For future discovery patches, change rport_create to return a previously
created rport_priv that has the FC_ID as long as it isn't in deleted state.
Signed-off-by: Joe Eykholt <jeykholt@cisco.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The list of remote ports (struct fc_rport_priv) has been
maintained by the discovery module. In preparation for having
lport->tt.rport_create() do a lookup first, maintain the
rports list in the rport module. It will still be protected
by the disc_mutex.
The DNS rport is an exception for until after further patches.
For now, do not add it to the list.
The point-to-point rport will be in the discovery list.
So at shutdown, it doesn't need to be separately logged out.
Don't print large negative decimal numbers for frame pointers in
the debug messages from fc_rport_error(). Just print 0 if its a
frame pointer, and print the error numbers as positive.
When a remote port becomes ready and a LOGO is received before
the READY event is in rport_work waiting on the mutex, the
event is changed to LOGO and the work queued, so both the
calls to rport_work see the LOGO event, and both try to do
the list_del(), causing a crash.
Don't change the event if it is already set.
Don't create a "dummy" remote port to go with fc_rport_priv.
Make the rport truly optional by allocating fc_rport_priv separately
and not requiring a dummy rport to be there if we haven't yet done
fc_remote_port_add().
The fc_rport_libfc_priv remains as a structure attached to the
rport for I/O purposes.
Be sure to hold references on rdata when the lock is dropped in
fc_rport_work().
Remote ports will become READY more than once after
ADISC is implemented in a later patch.
The event callback that has been called "CREATED" will mean "READY".
Rename it now in preparation for those changes.
This is a cleanup without semantic changes to use a switch
statement instead of a series of if-statements in fc_rport_work(),
and to move some declarations up to the top.
Allow a struct fc_rport_priv to have no fc_rport associated with it.
This sets up to remove the need for "rogue" rports.
Add a few fields to fc_rport_priv that are needed before the fc_rport
is created. These are the ids, maxframe_size, classes, and rport pointer.
Remove the macro PRIV_TO_RPORT(). Just use rdata->rport where appropriate.
To take the place of the get_device()/put_device ops that were used to
hold both the rport and rdata, add a reference count to rdata structures
using kref. When kref_get decrements the refcount to zero, a new template
function releasing the rdata should be called. This will take care of
freeing the rdata and releasing the hold on the rport (for now). After
subsequent patches make the rport truly optional, this release function
will simply free the rdata.
Remove the simple inline function fc_rport_set_name(), which becomes
semanticly ambiguous otherwise. The caller will set the port_name and
node_name in the rdata->Ids, which will later be copied to the rport
when it its created.
tt.elsct_send is used by both FCP and by the rport state machine.
After further patches, these two modules will use different
structures for the remote port.
So, change elsct_send to use the FC_ID instead of the fc_rport_priv
as its argument. It currently only uses the FC_ID anyway.
For CT requests the destination FC_ID is still implicitly 0xfffffc.
After further patches the did arg on CT requests will be used to
specify the FC_ID being inquired about for GPN_ID or other queries.
The rport and discovery modules deal with remote ports
before fc_remote_port_add() can be done, because the
full set of rport identifiers is not known at early stages.
In preparation for splitting the fc_rport/fc_rport_priv allocation,
make fc_rport_priv the primary interface for the remote port and
discovery engines.
The FCP / SCSI layers still deal with fc_rport and
fc_rport_libfc_priv, however.
The interface for lport->tt.rport_create() takes a fc_disc_port arg,
which is unnatural for most calls. The only reason for this was
to avoid passing in the local port as an argument, but otherwise
added to complexity.
Simplify by just using lport and fc_rport_identifiers.
While the I/O and LLD interfaces use fc_rport_libfc_priv, the
disc and rport interfaces will use fc_rport_priv, which will
be separately allocated.
Change the disc and rport usage of fc_rport_libfc_priv to fc_rport_priv.
Use #define temporarily to make both names equivalent until a
subsequent patch splits them.
The timer for rport retries wasn't getting canceled, and
would occasionally go off after the module was unloaded.
Add logic to cancel the timer in fc_rport_work().
Since we cancel the timer before deleting the rdata,
it is no longer necessary to do a get_device() for the pending timer.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
fc_rport_logoff drops the rport lock in order to cancel work
that may be pending. This is undesirable as the state can
completely change, and the caller may not expect that the
lock could've been dropped.
If there is work pending, it will acquire the rdata mutex and
so we're protected and can change the event from READY to DELETE.
Queue the work only if there is no event already pending.
There were a couple other cases where the state was set to
DELETE and work queued, even though the state may have already
been DELETE. Fix these using a common function fc_rport_enter_delete().
State RPORT_ST_NONE was intented to be an invalid state (0), never used.
This was a misguided attempt to be sure it was always initialized.
Having an extra state meaning nothing requires switch statements to
have a case covering that state.
State NONE has been used instead to mean the remote port is being deleted.
Changing the name to RPORT_ST_DELETE.
This patch adds the /sys/module/libfc/parameters/debug_logging
file to sysfs as a module parameter. It accepts an integer
bitmask for logging. Currently it supports:
bit
LSB 0 = general libfc debugging
1 = lport debugging
2 = disc debugging
3 = rport debugging
4 = fcp debugging
5 = EM debugging
6 = exch/seq debugging
7 = scsi logging (mostly error handling)
the other bits are not used at this time.
The patch converts all of the libfc source files to use
these new macros and removes the old FC_DBG macro.
This allows fnic to configure number of retries for lport and rport
separately.
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Acked-by: Robert Love <robert.w.love@intel.com>
Fix function declarations:
drivers/scsi/fcoe/fcoe.c:1356:28: warning: non-ANSI function declaration of function 'fcoe_dev_setup'
drivers/scsi/libfc/fc_rport.c:1293:20: warning: non-ANSI function declaration of function 'fc_setup_rport'
drivers/scsi/libfc/fc_rport.c:1302:23: warning: non-ANSI function declaration of function 'fc_destroy_rport'
[jejb: fixed wrong doc in comment noticed during inspection]
When building with a .config generated from 'make allmodconfig'
some build warnings are generated. This patch corrects the warnings,
adds a FC_FID_NONE (= 0) enumeration for FC-IDs and cleans up one
variable naming to meet our variable naming conventions. For example,
fc_lport's should be named "lport," not "lp."
When a delete event is queued for an rport, set state to NONE so that no
other processing is done on the rport as it is being removed.
Rogue ports are currently not tracked on any list. The only reference
to them is through any outstanding exchanges pending on the rogue ports.
If the module is removed while a retry is set on a rogue port
(say a Plogi retry for instance), this retry is not cancelled because there
is no reference to the rogue port in the discovery rports list. Thus the
local port can clean itself up, delete the exchange pool, and then the
rogue port timeout can fire and try to start up another exchange.
This patch tracks the rogue ports in a new list disc->rogue_rports. Creating
a new list instead of using the disc->rports list keeps remote port code
change to a minimum.
1) Whenever a rogue port is created, it is immediately added to the
disc->rogue_rports list.
2) When the rogues port goes to ready, it is removed from the rogue list
and the real remote port is added to the disc->rports list
3) The removal of the rogue from the disc->rogue_rports list is done in
the context of the fc_rport_work() workQ thread in discovery callback.
4) Real rports are removed from the disc->rports list like before. Lookup
is done only in the real rports list. This avoids making large changes
to the remote port code.
5) In fc_disc_stop_rports, the rogues list is traversed in addition to the
real list to stop the rogue ports and issue logoffs on them. This way, rogue
ports get cleaned up when the local port goes away.
6) rogue remote ports are not removed from the list right away, but
removed late in fc_rport_work() context, multiple threads can find the same
remote port in the list and call rport_logoff(). Rport_logoff() only
continues with the logoff if port is not in NONE state, thus preventing
multiple logoffs and multiple list deletions.
7) Since the rport is removed from the disc list at a later stage
(in the disc callback), incoming frames can find the rport even if
rport_logoff() has been called on the rport. When rport_logoff() is called,
the rport state is set to NONE, and we are trying to cancel all exchanges
and retries on that port. While in this state, if an incoming
Plogi/Prli/Logo or other frames match the rport, we should not reply
because the rport is in the NONE state. Just drop the frame, since the
rport will be deleted soon in the disc callback (fc_rport_work)
8) In fc_disc_single(), remove rport lookup and call to fc_disc_del_target.
fc_disc_single() is called from recv_rscn_req() where rport lookup
and rport_logoff is already done.
For instance, if there is a Plogi pending (remote port is in Plogi state),
and the state changes to say NONE (because the port is being logged off),
then when the Plogi resp times out, do not start a retry.
This patch partially reverts an earlier patch (libfc: check for err when
recv and state is incorrect), by moving the state check back to before
checking for error. However, if the state does not match, then there is
an additional check to see if its an error ptr or a real frame before
jumping to err or out respectively.
I got the following warnings on IA64:
drivers/scsi/libfc/fc_lport.c: In function 'fc_lport_recv_flogi_req':
drivers/scsi/libfc/fc_lport.c:788: warning: format '%llx' expects type 'long long unsigned int', but argument 3 has type 'u64'
drivers/scsi/libfc/fc_lport.c:792: warning: format '%llx' expects type 'long long unsigned int', but argument 3 has type 'u64'
scsi/libfc/fc_rport.c: In function 'fc_rport_recv_plogi_req':
/home/fujita/git/linux-2.6/drivers/scsi/libfc/fc_rport.c:968: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64'
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Robert Love <robert.w.love@intel.com>
1) There were a few functions with a strange layout, i.e. all
arguments on the second line, when not necessary.
Where ever possible I moved the return value to the same line
as the function name. However, when the line was too long
to have a single argument on the same line I moved the
return value to above line. For example:
<short return> <function name>(<arg 1>, <arg2>)
and
<very long return value>
<function name>(<arg1>,
<arg2>)
2) Removed one extra whitespace line
3) Fixed two typos
1) Added '()' for function names in kerneldoc comments
2) Changed comment bookends from '**/' to '*/'. The comment on the the
mailing list was that '**/' "is consistently unconventional. Not
wrong, just odd." The Documentation/kernel-doc-nano-HOWTO.txt
states that kerneldoc comment blocks should end with '**/' but most
(if not all) instance I found under drivers/scsi/ were only using
the '*/' so I converted to that style.
3) Removed incorrect linebreaks in kerneldoc comments where found
4) Removed a few unnecessary blank comment lines in kerneldoc comment
blocks
If we've just created an interface and the an rport is
logging in we may have a request on the wire (say PRLI).
If we destroy the interface, we'll go through each rport
on the disc->rports list and set each rport's state to NONE.
Then the lport will reset the EM. The EM reset will send a
CLOSED event to the prli_resp() handler which will notice
that the state != PRLI. In this case it frees the frame
pointer, decrements the refcount and unlocks the rport.
The problem is that there isn't a frame in this case. It's
just a pointer with an embedded error code. The free causes
an Oops.
This patch moves the error checking to be before the state
checking.
This allows any rport ELS to retry on LS_RJT.
The rport error handling would only retry on resource allocation failures
and exchange timeouts. I have a target that will occasionally reject PLOGI
when we do a quick LOGO/PLOGI. When a critical ELS was rejected, libfc would
fail silently leaving the rport in a dead state.
The retry count and delay are managed by fc_rport_error_retry. If the retry
count is exceeded fc_rport_error will be called. When retrying is not the
correct course of action, fc_rport_error can be called directly.
Signed-off-by: Chris Leech <christopher.leech@intel.com>
When a rport goes away, libFC does a plogi which will reset exchanges
at the rport. Clean exchanges at our end, both in transport and libFC.
If transport hooks into exch_mgr_reset, it will call back into
fc_exch_mgr_reset() to clean up libFC exchanges.
fc_exch_mgr structure is private to fc_exch.c. To export exch_mgr_reset to
transport, transport needs access to the exch manager. Change
exch_mgr_reset to use lport param which is the shared structure between
libFC and transport.
Alternatively, fc_exch_mgr definition can be moved to libfc.h so that lport
can be accessed from mp*.
libFC is composed of 4 blocks supported by an exchange manager
and a framing library. The upper 4 layers are fc_lport, fc_disc,
fc_rport and fc_fcp. A LLD that uses libfc could choose to
either use libfc's block, or using the transport template
defined in libfc.h, override one or more blocks with its own
implementation.
The EM (Exchange Manager) manages exhcanges/sequences for all
commands- ELS, CT and FCP.
The framing library frames ELS and CT commands.
The fc_lport block manages the library's representation of the
host's FC enabled ports.
The fc_disc block manages discovery of targets as well as
handling changes that occur in the FC fabric (via. RSCN events).
The fc_rport block manages the library's representation of other
entities in the FC fabric. Currently the library uses this block
for targets, its peer when in point-to-point mode and the
directory server, but can be extended for other entities if
needed.
The fc_fcp block interacts with the scsi-ml and handles all
I/O.
[jejb: added include of delay.h to fix ppc64 compile prob spotted by sfr]
