know to use the itt modifier. To make this easier on LLDs and so in the future we can easilly kill the session array and use the host shared map instead, this patch adds a nice wrapper to strip the itt into a session->cmds index and return a ctask. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session/conn_data_size from iscsi_transportMike Christie
This removes the session and conn data_size fields from the iscsi_transport. Just pass in the value like with host allocation. This patch also makes it so the LLD iscsi_conn data is allocated with the iscsi_cls_conn. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: add iscsi host helpersMike Christie
This finishes the host/session unbinding, by adding some helpers to add and remove hosts and the session they manage. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session and host binding in libiscsiMike Christie
bnx2i allocates a host per netdevice but will use libiscsi, so this unbinds the session from the host in that code. This will also be useful for the iser parent device dma settings fixes. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi class, iscsi drivers: remove unused iscsi_transport attrsMike Christie
max_cmd_len and max_conn are not really used. max_cmd_len is always 16 and can be set by the LLD. max_conn is always one since we do not support MCS. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
