This just has iscsi_tcp support ISCSI_PARAM_LOCAL_PORT which
exports the local port being used by the iscsi connection.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
Signed-off-by: Tom Herbert <therbert@google.com>
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Check that the session is setup before accessing its
connection. This fixes a oops where userspace tries
to get the ip address before the session is bound to
a host.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Replace the session lock with two locks, a forward lock and
a backwards lock named frwd_lock and back_lock respectively.
The forward lock protects resources that change while sending a
request to the target, such as cmdsn, queued_cmdsn, and allocating
task from the commands' pool with kfifo_out.
The backward lock protects resources that change while processing
a response or in error path, such as cmdsn_exp, cmdsn_max, and
returning tasks to the commands' pool with kfifo_in.
Under a steady state fast-path situation, that is when one
or more processes/threads submit IO to an iscsi device and
a single kernel upcall (e.g softirq) is dealing with processing
of responses without errors, this patch eliminates the contention
between the queuecommand()/request response/scsi_done() flows
associated with iscsi sessions.
Between the forward and the backward locks exists a strict locking
hierarchy. The mutual exclusion zone protected by the forward lock can
enclose the mutual exclusion zone protected by the backward lock but not
vice versa.
For example, in iscsi_conn_teardown or in iscsi_xmit_data when there is
a failure and __iscsi_put_task is called, the backward lock is taken while
the forward lock is still taken. On the other hand, if in the RX path a nop
is to be sent, for example in iscsi_handle_reject or __iscsi_complete_pdu
than the forward lock is released and the backward lock is taken for the
duration of iscsi_send_nopout, later the backward lock is released and the
forward lock is retaken.
libiscsi_tcp uses two kernel fifos the r2t pool and the r2t queue.
The insertion and deletion from these queues didn't corespond to the
assumption taken by the new forward/backwards session locking paradigm.
That is, in iscsi_tcp_clenup_task which belongs to the RX (backwards)
path, r2t is taken out from r2t queue and inserted to the r2t pool.
In iscsi_tcp_get_curr_r2t which belong to the TX (forward) path, r2t
is also inserted to the r2t pool and another r2t is pulled from r2t
queue.
Only in iscsi_tcp_r2t_rsp which is called in the RX path but can requeue
to the TX path, r2t is taken from the r2t pool and inserted to the r2t
queue.
In order to cope with this situation, two spin locks were added,
pool2queue and queue2pool. The former protects extracting from the
r2t pool and inserting to the r2t queue, and the later protects the
extracing from the r2t queue and inserting to the r2t pool.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[minor fix up to apply cleanly and compile fix]
It seems some iSCSI targets (including the Linux kernel target) close
the TCP connection from the target side immediately after processing a
session logout.
When a TCP FIN comes in right after the iSCSI logout response,
iscsi_sw_sk_state_check sees the local socket as not yet being in
CLOSE_WAIT or CLOSE and logs an error. But the initiator would close
the connection right after processing the logout response anyway, and
the error is confusing to admins who just requested that the session be
shut down.
This adds a check of the session state, and suppresses the error if we
are in the process of logging out.
Signed-off-by: Chris Leech <cleech@redhat.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
This patch has software iscsi use PF_MEMALLOC/__GFP_MEMALLOC
to be able to better support swap over iscsi disks similar to
what was added for nbd.
Signed-off-by: Rob Evers <revers@redhat.com>
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
Name them in a "backward compatible" manner, i.e. reuse or not
are still 1 and 0 respectively. The reuse value of 2 means that
the socket with it will forcibly reuse everyone else's port.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Problem description from Xi Wang:
A large max_r2t could lead to integer overflow in subsequent call to
iscsi_tcp_r2tpool_alloc(), allocating a smaller buffer than expected
and leading to out-of-bounds write.
The module.h header was implicitly present everywhere, so files
with no explicit include of the module infrastructure would build
anyway. We are now removing the implicit include, and so we need
to call out the module.h file that we need explicitly.
The iscsi class currently does not support writable sysfs
attrs for LLD sysfs settings. This patch converts the
iscsi class and driver's host attrs to use the attribute
container sysfs group and the sysfs group's is_visible callout
to be able to support readable or writable sysfs attrs.
iscsi class and driver's session attrs to use the attribute
iscsi class and drivers to use the attribute container
iscsi_sw_tcp_conn_restore_callbacks could have set
the sk_user_data field to NULL then iscsi_sw_tcp_data_ready
could read that and try to access the NULL pointer. This
adds some checks for NULL sk_user_data in the sk
callback functions and it uses the sk_callback_lock to
set/get that sk_user_data field.
This has iscsi_tcp use the iscsi_conn_get_addr_param
libiscsi function. It also drops the use of the libiscsi
session portal buffers, so they can be removed in
the next patches. Instead of copying the values
at bind time we get them during get() time. If we are
not connected userspace will now get -ENOTCONN,
so it knows that connection is disconnected instead
of a possible stale value.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
There is no need to call sk_sleep before calling wake_up_interruptible,
because the wait_queue_head is now with the socket.
The removal of the 'waitqueue_active()' test in commit d7d05548a6
("[SCSI] iscsi_tcp: fix relogin/shutdown hang") got incorrectly resolved
by David when he back-merged the main git tree into the networking tree
in commit 278554bd65 ("Merge branch 'master' of master.kernel.org:...").
There was a content conflict due to 'sock->sk->sk_sleep' being changed
into 'sk_sleep(sock->sk)' in the networking tree, but David didn't pick
up the iscsi change from the main tree.
Reported-by: James Bottomley <James.Bottomley@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits)
[SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline
[SCSI] aacraid: prohibit access to array container space
[SCSI] aacraid: add support for handling ATA pass-through commands.
[SCSI] aacraid: expose physical devices for models with newer firmware
[SCSI] aacraid: respond automatically to volumes added by config tool
[SCSI] fcoe: fix fcoe module ref counting
[SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn
[SCSI] libfcoe: Fix incorrect MAC address clearing
[SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex
[SCSI] libfc: Move the port_id into lport
[SCSI] fcoe: move link speed checking into its own routine
[SCSI] libfc: Remove extra pointer check
[SCSI] libfc: Remove unused fc_get_host_port_type
[SCSI] fcoe: fixes wrong error exit in fcoe_create
[SCSI] libfc: set seq_id for incoming sequence
[SCSI] qla2xxx: Updates to ISP82xx support.
[SCSI] qla2xxx: Optionally disable target reset.
[SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive
[SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did.
[SCSI] qla2xxx: T10 DIF support added.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
This patch changes the arguments to iscsi_sw_tcp_conn_restore_callbacks,
so that it works like the function to set the callbacks and because
in upcoming patches we need a iscsi_conn.
Signed-off-by: Avi Kaplan <savik751@gmail.com>
When I made this patch:
b64e77f70b8c11766e967e3485331a9e6ef01390
it was to solve a problem where we were already on the waitqueue
becuase a connection problem/logout caused us to be on there
when we were cleaning up the session. If we happen to get
on queue for more normal reasons like their just does not happen
to be any send space at the same time we are closing the connection
we hit a race and get stuck in the wait.
We should not check if the waitqueue is active
because we could race with the network code. If
the network xmit code is just about to enter the
prepare to wait when we check for the waitqueue to
be active then we will miss each other and the
network code will fall into the wait and we will
not run wake_up.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The iscsi_eh_target_reset has been modified to attempt
target reset only. If it fails, then iscsi_eh_session_reset
will be called.
Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com>
If the connection is bad, then the xmit thread could
end up waiting a long time (up to sendtmeo seconds) in
tcp_sendpage. This patch has us set the sk_error and
wake up the xmit thread so we can quickly fail.
This implements warm target reset tmf support for
the scsi-ml target reset callback. Previously we would
just drop the session in that callback. This patch will
now try a target reset and if that fails drop the session.
This patch contains changes that allow iscsi_session_setup
to allocate private space for LLD's
If a target closed the connection, we will detect it in the
state_changed or data_ready callout. This adds a new conn
error value to use for this problem, so it is not confused
with when the initiator throws a conn error and drops
the connection.
The network core will call the state_change() callback
prior to the data_ready() callback, which might cause
us to lose a connection state change.
So we have to evaluate the socket state at the end
of the data_ready() callback, too.
Signed-off-by: Hannes Reinecke <hare@suse.de>
The net layer might return -EAGAIN because it could not
get space/mem within the sock sndtimeo or becuase the tcp/ip
connection was down. For the latter we do not want to retry
because the conn/session should just be shutdown and restarted.
libiscsi knows the state of the session recovery so propogate
this error to that layer. It will either do iscsi recovery
or have us retry the operation. Right now if we have partially
sent a pdu we would always retry the IO xmit slowing down
recovery.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Set target can queue limit to the number of preallocated
session tasks we have.
This along with the cxgb3i can_queue patch will fix a throughput
problem where it could only queue one LU worth of data at a time.
If a command's scsi cmd pdu setup fails then we can just fail
the IO to the scsi layer. If a DATA_OUT for a R2T fails then
we will want to drop the session, because it means we got a
bad request from the target (iscsi protocol error).
This patch has us propogate the error upwards so libiscsi_tcp
or libiscsi can decide what the best action is to take. It
also fixes a bug where we could try to grab the session lock
while holding it, because if iscsi_tcp drops the session in the
pdu setup callout the session lock is held when setting up the
scsi cmd pdu.
We do not need to have llds set the host no for the session's
parent, because we know the session's parent is going to be
the host. This removes it from the session creation callback
and converts the drivers.
The qdepth setting was useful when we needed libiscsi to verify
the setting. Now we just need to make sure if older tools
passed in zero then we need to set some default.
So this patch just has us use the sht->cmd_per_lun or if
for LLD does a host per session then we can set it on per
host basis.
We were using the shost work queue which ended up being
a little akward since all iscsi hosts need a thread for
scanning, but only drivers hooked into libiscsi need
a workqueue for transmitting. So this patch moves the
xmit workqueue to the lib.
This makes the logging a compile time option and replaces
the tcp_debug macro with a iscsi connection one that prints
out a driver model id prefix.
Mark iscsi_tcp as being capable of bidirectional transfers. The
bsg interface checks this bit before attempting any bidirectional
commands.
Signed-off-by: Pete Wyckoff <pw@padd.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
cxgb3i does not offload the processing of the header,
but it will always process the padding. This patch
adds a padding offload flag to detect when the LLD
supports this.
The patch also modifies the header processing so that
we do not try to read/bypass the header dugest in the
skb. cxgb3i will not include it with the header like
with other offload cards.
We do not need to allocate a itt for data_out, so this
passes the opcode to the alloc_pdu callout.
This hooks iscsi_tcp into the libiscsi_tcp module and removes
code that is now in libiscsi_tcp.
Add iscsi_tcp prefix to most functions. Some are not changed
becuase they are going to move in the next patch.
libiscsi's iscsi_prep_data_out_pdu now handles what
iscsi_tcp's helpers were so we can remove iscsi_tcp's helpers.
This converts iscsi_tcp to the new api and modifies how
it handles r2ts.
cxgb3i is unlike qla4xxx and bnx2i in that it does not offload entire
scsi commands or iscsi sequences. Instead it only offloads the transfer
of a ISCSI DATA_IN pdu's data, the digests and padding. This patch fixes up the
iscsi tcp recv path so that it exports its skb recv processing so
cxgb3i and other drivers can call them. All they have to do is pass
the function the skb with the hdr or data pdu header and this function
will do the rest.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
The iscsi_ibft.c changes are almost certainly a bugfix as the
pointer 'ip' is a u8 *, so they never print the last 8 bytes
of the IPv6 address, and the eight bytes they do print have
a zero byte with them in each 16-bit word.
Other than that, this should cause no difference in functionality.
