Current implementation missed setting the duration field. Correct the code
to set the field.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <james.smart@broadcom.com>
The lancer G5 chip family fails the CQ create with 16k page size. The
hardware incorrectly reports it supports large page sizes when it is
actually limited to 4k pages.
A prior patch resolved this for the A0 chip revision only. This patch
excludes all revisions of the G5 asic from using large page sizes. As
knowing the actual chip revision is unnecessary, the now unused definitions
are removed
Reviewed-by: Hannes Reinecke <hare@suse.com>
Fix small formatting and wording nits in Broadcom copyright header
The driver encounters a link event ACQE with a fault code it doesn't
recognize, it logs an "Invalid" fault type and futher treats the unknown
value as a mailbox command failure. First off, there is no "invalid"
value, only values that are unknown. Secondly, the fault code doesn't
indicate status - the rest of the ACQE contains that status so there is
no reason to "fail the commands".
Change the "Invalid" to "Unknown". There is no "invalid" code value.
Separate fault code parsing and message genaration from any mbx handling
status.
In situations when the firmware image in inappropriate for the chip
type, initial validation checks were light, allowing the checks to pass,
thus allowing the firmware to be downloaded. Eventually, after the
download, the chip rejects the firmware but it is logged as a generic
firmware download error.
Revise the initial checks to validate the image vs asic type so that the
correct message is displayed and the download process is avoided.
The patch to enlarge WQ/CQ creation keys off of an adapter response that
indicates support for the larger values. Older adapters return an
incorrect response and are limited in size. Thus the adapters fail the
WQ creation steps.
Augment the WQ sizing checks with a check on the older adapter types and
limit them to the restricted sizes.
Fixes: c176ffa0841c ("scsi: lpfc: Increase CQ and WQ sizes for SCSI")
To reduce latency when initializing WQE content, create templates for the
most common wqes. This reduces the number of operations taken to set the
content. It's not a lot of speed up, but every bit helps.
This patch updates the NVME initiator path.
[mkp: fixed typo]
The driver is very sloppy about the WQE structure passed between routines.
The base struct type is a 64byte wqe. But in many routines they typecast and
access 128byte wqes. There were a couple of cases in the past (corrected
already) where the typecasts were incorrectly done and the 64byte buffer was
accessed as a 128 byte buffer.
Clean this up by properly declaring wqe's as 128byte wqe's and removing the
typecasts. 64byte wqes are considered a subset of the 128byte wqes.
The hardware offload for NVME commands was created when the
FC-NVME standard was setting SGL Descriptor Type to SGL Data
Block Descriptor (0h) and SGL Descriptor Sub Type to Address (0h).
A late change in NVMe-over-Fabrics obsoleted these values, creating
a transport SGL descriptor type with new values to go into these
fields.
For initial hardware support, in order to be compliant to the spec,
use host-supplied cmd IU buffers instead of the adapter generated
values. Later hardware will correct this.
Add a module parameter to override this offload disablement if looking
for lowest latency. This is reasonable as nothing in FC-NVME uses
the SQE SGL values.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
The current driver isn't taking advantage of a performance hint whereby
the initial data buffer descriptor can be placed in the WQE as well as
the SGL.
Add the logic to detect support for the feature and to use it when
supported.
Current code is very explicit in what it allows to be downloaded.
The driver checking prevented G7 firmware download. The driver
checking is unnecessary as the device will validate what it receives.
Revise the firmware download interface checking.
Added a little debug support in case there is still a failure.
Traditional SLI4 required the driver to clear Valid bits on
EQEs and CQEs after consuming them.
The new if_type=6 hardware will cycle the value for what is
valid on each queue itteration. The driver no longer has to
touch the valid bits. This also means all the cpu cache
dirtying and perhaps flush/refill's done by the hardware
in accessing the EQ/CQ elements is eliminated.
The G7 adapter supports 64G link speeds. Add support to the driver.
In addition, a small cleanup to replace the odd bitmap logic with
a switch case.
New if_type=6 adapters support an additional BAR that provides
apertures to allow direct WQE to adapter push support - termed
Direct Packet Push (DPP). WQ creation differs slightly to ask for
a WQ to be DPP-ized. When submitting a WQE to a DPP WQ, it is
submitted to the host memory for the WQ normally, but is also
written by the host cpu directly to a BAR aperture. Write buffer
coalescing in hardware is (hopefully) turned on, enabling single
pci write operation support. The doorbell is thing rung to indicate
the WQE is available and was pushed to the aperture.
This patch:
- Updates the WQ Create commands for the DPP options
- Adds the bar mapping for if_type=6 DPP bar
- Adds the WQE pushing to the DDP aperture received from WQ create
- Adds a new module parameter to disable DPP operation if desired.
Default is enabled.
New hardware supports a SLI-4 interface, but with a new if_type
variant of 6.
If_type=6 has a different PCI BAR map, separate EQ/CQ doorbells,
and some changes in doorbell formats.
Add the changes for the if_type into headers, adapter initialization
and control flows. Add new eq and cq handlers.
Updated Copyright in files updated 11.4.0.7
When using the special option to suppress the response iu, ensure the
adapter fully supports the feature by checking feature flags from the
adapter and validating the support when formatting the WQE.
Revise the NVME PRLI to indicate CONF support.
Increased CQ and WQ sizes for SCSI FCP, matching those used for NVMe
development.
Hardware queues are a fast staging area to push commands into the
adapter. The adapter should drain them extremely quickly. However,
under heavy io load, the host cpu is pushing commands faster than the
drain rate of the adapter causing the driver to resource busy commands.
Enlarge the hardware queue (wq & cq) to support a larger number of queue
entries (4x the prior size) before backpressure. Enlarging the queue
requires larger contiguous buffers (16k) per logical page for the
hardware. This changed calling sequences that were expecting 4K page
sizes that now must pass a parameter with the page sizes. It also
required use of a new version of an adapter command that can vary the
page size values.
Firmware update fails with: status x17 add_status x56 on the final write
If multiple DMA buffers are used for the download, some firmware revs
have difficulty with signatures and crcs split across the dma buffer
boundaries. Resolve by making all writes be a single 4k page in length.
Add Buffer to buffer credit recovery support to the driver. This is a
negotiated feature with the peer that allows for both sides to detect
dropped RRDY's and FC Frames and recover credit.
Administrator intervention is currently required to get good numbers
when switching from running latency tests to IOPS tests.
The configured interrupt coalescing values will greatly effect the
results of these tests. Currently, the driver has a single coalescing
value set by values of the module attribute. This patch changes the
driver to support auto-configuration of the coalescing value based on
the total number of outstanding IOs and average number of CQEs processed
per interrupt for an EQ. Values are checked every 5 seconds.
The driver defaults to the automatic selection. Automatic selection can
be disabled by the new lpfc_auto_imax module_parameter.
Older hardware can only change interrupt coalescing by mailbox
command. Newer hardware supports change via a register. The patch
support both.
Added code to support Cisco MDS loopback diagnostic. The diagnostics run
various loopbacks including one which loops-back frame through the
driver.
Using 2048 byte buffer and onle 128 bytes is needed.
Create nee LFPC_NVMET_DATA_BUF_SIZE define to use for NVMET RQ/MRQs.
The driver with nvme had this routine stubbed.
Right now XRI_ABORTED_CQE is not handled and the FC NVMET
Transport has a new API for the driver.
Missing code path, new NVME abort API
Update ABORT processing for NVMET
There are 3 new FC NVMET Transport API/ template routines for NVMET:
lpfc_nvmet_xmt_fcp_release
This NVMET template callback routine called to release context
associated with an IO This routine is ALWAYS called last, even
if the IO was aborted or completed in error.
lpfc_nvmet_xmt_fcp_abort
This NVMET template callback routine called to abort an exchange that
has an IO in progress
nvmet_fc_rcv_fcp_req
When the lpfc driver receives an ABTS, this NVME FC transport layer
callback routine is called. For this case there are 2 paths thru the
driver: the driver either has an outstanding exchange / context for the
XRI to be aborted or not. If not, a BA_RJT is issued otherwise a BA_ACC
NVMET Driver abort paths:
There are 2 paths for aborting an IO. The first one is we receive an IO and
decide not to process it because of lack of resources. An unsolicated ABTS
is immediately sent back to the initiator as a response.
lpfc_nvmet_unsol_fcp_buffer
lpfc_nvmet_unsol_issue_abort (XMIT_SEQUENCE_WQE)
The second one is we sent the IO up to the NVMET transport layer to
process, and for some reason the NVME Transport layer decided to abort the
IO before it completes all its phases. For this case there are 2 paths
thru the driver:
the driver either has an outstanding TSEND/TRECEIVE/TRSP WQE or no
outstanding WQEs are present for the exchange / context.
if (LPFC_NVMET_IO_INP)
lpfc_nvmet_sol_fcp_issue_abort (ABORT_WQE)
lpfc_nvmet_sol_fcp_abort_cmp
else
lpfc_nvmet_unsol_fcp_issue_abort
lpfc_nvmet_unsol_fcp_abort_cmp
Context flags:
LPFC_NVMET_IOP - his flag signifies an IO is in progress on the exchange.
LPFC_NVMET_XBUSY - this flag indicates the IO completed but the firmware
is still busy with the corresponding exchange. The exchange should not be
reused until after a XRI_ABORTED_CQE is received for that exchange.
LPFC_NVMET_ABORT_OP - this flag signifies an ABORT_WQE was issued on the
exchange.
LPFC_NVMET_CTX_RLS - this flag signifies a context free was requested,
but we are deferring it due to an XBUSY or ABORT in progress.
A ctxlock is added to the context structure that is used whenever these
flags are set/read within the context of an IO.
The LPFC_NVMET_CTX_RLS flag is only set in the defer_relase routine when
the transport has resolved all IO associated with the buffer. The flag is
cleared when the CTX is associated with a new IO.
An exchange can has both an LPFC_NVMET_XBUSY and a LPFC_NVMET_ABORT_OP
condition active simultaneously. Both conditions must complete before the
exchange is freed.
When the abort callback (lpfc_nvmet_xmt_fcp_abort) is envoked:
If there is an outstanding IO, the driver will issue an ABORT_WQE. This
should result in 3 completions for the exchange:
1) IO cmpl with XB bit set
2) Abort WQE cmpl
3) XRI_ABORTED_CQE cmpl
For this scenerio, after completion #1, the NVMET Transport IO rsp
callback is called. After completion #2, no action is taken with respect
to the exchange / context. After completion #3, the exchange context is
free for re-use on another IO.
If there is no outstanding activity on the exchange, the driver will send a
ABTS to the Initiator. Upon completion of this WQE, the exchange / context
is freed for re-use on another IO.
Adding support for Fabric assigned WWPN and WWNN.
Firmware sends first FLOGI to fabric with vendor version changes.
On link up driver gets updated service parameter with FAWWN assigned port
name. Driver sends 2nd FLOGI with updated fawwpn and modifies the
vport->fc_portname in driver.
Note:
Soft wwpn will not be allowed when fawwpn is enabled.
Without apriori understanding of what the define is, the name gives
a very different impression of what it is (a max delay value
for an EQ). Rename the define so it reflects what it is: the number
of EQ IDs that can be set in one instance of the MODIFY_EQ_DELAY
mbx command.
Update copyrights to 2017 for all files touched in this patch set
NVME Target: Receive buffer updates
Allocates buffer pools and configures adapter interfaces to handle
receive buffer (asynchronous FCP CMD ius, first burst data)
from the adapter. Splits by protocol, etc.
NVME Target: Base modifications
This set of patches adds the base modifications for NVME target support
The base modifications consist of:
- Additional module parameters or configuration tuning
- Enablement of configuration mode for NVME target. Ties into the
queueing model put into place by the initiator basemods patches.
- Target-specific buffer pools, dma pools, sgl pools
[mkp: fixed space at end of file]
NVME Initiator: Merge into FC discovery
Adds NVME PRLI support and Nameserver registrations and Queries for NVME
NVME Initiator: Base modifications
This patch adds base modifications for NVME initiator support.
- Formal split of SLI3 rings from SLI-4 WQs (sometimes referred to as
rings as well) as implementation now widely varies between the two.
- Addition of configuration modes:
SCSI initiator only; NVME initiator only; NVME target only; and
SCSI and NVME initiator.
The configuration mode drives overall adapter configuration,
offloads enabled, and resource splits.
NVME support is only available on SLI-4 devices and newer fw.
- Implements the following based on configuration mode:
- Exchange resources are split by protocol; Obviously, if only
1 mode, then no split occurs. Default is 50/50. module attribute
allows tuning.
- Pools and config parameters are separated per-protocol
- Each protocol has it's own set of queues, but share interrupt
vectors.
SCSI:
SLI3 devices have few queues and the original style of queue
allocation remains.
SLI4 devices piggy back on an "io-channel" concept that
eventually needs to merge with scsi-mq/blk-mq support (it is
underway). For now, the paradigm continues as it existed
prior. io channel allocates N msix and N WQs (N=4 default)
and either round robins or uses cpu # modulo N for scheduling.
A bunch of module parameters allow the configuration to be
tuned.
NVME (initiator):
Allocates an msix per cpu (or whatever pci_alloc_irq_vectors
gets)
Allocates a WQ per cpu, and maps the WQs to msix on a WQ #
modulo msix vector count basis.
Module parameters exist to cap/control the config if desired.
- Each protocol has its own buffer and dma pools.
I apologize for the size of the patch.
Correct WQ creation for pagesize
The driver was calculating the adapter command pagesize indicator from
the system pagesize. However, the buffers the driver allocates are only
one size (SLI4_PAGE_SIZE), so no calculation was necessary.
Fix fw download on SLI-4 FC adapters
Driver performs a quick validation of magic numbers in the fw
download image. Driver needed to be updated for more recent
magic numbers.
Synchronize link speed with boot driver
Link speed settings set by the boot driver are reported by the hw.
Driver will attempt to read them, and if set, will respect their
values.
The driver can override the settings with its own if instructed by
user space (via bsg), with the new values being picked up by the
boot driver.
Set driver environment data on adapter
Add MDS Diagnostics Support
Add recovery from adapter parity errors on some SLI4 adapters
Fix Transgression Flag of Optical Element descriptor for RDP on Linux
Signed-off-by: Dick Kennedy <dick.kennedy@avagotech.com>
Signed-off-by: James Smart <james.smart@avagotech.com>
Revise versions to reflect SmartSAN 2.0 support
RDP updated to support additional descriptors:
Credit descriptor
Optical Element Data descriptors for Temperature, Voltage,
Bias current, TX power and TX power.
Optical Product Data descriptor.
Pass cmd iu payloads inline to adapter job structure rather than as
separate dma buffers.
Add logging for misconfigured optics acqe reported by fw.
Reviewed-by: Hannes Reinicke <hare@suse.de>
Use new FDMI speed definitions for 10G, 25G and 40G FCoE.
The driver inadvertainly constrained the id space to 8 bits, when its
a full 16 bits from hw. This resulted in bad id's being written to the
hardware. Resulted in symptoms such as incomplete initialization, no
detection of link events, etc.
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
LCB requests to set Beacon would fail if the beacon was already enabled
internally as the mailbox command used to query the state failes with
an already-set status.
Correct by enhancing the check so we don't fail if if the already set
status comes back.
Also has a little whitespace fixing.
Update copyright to 2015
Signed-off-by: Dick Kennedy <dick.kennedy@emulex.com>
Signed-off-by: James Smart <james.smart@emulex.com>
