Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com>
Signed-off-by: Hiral Patel <hiral.patel@qlogic.com>
architectures.
Fixes some build warnings such as:
drivers/scsi/qla2xxx/qla_attr.c:162:6: warning: format '%lx' expects argument of
type 'long unsigned int', but argument 6 has type 'size_t'"
and
drivers/scsi/qla2xxx/qla_init.c:5198:7: warning: format '%lx' expects argument
of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat]
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
and ISP82XX.
Allow for the capture of a firmware dump but have a sysfs node
(allow_cna_fw_dump) to allow the feature to be enabled/disabled dynamically.
The default is off.
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- add support for SCSI Referrals (Hannes)
- add support for T10 DIF into target core (nab + mkp)
- add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab)
- add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab)
- prep changes to iser-target for >= v3.15 T10 DIF support (Sagi)
- add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn)
- allow percpu_ida_alloc() to receive task state bitmask (Kent)
- fix >= v3.12 iscsi-target session reset hung task regression (nab)
- fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab)
- fix a long-standing network portal creation race (Andy)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits)
target: Fix percpu_ref_put race in transport_lun_remove_cmd
target/iscsi: Fix network portal creation race
target: Report bad sector in sense data for DIF errors
iscsi-target: Convert gfp_t parameter to task state bitmask
iscsi-target: Fix connection reset hang with percpu_ida_alloc
percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask
iscsi-target: Pre-allocate more tags to avoid ack starvation
qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport
qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO.
qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure
IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine
IB/isert: Move fastreg descriptor creation to a function
IB/isert: Avoid frwr notation, user fastreg
IB/isert: seperate connection protection domains and dma MRs
tcm_loop: Enable DIF/DIX modes in SCSI host LLD
target/rd: Add DIF protection into rd_execute_rw
target/rd: Add support for protection SGL setup + release
target/rd: Refactor rd_build_device_space + rd_release_device_space
target/file: Add DIF protection support to fd_execute_rw
target/file: Add DIF protection init/format support
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com>
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
in accordance with firmware update.
On any Adapter when we flash through FC/FCoE without card reset option it still
shows the Running FW version in Flashed FW version. This new interface will be
used by API to instruct the driver to update its cache versions.
Add the missing FCP statistics to sysfs.
Add reset FCP statistics functionality via sysfs.
For supported ISPS, Read asic temperature by calling the
GET PARAMS (type C) mailbox command.
[jejb: checkpatch fixes]
Signed-off-by: Atul Deshmukh <atul.deshmukh@qlogic.com>
During a chip reset, the mailbox call to get FC statistics from the ISP will
not work resulting in needless mailbox accesses and errors printing out:
qla2xxx [0000:05:00.0]-00af:11: Performing ISP error recovery - ha=ffff881fad044800.
qla2xxx [0000:05:00.0]-1020:11: **** Failed mbx[0]=4001, mb[1]=4953, mb[2]=5020, mb[3]=b100, cmd=6d ****.
To prevent this, check for a chip reset when an application queries for FC
stats and return immediately if a chip reset is occurring.
[jejb: fix up checkpatch issues]
Signed-off-by: Andrew Vazquez <andrew.vasquez@qlogic.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Give priority to I2C thermal.
sequence while unloading qla2xxx driver.
Cc: <stable@vger.kernel.org> #3.7
Signed-off-by: Arun Easi <arun.easi@qlogic.com>
Update the driver copyright from 2003-2011 to 2003-2012.
[jejb: fix up checkpatch errors]
Signed-off-by: Santosh Vernekar <santosh.vernekar@qlogic.com>
Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com>
[jejb: merge fix for introduced warning]
Add LLD target mode for >= 24xx series HW. This code was originally based on
external qla2x00t module based on 8.02.01-k4, and has been refactored to
push the bulk of code into mainline qla2xxx.ko LLD -> qla_target.c.
The implementation uses internal workqueues for I/O context submission
into tcm_qla2xxx code, and includes the struct qla_tgt_func_tmpl API for
external interaction to allow qla2xxx LDD to function without direct
target-core dependencies:
It also enables qla_target.c usage within existing qla2xxx LLD code.
This includes:
*) Addition of target mode specific members to existing data
structures in qla_def.h and struct qla_hw_data->tgt_ops using
qla_target.h:struct qla_tgt_func_tmpl
*) Addition of struct qla_tgt_func_tmpl and direct calls into
qla_target.c logic w/ qlt_* prefixed functions.
*) Addition of qla_iocb.c:qla2x00_req_pkt() for ring processing, and
qla2x00_issue_marker() for handling request/response queue processing
for target mode operation
*) Addition of various qla_tgt_mode_enabled() logic checks in
qla24xx_nvram_config(), qla2x00_initialize_adapter(), qla2x00_rff_id(),
qla2x00_abort_isp(), qla24xx_modify_vp_config(), and
qla2x00_vp_abort_isp().
By default the new qlini_mode module parameter is setting initiator-mode
to 'enabled' in order for 'modprobe qla2xxx' to continue to function as
expected in initiator only mode. Enabling target-mode operation will
currently require a:
modprobe qla2xxx qlini_mode="disabled"
in order to explictly disabled initiator mode and allow target-mode
to be enabled via tcm_qla2xxx configfs fabric callers.
(nab: Convert to qlini_mode='enabled' by default in qla_target.c)
(joern: Remove loop_id from qla_tgt_make_local_sess() arguments +
Remove unused s_id + fix s_id endianness bug +
simplify qla_tgt_abort_work)
(gerard: fix section __exit mismatch in qla_tgt_exit)
(arun: Capture ATIO queue during firmware dump + Send SCR in target mode +
Target mode review comments)
(roland: Don't create duplicate target sessions to address tearing down
ACLs with IO in flight + Add missing call to qlt_fc_port_deleted
call during qla2x00_schedule_rport_del timeout)
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
application.
Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com>
Currently stats is part of ha data structure, common for physical and virtual
ports. Moved the stats to vha, each port will have its own stat.
During rport tear-down, make sure we do an implicit LOGO of the fcport in our
firmware to try to clear any residual commands associated with that fcport.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
When thermal temperature initially fails, return a blank string to the
sysfs interface. This fixes the initial display of 0.00 followed by
subsequent display of blank line; the initial 0.00 should have not
displayed for cards that do not support thermal temperature.
Many locations within the driver would use an inconsistent set of
checks to determine ISP-reset state. Consolidate the checks into
this inline-helper.
Correct the erroneous return codes introduced by the following patch:
"Return sysfs error codes appropriate to conditions".
This patch contains minor fixes to our new logging infrastructure:
- Remove extranous messages.
- Re-add 'nexus' and 'hdl' information.
- Adjusted the message ids to fill up the holes.
- Display FCP_CMND priority on update.
- Log only mail box error conditions.
- Do not print "Firmware ready **** FAILED ****" if cable is unplugged.
- Drop noisy 'fw_state...curr time...' message.
- Correct nexus display during abort.
- Add a special case error-logging set to '1'.
- Catagorize I/O exception display handling.
- Correct the bsg msg code printing.
- Dont use dynamic logging after host is removed.
the current broken uses as appropriate.
Add more fine grain parsing of vha->loop_state to export a more accurate
fc_host port_state.
Return sysfs error codes that match the conditions encountered.
This prevents sysfs from retrying a request which is conditioned
to fail under the current circumstance.
Corrects the return value for the cases where read/write edc fails;
this prevents sysfs from retrying the operation until forever.
Corrects the printk width specifier for the first byte of buf.
Minidump allows us to catpure a snapshot of the firmware/hardware states at the
time of failure for further analysis.
[jejb: added missing #include <linux/vmalloc.h>
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> ]
This fix:
- Disables app tag peeking; correct tag check will be added when the
SCSI API is available.
- Always derive ref_tag from scsi_get_lba()
- Removes incorrect swap of FCP_LUN in FCP_CMND
- Moves app-tag error check before ref-tag check. The reason being,
currently there is no interface in SCSI to retrieve the app-tag
for protection I/Os, so driver puts zero for app-tag in the
firmware interface, but requests not to validate it, but when a
ref-tag error is detected by firmware, it would put
expected/actual tags for all the protection tags (guard/app/ref).
As driver checks for app tag error first, a ref-tag error is
incorrectly flagged as app-tag error.
- Convert HBA specific checks to capability based.
Driver needs to update protection bytes for uninitialized sectors as they are
not DMA-d.
Reviewed-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
