path: root/drivers/scsi/ps3rom.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16ps3rom: Use ps3_system_bus_[gs]et_drvdata() instead of direct accessGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-16powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/scsiStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-04-07[SCSI] ps3rom: use scsi_build_sense_bufferFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] ps3rom: use sg buffer copy helper funcitonsFUJITA Tomonori
Note that if scsi_bufflen(cmd) is not zero, the command always has an sg list. So this patch doesn't do the error checking in fill_from_dev_buffer and fetch_to_dev_buffer did. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Looks-OK-to: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] ps3rom: Simplify fill_from_dev_buffer()Geert Uytterhoeven
As we no longer need to calculate the data length of the whole scatterlist, we can abort the loop earlier and coalesce req_len and act_len into one variable, making fill_from_dev_buffer() more similar to fetch_to_dev_buffer(). Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] ps3rom: disable clusteringFUJITA Tomonori
ps3rom does: scsi_for_each_sg(cmd, sgpnt, scsi_sg_count(cmd), k) { kaddr = kmap_atomic(sg_page(sgpnt), KM_IRQ0); We cannot do something like that with the clustering enabled (or we can use scsi_kmap_atomic_sg). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] ps3rom: fix wrong resid calculation bugFUJITA Tomonori
sg driver rounds up the length in struct scatterlist to be a multiple of 512 in some conditions. So LLDs can't use the data length in a sg list to calculate residual. Instead, the length in struct scsi_cmnd should be used. [Geert: the variable buflen already contains scsi_bufflen(cmd)] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] ps3rom: sector size should be 512 bytesAegis Lin
It should be desired that 64 KiB is available for ATAPI transferrring. (Historically) in SCSI/block layer sector size is defined as 512 during sector-byte calculation. Originally in ps3rom.c CD_FRAMESIZE (2048) was used, which limited /sys/block/sr0/queue/max_sectors_kb to 16 KiB (32 sectors). Signed-off-by: Aegis Lin <aegislin@gmail.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-23powerpc: Fix fallout from sg_page() changesOlof Johansson
Fix fallout from 18dabf473e15850c0dbc8ff13ac1e2806d542c15: In file included from include/linux/dma-mapping.h:52, from drivers/base/dma-mapping.c:10: include/asm/dma-mapping.h: In function 'dma_map_sg': include/asm/dma-mapping.h:288: error: 'struct scatterlist' has no member named 'page' include/asm/dma-mapping.h:288: error: 'struct scatterlist' has no member named 'page' include/asm/dma-mapping.h:288: error: 'struct scatterlist' has no member named 'page' include/asm/dma-mapping.h:289: error: 'struct scatterlist' has no member named 'page' include/asm/dma-mapping.h:290: error: 'struct scatterlist' has no member named 'page' include/asm/dma-mapping.h: In function 'dma_sync_sg_for_cpu': include/asm/dma-mapping.h:331: error: 'struct scatterlist' has no member named 'page' drivers/scsi/ps3rom.c: In function 'fetch_to_dev_buffer': drivers/scsi/ps3rom.c:150: error: 'struct scatterlist' has no member named 'page' Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-12[SCSI] ps3rom: convert to use the data buffer accessorsFUJITA Tomonori
This converts ps3rom driver to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-21ps3: BD/DVD/CD-ROM Storage DriverGeert Uytterhoeven
Add a BD/DVD/CD-ROM Storage Driver for the PS3: - Implemented as a SCSI device driver - Uses software scatter-gather with a 64 KiB bounce buffer as the hypervisor doesn't support scatter-gather Cc: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
