Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
The driver can typically detect port-loss during an
interrupt context (i.e. via interrogation of a status IOCB's
completion status [CS_PORT_LOGGED_OUT]. Due to the calling
requirements of the fc_rport APIs, the driver would defer
removal of the device to the default workqueue. If the
work-item was preceded by an event which caused the port to
obtain visibility (relogin successful, target re-logged into
the topology), deferred removal could inadvertently drop the
rport. The code also no longer defers removal via the
default workqueue, instead opting for use of the driver's
own DPC thread.
This merge is pretty extensive. The conflict is over the new
req->retries parameter, so I had to change the prototype to
scsi_setup_blk_pc_cmnd() and the usage in sd, sr and st.
Transition driver to exclusively use the request_firmware()
interfaces to retrieve firmware-blobs from user-space. This
will be the default behaviour going forward until the
embedded firmware-binary images are removed from the
upstream kernel.
Upon request, the driver caches the firmware image until the
driver is unloaded.
NOTE: The option is present to allow the user to continue to
use the firmware-loader modules, but, should be considered
deprecated.
Rejections fixed up and
A regression in a recent change
33135aa2a568ec1a30e734f18e5315e10516e4f3 caused the driver
to mistakenly drop handling of AENs. Due to the incorrect
handling, ports would not reappear after RSCNs and LIPs.
Drops unused/incorrect compound #define from qla_def.h.
We recently went back to implement a board reset. When we perform the
reset, we wanted to tear down the internal data structures and rebuild
them. Unfortunately, when it came to the rport structure, things were
odd. If we deleted them, the scsi targets and sdevs would be
torn down. Not a good thing for a temporary reset. We could block the
rports, but we either maintain the internal structures to keep the
rport reference (perhaps even replicating what's in the transport),
or we have to fatten the fc transport with new search routines to find
the rport (and deal with a case of a dangling rport that the driver
forgets).
It dawned on me that we had actually reached this state incorrectly.
When the fc transport first started, we did the block/unblock first, then
added the rport interface. The purpose of block/unblock is to hide the
temporary disappearance of the rport (e.g. being deleted, then readded).
Why are we making the driver do the block/unblock ? We should be making
the transport have only an rport add/delete, and the let the transport
handle the block/unblock.
So... This patch removes the existing fc_remote_port_block/unblock
functions. It moves the block/unblock functionality into the
fc_remote_port_add/delete functions. Updates for the lpfc driver are
included. Qlogic driver updates are also enclosed, thanks to the
contributions of Andrew Vasquez. [Note: the qla2xxx changes are
relative to the scsi-misc-2.6 tree as of this morning - which does
not include the recent patches sent by Andrew]. The zfcp driver does
not use the block/unblock functions.
One last comment: The resulting behavior feels very clean. The LLDD is
concerned only with add/delete, which corresponds to the physical
disappearance. However, the fact that the scsi target and sdevs are
not immediately torn down after the LLDD calls delete causes an
interesting scenario... the midlayer can call the xxx_slave_alloc and
xxx_queuecommand functions with a sdev that is at the location the
rport used to be. The driver must validate the device exists when it
first enters these functions. In thinking about it, this has always
been the case for the LLDD and these routines. The existing drivers
already check for existence. However, this highlights that simple
validation via data structure dereferencing needs to be watched.
To deal with this, a new transport function, fc_remote_port_chkready()
was created that LLDDs should call when they first enter these two
routines. It validates the rport state, and returns a scsi result
which could be returned. In addition to solving the above, it also
creates consistent behavior from the LLDD's when the block and deletes
are occuring.
ISP23xx and ISP24xx chips have support for an adaptive
method of posting SCSI command completions for multiple SCSI
commands during a single system interrupt.
SCSI commands are placed on the system response queue
without interrupting the host until 1) a delay timer
expires; or 2) a SCSI command completes with an error.
As long as the host software (qla2xxx) services the response
queue for completions (this polling is done during
queuecommand()) within the 'delay timer' period, the
firmware will not generate system interrupt.
On ISP24xx parts, stop execution of firmware during ISP
tear-down.
Original implementation used an overloaded bit in the EFI
parameters. The correct bit is BIT_4 of the special_options
section of NVRAM.
Export COS information for the fc_host and fc_remote_port
objects added by the driver.
Older gcc's dont support anonymous unions, so this driver gets hundreds of
error.
Fortunately the fix is easy...
Cc: James Bottomley <James.Bottomley@steeleye.com>
Correct maximum supported lun and target-id definitions.
The driver uses command-IOCBs which support a maximum lun
value of 0xffff -- correct #define to reflect the change.
Also, remove superfluous MAX_TARGET definition.
Update copyright banner.
Code scrubbing.
- Remove trailing whitespace from driver files.
- Remove unused #defines and inlines.
- Standardize on C comments (// -> /* */)
Add OS initialization codes for ISP24xx recognition.
Add MBX command routines for ISP24xx support.
Generalize several routines [qla2x00_load_ram_ext(),
qla2x00_execute_fw(), qla2x00_verify_checksum()] to handle
larger addressing space.
Generalize SNS generic-services routines.
Consolidate completion-status checking while adding support
for the ISP24xx.
Add ISP24xx definitions.
Add requisite structure definitions and #define's for ISP24xx
support. Also drop volatile modifiers from device_reg_* register
layouts as the members are never really accessed, only their
offsets within the layout are used during reads and writes.
Add pci ids for new ISP types.
Move old definitions in local qla_def.h file to pci_ids.h as
well.
Factor-out ISP specific functions to method-based call tables.
In anticipation of ISP24xx/ISP25xx support, factor-out ISP
specific functions into a method-based call table.
Original from: Christoph Hellwig <hch@lst.de>
Modified and
Remove internal lun discovery routines and support
structures.
Add initial support for FC remote port infrastructure.
o Use fc_remote_port...() registration and block/unlock
functions.
o Consolidate 'attribute' (fc-remote/sysfs) helpers into
new qla_attr.c file.
Remove internal command queuing from the driver. As is, this
driver cannot tolerate cable-pulls as I/Os will begin to fail
by the upper layers.
o Should be used in conjuction with the
11-fc_rport_adds_2.diff patch.
o Removes qla_listops.h file -- no longer needed.
infrastructure for it.
Let it rip!
