path: root/drivers/scsi/pmcraid.h
2010-12-09[SCSI] pmcraid: disable msix and expand device config entryAnil Ravindranath
Firmware requires a larger configuration entry size than the driver currently allows, and MSI-X pretty much doesn't work with current FW, so disable it for now. Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-29[SCSI] pmcraid: add support for set timestamp command and other fixesAnil Ravindranath
The following are the fixes in this patch: 1. Added support of set timestamp command in the driver 2. Pass all status code to mgmt application. Earlier we were passing only failed ones. 3. Call class_destroy after unregister_chrdev and pci_unregister_driver Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-26[SCSI] pmcraid: remove duplicate struct memberAnil Ravindranath
sense_buffer is both a direct member of struct pmcraid_cmd as well as an indirect one via an anonymous union and struct. Fix this clash by eliminating the direct member in favour of the anonymous struct/union one. The name duplication apparently isn't noticed by gcc versions earlier than 4.4 Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] pmcraid: MSI-X support and other changesAnil Ravindranath
1. MSI-X interrupt support 2. Driver changes to support new maxRAID controller FW version. The changes are mainly done to handle async notification changes done in newer controller FW version. 3. Added state change notifications to notify applications of controller states. Signed-off-by: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-10[SCSI] pmcraid: support SMI-S object model of storage poolAnil Ravindranath
PMC-Sierra mgmt application uses SMI-S model. According to SMI-S, the object model exposed by the SMI-S provider should show an StoragePool which contains member disks of a RAID Virtual disk and StorageVolume based on the StoragePool. But according to SMI-S, there is a possibility where StoragePool is created but StorageVolume is not yet created. To satisfy this scenario, we are trying a hidden RAID Virtual disk. The hidden RAID virtual disk will not be exposed to OS. Once a StorageVolume is created for this RAID virtual disk it is exposed. Signed-off-by: Anil Ravindranath<anil_ravindranath@pmc-sierra.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-26headers: kref.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from kref.h -- not needed, linux/types.h is enough for atomic_t * remove linux/kref.h inclusion from files which do not need it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12[SCSI] pmcraid: PMC-Sierra MaxRAID driver to support 6Gb/s SAS RAID controllerAnil Ravindranath
