Make the read/write sfp mailbox command routines uniform, and remove redundancy.
Also protect against attempting to do a single byte dma in these routines.
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com>
Signed-off-by: Madhuranath Iyengar <Madhu.Iyengar@qlogic.com>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The 'max_lun' value registered for each scsi_host is currently
capped at 0xffff. The new module parameter can allow for
2nd-level flat-space addressing method-infrastructure to be
supported.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Encapsulate the unlocking of the ROM lock in a function for better
code readability.
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Also, change the ISP82xx code to only reset if this module_param is set
and reset is intended via the QLA82XX_DEV_NEED_RESET case.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
If fabric device has invalid loop id (FC_NO_LOOP_ID) then call
qla2x00_find_new_loop_id() to attempt to obtain valid loop id.
The FCP priority info was not being updated properly in certain situations.
Here are the changes that needs to be done to take care of this issue:
1. No need to check fcport->state for FCS_UNCONFIGURED in
qla24xx_update_fcport_fcp_prio(), since an invalid loop id check is
already performed which is sufficient.
2. Add the missing qla24xx_update_fcport_fcp_prio() function call
within qla2x00_update_fcport() function, so that the priority info
is updated on every port addition or change.
3. Perform proper adapter types checking.
4. Other changes, associated with DEBUG/printk's and parameter passing.
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Support is added for quiescence mode. This feature is for P3P
adapters. Any of the functions can put the firmware into quiescence
state. All the others have to ack that request. During quiescence mode
current commands are processed and all the new incoming I/Os are
blocked. Loop resync is performed after firmware comes out of
quiescence state.
Add the module parameter ql2xgffidenable to disable/enable the use of the
GFF_ID name server command to prevent non FCP SCSI devices from being added to
the driver's internal fc_port database.
In case the MPI times out, the FW issues an async event AE8002
to indicate this to every FCoE function. The FC/FCoE driver is
required to handle this, by doing a soft reset and issuing a
Write MPI register mailbox command to reset the MPI.
pending commands.
Re-organized and cleaned up the ISP82xx specific code.
This function was added to encapsulate freeing the memory for all the fcports
associated with a particular vha. Also added a call to qla2x00_free_fcports()
to qla2x00_free_device() to free the memory for all the fcports associated with
a vha during device removal.
Nx_Ports
The default method that qla2xxx uses is the GID_PT nameserver command to
get a list of Nx_Ports. This patch adds a GFF_ID call for each port
returned by GID_PT to get the FC4 type. If the FC4 type is not FCP SCSI
then the qla2xxx driver will not record that port in it's port database.
For switches that do not support the GFF_ID command, the behavior will be
for qla2xxx to store that port anyways.
The CRB drive active register is cleared when driver is unloaded
or when driver enters failed state.
Signed-off-by: Duane Grigsby <duane.grigsby@qlogic.com>
Currently we can only issue the task management (TM)
commands via the mailbox mechanism. This is a limitation,
since only one mailbox command can be issued at a time.
The purpose of this effort is to provide support for
issuing and processing the respose to TM and Marker
IOCBs asynchronously. Towards achieving this, the
consolidated srb architecture that is currently used for
BSG and IOCB/Logio commands has been enhanced and used.
Currently, BSG and IOCB/Logio commands have a different
framework (srb structs). The purpose of this effort is to
consolidate them into a generalized framework for these
as well as other asynchronous operations in the future.
Enhanced the driver to support new FCoE host bus adapter.
Allows priority setting for FCP_CMNDs.
1. Segregate BSG interface specific code to new files.
2. Handle multiple vendor specific commands indepedently.
3. Reorganised support for reset, management and update FCoE firmware commands.
4. Fixed memory leak issue in Loopback.
5. Added new vendor command to support iiDMA using BSG interface.
6. Proper cleanup of dma mapped and dma allocated buffers for BSG request.
[jejb: fix up conflict and merge in Jiri Slaby lock imbalance patch]
Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits)
[SCSI] Fix printing of failed 32-byte commands
[SCSI] Fix printing of variable length commands
[SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation
[SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list
[SCSI] scsi_dh_alua: add netapp to dev list
[SCSI] qla2xxx: Update version number to 8.03.02-k1.
[SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset.
[SCSI] qla2xxx: Add firmware ETS burst support.
[SCSI] qla2xxx: Correct loop-resync issues during SNS scans.
[SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback.
[SCSI] qla2xxx: Correct EH bus-reset handling.
[SCSI] qla2xxx: Proper clean-up of BSG requests when request times out.
[SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands
[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev
[SCSI] fix refcounting bug in scsi_get_host_dev
[SCSI] fix memory leak in scsi_report_lun_scan
[SCSI] lpfc: correct PPC build failure
[SCSI] raid_class: add raid1e
[SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes.
[SCSI] zfcp: Introduce header file for qdio structs and inline functions
Can be used to balance NIC/FCoE traffic distribution.
Cc: stable@kernel.org
The explicit logout (LOGO) issued at the end of the callback will
flush (via normal scsi_cmnd->done()) any outstanding commands
(FCP2) the firmware is holding. While iterating through the
outstanding_cmnd array in qla2x00_abort_fcport_cmds(), locking
and unlocking of the hardware spinlock, opens-up the driver to
cases where the processed SRB (sp) could be used after the
command completed from interrupt context.
Original code incorrectly assumed only status-type-0
IOCBs would be queued to the response-queue, and thus all
entries would safely reference a VHA from the IOCB
'handle.'
[jejb: fixed printk casting issues]
Signed-off-by: Sarang Radke <sarang.radke@qlogic.com>
When the hba port gets logged out of the fabric, or other
such transitional state when the physical link is still present,
the driver doesn't receive a loop up asyn event (where the link
data rate currently gets set). Hence send a explicit mailbox command
to get the link rate in such conditions.
Removed the module parameters ql2xqfulltracking and ql2xqfullrampup
since the queue depth ramp up/down functionality is moved to scsi-ml.
ISPs which support this feature include 23xx and above.
Ensure MPS remains in synchronization across all NIC/FCoE
functions after a reset.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Unlike earlier ISPs, recent ISPs (ISP81xx) can in fact fail this
mailbox command.
Firmware currently provides PB and PGF TLVs.
As it may be useful during debugging to use a specific firmware
image.
Changing a lun's queue depth (/sys/block/sdX/device/queue_depth)
isn't sticky when the device is connected via a QLogic fibre
channel adapter.
The QLogic qla2xxx fibre channel driver dynamically adjusts a
lun's queue depth. If a user has a specific need to limit the
number of commands issued to a lun (say a tape drive, or a shared
raid where the total commands issued to all luns is limited at
the controller level, for example) and writes a limiting value to
/sys/block/sdXX/device/queue_depth, the qla2xxx driver will
silently and gradually increase the queue depth back to the
driver limit of ql2xmaxqdepth. While reducing this value (module
parameter) or increasing the interval between ramp ups
(ql2xqfullrampup) offers the potential for a work around it would
be better to have the option of just disabling the dynamic
adjustment of queue depth.
This patch implements an "off switch" as a module parameter.
Signed-off-by: Michael Reed <mdr@sgi.com>
Set the number of request queues to the module paramater
ql2xmaxqueues. Each vport gets a request queue. The QoS value
set to the request queues determines priority control for queued
IOs. If QoS value is not specified, the vports use the default
queue 0.
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Interface allows for the update of onboard EDC firmware
present on mezzanine ISP25xx type cards.
