Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Update the driver copyright from 2003-2011 to 2003-2012.
A minor change in the versioning. We'll be attaching the "-k"
in the end.
Signed-off-by: Madhuranath Iyengar <Madhu.Iyengar@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
We'll be using the new version number scheme from now on.
The 'k' in the version in the past will be removed.
The format will be: <major>.<minor>.<sub_minor>.<iter>
A scsi-misc submission increments <sub_minor> and resets <iter>.
An scsi-rc-fixes submission, increments <iter>.
Cc: stable@kernel.org
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Following changes have been made.
1. qla_hw_data structure holds an array for request queue pointers,
and an array for response queue pointers.
2. The base request and response queues are created by default.
3. Additional request and response queues are created at the time of vport
creation. If queue resources are exhausted during vport creation, newly
created vports use the default queue.
4. Requests are sent to the request queue that the vport was assigned
in the beginning.
5. Responses are completed on the response queue with which the request queue
is associated with.
[fixup memcpy argument reversal spotted by davej@redhat.com]
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Following changes have been made:
1. Outstanding commands are based on a request queue, scsi_qla_host
does not maintain it anymore.
2. start_scsi is accessed via isp_ops struct instead of direct
invocation.
3. Interrupt registrations are done using response queue instead of
device id.
