[ Upstream commit fc1ffd6cb38a1c1af625b9833c41928039e733f5 ]
During code inspection, while investigating following stack trace
seen on one of the test setup, we found out there was possibility
of memory leak becuase driver was not unwinding the stack properly.
This issue has not been reproduced in a test environment or on a
customer setup.
Here's stack trace that was seen.
[1469877.797315] Call Trace:
[1469877.799940] [<ffffffffa03ab6e9>] qla2x00_mem_alloc+0xb09/0x10c0 [qla2xxx]
[1469877.806980] [<ffffffffa03ac50a>] qla2x00_probe_one+0x86a/0x1b50 [qla2xxx]
[1469877.814013] [<ffffffff813b6d01>] ? __pm_runtime_resume+0x51/0xa0
[1469877.820265] [<ffffffff8157c1f5>] ? _raw_spin_lock_irqsave+0x25/0x90
[1469877.826776] [<ffffffff8157cd2d>] ? _raw_spin_unlock_irqrestore+0x6d/0x80
[1469877.833720] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.839885] [<ffffffff8157cd0c>] ? _raw_spin_unlock_irqrestore+0x4c/0x80
[1469877.846830] [<ffffffff81319b9c>] local_pci_probe+0x4c/0xb0
[1469877.852562] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.858727] [<ffffffff81319c89>] pci_call_probe+0x89/0xb0
Cc: <stable@vger.kernel.org>
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ bvanassche: Fixed spelling in patch description ]
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
[ Upstream commit 84e32a06f4f8756ce9ec3c8dc7e97896575f0771 ]
As result of deprecation of MSI-X/MSI enablement functions
pci_enable_msix() and pci_enable_msi_block() all drivers
using these two interfaces need to be updated to use the
new pci_enable_msi_range() or pci_enable_msi_exact()
and pci_enable_msix_range() or pci_enable_msix_exact()
interfaces.
Log message code 0x00c6 preserved, although it is reported
after successful call to pci_enable_msix_range(), not before
possibly unsuccessful call to pci_enable_msix(). Consumers
of the error code should not notice the difference.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Acked-by: Chad Dupuis <chad.dupuis@qlogic.com>
Cc: qla2xxx-upstream@qlogic.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-pci@vger.kernel.org
[ Upstream commit afc16604c06414223478df3e42301ab630b9960a ]
The first argument of these two functions is always identical
to se_cmd->se_sess. Hence remove the first argument.
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Andy Grover <agrover@redhat.com>
Cc: <qla2xxx-upstream@qlogic.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 7359df25a53386dd33c223672bbd12cb49d0ce4f ]
The newly introduced aborted_task TFO callback has to terminate
exchange with QLogic driver, since command is being deleted and
no status will be queued to the driver at a later point.
This patch also moves the burden of releasing one cmd refcount to
the aborted_task handler.
Changed iSCSI aborted_task logic to satisfy the above requirement.
Cc: <stable@vger.kernel.org> # v3.18+
Signed-off-by: Alexei Potashnik <alexei@purestorage.com>
Acked-by: Quinn Tran <quinn.tran@qlogic.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
[ Upstream commit df673274fa4896f25f0bf348d2a3535d74b4cbec ]
RSCN processing in qla2xxx driver can run in parallel with ELS/IO
processing. As such the decision to remove disappeared fc port's
session could be stale, because a new login sequence has occurred
since and created a brand new session.
Previous mechanism of dealing with this by delaying deletion request
was prone to erroneous deletions if the event that was supposed to
cancel the deletion never arrived or has been delayed in processing.
New mechanism relies on a time-like generation counter to serialize
RSCN updates relative to ELS/IO updates.
[ Upstream commit daddf5cf9b5c68b81b2bb7133f1dd0fda4552d0b ]
cancel any commands from initiator's s_id that are still waiting
on qla_tgt_wq when PLOGI arrives.
[ Upstream commit e52a8b45b9c782937f74b701f8c656d4e5619eb5 ]
If a new initiator (different WWN) shows up on the same fcport, old
initiator's session is scheduled for deletion. But there is a small
window between it being marked with QLA_SESS_DELETION_IN_PROGRESS
and qlt_unret_sess getting called when new session's commands will
keep finding old session in the fcport map.
This patch drops cmds/tmrs if they find session in the progress of
being deleted.
[ Upstream commit a6ca88780dd66b0700d89419abd17b6b4bb49483 ]
- keep qla_tgt_sess object on the session list until it's freed
- modify use of sess->deleted flag to differentiate delayed
session deletion that can be cancelled from irreversible one:
QLA_SESS_DELETION_PENDING vs QLA_SESS_DELETION_IN_PROGRESS
- during IN_PROGRESS deletion all newly arrived commands and TMRs will
be rejected, existing commands and TMRs will be terminated when
given by the core to the fabric or simply dropped if session logout
has already happened (logout terminates all existing exchanges)
- new PLOGI will initiate deletion of the following sessions
(unless deletion is already IN_PROGRESS):
- with the same port_name (with logout)
- different port_name, different loop_id but the same port_id
(with logout)
- different port_name, different port_id, but the same loop_id
(without logout)
- additionally each new PLOGI will store imm notify iocb in the
same port_name session being deleted. When deletion process
completes this iocb will be acked. Only the most recent PLOGI
iocb is stored. The older ones will be terminated when replaced.
- new PRLI will initiate deletion of the following sessions
(without logout)
[ Upstream commit 8b2f5ff3d05c2c48b722c3cc67b8226f1601042b ]
Since cmds go into qla_tgt_wq and TMRs don't, it's possible that TMR
like TASK_ABORT can be queued over the cmd for which it was meant.
To avoid this race, use a per-port list to keep track of cmds that
are enqueued to qla_tgt_wq but not yet processed. When a TMR arrives,
iterate through this list and remove any cmds that match the TMR.
This patch supports TASK_ABORT and LUN_RESET.
Signed-off-by: Swapnil Nagle <swapnil.nagle@purestorage.com>
commit b2032fd567326ad0b2d443bb6d96d2580ec670a5 upstream.
To fix some issues talking to ESX, this patch modifies the qla2xxx driver
so that it never logs into remote ports. This has the side effect of
getting rid of the "rports" entirely, which means we never log out of
initiators and never tear down sessions when an initiator goes away.
This is mostly OK, except that we can run into trouble if we have
initiator A assigned FC address X:Y:Z by the fabric talking to us, and
then initiator A goes away. Some time (could be a long time) later,
initiator B comes along and also gets FC address X:Y:Z (which is
available again, because initiator A is gone). If initiator B starts
talking to us, then we'll still have the session for initiator A, and
since we look up incoming IO based on the FC address X:Y:Z, initiator B
will end up using ACLs for initiator A.
Fix this by:
1. Handling RSCN events somewhat differently; instead of completely
skipping the processing of fcports, we look through the list, and if
an fcport disappears, we tell the target code the tear down the
session and tell the HBA FW to release the N_Port handle.
2. Handling "port down" events by flushing all of our sessions. The
firmware was already releasing the N_Port handle but we want the
target code to drop all the sessions too.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 9fce12540cb9f91e7f1f539a80b70f0b388bdae0 upstream.
Signed-off-by: Kanoj Sarcar <kanoj.sarcar@qlogic.com>
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
commit 6bc85dd595a5438b50ec085668e53ef26058bb90 upstream.
Remove unnecessary msleep from qlt_send_term_exchange as it
adds latency of 250 msec while sending terminate exchange to
an aborted task.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit 810e30bc4658e9c069577bde52394a5af872803c upstream.
Request IOCB queue element(s) is reserved during
good path IO. Under error condition such as unable
to allocate IOCB handle condition, the IOCB count
that was reserved is not released.
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
commit ba9f6f64a0ff6b7ecaed72144c179061f8eca378 upstream.
[ Upstream commit ef86cb2059a14b4024c7320999ee58e938873032 ]
This patch fixes a kernel panic for qla2xxx Target core
Module driver introduced by a fix in the qla2xxx initiator code.
Commit ef86cb2 ("qla2xxx: Mark port lost when we receive an RSCN for it.")
introduced the regression for qla2xxx Target driver.
Stack trace will have following signature
--- <NMI exception stack> ---
[ffff88081faa3cc8] _raw_spin_lock_irqsave at ffffffff815b1f03
[ffff88081faa3cd0] qlt_fc_port_deleted at ffffffffa096ccd0 [qla2xxx]
[ffff88081faa3d20] qla2x00_schedule_rport_del at ffffffffa0913831[qla2xxx]
[ffff88081faa3d50] qla2x00_mark_device_lost at ffffffffa09159c5[qla2xxx]
[ffff88081faa3db0] qla2x00_async_event at ffffffffa0938d59 [qla2xxx]
[ffff88081faa3e30] qla24xx_msix_default at ffffffffa093a326 [qla2xxx]
[ffff88081faa3e90] handle_irq_event_percpu at ffffffff810a7b8d
[ffff88081faa3ee0] handle_irq_event at ffffffff810a7d32
[ffff88081faa3f10] handle_edge_irq at ffffffff810ab6b9
[ffff88081faa3f30] handle_irq at ffffffff8100619c
[ffff88081faa3f70] do_IRQ at ffffffff815b4b1c
--- <IRQ stack> ---
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
There is just one configfs subsystem in the target code, so we might as
well add two helpers to reference / unreference it from the core code
instead of passing pointers to it around.
This fixes a regression introduced for v4.1-rc1 with commit 9ac8928e6,
where configfs_depend_item() callers using se_tpg_tfo->tf_subsys would
fail, because the assignment from the original target_core_subsystem[]
is no longer happening at target_register_template() time.
(Fix target_core_exit_configfs pointer dereference - Sagi)
Reported-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Lots of activity in target land the last months.
The highlights include:
- Convert fabric drivers tree-wide to target_register_template() (hch
+ bart)
- iser-target hardening fixes + v1.0 improvements (sagi)
- Convert iscsi_thread_set usage to kthread.h + kill
iscsi_target_tq.c (sagi + nab)
- Add support for T10-PI WRITE_STRIP + READ_INSERT operation (mkp +
sagi + nab)
- DIF fixes for CONFIG_DEBUG_SG=y + UNMAP file emulation (akinobu +
sagi + mkp)
- Extended TCMU ABI v2 for future BIDI + DIF support (andy + ilias)
- Fix COMPARE_AND_WRITE handling for NO_ALLLOC drivers (hch + nab)
Thanks to everyone who contributed this round with new features,
bug-reports, fixes, cleanups and improvements.
Looking forward, it's currently shaping up to be a busy v4.2 as well"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (69 commits)
target: Put TCMU under a new config option
target: Version 2 of TCMU ABI
target: fix tcm_mod_builder.py
target/file: Fix UNMAP with DIF protection support
target/file: Fix SG table for prot_buf initialization
target/file: Fix BUG() when CONFIG_DEBUG_SG=y and DIF protection enabled
target: Make core_tmr_abort_task() skip TMFs
target/sbc: Update sbc_dif_generate pr_debug output
target/sbc: Make internal DIF emulation honor ->prot_checks
target/sbc: Return INVALID_CDB_FIELD if DIF + sess_prot_type disabled
target: Ensure sess_prot_type is saved across session restart
target/rd: Don't pass incomplete scatterlist entries to sbc_dif_verify_*
target: Remove the unused flag SCF_ACK_KREF
target: Fix two sparse warnings
target: Fix COMPARE_AND_WRITE with SG_TO_MEM_NOALLOC handling
target: simplify the target template registration API
target: simplify target_xcopy_init_pt_lun
target: remove the unused SCF_CMD_XCOPY_PASSTHROUGH flag
target/rd: reduce code duplication in rd_execute_rw()
tcm_loop: fixup tpgt string to integer conversion
Pull SCSI updates from James Bottomley:
"This is the usual grab bag of driver updates (lpfc, qla2xxx, storvsc,
aacraid, ipr) plus an assortment of minor updates. There's also a
major update to aic1542 which moves the driver into this millenium"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (106 commits)
change SCSI Maintainer email
sd, mmc, virtio_blk, string_helpers: fix block size units
ufs: add support to allow non standard behaviours (quirks)
ufs-qcom: save controller revision info in internal structure
qla2xxx: Update driver version to 8.07.00.18-k
qla2xxx: Restore physical port WWPN only, when port down detected for FA-WWPN port.
qla2xxx: Fix virtual port configuration, when switch port is disabled/enabled.
qla2xxx: Prevent multiple firmware dump collection for ISP27XX.
qla2xxx: Disable Interrupt handshake for ISP27XX.
qla2xxx: Add debugging info for MBX timeout.
qla2xxx: Add serdes read/write support for ISP27XX
qla2xxx: Add udev notification to save fw dump for ISP27XX
qla2xxx: Add message for sucessful FW dump collected for ISP27XX.
qla2xxx: Add support to load firmware from file for ISP 26XX/27XX.
qla2xxx: Fix beacon blink for ISP27XX.
qla2xxx: Increase the wait time for firmware to be ready for P3P.
qla2xxx: Fix crash due to wrong casting of reg for ISP27XX.
qla2xxx: Fix warnings reported by static checker.
lpfc: Update version to 10.5.0.0 for upstream patch set
lpfc: Update copyright to 2015
Instead of calling target_fabric_configfs_init() +
target_fabric_configfs_register() / target_fabric_configfs_deregister()
target_fabric_configfs_free() from every target driver, rewrite the API
so that we have simple register/unregister functions that operate on
a const operations vector.
This patch also fixes a memory leak in several target drivers. Several
target drivers namely called target_fabric_configfs_deregister()
without calling target_fabric_configfs_free().
A large part of this patch is based on earlier changes from
Bart Van Assche <bart.vanassche@sandisk.com>.
(v2: Add a new TF_CIT_SETUP_DRV macro so that the core configfs code
can declare attributes as either core only or for drivers)
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
FA-WWPN port.
For FA-WWPN is enabled port, if NPIV created on that port and,
if port link is brought down, then WWPN was restored from flash for both
physical and NPIV port. This will result in NPIV port and physical port
sharing same WWPN. Any application refreshing ports information will
not be able to scan NPIV port because of this behavior. So while restoring WWPN,
only restore physical port WWPN.
Signed-off-by: Sawan Chandak <sawan.chandak@qlogic.com>
On some vendor switches, when switch port is toggled (down /up),
then in some condition driver tries to configure virtual port,
before FW is actually in ready state to process any commands on wire.
At this time, configuring virtual port can fail. Add fix in driver
to make driver wait, for FW to be ready state before
For ISP27XX, driver will capture new firmware dump even if there is
one already collected. Prevent this from happening by checking
fw_dumped flag.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Harish Zunjarrao <harish.zunjarrao@qlogic.com>
o Added message indicating firmware dump was sucessfully collected
for ISP27XX.
o Improve logging to help debug firmware dump process for ISP27XX.
Signed-off-by: Nigel Kirkland <nigel.kirkland@qlogic.com>
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
[Bart: additional sparse warning caused by this patch]
[jejb: fix sparse warning]
Cc: Bart Van Assche <bart.vanassche@sandisk.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This patch updates qla2xxx target to add a new fabric_prot_type TPG
attribute, used for controlling LLD level protection into LIO when
the backend device does not support T10-PI.
This is required for qla_target.c to enable WRITE_STRIP + READ_INSERT
hardware offloads.
It's disabled by default and controls which se_sesion->sess_prot_type
are set at tcm_qla2xxx_check_initiator_node_acl() session registration
time.
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Saurav Kashyap <saurav.kashyap@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Martin Petersen <martin.petersen@oracle.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
This patch adds the missing TARGET_PROT_ALL when initializing a new
session and declaring the capable se_sess->sup_prot_ops for T10-PI.
This is required in order to function with existing qla_target.c
DIF protection offload support.
This patch fixes the incorrect use of __transport_register_session()
in tcm_qla2xxx_check_initiator_node_acl() code, that does not perform
explicit se_tpg->session_lock when accessing se_tpg->tpg_sess_list
to add new se_sess nodes.
Given that tcm_qla2xxx_check_initiator_node_acl() is not called with
qla_hw->hardware_lock held for all accesses of ->tpg_sess_list, the
code should be using transport_register_session() instead.
Cc: <stable@vger.kernel.org> # 3.5+
This patch exposes a new ../qla2xxx*/$WWPN/$TPGT/dynamic_sessions
attribute to dump the currently active sessions by FC initiator WWPN
that have been created with dynamically generated se_node_acls.
This information is useful so that user-space can optionally perform
dynamic -> explicit NodeACL conversion based on $INITIATOR_WWPN.
Change 'Fimware' to 'Firmware'
Change 'enalbled' to 'enabled'
Signed-off-by: Yannick Guerrini <yguerrini@tomshardware.fr>
Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Change 'enalbed' to 'enabled'
This patch fix spelling typo in printk messages.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
"The highlights this round include:
- Update vhost-scsi to support F_ANY_LAYOUT using mm/iov_iter.c
logic, and signal VERSION_1 support (MST + Viro + nab)
- Fix iscsi/iser-target to remove problematic active_ts_set usage
(Gavin Guo)
- Update iscsi/iser-target to support multi-sequence sendtargets
(Sagi)
- Fix original PR_APTPL_BUF_LEN 8k size limitation (Martin Svec)
- Add missing WRITE_SAME end-of-device sanity check (Bart)
- Check for LBA + sectors wrap-around in sbc_parse_cdb() (nab)
- Other various minor SPC/SBC compliance fixes based upon Ronnie
Sahlberg test suite (nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (32 commits)
target: Set LBPWS10 bit in Logical Block Provisioning EVPD
target: Fail UNMAP when emulate_tpu=0
target: Fail WRITE_SAME w/ UNMAP=1 when emulate_tpws=0
target: Add sanity checks for DPO/FUA bit usage
target: Perform PROTECT sanity checks for WRITE_SAME
target: Fail I/O with PROTECT bit when protection is unsupported
target: Check for LBA + sectors wrap-around in sbc_parse_cdb
target: Add missing WRITE_SAME end-of-device sanity check
iscsi-target: Avoid IN_LOGOUT failure case for iser-target
target: Fix PR_APTPL_BUF_LEN buffer size limitation
iscsi-target: Drop problematic active_ts_list usage
iscsi/iser-target: Support multi-sequence sendtargets text response
iser-target: Remove duplicate function names
vhost/scsi: potential memory corruption
vhost/scsi: Global tcm_vhost -> vhost_scsi rename
vhost/scsi: Drop left-over scsi_tcq.h include
vhost/scsi: Set VIRTIO_F_ANY_LAYOUT + VIRTIO_F_VERSION_1 feature bits
vhost/scsi: Add ANY_LAYOUT support in vhost_scsi_handle_vq
vhost/scsi: Add ANY_LAYOUT iov -> sgl mapping prerequisites
vhost/scsi: Change vhost_scsi_map_to_sgl to accept iov ptr + len
Using seq_putc to print a single character saves at least a strlen()
call and a memory access, and may also give a small .text reduction.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
Using seq_printf to print a simple string is a lot more expensive than
it needs to be, since seq_puts exists. Replace seq_printf with
seq_puts when possible.
Instead of pushing each byte via stack let's use custom specifier which allows
to print small buffers as a hex string.
Commit e05fe29248 (qla2xxx: Honor FCP_RSP retry delay timer field.)
causes systems to busy-wait for about 3 minutes after boot prior to
detecting SAN disks.
During this wait period one kworker is running full-time
(though /proc/<pid>/stack has no useful data). Another kworker is
waiting for IO to complete during that whole time period.
Looking at drivers/scsi/qla2xxx/qla_os.c, fcport->retry_delay_timestamp
has a special value of 0 though that 0 value forces system to wait when
jiffies is very large value (e.g. 4294952605 - "negative" value when
signed on 32bit systems).
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
When we have an rport disconnect we race during rport deletion and
re-connection resulting in a panic. When we do this, we call
fc_remote_port_del() just before we do the calls to re-establish the
session with the FC transport with fc_remote_port_add() and then
fc_remote_port_rolechg().
If we remove the call to fc_remote_port_del() before re-establishing
the connection this prevents the race. This patch has resolved this
for multiple customers via test kernels.
Suggested by Chad Dupuis, implemented and tested by Laurence Oberman.
Signed-off-by: Laurence Oberman <loberman@redhat.com>
For SPI drivers use the message definitions from scsi.h, and for target
drivers introduce a new TCM_*_TAG namespace.
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com
Since we got rid of ordered tag support in 2010 the prime use case of
switching on and off ordered tags has been obsolete. The other function
of enabling/disabling tagging entirely has only been correctly implemented
by the 53c700 driver and isn't generally useful.
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
All drivers use the implementation for ramping the queue up and down, so
instead of overloading the change_queue_depth method call the
implementation diretly if the driver opts into it by setting the
track_queue_depth flag in the host template.
Note that a few drivers validated the new queue depth in their
change_queue_depth method, but as we never go over the queue depth
set during slave_configure or the sysfs file this isn't nessecary
and can safely be removed.
Reviewed-by: Venkatesh Srinivas <venkateshs@google.com>
