Add LLD target mode for >= 24xx series HW. This code was originally based on
external qla2x00t module based on 8.02.01-k4, and has been refactored to
push the bulk of code into mainline qla2xxx.ko LLD -> qla_target.c.
The implementation uses internal workqueues for I/O context submission
into tcm_qla2xxx code, and includes the struct qla_tgt_func_tmpl API for
external interaction to allow qla2xxx LDD to function without direct
target-core dependencies:
It also enables qla_target.c usage within existing qla2xxx LLD code.
This includes:
*) Addition of target mode specific members to existing data
structures in qla_def.h and struct qla_hw_data->tgt_ops using
qla_target.h:struct qla_tgt_func_tmpl
*) Addition of struct qla_tgt_func_tmpl and direct calls into
qla_target.c logic w/ qlt_* prefixed functions.
*) Addition of qla_iocb.c:qla2x00_req_pkt() for ring processing, and
qla2x00_issue_marker() for handling request/response queue processing
for target mode operation
*) Addition of various qla_tgt_mode_enabled() logic checks in
qla24xx_nvram_config(), qla2x00_initialize_adapter(), qla2x00_rff_id(),
qla2x00_abort_isp(), qla24xx_modify_vp_config(), and
qla2x00_vp_abort_isp().
By default the new qlini_mode module parameter is setting initiator-mode
to 'enabled' in order for 'modprobe qla2xxx' to continue to function as
expected in initiator only mode. Enabling target-mode operation will
currently require a:
modprobe qla2xxx qlini_mode="disabled"
in order to explictly disabled initiator mode and allow target-mode
to be enabled via tcm_qla2xxx configfs fabric callers.
(nab: Convert to qlini_mode='enabled' by default in qla_target.c)
(joern: Remove loop_id from qla_tgt_make_local_sess() arguments +
Remove unused s_id + fix s_id endianness bug +
simplify qla_tgt_abort_work)
(gerard: fix section __exit mismatch in qla_tgt_exit)
(arun: Capture ATIO queue during firmware dump + Send SCR in target mode +
Target mode review comments)
(roland: Don't create duplicate target sessions to address tearing down
ACLs with IO in flight + Add missing call to qlt_fc_port_deleted
call during qla2x00_schedule_rport_del timeout)
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
The field vp_idx in struct fc_port is a redundant/mirror copy of
the same field in struct scsi_qla_host;
struct fc_port has a pointer vha to scsi_qla_host which allows
the original copy of vp_idx to be readily accessed.
Signed-off-by: Joe Carnuccio <joe.carnuccio@qlogic.com>
Add an extra layer of logging granularity for messages that are necessary in
some circumstances but may flood the kernel log buffer with too many messages
otherwise.
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
qla2x00_port_logout.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Correct spelling "occured" to "occurred" in
drivers/scsi/qla2xxx/qla_mbx.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
A device logout sent in the delete path of a fcport would clear the
port handle binding inside the firmware. This could lead to queued
work items for the fcport, if any, getting incorrect results. This
patch fixes the issue by checking for device name changes after a
call to get port database.
Signed-off-by: Arun Easi <arun.easi@qlogic.com>
times out.
Don't use default 30 second mailbox-command timeout for these
serial requests, instead, limit the TMO to the standard 2*RATOV
plus some fudge-factor.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
During rport tear-down, make sure we do an implicit LOGO of the fcport in our
firmware to try to clear any residual commands associated with that fcport.
Rework the structures related to SRB processing to minimize the memory
allocations per I/O and manage resources associated with and completions
from common routines.
Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com>
Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com>
failures during next reset cycle.
Complete the mailbox command timed out before initiating another abort cycle
to recover so that mailbox commands issued during next reset cycle don't fail
due to pending mailbox access timeout.
Not clearing the options flags in mbx1 could lead the firmware
into interpreting old data in mbx1 through mbx8. This could
lead to inadvertent DMA read/write operations to stale memory.
for ISP82xx.
for ISP82xx.
reset recovery.
We need to return QLA_FUNCTION_TIMEOUT immediately otherwise we mess up the
mailbox command state machine.
[jejb: fix up checkpatch.pl errors]
Minidump allows us to catpure a snapshot of the firmware/hardware states at the
time of failure for further analysis.
[jejb: added missing #include <linux/vmalloc.h>
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> ]
The code is changed to support the new dynamic logging infrastructure.
Following are the levels added.
Default is 0 - no logging. 0x40000000 - Module Init & Probe.
0x20000000 - Mailbox Cmnds. 0x10000000 - Device Discovery.
0x08000000 - IO tracing. 0x04000000 - DPC Thread.
0x02000000 - Async events. 0x01000000 - Timer routines.
0x00800000 - User space. 0x00400000 - Task Management.
0x00200000 - AER/EEH. 0x00100000 - Multi Q.
0x00080000 - P3P Specific. 0x00040000 - Virtual Port.
0x00020000 - Buffer Dump. 0x00010000 - Misc.
0x7fffffff - For enabling all logs, can be too many logs.
Setting ql2xextended_error_logging module parameter to any of the above
value, will enable the debug for that particular level.
Do LOGICAL OR of the value to enable more than one level.
Signed-off-by: Madhuranath Iyengar <Madhu.Iyengar@qlogic.com>
Eliminate duplicate code by refactoring the calls to qla2xxx_read_sfp()
in qla2x00_get_thermal_temp(). This keeps the parameter values separate
from the mailbox register mechanics. This also allows qla2xxx_read_sfp()
to be the sole "spec" for READ SFP semantics.
Signed-off_by: Joe Carnuccio <joe.carnuccio@qlogic.com>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Make the read/write sfp mailbox command routines uniform, and remove redundancy.
Also protect against attempting to do a single byte dma in these routines.
When reading a single byte using the READ SFP mailbox command, the
single byte of data is returned in MB[1] and not MB[8].
The reason that MB[8] was being used is that the spec was unclear
as it evolved over time; and we have not needed to read a single
byte until recently.
Before driver's own internal state is marked as PLOGI/PRLI
complete. This additional check closes a window seen with
dual-personality initiator/target devices where a driver's
PLOGI/PRLI request occurs within the window after the target's
PLOGI request has completed, but prior to the target's PRLI
arriving and processed by the firmware. Without this additional
check, the firmware will return port-information stating that the
port neither supports target nor initiator functions, causing the
driver to register the rport prematurely to the FC-transport
without the proper 'roles' being set.
handle for Abort I/O IOCBs.
The upper 16-bits of the handle for all I/O in multi-queue supported
drivers carries the ID of the request queue it was submitted on. When
using Abort I/O IOCB, the driver needs to also populate the upper
16-bits in the handle_to_abort field so the fw can correlate with the
actual I/O.
Signed-off-by: Mike Hernandez <michael.hernandez@qlogic.com>
Based on reading of the FCP2/4 specification, the driver cannot
expect the storage device to send FCP_RSP information. Instead,
the driver should interpret the data which is present in the frame
to base decisions on the success or failure of the system.
firmware is hung.
The FCP priority info was not being updated properly in certain situations.
Here are the changes that needs to be done to take care of this issue:
1. No need to check fcport->state for FCS_UNCONFIGURED in
qla24xx_update_fcport_fcp_prio(), since an invalid loop id check is
already performed which is sufficient.
2. Add the missing qla24xx_update_fcport_fcp_prio() function call
within qla2x00_update_fcport() function, so that the priority info
is updated on every port addition or change.
3. Perform proper adapter types checking.
4. Other changes, associated with DEBUG/printk's and parameter passing.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits)
[SCSI] be2iscsi: SGE Len == 64K
[SCSI] be2iscsi: Remove premature free of cid
[SCSI] be2iscsi: More time for FW
[SCSI] libsas: fix bug for vacant phy
[SCSI] sd: Fix overflow with big physical blocks
[SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer
[SCSI] libsas: Don't issue commands to devices that have been hot-removed
[SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive
[SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17
[SCSI] lpfc 8.3.17: Replace function reset methodology
[SCSI] lpfc 8.3.17: SCSI fixes
[SCSI] lpfc 8.3.17: BSG fixes
[SCSI] lpfc 8.3.17: SLI Additions and Fixes
[SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes
[SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces
[SCSI] ipr: fix array error logging
[SCSI] aha152x: enable PCMCIA on 64bit
[SCSI] scsi_dh_alua: Handle all states correctly
[SCSI] cxgb4i: connection and ddp setting update
[SCSI] cxgb3i: fixed connection over vlan
In case the MPI times out, the FW issues an async event AE8002
to indicate this to every FCoE function. The FC/FCoE driver is
required to handle this, by doing a soft reset and issuing a
Write MPI register mailbox command to reset the MPI.
fail.
Re-organized and cleaned up the ISP82xx specific code.
Outstanding mailbox commands, have no way to recover on f/w hung, and we
timeout on waiting for mbx response. This in turn affects the recovery process
as follows:
- We might already be in dpc while waiting for mbx to complete, so recovery for
that pci function will never get invoked. Reset Timeout (10 sec) is far less
than mbx timeout (30 sec).
- Other mbx cmds will get stuck due to serial mbx access.
Solution is to identify fw-hung scenario and handle outstanding mbx commands to
have an early-exit instead of waiting for response.
Other mbx commands waiting for access will also do an early-exit if fw-hung is
still applicable.
The TMFs used for pre-24xx ISPs incorrectly assumed 'cpu' tag
data could be valid. These chips have no multi-q/cpu-affinity
support. This corrects an oops seen on ISP23xx parts.
Currently we can only issue the task management (TM)
commands via the mailbox mechanism. This is a limitation,
since only one mailbox command can be issued at a time.
The purpose of this effort is to provide support for
issuing and processing the respose to TM and Marker
IOCBs asynchronously. Towards achieving this, the
consolidated srb architecture that is currently used for
BSG and IOCB/Logio commands has been enhanced and used.
Enhanced the driver to support new FCoE host bus adapter.
Allows priority setting for FCP_CMNDs.
1. Segregate BSG interface specific code to new files.
2. Handle multiple vendor specific commands indepedently.
3. Reorganised support for reset, management and update FCoE firmware commands.
4. Fixed memory leak issue in Loopback.
5. Added new vendor command to support iiDMA using BSG interface.
6. Proper cleanup of dma mapped and dma allocated buffers for BSG request.
[jejb: fix up conflict and merge in Jiri Slaby lock imbalance patch]
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] qla1280: retain firmware for error recovery
[SCSI] attirbute_container: Initialize sysfs attributes with sysfs_attr_init
[SCSI] advansys: fix regression with request_firmware change
[SCSI] qla2xxx: Updated version number to 8.03.02-k2.
[SCSI] qla2xxx: Prevent sending mbx commands from sysfs during isp reset.
[SCSI] qla2xxx: Disable MSI on qla24xx chips other than QLA2432.
[SCSI] qla2xxx: Check to make sure multique and CPU affinity support is not enabled at the same time.
[SCSI] qla2xxx: Correct vp_idx checking during PORT_UPDATE processing.
[SCSI] qla2xxx: Honour "Extended BB credits" bit for CNAs.
[SCSI] scsi_transport_fc: Make sure commands are completed when rport is offline
[SCSI] libiscsi: Fix recovery slowdown regression
