path: root/drivers/scsi/qla1280.c
2008-05-23scsi: fix integer as NULL pointer warningHarvey Harrison
drivers/scsi/aha152x.c:3585:60: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:3845:56: warning: Using plain integer as NULL pointer drivers/scsi/qla1280.c:2814:37: warning: Using plain integer as NULL pointer drivers/scsi/atp870u.c:750:47: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1281:36: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1293:36: warning: Using plain integer as NULL pointer drivers/scsi/3w-9xxx.c:1301:35: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:447:10: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:457:10: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:479:24: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:483:22: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:1213:23: warning: Using plain integer as NULL pointer drivers/scsi/hptiop.c:1214:23: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13[SCSI] qla1280: Fix queue depth problemJeremy Higdon
The qla1280 driver was ANDing the output value of mailbox register 0 with (1 << target-number) to determine whether to enable queueing on the target in question. But mailbox register 0 has the status code for the mailbox command (in this case, Set Target Parameters). Potential values are: /* * ISP mailbox command complete status codes */ So clearly that is in error. I can't think what the author of that line was looking for in a mailbox register, so I just eliminated the AND. flag is used later in the function, and I think that the later usage was also wrong, though it was used to set values that aren't used. Oh well, an overhaul of this driver is not what I want to do now -- just a bugfix. After the fix, I found that my disks were getting a queue depth of 255, which is far too many. Most SCSI disks are limited to 32 or 64. In any case, there's no point, queueing up a bunch of commands to the adapter that will just result in queue full or starve other targets from being issued commands due to running out of internal memory. So I dropped default queue depth to 32 (from which 1 is subtracted elsewhere, giving net of 31). I tested with a Seagate ST336753LC, and results look good, so I'm satisfied with this patch. Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Acked-by: Jes Sorensen <jes@sgi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-17[SCSI] qla1280: remove version checkAdrian Bunk
There's no point for an in-kernel driver to check whether it's compiled under kernel < 2.6.0 . Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-09[SCSI] qla1280: fix 32 bit segment codeFUJITA Tomonori
There's an error remaining in the 32 bit descriptor code after the conversion to dma accessors: req_cnt is left uninitialised. qla1280_32bit_start_scsi gives the following warnings: drivers/scsi/qla1280.c: In function 'qla1280_32bit_start_scsi': drivers/scsi/qla1280.c:3044: warning: unused variable 'dma_handle' drivers/scsi/qla1280.c: In function 'qla1280_queuecommand': drivers/scsi/qla1280.c:3060: warning: 'req_cnt' is used uninitialized in this function drivers/scsi/qla1280.c:3042: note: 'req_cnt' was declared here Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-14[SCSI] qla1280: convert to use the data buffer accessorsJes Sorensen
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Fixed to missing initialization of sg lists before calling for_each_sg() by Jes Sorensen - sg list needs to be initialized before trying to pull the elements out of it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-21[SCSI] qla1280: uses wrong failure path after failed pci_set_dma_maskJohannes Dickgreber
A failure here wouldn't currently free the irq; go to the irq free path instead. Signed-off-by: Johannes Dickgreber <tanzy@gmx.de> Acked-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-16qla1280: enable use_sg_chaining optionFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16qla1280: sg chaining fixesFUJITA Tomonori
2007-10-16qla1280: sg chaining supportJens Axboe
Interesting hardware setup... Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] Remove ->pid field from scsi_cmndMatthew Wilcox
The pid field is a duplicate of the serial_number field and has been scheduled for removal for a long time. A few drivers were still using it, so just change them to use serial_number instead. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] qla1280: use DMA_64BIT_MASK instead of ~ 0ULLMatthias Kaehlcke
QLA1280: call pci_set_dma_mask with DMA_64BIT_MASK instead of ~ 0ULL Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] qla1280: set residual correctlyJes Sorensen
Jeremy caught a bug in the qla1280 driver where it didn't set the residual value correctly. Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla1280 bus reset typoJes Sorensen
Fix typo in check of return value of qla1280_bus_reset() which would result in an adapter reset in addition to the bus reset. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[SCSI] pci_module_init conversion in scsi subsystemHenrik Kretzschmar
Converts pci_module_init() to pci_register_driver() in the scsi subsys on 23 drivers which only return the value of pci_module_init(). Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-26[SCSI] qla1280 command timeoutJes Sorensen
Original patch from Ian Dall in bugzilla. Set command timeout as specified by the SCSI layer rather than hardcode it to 30 seconds. I have received a couple of reports of people hitting this one with various tape configurations and the patch looks obviously correct. - Jes From http://bugzilla.kernel.org/show_bug.cgi?id=6275 ian@beware.dropbear.id.au (Ian Dall): The command sent to the card was using a 30second timeout regardless of the timeout requested in the scsi command passed down from higher levels. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[SCSI] qla1280: fix section mismatch warningsRandy Dunlap
Fix section mismatch warnings: WARNING: drivers/scsi/qla1280.o - Section mismatch: reference to .init.data: from .text between 'qla1280_get_token' (at offset 0x2a16) and 'qla1280_probe_one' WARNING: drivers/scsi/qla1280.o - Section mismatch: reference to .init.data: from .text between 'qla1280_get_token' (at offset 0x2a3c) and 'qla1280_probe_one' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-21[PATCH] PCI: Move various PCI IDs to header fileBrent Casavant
Move various QLogic, Vitesse, and Intel storage controller PCI IDs to the main header file. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Acked-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-26[SCSI] qla1280: remove < 2.6.0 supportJes Sorensen
Remove support for kernels older than 2.6.0. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-06[SCSI] remove the obsolete SCSI qlogicisp driverAdrian Bunk
The SCSI qlogicisp driver is both marked BROKEN and superseded by the qla1280 driver. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] qla1280: endianess annotationsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] qla1280: don't use bitfields for hardware access, parametersChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thiemo Seufer <ths@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] qla1280: don't use bitfields for hardware access in isp_configChristoph Hellwig
2005-08-02[SCSI] qla1280: always load microcodeChristoph Hellwig
we have the most recent microcode, make sure to always load it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] qla1280: use SAM_ constantsChristoph Hellwig
2005-08-02[SCSI] qla1280: misc cleanupsChristoph Hellwig
print message tidy ups and some excess brace removal. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thiemo Seufer <ths@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-02[SCSI] qla1280: interupt posting for irq disabling/enablingChristoph Hellwig
2005-08-02[SCSI] qla1280: remove dead per-host flag variablesChristoph Hellwig
2005-06-26[SCSI] scsi/qla1280: replace schedule_timeout() with ssleep()Nishanth Aravamudan
Use ssleep() instead of schedule_timeout to guarantee the task delays as expected. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_device_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_abort_handler()Jeff Garzik
2005-05-20[SCSI] qla1280.c - fix result for device Busy and Queue FullJeremy Higdon
I discovered that the qla1280 driver does not send the correct status to the midlayer when it gets Queue Full or Busy from a device. Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
