context
_scsih_smart_predicted_fault is called in an interrupt and therefore
must allocate memory using GFP_ATOMIC.
Cc: <stable@kernel.org>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
There was supposed to be a kzalloc() here and the compiler complained
about it.
mpt2sas_scsih.c: In function ‘mpt2sas_scsih_reset_handler’:
mpt2sas_scsih.c:2807:21: warning: ‘fw_event’ may be used uninitialized in this function [-Wuninitialized]
Acked-by: "Nandigama, Nagalakshmi" <Nagalakshmi.Nandigama@lsi.com>
The driver was setting the action to MPI2_CONFIG_ACTION_PAGE_READ_CURRENT,
which only returns active volumes. In order to get info on inactive volumes,
the driver needs to change the action to
MPI2_RAID_PGAD_FORM_GET_NEXT_CONFIGNUM, and traverse each config till the
iocstatus is MPI2_IOCSTATUS_CONFIG_INVALID_PAGE returned.
Added a change in the driver to remove the instance of
sas_device object when the driver returns "1" from the slave_configure callback.
Also fixed code to report the hot spares to the operating system with a /dev/sg
assigned.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Cc: stable@kernel.org
complete while issued during creating a volume
This is due to the slave_configuration routine is getting called when
host reset is active, and config page reads are failing, and driver
attempts to added device with stale config data.
To fix the issue, added error checking in slave_configure to check
for configuration pages failing, and return "1" so the device is
not configured. The config pages are failing if raid volume is
configured while issuing a host reset, thus driver is reading stale
data and proceeding to attempt to add. The fix is to return error
so the volume is not configured.
reset context
This is due to driver reporting a device missing to the OS then the OS sending
a SYNC_CACHE request to driver while the IO queues are locked due to host reset.
To fix the issue, the driver will be waking up the port enable context
immediately when the driver receives the reply message, instead of waiting
on the hot plug worker threads.
sas_device_lock
Fix for dead lock occurring between host_lock and sas_device_lock.
The deadlock is between two spin locks, between the shost->host_lock
and driver ioc->sas_device_lock.
The fix is to rearrange the code in the FW/Driver device removal
handshake so the ioc->sas_device_lock is not occurring when the
shost->host_lock is taken.
[jejb: zero initialise sas_address to fix spurious compiler warning]
removed while host reset is active
The fix is in the driver-firmware handshake device removal code. We
need to read the controller ioc_state to see if controller is OPERATIONAL
prior to sending target reset and OP_REMOVE. Previously it was checking
the flag ioc->shost_recovery flag, which is always set when host reset is
active, thus preventing drives from getting properly deleted.
The fix is to inhibit the warning message in _scsih_get_sas_address
when the MPI2_IOCSTATUS_CONFIG_INVALID_PAGE ioc status is returned.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
New feature Fast Load Support.
(1)Asynchronous SCSI scanning: This will allow the drivers to scan
for devices in parallel while other device drivers are loading at
the same time. This will improve the amount of time it takes for the
OS to load.
(2) Reporting Devices while port enable is active: This feature will
allow devices to be reported to OS immediately while port enable is
active. The previous implementation waits for port enable to complete,
and then report devices. This feature is only enabled on IT firmware
configurations when there are no boot device configured in BIOS Configuration
Utility, else the driver will wait till port enable completes reporting
devices. For IR firmware, this feature is turned off. This feature is to
address large SAS topologies (>100 drives) when the boot OS is using onboard
SATA device, in other words, the boot devices is not
connected to our controller.
(3) Scanning for devices after diagnostic reset completes: A new routine
_scsih_scan_start is added. This will scan the expander pages, IR pages,
and sas device pages, then reporting new devices to SCSI Mid layer. It
seems the driver is not supporting adding devices while diagnostic reset
is active. Apparently this is due to the sanity checks on
ioc->shost_recovery flag throughout the context of kernel work thread FIFO,
and the mpt2sas_fw_work.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (204 commits)
[SCSI] qla4xxx: export address/port of connection (fix udev disk names)
[SCSI] ipr: Fix BUG on adapter dump timeout
[SCSI] megaraid_sas: Fix instance access in megasas_reset_timer
[SCSI] hpsa: change confusing message to be more clear
[SCSI] iscsi class: fix vlan configuration
[SCSI] qla4xxx: fix data alignment and use nl helpers
[SCSI] iscsi class: fix link local mispelling
[SCSI] iscsi class: Replace iscsi_get_next_target_id with IDA
[SCSI] aacraid: use lower snprintf() limit
[SCSI] lpfc 8.3.27: Change driver version to 8.3.27
[SCSI] lpfc 8.3.27: T10 additions for SLI4
[SCSI] lpfc 8.3.27: Fix queue allocation failure recovery
[SCSI] lpfc 8.3.27: Change algorithm for getting physical port name
[SCSI] lpfc 8.3.27: Changed worst case mailbox timeout
[SCSI] lpfc 8.3.27: Miscellanous logic and interface fixes
[SCSI] megaraid_sas: Changelog and version update
[SCSI] megaraid_sas: Add driver workaround for PERC5/1068 kdump kernel panic
[SCSI] megaraid_sas: Add multiple MSI-X vector/multiple reply queue support
[SCSI] megaraid_sas: Add support for MegaRAID 9360/9380 12GB/s controllers
[SCSI] megaraid_sas: Clear FUSION_IN_RESET before enabling interrupts
support of the HBA
Support added for controllers capable of multi reply queues.
The following are the modifications to the driver to support NUMA.
1) Create the new structure adapter_reply_queue to contain the reply queue
info for every msix vector. This object will contain a
reply_post_host_index, reply_post_free for each instance, msix_index, among
other parameters. We will track all the reply queues on a link list called
ioc->reply_queue_list. Each reply queue is aligned with each IRQ, and is
passed to the interrupt via the bus_id parameter.
(2) The driver will figure out the msix_vector_count from the PCIe MSIX
capabilities register instead of the IOC Facts->MaxMSIxVectors. This is
because the firmware is not filling in this field until the driver has
already registered MSIX support.
(3) If the ioc_facts reports that the controller is MSIX compatible in the
capabilities, then the driver will request for multiple irqs. This count
is calculated based on the minimum between the online cpus available and
the ioc->msix_vector_count. This count is reported to firmware in the
ioc_init request.
(4) New routines were added _base_free_irq and _base_request_irq, so
registering and freeing msix vectors were done thru simple function API.
(5) The new routine _base_assign_reply_queues was added to align the msix
indexes across cpus. This will initialize the array called
ioc->cpu_msix_table. This array is looked up on every MPI request so the
MSIxIndex is set appropriately.
(6) A new shost sysfs attribute was added to report the reply_queue_count.
(7) User needs to set the affinity cpu mask, so the interrupts occur on the
same cpu that sent the original request.
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
It was pointed out by 'make versioncheck' that some includes of
linux/version.h are not needed in drivers/scsi/.
This patch removes them.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
mpt2sas_base_detach() call was removed from _scsih_remove() while
doing some code shuffling. Mainly when we work on adding code for
scsih_shutdown(). I have added back mpt2sas_base_detach() which will
get callled from _scsih_remove().
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
entry in MPI message
Issue:
This issue is seen on LSI H/W WarpDrive SSS6200 When filed direct I/O
is tried as volume I/O the scmd field in internal lookup table get
cleared and because of that the retried volume I/O never gets reported
as completed to SML.
Result:
I/O timeout and Error handling thread will kicking off
Fix:
Setting back the scmd in the lookup table before retrying the failed
direct i/o
shutdown call
Driver should not call shutdown call from _scsih_remove otherwise,
The scsi midlayer can be deadlocked when devices are removed from the driver
pci_driver->shutdown handler.
Properly handling of target reset in multi-initiator environment
Clean up in broadcast change handling:
(1) Need to look at the status of each task management request, and retry
the TM when there are failures.
(2) Need quiescence IO so the driver doesn't take on more IO request while
it's in the middle of sending TM request to firmware
(3) Add support to keep track of how many pending broadcast AEN events
are received while the broadcast handling is active, then loop back at
the end of this routine if there were any events received.
Clean up in mpt2sas_scsih_issue_tm routine:
(1) Make sure proper status is returned when host reset fails
(2) Clean up sanity checks near end of routine, insuring all outstanding
IOs were completed.
This feature is to override the default
max_sectors setting at load time, taking max_sectors as an
command line option when loading the driver. The setting is
currently hard-coded in the driver to 8192 sectors (4MB transfers).
If max_sectors is specified at load time, minimum specified
setting will be 64, and the maximum is 8192. The driver will
modify the setting to be on even boundary. If max_sectors is not
specified, the driver will default to 8192.
This patch addresses many endian issues solved by runing sparse with the
option __CHECK_ENDIAN__ turned on.
Ensure that the initial reference tag is passed on to the HBA firmware
for DIF Type 2 devices.
Acked-by: Kashyap Desai <Kashyap.Desai@lsi.com>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
context
Driver was a sending a SEP request during interrupt context which
required to go to sleep.
The fix is to rearrange the code so a fake event
MPT2SAS_TURN_ON_FAULT_LED is fired from interrupt context, then later
during the kernel worker threads processing, the SEP request is issued
to firmware.
This patch has Support for the new solid state device product SSS6200
from LSI and relavent features w.r.t SSS6200.
The major feature added in this driver is supporting Direct-I/O to the
SSS6200 storage.There are some additional changes done to avoid exposing
the RAID member disks to the OS and hiding/exposing drives based on the
OEM Specific Flag in Manufacturing Page10 (this is required to handle
specific changes in the SSS6200 firmware).
Each and every changes are listed below.
1. Hiding IR related messages.
For SSS6200, the driver is modified not to print IR related events.
Even if the debugging is enabled the IR related messages will not be displayed.
In some places if there is a need to display a message related to IR the
string "IR" is replaced with string "DD" and the string "volume" is replaced
with "direct drive". But the function names are not changed hence there are
some places where the reference to volume can be seen if debug level is set.
2. Removed RAID transport support
In Linux the user can retrieve RAID volume information from the sysfs directory.
This support is removed for SSS6200.
3. Direct I/O support.
The driver tries to enable direct I/O when a volume is reported to the driver
by the firmware through IRCC events and the driver does this just before
reporting to the OS, hence all the OS issued I/O can go through direct path
if they can, The first validation is to see whether the manufacturing page10
flag is set to expose all drives always. If that is set, the driver will not
enable direct I/O and displays the message "DDIO" is disabled globally as
drives are exposed. The driver checks whether there is more than one volume
in the controller, if so the direct I/O will be disabled globally for all
volumes in the controller and the message displayed will be "DDIO is disabled
globally as number of drives > 1.
If retrieving number of PD is failed the driver will not enable direct I/O
and displays the message Failure in computing number of drives DDIO disabled.
If memory allocation for RAIDVolumePage0 is failed, the driver will not enable
direct I/O and displays the message Memory allocation failure for
RVPG0 DDIO disabled. If retrieving RAIDVolumePage0 is failed the driver will
not enable direct I/O and displays the message Failure in retrieving
RVPG0 DDIO disabled
If the number of PD in a volume is greater than 8, then the direct I/O will
be disabled.
If any of individual drives handle retrieval is failed then the DD-IO will
be disabled.
If the volume is not RAID0 or if the block size is not 512 then the DD-IO will
be disabled.
If the volume size is greater than 2TB then the DD-IO will be disabled.
If the driver is not able to find a valid stripe exponent using the configured
stripe size then the DD-IO will be disabled
When the DD-IO is enabled the driver will check every I/O request issued to
the storage and checks whether the request is either
READ6/WRITE6/READ10/WRITE10, if it is and if the complete I/O transfer
is within a stripe size then the I/O is redirected to
the drive directly instead of the volume.
On completion of every I/O, if the completion is failure means if the reply
is address reply with a reply frame associated with it, then the type of I/O
will be checked, if the I/O is direct then the I/O will be retried to
the volume once.
Reviewed-by: Eric Moore <eric.moore@lsi.com>
Reviewed-by: Sathya Prakash <sathya.prakash@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The SCSI midlayer stops all command processing when in error handling, which
means there is no chance for command reuse when the abort handler is called.
Acked-by: "Moore, Eric" <Eric.Moore@lsi.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
Simple conversions to drop flush_scheduled_work() usages in
drivers/scsi. More involved ones will be done in separate patches.
* NCR5380, megaraid_sas: cancel_delayed_work() +
flush_scheduled_work() -> cancel_delayed_work_sync().
* mpt2sas_scsih: drop unnecessary flush_scheduled_work().
* arcmsr_hba, ipr, pmcraid: flush the used work explicitly instead of
using flush_scheduled_work().
Issue:
IR shutdown(sending) and IR shutdown(complete) messages not
listed in /var/log/messages when driver is removed.
The driver needs to issue a MPI2_RAID_ACTION_SYSTEM_SHUTDOWN_INITIATED
request when the driver is unloaded so the IR metadata journal is updated.
If this request is not sent, then the volume would need a "check
consistency" issued on the next bootup if the volume was roamed from one
initiator to another. The current driver supports this feature only when the
system is rebooted, however this also need to be supported if the driver is
unloaded
Fix:
To fix this issue, the driver is going
to need to call the _scsih_ir_shutdown prior to reporting
the volumes missing from the OS, hence the device handles
are still present.
completion
False timeout after hard resets, there were two issues which leads
to timeout.
(1) Panic because of invalid memory access in the broadcast asyn
event processing routine due to a race between accessing the scsi command
pointer from broadcast asyn event processing thread and completing
the same scsi command from the interrupt context.
(2) Broadcast asyn event notifcations are not handled due to events
ignored while the broadcast asyn event is activity being processed
from the event process kernel thread.
In addition, changed the ABRT_TASK_SET to ABORT_TASK in the
broadcast async event processing routine. This is less disruptive to other
request that generate Broadcast Asyn Primitives besides target
reset. e.g clear reservations, microcode download,and mode select.
The "internal device reset complete" event is not supported
for older firmware prior to MPI Rev K We added
a check in the driver so the "internal device reset" event is
ignored for older firmware. When ignored, the tm_busy flag doesn't
get set nor cleared. Without this fix, IO queues would be froozen
indefinetly after the "internal device reset" event, as the "complete" event
never sent to clear the flag.
When zoning end devices, the driver is not sending device
removal handshake alogrithm to firmware. This results in controller
firmware not sending sas topology add events the next time the device is
added. The fix is the driver should be doing the device removal handshake
even though the PHYSTATUS_VACANT bit is set in the PhyStatus of the
event data. The current design is avoiding the handshake when the
VACANT bit is set in the phy status.
Changing debug print to correct string.
Fix oops loading driver when there is direct attached
SEP device
The driver set max phys count to the value reported in sas iounit page
zero. However this page doesn't take into account additional virutal
phys. When sas topology event arrives, the phy count is larger than
expected, and the driver accesses memory array beyond the end of
allocated space, then oops. Manufacturing page 8 contains the info
on direct attached phys.
For this fix will making sure that sas topology event is not
processing phys greater than the expected phy count.
change_queue_depth callback API changed
The change_queue_depth callback changed where there is now an additional
parameter called reason, with SCSI_QDEPTH_DEFAULT, SCSI_QDEPTH_QFULL,
and SCSI_QDEPTH_RAMP_UP codes.
remove support for MPI2_EVENT_TASK_SET_FULL
This event is obsoleted, so this processing of this event
needs to be removed from the driver. The controller firmware is going
to handle TASK_SET_FULL, the driver doesn't need to do anything.
Even though we are removing the EVENT handling, the behavour has not
changed between driver versions becuase fimrware will still be handling
queue throttling, and retrying of commands when the target device queues
are full.
Issue : Switch swap doesn't work when device missing delay is enabled.
(1) add support to individually add and remove phys to and from
existing ports. This replaces the routine
_transport_delete_duplicate_port.
(2) _scsih_sas_host_refresh - was modified to change the link rate
from zero to 1.5 GB rate when the firmware reports there is an
attached device with zero link.
(3) add new function mpt2sas_device_remove, this is wrapper function
deletes some redundant code through out driver by combining into one
subrountine
(4) two subroutines were modified so the sas_device, raid_device, and
port lists are traversed once when objects are deleted from the list.
Previously it was looping back each time an object was deleted from the
list.
Create a pool of chain buffers, instead of dedicated per IO:
This enahancment is to address memory allocation failure when asking
for more than 2300 IOs per host. There is just not enough contiquious
DMA physical memory to make one single allocation to hold both message
frames and chain buffers when asking for more than 2300 request. In order
to address this problem we will have to allocate memory for each chain
buffer in a seperate individual memory allocation, placing each chain
element of 128 bytes onto a pool of available chains, which can be
shared amoung all request.
The compiler throws warning messages while compiling without
CONFIG_SCSI_MPT2SAS_LOGGING.
Set proper ifdef for CONFIG_SCSI_MPT2SAS_LOGGING to avoid warnnings.
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
fixes surrounding PCIe enhanced error handling:
(1) We need to reject all request generated internaly inside the driver as well
as request arriving from the scsi mid layer when PCIe EEH is active. The fix is
to add a per adapter flag called pci_error_recovery which is checked thru out
the driver when request are generated.
(2) We don't need to call the pci_driver->remove directly from the PCIe
callbacks becuase its already called from the PCIe EEH code. In its place we are
shutting down the watchdog timer, and flushing back all pending IO.
(3) We need to save and restore the pci state across PCIe EEH handling.
Signed-off-by: Eric Moore <eric.moore@lsi.com>
Adding additional messages to the error escallation callbacks which
displays the wwid, sas address, handle, phy number, enclosure logical id,
and slot. In the same eh callbacks, routines, the printks were converted
to sdev_printks, which displays the bus target mapping. These additional
modifications help better identify the device which is in recovery.
ISSUE DESCRIPTION:
This test case involves creating two RAID1 volumes, then
simultaneiously issue host reset and pull all the drives associated to
the 1st raid volume. The observed behavour is the physical drives are
removed, however the volume remains. The expected behavour is the
volume as well as physical drives should be removed from OS.
FIX:
Add support in the post host reset device scan logic for raid volumes
where the driver will have an additional check for responding raid
volume where the status should be either online, optimal, or degraded.
So for voluemes that have a status of missing or failed, the driver
will mark them for deletion.
Actual problem :
Driver may receiving the top level expander
removal event prior to all the individual PD removal events, hence the
driver is breaking down all the PDs in advanced to the actaul PD UNHIDE
event. Driver sends multiple
Target Resets to the same volume handle for each individual PD removal.
FIX DESCRIPTION:
To fix this issue, the entire PD device handshake protocal has to be
moved to interrupt context so the breakdown occurs immediately after the
actual UNHIDE event arrives. The driver will only issue one Target Reset to
the volume handle, occurring after the FAILED or MISSING volume status
event arrives from interrupt context. For the PD UNHIDE event, the driver
will issue target resets to the PD handles, followed by OP_REMOVE. The
driver will set the "deteleted" flag during interrupt context. A "pd_handle"
bitmask was introduced so the driver has a list of known pds during entire
life of the PD; this replaces the "hidden_raid_component" flag handle in
the sas_device object. Each bit in the bitmask represents a device handle.
The bit in the bitmask would be toggled ON/OFF when the HIDE/UNHIDE
events arrive; also this pd_handle bitmask would bould be refreshed
across host resets.
Here we kept older behavior of sending target reset to volume when there is
a single drive pull, wait for the reply, then send target resets
to the PDs. We kept this behavior so the driver will
behave the same for older versions of firmware.
Add support to display additional debug info for SCSI_IO and
RAID_SCSI_IO_PASSTHROUGH sent from the normal entry queued entry
point, as well as internal generated commands, and IOCTLS. The
additional debug info included the phy number, as well as the
sas address, enclosure logical id, and slot number. This debug info
has to be enabled thru the logging_level command line option, by
default this will not be displayed.
Converting print level from MPT2SAS_DEBUG_FMT to MPT2SAS_INFO_FMT.
Updating MPI header version N.
Removed mpi_history.txt.
Driver should not allow multiple host reset when already host reset is in
progress. It is possible that host reset was sent by scsi mid layer while there was already an host reset active,
either issued via IOCTL interface or internaly, like a config page timeout.
Since there was a host reset active, the driver would return a FAILED response
to the scsi mid layer. The solution is make sure pending host resets will
wait for the active host reset to complete before returning control
back up the call stack.
Adding DIF Type 2 protection support, as well as turning on 32 byte cdb's,
and setting the cdb length for > 16 byte in the SCSI_IO->control parameter.
Signed-off-by: Martin Petersen <martin.petersen@oracle.com>
