path: root/drivers/scsi/megaraid/megaraid_ioctl.h
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-01-13[SCSI] megaraid: fix kernel-docRandy Dunlap
kernel-doc modifications: - change "@param var" notation to @var; - change function/description separator from ':' to '-'; - change var/description separator from '-' to ':'; - fix a few doc. typos; - don't use kernel-doc /** lead-in when the doc. block is not kernel-doc; - use Linux common */ ending comment format instead of **/; - use correct function parameter names; - place function parameters immediately after the function short description; - place kernel-doc immediately before its function or macro; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sumant Patro <sumantp@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-28[SCSI] megaraid_{mm,mbox}: a fix on "kernel unaligned access address" issueJu, Seokmann
There was an issue in the data structure defined by megaraid driver casuing "kernel unaligned access.." messages to be displayed during IOCTL on IA64 platform. The issue has been reported/fixed by Sakurai Hiroomi [sakurai_hiro@soft.fujitsu.com]. Signed-Off By: Seokmann Ju <seokmann.ju@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
