path: root/drivers/scsi/qla2xxx/qla_os.c
2008-05-30[SCSI] qla2xxx: Correct handling of AENs postings for vports.Seokmann Ju
Initialize all proper structure members in order to support work-list vport processing. This code also properly acquires the correct (physical hardware_lock) lock during work submission. Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-15[SCSI] qla2xxx: Convert vport_sem to a mutexmatthias@kaehlcke.net
The semaphore vport_sem is used as a mutex. Convert it to the mutex API. Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-15[SCSI] qla2xxx: firmware semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-15[SCSI] qla2xxx: Display driver version at module init-time.Andrew Vasquez
2008-04-27[SCSI] qla2xxx: Correct regression in relogin code.Andrew Vasquez
Commit 63a8651f2548c6bb5132c0b4e7dad4f57a9274db ([SCSI] qla2xxx: Correct infinite-login-retry issue.) introduced a small regression where a successful relogin would result in an fcport's loop_id to be incorrectly reset to FC_NO_LOOP_ID. Only clear-out loopid, if retries have been 'truly' exhausted. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: qla_os.c, make 2 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - qla2x00_alloc_work() - qla2x00_post_work() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Re-register FDMI information after a LIP.Andrew Vasquez
Original code would (incorrectly) only re-register after a loop-down condition. Also, FDMI registration should be enabled by default. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Wakeup DPC thread to process any deferred-work requests.Andrew Vasquez
2008-04-07[SCSI] qla2xxx: Check DFLG_NO_CABLE only on physical port.Seokmann Ju
As there is no actual cable connection on vports, made change so that the driver checks DFLG_NO_CABLE against ha->device_flags only for physical port. Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Add ISP84XX support.Harihara Kadayam
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com> Additional cleanups and Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Add midlayer target/device reset support.Andrew Vasquez
Now that infrastructure is present within the midlayer and there is a clear distinction between what is expected from a device and target reset, convert the current device-reset codes to a target-reset, and add codes to perform a proper device-reset (LUN reset). In the process of adding reset support, collapse and consolidate large sections of mailbox-command (TMF issuance) codes, generalize the two 'wait-for-commands-to-complete' functions, and add a generic-reset routine for use by midlayer reset functions. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Use PCI-SIG nomenclature for PCIe bandwidth units.Andrew Vasquez
2008-04-07[SCSI] qla2xxx: Cruft cleanup of functions and structures.Andrew Vasquez
Strip unused (DEBUG-ONLY) enabled functions, inlines, useless wrappers, and unused DPC flags from the code. Another step in the migration towards a cleaner (less-crusty) driver. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Add hardware trace-logging support.Andrew Vasquez
Recent ISPs have a region within FLASH which acts as a repository for the logging of serious hardware and software failures. Currently, the region is large enough to support up to 255 entries. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Add FC-transport Asynchronous Event Notification support.Andrew Vasquez
Supported events include LIP, LIP reset, RSCN, link up, and link down. To support AEN (and additional forthcoming features), we also introduce a simple deferred-work construct to manage events which require a non-atomic sleeping-capable context. This work-list is processed as part of the driver's standard DPC routine. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla2xxx: Remove unused and obsolete #define's.Andrew Vasquez
2008-04-07[SCSI] qla2xxx: Update copyright banner.Andrew Vasquez
2008-02-07[SCSI] qla2xxx: Correct issue where vport-state was not updated during an ↵Seokmann Ju
ISP_ABORT_NEEDED requst. While running IO simultaneously through physical port and virtual port, if user changes Data Rate (from scli utility), IO through virtual port fails. It failed because the vport had not received the ISP_ABORT_NEEDED notification. Signed-Off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla2xxx: Move RISC-interrupt-register modifications to ↵Andrew Vasquez
qla2x00_request_irqs(). There's no functional change involved with this update, instead it simply migrates the "set cleared interrupt state" codes to a more approprate method, qla2x00_request_irqs(), and cleans-up the driver's probe() logic. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla2xxx: Consolidate RISC-parity enablement codes.Andrew Vasquez
Collapse duplicate codes called during probe() and RISC-reset into qla2x00_setup_chip(). Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla2xxx: Cleanse memory allocation logic during probe.Andrew Vasquez
- Drop loop-till-allocated structure of code within qla2x00_mem_alloc(). - Properly unwind deallcations of memory during failures. - Drop qla2x00_allocate_sp_pool() and qla2x00_free_sp_pool() functions as their implementations can easily be collapsed into the callers. - Defer DMA pool allocation of SFP data until requested. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla2xxx: Cleanup any outstanding SRB resources during shutdown.Andrew Vasquez
Refactor SRB-failure completion codes in the process. Also, signal the DPC routine to complete sooner as backend processing at shutdown-time is superflous. [jejb: resolve conflicts with pci_enable_device_bars removal] Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla2xxx: Add MODULE_FIRMWARE hint for ISP25XX firmware.Andrew Vasquez
2008-02-01PCI: Remove users of pci_enable_device_bars()Benjamin Herrenschmidt
This patch converts users of pci_enable_device_bars() to the new pci_enable_device_{io,mem} interface. The new API fits nicely, except maybe for the QLA case where a bit of code re-organization might be a good idea but I prefer sticking to the simple patch as I don't have hardware to test on. I'll also need some feedback on the cs5520 change. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-23[SCSI] qla2xxx: Add Fibre Channel Event (FCE) tracing support.Andrew Vasquez
FCE support enables the firmware to record FC extended link services and basic link services frames which have been transmitted and received by the ISP. This allows for a limited view of the FC traffic through the ISP without using a FC analyzer. This can be useful in situations where a physical connection to the FC bus is not possible. The driver exports this information in two ways -- first, via a debugfs node exported for all supported ISPs under: <debugfs_mount_point>/qla2xxx/qla2xxx_<host_no>/fce where a read of the 'fce' file will provide a snapshot of the firmware's FCE buffer; and finally, the FCE buffer will be extracted during a firmware-dump scenario. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] qla2xxx: Trace-Control naming cleanups.Andrew Vasquez
In preparation for FCE (Fibre Channel Event) tracing support. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] qla2xxx: Code cleanups.Adrian Bunk
- make the following needlessly global code static: - qla_attr.c: qla24xx_vport_delete() - qla_attr.c: qla24xx_vport_disable() - qla_mid.c: qla24xx_allocate_vp_id() - qla_mid.c: qla24xx_find_vhost_by_name() - qla_mid.c: qla2x00_do_dpc_vp() - qla_os.c: struct qla2x00_driver_template - qla_os.c: qla2x00_stop_timer() - qla_os.c: qla2x00_mem_alloc() - qla_os.c: qla2x00_mem_free() - qla_sup.c: qla2x00_lock_nvram_access() - qla_sup.c: qla2x00_unlock_nvram_access() - qla_sup.c: qla2x00_get_nvram_word() - qla_sup.c: qla2x00_write_nvram_word() - #if 0 the following unused global functions: - qla_mbx.c: qla2x00_system_error() - qla_os.c: remove some unneeded function prototypes - removed unused functions: - qla_dbg.c: qla2x00_dump_pkt() - qla_mbx.c: qla2x00_get_serdes_params() - qla_mbx.c: qla2x00_get_idma_speed() - qla_mbx.c: qla24xx_get_vp_database() - qla_mbx.c: qla24xx_get_vp_entry() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Small modifications and Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] qla2xxx: Use completion routines.Marcus Barrow
Instead of abusing the semaphore interfaces for mailbox command completions. Additional cleanups and Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] qla2xxx: Don't schedule the DPC routine to perform an issue-lip request.Andrew Vasquez
As the driver depends on the DPC routine to handle bottom-half loop resynchronization in order to recover from the issue-lip request. The issue_lip call is sleeping context capable, so just issue the reset function there. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] qla2xxx: Fix for 32-bit platforms with 64-bit resources.Andrew Vasquez
The driver stores the contents of PCI resources into unsigned long's before ioremapping. This breaks on 32-bit platforms which support 64-bit MMIO resources. Correct code by removing the temporary variables used during MMIO PIO mapping and using resource_size_t where applicable. Also correct a small typo in a printk() where the wrong region number was displayed. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-14scsi/qla2xxx/qla_os.c section fixAdrian Bunk
WARNING: vmlinux.o(.text+0x2a4462): Section mismatch: reference to .exit.text:qla2x00_remove_one (between 'qla2xxx_pci_error_detected' and 'qla2x00_stop_timer') qla2x00_remove_one() mustn't be __devexit since it's called from qla2xxx_pci_error_detected(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Seokmann Ju <seokmann.ju@qlogic.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23[SCSI] qla2xxx: Make driver (mostly) legacy I/O port free.Andrew Vasquez
Recent ISPs need only the single MMIO BAR to manipulate HW registers. Unfortunately, ISP21xx, ISP22xx, ISP23xx, and ISP63xx type cards still require the I/O mapped region to manipulate the FLASH via the two HW flash-registers (flash_address and flash_data). Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] qla2xxx: Use shost_priv().Andrew Vasquez
Drop usage of legacy to_qla_host() macro. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] qla2xxx: Correct infinite-login-retry issue.Ravi Anand
Where the DPC logic would get jammed into continuously reloging-into a port. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] qla2xxx: Add PCI error recovery support.Seokmann Ju
Additional cleanups and Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] qla2xxx: Add flash burst-read/write support.Andrew Vasquez
Newer ISPs support a mechanism to read and write flash-memory via the firmware LOAD/DUMP memory mailbox command routines. When supported, utilizing these mechanisms significantly reduces overall access times. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-08-15[SCSI] qla2xxx: Allocate enough space for the full PCI descriptor.Andrew Vasquez
2007-07-31[SCSI] qla2xxx: fix panic caused by previous patchSeokmann Ju
- this patch will fix a panic caused by omitted memory allocation for the nvram. Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-22Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] libsas: make ATA functions selectable by a config option [SCSI] bsg: unexport sg v3 helper functions [SCSI] bsg: fix bsg_unregister_queue [SCSI] bsg: make class backlinks [SCSI] 3w-9xxx: add support for 9690SA [SCSI] bsg: fix bsg_register_queue error path [SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275. [SCSI] libsas: fix scr_read/write users and update the libata documentation [SCSI] mpt fusion: update Kconfig help [SCSI] scsi_transport_sas: add destructor for bsg [SCSI] iscsi_tcp: buggered kmalloc() [SCSI] qla2xxx: Update version number to 8.02.00-k2. [SCSI] qla2xxx: Add ISP25XX support. [SCSI] qla2xxx: Use pci_try_set_mwi(). [SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces. [SCSI] qla2xxx: Re-factor isp_operations to static structures. [SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling. [SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration. [SCSI] qla2xxx: Generalize iIDMA support. [SCSI] qla2xxx: Generalize FW-Interface-2 support. ...
2007-07-20[SCSI] qla2xxx: Add ISP25XX support.Andrew Vasquez
Large code-reuse from ISP24xx, consolidate RISC memory extraction routines during firmware-dump. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-20[SCSI] qla2xxx: Re-factor isp_operations to static structures.Andrew Vasquez
In preparation for new ISP types. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-20[SCSI] qla2xxx: Generalize iIDMA support.Andrew Vasquez
2007-07-20[SCSI] qla2xxx: Generalize FW-Interface-2 support.Andrew Vasquez
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-07-14[SCSI] qla2xxx: add support for NPIVSeokmann Ju
Following patch adds support for NPIV (N-Port ID Virtualization) to the qla2xxx. - supported within switched-fabric topologies only. - supports up to 63 virtual ports on each physical port. Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-31[SCSI] qla2xxx: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
