path: root/drivers/scsi/mvumi.c
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-08-08scsi: use pci_zalloc_consistentJoe Perches
Remove the now unnecessary memset too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Adam Radford <linuxraid@lsi.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Jayamohan Kallickal <jayamohan.kallickal@emulex.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: Michael Neuffer <mike@i-Connect.Net> Cc: "Stephen M. Cameron" <scameron@beardog.cce.hp.com> Cc: Neela Syam Kolli <megaraidlinux@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-14SCSI: remove unnecessary pci_set_drvdata()Jingoo Han
Since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound), the driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-15[SCSI] mvumi: Use PCI_VENDOR_ID_MARVELL_EXT for 0x1b4bMyron Stowe
With the 0x1b4b vendor ID #define in place, convert hard-coded ID values. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: James Bottomley <James.Bottomley@hansenpartnership.com>
2013-01-03Drivers: scsi: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Adam Radford <linuxraid@lsi.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07[SCSI] mvumi: Add support for Marvell SAS/SATA RAID-on-Chip(ROC) 88RC9580Shun Fu
[jejb: fix up for spelling correction patch] Signed-off-by: Shun Fu <fushun@marvell.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-09-01scsi: fix various printk and comment typosMasanari Iida
Correct spelling typo within drivers/scsi Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-27[SCSI] mvumi: Add Marvell UMI driverJianyun Li
The Marvell Universal Message Interface (UMI) defines a messaging interface between host and Marvell products (Plato, for example). It considers situations of limited system resource and optimized system performance. UMI driver translates host request to message and sends message to FW via UMI, FW receives message and processes it, then sends response to UMI driver. FW generates an interrupt when it needs to send information or response to UMI driver Signed-off-by: Jianyun Li <jyli@marvell.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
