path: root/drivers/scsi/qla2xxx/qla_attr.c
2019-12-17scsi: qla2xxx: Always check the qla2x00_wait_for_hba_online() return valueBart Van Assche
[ Upstream commit e6803efae5acd109fad9f2f07dab674563441a53 ] This patch fixes several Coverity complaints about not always checking the qla2x00_wait_for_hba_online() return value. Cc: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Himanshu Madhani <hmadhani@marvell.com> Reviewed-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-10scsi: qla2xxx: Fix incorrect region-size setting in optrom SYSFS routinesAndrew Vasquez
commit 5cbdae10bf11f96e30b4d14de7b08c8b490e903c upstream. Commit e6f77540c067 ("scsi: qla2xxx: Fix an integer overflow in sysfs code") incorrectly set 'optrom_region_size' to 'start+size', which can overflow option-rom boundaries when 'start' is non-zero. Continue setting optrom_region_size to the proper adjusted value of 'size'. Fixes: e6f77540c067 ("scsi: qla2xxx: Fix an integer overflow in sysfs code") Cc: stable@vger.kernel.org Signed-off-by: Andrew Vasquez <andrewv@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09scsi: qla2xxx: Fix NPIV deletion by calling wait_for_sess_deletionQuinn Tran
commit efa93f48fa9d423fda166bc3b6c0cbb09682492e upstream. Add wait for session deletion to finish before freeing an NPIV scsi host. Fixes: 726b85487067 ("qla2xxx: Add framework for async fabric discovery") Cc: <stable@vger.kernel.org> Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07Merge branch 'fixes' into miscJames Bottomley
2017-08-30scsi: qla2xxx: Fix an integer overflow in sysfs codeDan Carpenter
The value of "size" comes from the user. When we add "start + size" it could lead to an integer overflow bug. It means we vmalloc() a lot more memory than we had intended. I believe that on 64 bit systems vmalloc() can succeed even if we ask it to allocate huge 4GB buffers. So we would get memory corruption and likely a crash when we call ha->isp_ops->write_optrom() and ->read_optrom(). Only root can trigger this bug. Link: https://bugzilla.kernel.org/show_bug.cgi?id=194061 Cc: <stable@vger.kernel.org> Fixes: b7cc176c9eb3 ("[SCSI] qla2xxx: Allow region-based flash-part accesses.") Reported-by: shqking <shqking@gmail.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-24scsi: qla2xxx: Add support for minimum link speedSawan Chandak
Signed-off-by: Sawan Chandak <sawan.chandak@cavium.com> Signed-off-by: Joe Carnuccio <joe.carnuccio@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-08-24scsi: qla2xxx: Add ability to autodetect SFP typeQuinn Tran
SFP can come in 2 formats: short range/SR and long range/LR. For LR, user the can increase the number of Buffer to Buffer credits between end points via Cavium's command line tool. By default, FW uses a lower BB Credit value optimized for SR. This patch will read the SFP for each link up event and during chip reset sequence. If the SFP type and setting are mismatch, then the chip is reset 1 time to use the appropriate setting. Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-07-01scsi: qla2xxx: fix a bunch of typos and spelling mistakesColin Ian King
Fix the following typos/spelling mistakes: "attribure" -> "attribute" "suppored" -> "supported" "Symobilic" -> "Symbolic" "iteself" -> "itself" "reqeust" -> "request" "nvme_wait_on_comand" -> "nvme_wait_on_command" "bount" -> "bound" "captrue_mask" -> "capture_mask" "tempelate" -> "template" ..and also unwrap a line to fix a checkpatch warning. Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: qla2xxx: move fields from qla_hw_data to qla_qpairQuinn Tran
- Move chip_reset, enable_class_2 fields from qla_hw_data to qla_qpair to reduce cache thrash for target MQ. - Optimizations to reduce unnecessary memory load for good path io. Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-27scsi: qla2xxx: Preparation for Target MQ.Quinn Tran
In Current code, Req Q 0, RespQ 0 & hardware_lock are the main resources for sending and process completion of Target IO. These resources are now referenced behind a new qpair/"struct qla_qpair base_qpair". Main path IO handle will access those resources via the qpair pointer in preparation for Target MQ. Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-06-12scsi: qla2xxx: Cleanup debug message IDsQuinn Tran
Assign unique id to all traces and logs for debug purpose. Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-05-04Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This update includes the usual round of major driver updates (hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the usual amount of cosmetic and spelling stuff" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits) scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template" scsi: stex: make S6flag static scsi: mac_esp: fix to pass correct device identity to free_irq() scsi: aacraid: pci_alloc_consistent() failures on ARM64 scsi: ufs: make ufshcd_get_lists_status() register operation obvious scsi: ufs: use MASK_EE_STATUS scsi: mac_esp: Replace bogus memory barrier with spinlock scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static scsi: sd_zbc: Do not write lock zones for reset scsi: sd_zbc: Remove superfluous assignments scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd scsi: Improve scsi_get_sense_info_fld scsi: sd: Cleanup sd_done sense data handling scsi: sd: Improve sd_completed_bytes scsi: sd: Fix function descriptions scsi: mpt3sas: remove redundant wmb scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host() scsi: sg: reset 'res_in_use' after unlinking reserved array scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency" ...
2017-04-04scsi: qla2xxx: Fix typo in driverMilan P Gandhi
Signed-off-by: Milan P Gandhi <mgandhi@redhat.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2017-03-18qla2xxx: Allow vref count to timeout on vport delete.Joe Carnuccio
Cc: <stable@vger.kernel.org> Signed-off-by: Joe Carnuccio <joe.carnuccio@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2017-02-09qla2xxx: Add framework for async fabric discoveryQuinn Tran
Currently code performs a full scan of the fabric for every RSCN. Its an expensive process in a noisy large SAN. This patch optimizes expensive fabric discovery process by scanning switch for the affected port when RSCN is received. Currently Initiator Mode code makes login/logout decision without knowledge of target mode. This causes driver and firmware to go out-of-sync. This framework synchronizes both initiator mode personality and target mode personality in making login/logout decision. This patch adds following capabilities in the driver - Send Notification Acknowledgement asynchronously. - Update session/fcport state asynchronously. - Create a session or fcport struct asynchronously. - Send GNL asynchronously. The command will ask FW to provide a list of FC Port entries FW knows about. - Send GPDB asynchronously. The command will ask FW to provide detail data of an FC Port FW knows about or perform ADISC to verify the state of the session. - Send GPNID asynchronously. The command will ask switch to provide WWPN for provided NPort ID. - Send GPSC asynchronously. The command will ask switch to provide registered port speed for provided WWPN. - Send GIDPN asynchronously. The command will ask the switch to provide Nport ID for provided WWPN. - In driver unload path, schedule all session for deletion and wait for deletion to complete before allowing driver unload to proceed. Signed-off-by: Quinn Tran <quinn.tran@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> [ bvanassche: fixed spelling in patch description ] Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2017-01-20Merge branch 'scsi-target-for-v4.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bvanassche/linux Pull SCSI target fixes from Bart Van Assche: - two small fixes for the ibmvscsis driver - ten patches with bug fixes for the target mode of the qla2xxx driver - four patches that avoid that the "sparse" and "smatch" static analyzer tools report false positives for the qla2xxx code base * 'scsi-target-for-v4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/bvanassche/linux: qla2xxx: Disable out-of-order processing by default in firmware qla2xxx: Fix erroneous invalid handle message qla2xxx: Reduce exess wait during chip reset qla2xxx: Terminate exchange if corrupted qla2xxx: Fix crash due to null pointer access qla2xxx: Collect additional information to debug fw dump qla2xxx: Reset reserved field in firmware options to 0 qla2xxx: Set tcm_qla2xxx version to automatically track qla2xxx version qla2xxx: Include ATIO queue in firmware dump when in target mode qla2xxx: Fix wrong IOCB type assumption qla2xxx: Avoid that building with W=1 triggers complaints about set-but-not-used variables qla2xxx: Move two arrays from header files to .c files qla2xxx: Declare an array with file scope static qla2xxx: Fix indentation ibmvscsis: Fix sleeping in interrupt context ibmvscsis: Fix max transfer length
2017-01-17qla2xxx: Avoid that building with W=1 triggers complaints about ↵Bart Van Assche
set-but-not-used variables Remove two set-but-not-used variables and avoid that the compiler warns about a third variable (rc). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Cc: Quinn Tran <quinn.tran@qlogic.com> Cc: Christoph Hellwig <hch@lst.de>
2017-01-09scsi: qla2xxx: Get mutex lock before checking optrom_stateMilan P. Gandhi
There is a race condition with qla2xxx optrom functions where one thread might modify optrom buffer, optrom_state while other thread is still reading from it. In couple of crashes, it was found that we had successfully passed the following 'if' check where we confirm optrom_state to be QLA_SREADING. But by the time we acquired mutex lock to proceed with memory_read_from_buffer function, some other thread/process had already modified that option rom buffer and optrom_state from QLA_SREADING to QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system: if (ha->optrom_state != QLA_SREADING) return 0; mutex_lock(&ha->optrom_mutex); rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer, ha->optrom_region_size); mutex_unlock(&ha->optrom_mutex); With current optrom function we get following crash due to a race condition: [ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null) [ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110 [...] [ 1479.473673] Call Trace: [ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60 [ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx] [ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0 [ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170 [ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0 [ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b Below patch modifies qla2x00_sysfs_read_optrom, qla2x00_sysfs_write_optrom functions to get the mutex_lock before checking ha->optrom_state to avoid similar crashes. The patch was applied and tested and same crashes were no longer observed again. Tested-by: Milan P. Gandhi <mgandhi@redhat.com> Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com> Reviewed-by: Laurence Oberman <loberman@redhat.com> Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-12-14scsi: qla2xxx: Add multiple queue pair functionality.Michael Hernandez
Replaced existing multiple queue functionality with framework that allows for the creation of pairs of request and response queues, either at start of day or dynamically. Queue pair creation depend on module parameter "ql2xmqsupport", which need to be enabled to create queue pair. Signed-off-by: Sawan Chandak <sawan.chandak@cavium.com> Signed-off-by: Michael Hernandez <michael.hernandez@cavium.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-15qla2xxx: Disable the adapter and skip error recovery in case of register ↵Sawan Chandak
disconnect. If there is error recovery going on due to command timeout and there is register disconnect, then disable the adapter. Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-15qla2xxx: Properly reset firmware statistics.Joe Carnuccio
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-15qla2xxx: Properly initialize IO statistics.Joe Carnuccio
Properly initialize IO statistics to avoid initial 0xFFFFFFF (-1) values. Cleanup/simplify usage of pointer to statistics structure. Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-07-15qla2xxx: Remove sysfs node fw_dump_template.Joe Carnuccio
2016-02-23qla2xxx: Avoid side effects when using endianizer macros.Joe Carnuccio
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-02-23qla2xxx: Add support for Private link statistics counters.Harish Zunjarrao
Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-02-23qla2xxx: Add support for online flash update for ISP27XX.Sawan Chandak
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com>
2016-01-07qla2xxx: Added interface to send explicit LOGO.Himanshu Madhani
This patch adds interface to send explicit LOGO explicit LOGO using using ELS commands from driver. Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-09-02Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "This includes one new driver: cxlflash plus the usual grab bag of updates for the major drivers: qla2xxx, ipr, storvsc, pm80xx, hptiop, plus a few assorted fixes. There's another tranch coming, but I want to incubate it another few days in the checkers, plus it includes a mpt2sas separated lifetime fix, which Avago won't get done testing until Friday" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (85 commits) aic94xx: set an error code on failure storvsc: Set the error code correctly in failure conditions storvsc: Allow write_same when host is windows 10 storvsc: use storage protocol version to determine storage capabilities storvsc: use correct defaults for values determined by protocol negotiation storvsc: Untangle the storage protocol negotiation from the vmbus protocol negotiation. storvsc: Use a single value to track protocol versions storvsc: Rather than look for sets of specific protocol versions, make decisions based on ranges. cxlflash: Remove unused variable from queuecommand cxlflash: shift wrapping bug in afu_link_reset() cxlflash: off by one bug in cxlflash_show_port_status() cxlflash: Virtual LUN support cxlflash: Superpipe support cxlflash: Base error recovery support qla2xxx: Update driver version to 8.07.00.26-k qla2xxx: Add pci device id 0x2261. qla2xxx: Fix missing device login retries. qla2xxx: do not clear slot in outstanding cmd array qla2xxx: Remove decrement of sp reference count in abort handler. qla2xxx: Add support to show MPI and PEP FW version for ISP27xx. ...
2015-08-26qla2xxx: Add support to show MPI and PEP FW version for ISP27xx.Sawan Chandak
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-26qla2xxx: Remove a superfluous testBart Van Assche
Avoid that smatch reports the following warning: drivers/scsi/qla2xxx/qla_attr.c:1081: qla2x00_model_desc_show() warn: this array is probably non-NULL. 'vha->hw->model_desc' Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-08-26qla2xxx: Remove set-but-not-used variablesBart Van Assche
Detected these variables by building with W=1. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-07-24qla2xxx: Enable target mode for ISP27XXHimanshu Madhani
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-09-25qla2xxx: Add missing ISP27xx checks to optrom code.Alex Vechersky
Signed-off-by: Alex Vechersky <alex.vechersky@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-09-25qla2xxx: Free sysfs attributes for ISP27xx.Nigel Kirkland
Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-09-25qla2xxx: Add diagnostic port functionality.Joe Carnuccio
Add support for the D-port (diagnostic port) fabric switch feature. (Fabric Switch initiates loopback style port testing) Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-09-25qla2xxx: Add FDMI-2 functionality.Himanshu Madhani
Add support for the FDMI-2 fabric switch feature. Since FDMI-2 uses code from FDMI-1, some of the existing code needed to be repaired to prevent fields from being overflowed. Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-19qla2xxx: Add MBC option for fast SFP data access.Joe Carnuccio
2014-05-19qla2xxx: Change copyright year to 2014 in all the source files.Armen Baloyan
Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-05-19qla2xxx: Enable fw_dump_size for ISP8044.Hiral Patel
Signed-off-by: Hiral Patel <hiral.patel@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-03-19[SCSI] qla2xxx: Fix build errors related to invalid print fields on some ↵Chad Dupuis
architectures. Fixes some build warnings such as: drivers/scsi/qla2xxx/qla_attr.c:162:6: warning: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type 'size_t'" and drivers/scsi/qla2xxx/qla_init.c:5198:7: warning: format '%lx' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat] Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-03-15[SCSI] qla2xxx: Read capture firmware dump on mailbox timeout for ISP8044 ↵Chad Dupuis
and ISP82XX. Allow for the capture of a firmware dump but have a sysfs node (allow_cna_fw_dump) to allow the feature to be enabled/disabled dynamically. The default is off. Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-03-15[SCSI] qla2xxx: Add support for ISP2071.Chad Dupuis
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com> Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-03-15[SCSI] qla2xxx: Add mutex around optrom calls to serialize accesses.Chad Dupuis
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-19qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO.Saurav Kashyap
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Quinn Tran <quinn.tran@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19[SCSI] qla2xxx: Use scnprintf() instead of snprintf() in the sysfs handlers.Sawan Chandak
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] qla2xxx: Add changes to obtain ISPFX00 adapters product information ↵Armen Baloyan
in accordance with firmware update. Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-12-19[SCSI] qla2xxx: Fix undefined behavior in call to snprintf().Joe Carnuccio
2013-12-19[SCSI] qla2xxx: Refactor shutdown code so some functionality can be reused.Chad Dupuis
2013-09-03[SCSI] qla2xxx: print MAC via %pMR.Andy Shevchenko
Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
